GXTS04
High-Accuracy Digital Temperature
Sensor IC
GXCAS
Technology
DESCRIPTION
The GXTS04 is GXCAS’s new high accuracy digital
temperature sensor. Its functionality includes
enhanced signal processing, two distinctive and
user
selectable
I2C
addresses
and
communication speeds of up to 1 MHz. The DFN
package has a footprint of 2 x 2mm2 while keeping
a height of 0.75 mm. This allows for integration of the
GXTS04 into a great variety of applications.
Additionally, the wide supply voltage range of 1.6 V
to 5.5 V guarantees compatibility with a wide range
of applications.
Measures Temperatures from -45~130℃
±0.1°C Accuracy from 35°C to +45°C
Thermometer Resolution is 16 Bits
Converts Temperature to 16-Bit Digital Word in
1.5ms
6-Pin DFN package
PIN CONFIGURATIONS
FEATURES
Fully calibrated and linearized digital output
Wide supply voltage range, from 1.6 V to 5.5 V
I2C Interface with communication speeds up to
1MHz and two user selectable addresses
Typical accuracy of 0.3 °C
Very fast start-up and measurement time
Content
1
Sensor Performance.............................................2
2
Specifications .......................................................3
3
Pin Assignment ....................................................5
4
Operation and Communication.............................5
5
Quality...................................................................7
6
Order Information ...........................................
7
Technical Drawing ........................................... 8
7
www.galaxy-cas.com
1
GXTS04
1
Sensor Performance
1.1
Temperature Sensor Performance
Parameter
Accuracy tolerance
Accuracy tolerance
Condition
Value
Units
typ., 35°C to 45°C
0.1
°C
0.3
0.24
0.12
0.06
°C
typ., 0°C to 90°C
Repeatability
Low
Medium
High
Resolution
Specified Range
Typ.
Response time
63%
Long
Term Drift
max
°C
°C
°C
0.015
-40 to 125
°C
°C
>1
s
很抱歉,暂时无法提供与“GXTS04D-T&R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.30920
- 10+3.47760
- 30+3.05640
- 100+2.63520
- 500+2.38680
- 1000+2.25720
