ASMD1206SL600
ASMD1206SL600
    JDTFUSE(集电通)
    PTC自恢复保险丝 6V 50A It=12A Ih=6A 1206
ASMD1206SL600 数据手册
PRODUCT DATASHEET Surface Mount PTC Devices ASMD1206SL Series Surface Mount PTC Devices ASMD1206SL Series Surface Mount PTC Devices Description ASMD1206SL series provides miniature surface mount overcurrent protection ,It suitable for wide range of applications in modern electronics where space is limited. Features ● RoHS compliant ● Halogen-free ● Faster tripping ● 1206 Dimension ● Surface mountable ● Solid state ● Maximum Voltage: 6V/12V ● Operating Temperature:-40°C~ 85°C ● Certification: ROHS,UL Agency Approvals Agency Applications File Number E472196 ● Battery PCM ● Game console port protection ● USB hubs, ports and peripherals ● Optical disk drives ● Set-top-box and HDMI ● General electronics Regulation Standard   2002/95/EC   EN14582 JDT Fuse Industrial Co., Ltd www.jdtfuse.com Page 1/7 Revised 10/10/22 ASMD1206SL Series Surface Mount PTC Devices Electrical Characteristics Model V max (V) I max (A) I hold @25°C (A) I trip @25°C (A) Pd Typ. (W) Maximum Time To Trip Current (A) Time (Sec) Resistance R i min R1max (Ω) (Ω) ASMD1206SL110 6 50 1.10 2.20 0.8 8.0 5.0 0.015 0.100 ASMD1206SL110-12V 12 50 1.10 2.20 0.8 8.0 5.0 0.015 0.100 ASMD1206SL150 6 50 1.50 3.0 0.8 8.0 5.0 0.010 0.065 ASMD1206SL150-12V 12 50 1.50 3.0 0.8 8.0 5.0 0.010 0.065 ASMD1206SL175 6 50 1.75 3.5 0.8 8.0 5.0 0.010 0.060 ASMD1206SL175-12V 12 50 1.75 3.5 0.8 8.0 5.0 0.010 0.060 ASMD1206SL200 6 50 2.00 4.0 0.8 8.0 5.0 0.008 0.040 ASMD1206SL200-12V 12 50 2.00 4.0 0.8 8.0 5.0 0.008 0.040 ASMD1206SL260 6 50 2.60 5.2 0.8 8.0 5.0 0.004 0.026 ASMD1206SL260-12V 12 50 2.60 5.2 0.8 8.0 5.0 0.004 0.026 ASMD1206SL300 6 50 3.00 6.0 0.8 15.0 2.0 0.004 0.020 ASMD1206SL300-12V 12 50 3.00 6.0 0.8 15.0 2.0 0.004 0.020 ASMD1206SL350 6 50 3.50 7.0 1.0 17.5 2.0 0.004 0.018 ASMD1206SL350-12V 12 50 3.50 7.0 1.0 17.5 2.0 0.004 0.018 ASMD1206SL380 6 50 3.80 7.6 1.0 19.0 2.0 0.004 0.016 ASMD1206SL380-12V 12 50 3.80 7.6 1.0 19.0 2.0 0.004 0.016 ASMD1206SL400 6 50 4.00 8.0 1.0 20.0 2.0 0.004 0.014 ASMD1206SL400-12V 12 50 4.00 8.0 1.0 20.0 2.0 0.004 0.014 ASMD1206SL450 6 50 4.50 9.0 1.0 22.5 2.0 0.002 0.012 ASMD1206SL450-12V 12 50 4.50 9.0 1.0 22.5 2.0 0.002 0.012 ASMD1206SL500 6 50 5.00 10.0 1.0 25.0 2.0 0.002 0.011 ASMD1206SL500-12V 12 50 5.00 10.0 1.0 25.0 2.0 0.002 0.011 ASMD1206SL550 6 50 5.50 11.0 1.2 27.5 2.0 0.002 0.010 ASMD1206SL550-12V 12 50 5.50 11.0 1.2 27.5 2.0 0.002 0.010 ASMD1206SL600 6 50 6.00 12.0 1.2 30.0 2.0 0.002 0.009 ASMD1206SL600-12V 12 50 6.00 12.0 1.2 30.0 2.0 0.002 0.009 ASMD1206SL650 6 50 6.50 13.0 1.5 32.5 2.0 0.001 0.009 