Document: W03010141, Rev: H
WS4.5D3HP
Transient Voltage Suppressor
Features
1260 Watts Peak Pulse Power per Line (tp=8/20μs)
Small Body Outline Dimensions
Protects one I/O or power line
Low Clamping Voltage
Working Voltage: 4.5V
Low Leakage Current
SOD-323F
IEC COMPATIBILITY (EN61000-4)
IEC 61000-4-2 (ESD) ±30kV (air), ±30kV (contact)
IEC 61000-4-4 (EFT) 40A (5/50ns)
IEC 61000-4-5 (Lightning)90A (8/20μs)
Mechanical Characteristics
Applications
SOD-323F package
Laptop Computers
Marking : Marking Code
Cellular Phones
Packaging : Tape and Reel
Digital Cameras
RoHS Compliant
Personal Digital Assistants (PDAs)
Schematic & PIN Configuration
2
1
SOD-323F (Top View)
©2019 WAYON Corporation
www.way-on.com
1/5
WS4.5D3HP
Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp = 8/20μs )
PPP
1260
Watts
Peak Pulse Current(tp =8/20μs)
IPP
90
A
Operating Temperature
TJ
-55 to + 125
TSTG
-55 to +150
Storage Temperature
Electrical Parameters (T=25℃)
Symbol
Parameter
I
IPP
Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
IR
VBR
IF
Reverse Stand-Off Voltage
VC VBR VRWM
Reverse Leakage Current @ VRWM
Breakdown Voltage @ IT
IT
Test Current
IF
Forward Current
VF
Forward Voltage @ IF
V
IR VF
IT
IPP
Electrical Characteristics
WS4.5D3HP
Parameter
Reverse Breakdown Voltage
Symbol
Conditions
Minimum
Typical
VRWM
5
Maximum
Units
4.5
V
7
V
500
nA
1
V
14
V
VBR
IT=1mA
IR
VRWM=4.5V, T=25℃
Forward Voltage
VF
IF=10mA
Clamping Voltage
VC
IPP=90A, tp=8/20μs
12
Dynamic Resistance1,2
RDYN
TLP=0.2/100ns
0.05
Ω
ESD Clamping Voltage1
VC
IPP = 4A,
tp = 0.2/100ns (TLP)
7
V
VC
IPP = 16A,
7.6
V
Junction Capacitance
Cj
VR = 0V, f = 1MHz
660
0.5
800
pF
Note:1、TLP Setting:tp=100ns, tr=0.2ns, ITLP and VTLP sample window:t1=70ns to t2=90ns.
2、Dynamic resistance calculated from IPP=4A to IPP=16A using “Best Fit”
www.way-on.com
2/5
WS4.5D3HP
Typical Characteristics
Figure 2: Power Derating Curve
110
100
Percent of Rated Power for Ipp
Ppp – Peak Pulse Power - Ppp(KW)
Figure 1: Peak Pulse Power vs. Pulse Time
10
1260w 8/20µs
Waveform
1
0.1
100
90
80
70
60
50
40
30
td – Pulse Duration - µs
Ambient Temperature - TA (
Figure 4: Normalized Junction
Capacitance vs. Reverse Voltage
Figure 3: Clamping Voltage vs. Peak Pulse
Current
16
1.2
1
12
Cj(VR)/Cj(VR=0)
Clamping Voltage -Vc(V)
1.1
8
0.9
0.8
0.7
0.6
0.5
0.4
0.3
4
0.2
0.1
00
60
80
Peak Pulse Current -Ipp(A)
tr=8µs
60
50
40
Half Value Ipp/2
10
RDYN=0.05Ohms
5
TLP
Parameters:
tp=100ns
tr=0.2ns
30
td=20µs
15
TLP Current (A)
Percent Ipp
70
4
Waveform
Paramters
tr=8µs
td=20µs
80
3
Figure 6: TLP Curve
110
90
2
Reverse Voltage -VR(V)
Figure 5: 8/20µs Pulse Waveform
100
1
-5
Time (µs)
2
4
6
8
10
12
TLP Voltage (V)
www.way-on.com
3/5
WS4.5D3HP
Soldering Parameters
Pb – Free assembly
Reflow Condition
Pre Heat
Temperature Min (Ts(min))
Temperature Max (Ts(max))
Time (min to max) (ts )
Average ramp up rate (Liquidus Temp) (TL) to peak
TS(max) to TL——Ramp-up Rate
Temperature (TL) (Liquidus)
Reflow
Temperature (tL)
Peak Temperature (TP)
150°C
200°C
60 – 190 secs
5°C/second max
5°C/second max
217°C
60 – 150 seconds
260+0/-5 °C
Time within actual peak Temperature (t p )
20 – 40 seconds
Ramp-down Rate
Time 25°C to peak Temperature (T P)
Do not exceed
5°C/second max
8 minutes Max.
280°C
Reflow Condition
www.way-on.com
4/5
WS4.5D3HP
Outline Drawing – SOD-323F
PACKAGE OUTLINE
D
b
E
1
2
SYMBOL
A
C
L
HE
MILLIMETER
MIN
TYP
MAX
A
0.60
0.65
0.75
b
0.25
0.30
0.40
C
0.06
0.13
0.21
D
1.60
1.70
1.80
E
1.15
1.25
1.35
HE
2.30
2.50
2.70
L
0.30
0.40
0.50
Notes:
1.70
Controlling Dimension: Millimeter.
0.40
0.50
DIMENSIONS: MILLIMETERS
Marking Codes
Part Number
Marking Code
WS4.5D3HP
HX
H=Specific Device Code
X=Annual production times
Package Information
Qty:3k/Reel
CONTACT INFORMATION
No.1001, Shiwan (7) Road, Pudong District, Shanghai, P.R.China.201207
Tel: 86-21-68969993 Fax: 86-21-50757680 Email: market@way-on.com
WAYON website: http://www.way-on.com
For additional information, please contact your local Sales Representative.
® is registered trademark of Wayon Corporation.
Specifications are subject to change without notice.
The device characteristics and parameters in this data sheet can and do vary in different applications and actual device performance may vary over time.
Users should verify actual device performance in their specific applications.
www.way-on.com
5/5
很抱歉,暂时无法提供与“WS4.5D3HP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.44572
- 100+0.36796
- 300+0.32908
- 3000+0.29625
- 6000+0.27292
- 9000+0.26115
- 国内价格
- 1+0.35420
- 200+0.22880
- 1500+0.19910
- 3000+0.17600
