LMC555MM/TR
LMC555MM/TR
    HGSEMI(华冠)
    MSOP-8
    LMC555是CMOS版本555系列通用定时器。该LMC555可提供产生精确的时间延迟和频率,具有非常低的功率损耗和电源电流尖峰。当芯片作为触发延时使用时,时间延时由一个单一的外部电阻和电容精确控制。
LMC555MM/TR 数据手册
LMC555 CMOS general purpose timer Features         Exact equivalent in most cases for SE/NE555. Low Supply Current. High speed operation – 500 kHz guaranteed. Wide operation supply voltage range – 2 to 18 volts. Timing from microseconds through hours. Operates in both astable and monostable modes. Adjustable duty cycle. High output source/sink driver can drive TTL/CMOS DIP8 SOP8 MSOP8 Ordering Information DEVICE Package Type MARKING Packing Packing Qty LMC555CN DIP8 LMC555 TUBE 2000/box LMC555CM/TR SOP8 LMC555 REEL 2500/reel MSOP8 C555 REEL 3000/reel LMC555IN DIP8 LMC555 TUBE 2000/box LMC555IM/TR SOP8 LMC555 REEL 2500/reel MSOP8 C555 REEL 3000/reel LMC555CMM/TR LMC555IMM/TR http://www.hgsemi.com.cn 1/8 2015 MAR LMC555 General Description The LMC555 is CMOS RC timers providing significantly improved performance over the standard SE/NE555 and 355 timers, while at the same time being direct replacements for those devices in most applications. Improved parameters include low supply current, wide operating supply voltage range, low THRESHOLD, TRIGGER and RESET currents, no crowbarring of the supply current during output transitions, higher frequency performance and no requirement to decouple CONTROL VOLTAGE for stable operation. Specifically, the LMC555 is stable controller capable of producing accurate time delays of frequencies. PIN ASSIGNMENT LMC555 TRUTH TABLE THRESHOLD X ������� X ����� OUTPUT DISCHARGE L L ON > 2/3 VCC > 1/3 VCC H L ON < 2/3 VCC > 1/3 VCC H STABLE STABLE < 1/3 VCC H H OFF X http://www.hgsemi.com.cn 2/8 2015 MAR LMC555 Maximum Ratings And Recommended Operating Conditions Parameter, unit Supply Voltage, V Output Current, mА Input Voltage, V Power Dissipation, mW Operating Temperature,°C LMC555C Operating Temperature,°C LMC555I Storage Temperature,°C Lead Temperature, 1 mm from Case for 10 Seconds,°C http://www.hgsemi.com.cn Symbol Recommended operatingconditions Maximum ratings Value Value min max min max VCC 2.0 18.0 0 18.0 IO - 20 - 100 VTH, VTRIG, VRST - - -0.3 VCC+0.3 PD - - - 200 0 70 0 70 -40 85 -40 85 TSTG - - -65 150 TSOLDER - - TOPR 3/8 260 2015 MAR LMC555 DC ELECTRICAL CHARACTERISTICS (Voltages Referenced to GND) Test Conditions Parameter, units Symbol Threshold Voltage, V VTH 5.0 Trigger voltage, V VTRIG 5.0 IOL, IOH VCC, В 2.0 Reset voltage, V 18.0 VRST 2.0 18.0 Control Voltage Lead, V Output voltage Low, V Output voltage High, V Supply Current, µA http://www.hgsemi.com.cn VCV VOL VOH Value min max Temperature, °С 0.65 VCC 0.70 VCC 25±10 0.60 VCC 0.80 VCC -20, 70 0.31 VCC 0.36 VCC 25±10 0.28 VCC 0.40 VCC -20, 70 0.4 1.0 25±10 0.2 1.5 -20, 70 0.65 VCC 0.69 VCC 25 0.60 VCC 0.80 VCC -20, 70 IOL = 3.2 mА 5.0 0.4 IOL = 20 mА 15.0 1.0 IOL = 3.2 mА 5.0 0.6 IOL = 20 mА 15.0 1.5 IOH = -0.8 mА ICC 4/8 5.0 4.0 15.0 14.3 5.0 3.5 15.0 14.0 10 25±10 -20, 70 25±10 -20, 70 2.0 200 18.0 300 2.0 400 18.0 600 25±10 -20, 70 2015 MAR LMC555 AC ELECTRICAL CHARACTERISTICS Parameter, unit Test Conditions Symbol RL , C L Rise (Fall) Time of Output,ns tTHL, tTLH Guaranteed Max Osc Freq,kHz fMAX Astable Operation Drift with Temperature, %/°С f RL = 1 - 100 k CL = 0.1 μF Drift with Supply Voltage, %/В f RL = 10 М , CL = 