ASMD1206SL650-12V 12 50 6.50 13.0 1.5 32.5 2.0 0.001 0.009 ASMD1206SL700 6 50 7.00 14.0 1.5 35.0 2.0 0.001 0.008 ASMD1206SL700-12V 12 50 7.00 14.0 1.5 35.0 2.0 0.001 0.008 ASMD1206SL750 9 50 7.50 15.0 1.5 35.0 5.0 0.001 0.007 ASMD1206SL750-12V 12 50 7.50 15.0 1.5 35.0 5.0 0.001 0.007 JDT Fuse Industrial Co., Ltd www.jdtfuse.com Page 2/7 Revised 10/10/22 ASMD1206SL Series Surface Mount PTC Devices I hold = Hold Current. Maximum current device will not trip in 25°C still air. I trip = Trip Current. Minimum current at which the device will always trip in 25°C still air. V max = Maximum operating voltage device can withstand without damage at rated current (Imax). I max = Maximum fault current device can withstand without damage at rated voltage (V max). Pd = Power dissipation when device is in the tripped state in 25°C still air environment at rated voltage. Ri min/max = Minimum/Maximum device resistance prior to tripping at 25°C. R1max = Maximum device resistance is measured one hour post reflow. CAUTION : Operation beyond the specified ratings may result in damage and possible arcing and flame. Test Procedures and Requirements Conditions Test Conditions Accept/Reject Criteria Resistance change Initial Resistance    In still air at 25°C Rimin≤R≤R1max Time to Trip    Specified current,Vmax,25°C T≤Maximum Time to Trip Holding Current    30min,at IH ,@25°C No trip Trip Endurance      Vmax,Imax,1 hour No arcing or burning   Physical Characteristics Terminal Materials Tin-Plated Nickle-copper Conditions Resistance change Soldering Zone     Meets EIA specification RS 186-9E and ANSI/J-STD-002 Category 3. Moisture Sensitivity     Level 2a, per IPC/JEDEC J-STD 020C Environmental Specifications Test Conditions Conditions Resistance change change Resistance Passive aging   +85°C, 1000 hrs.   ±10% typical Humidity aging   +85°C, 85% R.H. , 100 hours   ±5% typical Thermal shock   MIL-STD-202,Method 107G+85°C to -40°C, 20 times   -30% typical Resistance to solvent   MIL-STD-202,Method 215   No change Vibration MIL-STD-833C,Test Condition A No change   JDT Fuse Industrial Co., Ltd www.jdtfuse.com   Page 3/7 Revised 10/10/22 ASMD1206SL Series Surface Mount PTC Devices Thermal Derading Chart Maximum ambient operating temperature (Tmao) vs. hold current (Ihold) Model - 40°C - 20°C 0°C 25°C 40°C 50°C 60°C 70°C 85°C ASMD1206SL110 1.61 1.45 1.26 1.10 0.96 0.85 0.77 0.67 0.52 ASMD1206SL150 2.01 1.77 1.62 1.50 1.22 1.12 .04 0.87 0.61 ASMD1206SL175 2.34 2.05 1.89 1.75 1.44 1.31 1.20 1.00 0.72 ASMD1206SL200 2.68 2.33 2.15 2.00 1.66 1.49 1.37 1.15 0.80 ASMD1206SL260 3.49 3.05 2.82 2.60 2.15 1.93 1.78 1.49 1.04 