MBRF3045CT
MBRF3045CT
    GOODWORK(固得沃克)
    ITO220AB
    肖特基二极管 30A ITO220AB 570pF 550mV 100μA 250A 45V -65℃~+150℃
MBRF3045CT 数据手册
MBRF3020CT THRU MBRF30200CT 30.0 AMP SCHOTTKY BARRIER RECTIFIERS VOLTAGE RANGE 20 to 200 Volts CURRENT 30.0 Amperes FEATURES * Low forward voltage drop * High current capability * High reliability * High surge current capability * Good for switching mode application ITO-220AB (FULLY INSULATED) .108 .248 (6.3) MECHANICAL DATA * Case: Molded plastic * Epoxy: UL 94V-0 rate flame retardant * Lead: Lead solderable per MIL-STD-202, method 208 guranteed * Polarity: As Marked * Mounting position: Any .189 MAX. (4.8) .122 MAX. (3.1) 3.4 f MAX. HOLE THRU .412 (10.5) MAX. .610 (15.5) MAX. .550 (14.0) .158 (4.0) MIN. MAX. .060 MAX. (1.5) .035 MAX. (0.9) .100 (2.54) .114(2.9) .098(2.5) PIN 1 + PIN 1 PIN 3 CASE PIN 2 PIN 3 CASE PIN 2 Negative CT Suffix "A" Positive CT Suffix "C" Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating 25 C ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. TYPE NUMBER Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current MBRF3020CT MBRF3045CT MBRF3060CT MBRF3080CT MBRF30100CT MBRF30150CT MBRF30200CT UNITS 20 14 20 45 32 45 60 42 60 80 56 80 at Rated DC Blocking Voltage Ta=100 C Typical Junction Capacitance (Note1) Typical Thermal Resistance R JC (Note 2) Operating Temperature Range TJ Storage Temperature Range TSTG 150 105 150 200 140 200 0.55 250 0.85 0.7 0.92 0.02 0.1 2 5 570 2.5 -65 +150 -65 +150 V V V A 30 at Tc=125 C Peak Forward Surge Current, 8.3 ms single half sine-wave superimposed on rated load (JEDEC method) Maximum Instantaneous Forward Voltage at 30A Maximum DC Reverse Current Ta=25 C 100 70 100 A V mA mA pF C/W C C NOTES: 1. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2. Thermal Resistance Junction to Case. REV 1.0 2015 JAN PAGE:1/2 RATING AND CHARACTERISTIC CURVES (MBRF3020CT THRU MBRF30200CT) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL FORWARD T 5C 04 25 0 0 20 40 60 80 100 120 140 160 180 200 CASE TEMPERATURE,( C) FIG.3-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT -M RF 30 15 0C T -M MB 8.0 BR F3 02 00 CT BR F3 01 00 CT BR -M CT 60 CT 30 20 RF 30 MB RF RF 30 80 CT 5 MB 10 30 MB 15 F3 50 20 INSTANTANEOUS FORWARD CURRENT,(A) AVERAGE FORWARD CURRENT,(A) CHARACTERISTICS 30 1.0 Tj=25 C Pulse Width 300us 1% Duty Cycle 0.1 PEAK FORWARD SURGE CURRENT,(A) 250 .01 200 .1 .3 .5 .7 .9 1.1 1.3 1.5 FORWARD VOLTAGE,(V) 150 8.3ms Single Half Tj=25 C Sine Wave 100 JEDEC method 50 FIG.5 - TYPICAL REVERSE CHARACTERISTICS 0 1 5 50 10 100 100 NUMBER OF CYCLES AT 60Hz REVERSE LEAKAGE CURRENT, (mA) FIG.4-TYPICAL JUNCTION CAPACITANCE JUNCTION CAPACITANCE,(pF) 1400 1200 1000 800 600 400 10 Tj=100 C 1.0 Tj=75 C .1 Tj=25 C 200 0 .01 .05 .1 .5 1 REVERSE VOLTAGE,(V) 5 10 50 100 .01 0 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) REV 1.0 2015 JAN PAGE:2/2
MBRF3045CT 价格&库存
很抱歉,暂时无法提供与“MBRF3045CT”相匹配的价格&库存,您可以联系我们找货
MBRF3045CT
  • 5+1.93439
  • 50+1.52626
  • 150+1.38629
  • 500+1.21166
  • 2000+1.13390
  • 5000+1.08713
库存:76