10 pF Value VCC, V 5.0 2.018.0 Initial accuracy, % Min Max 35 75 25±10 70 150 -20, 70 500 25±10 200 5 -20, 70 5.0 0.02 10.0 15.0 0.03 0.06 3 6 5.0 Temperature, °С -20, 70 25±10 -20, 70 Figura 1. Block Diagram Figura 2. http://www.hgsemi.com.cn Switcing Waveforms 5/8 2015 MAR LMC555 Physical Dimensions SOP8 Q A C C1 B D A1 a 0.25 b Dimensions In Millimeters(SOP8) A A1 B C C1 D Min: 1.35 0.05 4.90 5.80 3.80 0.40 0° 0.35 Max: 1.55 0.20 5.10 6.20 4.00 0.80 8° 0.45 Symbol: Q a b 1.27 BSC DIP8 D1 L1 L E B d D A c a b Dimensions In Millimeters(DIP8) A B D D1 E L L1 a b c Min: 6.10 9.00 8.40 7.42 3.10 0.50 3.00 1.50 0.85 0.40 Max: 6.68 9.50 9.00 7.82 3.55 0.70 3.60 1.55 0.90 0.50 Symbol: http://www.hgsemi.com.cn 6/8 d 2.54 BSC 2015 MAR LMC555 Physical Dimensions MSOP8 Q A C1 C B A1 D 0.20 b a Dimensions In Millimeters(MSOP8) A A1 B C C1 D Min: 0.80 0.05 2.90 4.75 2.90 0.35 0° 0.25 Max: 0.90 0.20 3.10 5.05 3.10 0.75 8° 0.35 Symbol: http://www.hgsemi.com.cn 7/8 Q a b 0.65 BSC 2015 MAR LMC555 IMPORTANT STATEMENT: Huaguan Semiconductor reserves the right to change its products and services without notice. Before ordering, the customer shall obtain the latest relevant information and verify whether the information is up to date and complete. Huaguan Semiconductor does not assume any responsibility or obligation for the altered documents. Customers are responsible for complying with safety standards and taking safety measures when using Huaguan Semiconductor products for system design and machine manufacturing. You will bear all the following responsibilities: select the appropriate Huaguan Semiconductor products for your application; Design, validate and test your application; Ensure that your application meets the appropriate standards and any other safety, security or other requirements. To avoid the occurrence of potential risks that may lead to personal injury or property loss. Huaguan Semiconductor products have not been approved for applications in life support, military, aerospace and other fields, and Huaguan Semiconductor will not bear the consequences caused by the application of products in these fields. The technical and reliability data (including data sheets), design resources (including reference designs), application or other design suggestions, network tools, safety information and other resources provided for the performance of semiconductor products produced by Huaguan Semiconductor are not guaranteed to be free from defects and no warranty, express or implied, is made. The use of testing and other quality control technologies is limited to the quality assurance scope of Huaguan Semiconductor. Not all parameters of each device need to be tested. The documentation of Huaguan Semiconductor authorizes you to use these resources only for developing the application of the product described in this document. You have no right to use any other Huaguan Semiconductor intellectual property rights or any third party intellectual property rights. It is strictly forbidden to make other copies or displays of these resources. You should fully compensate Huaguan Semiconductor and its agents for any claims, damages, costs, losses and debts caused by the use of these resources. Huaguan Semiconductor accepts no liability for any loss or damage caused by infringement. http://www.hgsemi.com.cn 8/8 2015 MAR