ASMD1206SL300 4.03 3.51 3.26 3.00 2.49 2.23 2.06 1.71 1.20 ASMD1206SL350 4.70 4.10 3.80 3.50 2.90 2.60 2.40 2.00 ASMD1206SL380 6.40 4.85 4.25 3.80 3.20 2.80 2.49 2.05 ASMD1206SL400 6.74 5.11 4.47 4.00 3.37 2.95 2.62 2.16 1.51 ASMD1206SL450 6.85 5.92 5.47 4.50 3.73 3.34 3.00 2.35 1.55 ASMD1206SL500 7.30 6.34 5.66 5.00 4.42 3.85 3.47 3.12 2.38 ASMD1206SL550 8.03 6.97 6.32 5.50 4.86 4.24 3.82 3.43 2.62 ASMD1206SL600 8.46 7.60 6.75 6.00 5.15 4.35 4.00 3.55 2.86 ASMD1206SL650 9.49 8.59 7.44 6.50 5.68 4.99 4.53 3.93 3.10 ASMD1206SL700 10.22 9.25 8.01 7.00 6.12 5.38 4.88 4.24 3.33 ASMD1206SL750 10.87 9.75 9.00 7.50 6.60 6.00 5.32 4.95 4.20   1.40 1.43 Soldering Parameters Profile Feature Average Ramp-Up Rate Ramp-up Critical Zone TL to TP TL 217 tL Tsmax 60~150 s Temperature (°C ) 200 Tsmin 150 Ramp-down ts Preheat 60~120 s 25 Preheat -Temperature Min(Ts min) 150℃ -Temperature Max(Ts max) 200℃ -Time(Ts min to Ts max) 60~120 seconds Time maintained above: -Temperature(TL) 217℃ -Time(tL) 60~150 seconds Peak/Classification Temperature(Tp) t 25°C to peak Time 3℃/second max. (Ts max to T p) TP 20~40 S TP 260 Pb-Free Assembly 260℃ Time within 5℃ of actual peak temperature Time (TP) 30 seconds max. Ramp down rate 3℃/seconds max. Time 25℃ to peak temperature 8 minutes max. ● Recommended reflow methods: IR, vapor phase oven, hot air oven, N2 environment for lead-free. ● Devices are not designed to be wave soldered to the bottom side of the board. ● Recommended maximum paste thickness is 0.25mm (0.010inch). ● Devices can be cleaned using standard industry methods and solvents. Note 1: All temperature refer to topside of the package, measured on the package body surface. Note 2: If reflow temperature exceed the recommended profile, devices may not meet the performance requirements. JDT Fuse Industrial Co., Ltd www.jdtfuse.com Page 4/7 Revised 10/10/22 ASMD1206SL Series Surface Mount PTC Devices Physical Dimensions(mm.) F F H G A Model B C D E Min. Max. Min. Max. Min. Max. Min. Min. ASMD1206SL110 3.0 3.5 1.5 1.8 0.3 0.7 0.15 0.1 ASMD1206SL150 3.0 3.5 1.5 1.8 0.3 0.7 0.15 0.1 ASMD1206SL175 3.0 3.5 1.5 1.8 0.3 0.7 0.15 0.1 ASMD1206SL200 3.0 3.5 1.5 1.8 0.3 0.7 0.15 0.1 ASMD1206SL260 3.0 3.5 1.5 1.8 0.4 1.0 0.15 0.1 ASMD1206SL300 3.0 3.5 1.5 1.8 0.4 1.2 0.15 0.1 ASMD1206SL350 3.0 3.5 1.5 1.8 0.4 1.2 0.15 0.1 ASMD1206SL380 3.0 3.5 1.5 1.8 0.4 1.2 0.15 0.1 ASMD1206SL400 3.0 3.5 1.5 1.8 0.5 1.2 0.15 0.1 ASMD1206SL450 3.0 3.5 1.5 1.8 0.5 1.4 0.15 0.1 ASMD1206SL500 3.0 3.5 1.5 1.8 0.5 1.4 0.15 0.1 ASMD1206SL550 3.0 3.5 1.5 1.8 0.6 1.6 0.15 0.1 ASMD1206SL600 3.0 3.5 1.5 1.8 0.6 1.6 0.15 0.1 ASMD1206SL650 3.0 3.5 1.5 1.8 0.8 1.6 0.15 0.1 ASMD1206SL700 3.0 3.5 1.5 1.8 0.8 1.6 0.15 0.1 ASMD1206SL750 3.0 3.5 1.4 1.8 0.8 1.6 0.15 0.1 Recommended Solder Pad Layout Dimensions (mm.) Device 1206SL Series F G H Normal Value Normal Value Normal Value 1.0 1.8 1.8 Packaging Quantity Model Quantity ASMD1206SL110~350 5,000 pcs/reel ASMD1206SL380~500/600 3,500 pcs/reel Others 3,000 pcs/reel JDT Fuse Industrial Co., Ltd www.jdtfuse.com Page 5/7 Revised 10/10/22 ASMD1206SL Series Surface Mount PTC Devices Tape And Reel Specifications (mm) Governing Specifications W 8.15 ± 0.15/-0.3 P0 4.0 ± 0.10 P1 4.0 ± 0.10 P2 2.0 ± 0.05 A0 1.95 ± 0.10 B0 3.65 ± 0.10 D0 1.55 + 0.05 F 3.5 ± 0.05 E1 1.75 ± 0.10 T 0.20± 0.10 Leader min. 390 Trailer min. 160   Reel Dimensions A 178± 1 N 59± 1 W1 8.5 ± 1.0/-0.2 W2 12.0 ± 1 Part Number System ASMD 1206 SL Special Voltage Rating(Optional) Holding Current Rating Super Low resistance Device Dimensions: Length/width(Unit:1/100 inch) Size 3216 mm /1206 inch Surface Mount Device JDT Fuse Industrial Co., Ltd www.jdtfuse.com Page 6/7 Revised 10/10/22 ASMD1206SL Series Surface Mount PTC Devices Application Notice 1. Operation of these PPTC devices beyond the stated maximum ratings could result in damage to the devices and lead to electrical arcing and/or fire; PPTC 器件在超过规定的最大值额定值运行可能会导致器件损坏以及导致电弧和/或火灾。 2. These PPTC devices are intended to protect against the effects of temporary over-current or over-temperature conditions and shall not be taken for use as switch. PPTC 的作用是防止临时的过流或过温造成的不良影响,不能当作开关使用。 3. Exposure to lubricants, silicon-based oils, solvents, gels, electrolytes, acids, and other related or similar materials may adversely affect the performance of PPTC devices. PPTC 接触润滑剂、硅基油、溶剂、凝胶、电解质、酸和其他相关或类似材料可能会对 PPTC 器件的性能有不利影响。 4. Circuits with inductance may generate a voltage above the rated voltage of the PPTC device and should be thoroughly evaluated within the user’s application during the PPTC selection and qualification process. 带有电感的电路可能产生高于 PPTC 额定电压的电压,因此客户在选型和认定过程中应进行彻底的评估。 5. Please do not smash, clamp, pull, dent or twist by tool during assembling process,as they may result in the PPTC damage. 在装配过程中,避免有砸、挤、拉、扭等方式外力作用于 PPTC 本体上,因为它们可能导致 PPTC 损坏。 6. Hand-soldering of PPTC devices on boards is generally not recommended.Users shall define and verify this process if needed. 不推荐使用手工焊接的方式焊接 PPTC。如果需要,用户需要定义和验证此过程。 7. Recommended storage conditions should be followed at all times , The MSL classification of PPTC is grade 2a. 必须始终遵守推荐的保存条件要求, PPTC 的 MSL 等级为 2 a级。 JDT Fuse Industrial Co., Ltd www.jdtfuse.com Page 7/7 Revised 10/10/22
ASMD1206SL600 价格&库存
很抱歉,暂时无法提供与“ASMD1206SL600”相匹配的价格&库存,您可以联系我们找货
