GT5
Interface Connector
GT13
GT19
GT21
Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
PO5G
— SMT Multi-contact Connectors —
GT16
GT25 Series
GT26
GT36
GT11
GT17
GT32
GT3
GT10
The width of tab is 025 size.
GT25
■ Product Specifications
Insulation Resistance
100MΩ min
Withstanding Voltage
AC650V for one minute
Contact Resistance
Operating Temperature Range
No more than 30mΩ (initially) −40℃ to +105℃(Note 2)
Note 1 : When using different consitions, please consult with Hirose.
Note 2 : Includes temperature rise caused by current flow.
GT8E
Rated Current
3A(Note 1)
GT18W
Metal holddowns to solder by reflow are used instead of screws for PCB mounting.
GT9
GT15
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
195
Interface Connector
GT7
Features
■ F Terminal
GT13
GT5
GT25 Series ● Interface Connector
1.9
15.3
11.8
GT19
GT21
GT26
HRS No.
775-0039-6
775-0070-6
Material
Plating
Copper palloy
Tin plating
Conductor Size (AWG)
20 to 22 AWG
24 to 28 AWG
Outer Diameter
φ1.0 to 1.7
φ0.5 to 1.0
Packaging
RoHS
10,000 pcs/reel
YES
■ F Connector
● Housing(Pre-assembled retainer)
18.5
GT17
GT11
GT36
Part No.
GT25H-2024SCF
GT25HB-2428SCF
GT32
GZiV^cZgXdbeaZiZanVhhZbWaZYXdcY^i^dc
GT3
A
7.4
13
2.8
GT7
9.5
2.7
GZiV^cZgiZbedgVg^anVhhZbWaZYXdcY^i^dc
GT10
GZiV^cZg
=djh^c\
GT18W
GT25
GT8E
GT9
GT15
Interface Connector
PO5G
GT16
1.4
196
Part No.
HRS No.
GT25-8DS-HU/R
775-0059-3
GT25-12DS-HU/R
775-0062-8
GT25-24DS-HU/R
775-0046-1
GT25-32DS-HU/R
775-0044-6
Color
Housing:Black
Retainer:Dark
Gray
Material
No. of Contacts
A Dimension
Housing:PPE
Retainer:PBT
8
11
PBT
12
15.4
24
28.6
32
37.4
Housing:PPE
Retainer:PBT
Note 1 : Pre-assembled retainer into housing body
Note 2 : After insert assembled contact, retainer has to be pushed-in correct position
Note 3 : Available to purchase housing and retainer separately for repair.
Packaging
RoHS
1
YES
GT5
Improved prying force
3
BRecommended PCB pattern
D
0.75±0.03
+0.1
7.4 0
8.9±0.05
4.3±0.05
.05
+00
PO5G
(8)
9.65
A
+0.1
E
0.8
4.3
8
0.4
C
1.4
0.64
0.1
2.2
GT19
4
3
13
0.64
2 0
2H
GT21
GT26
(Under
development)
775-0045-9
GT25H-32DP-2.2H
(Under
development)
PPS
Brass/
Tin plating
23.7
19.3
20.73
12.1±0.05
20.73±0.05
28.1
29.53
20.9±0.05
29.53±0.05
24
36.9
32.5
33.93
25.3±0.05
33.93±0.05
32
45.7
41.3
42.73
34.1±0.05
42.73±0.05
RoHS
200 pcs/reel
YES
GT17
GT25H-24DP-2.2H
Black
12
Packaging
1.5
Ø1
1.2±0.05
.2
0.0
0 5
GT25H-*DP-2.2V
0.0
0 5
6.48 -0.05
2 0
E
推奨基板寸法図
4.4
18.8
GT10
9.65
4.3
3.3
0.8
GT18W
0.4
C
4.825
GT25
GT8E
Part No.
Material/
Plating
Black
PPS
Brass/
Tin plating
775-0050-9
GT25H-24DP-2.2V
(Under
development)
GT25H-32DP-2.2V
775-0053-7
No. of
A
B
C
D
Contacts Dimension Dimension Dimension Dimension
E
Dimension
12
23.7
19.3
20.73
11±0.05
20.73±0.05
24
36.9
32.5
33.93
24.2±0.05
33.93±0.05
32
45.7
41.3
42.73
33±0.05
42.73±0.05
Packaging
RoHS
1
YES
GT15
Color
GT9
GT25H-12DP-2.2V
HRS No.
197
Interface Connector
9.65
GT7
4.3±0.05
7.4 0
2
B
1.2±0.05
.2
+0.1
4.3±0.05
Ø1
7.4 0
13.25
3
6×
1.15
0.64
0.6
2.2±0.05
GT3
2.2
3.23 -0.05
D
0.64
GT32
2.2±0.05
6×
A
+0.05
GT25H-20DP-2.2H
E
Dimension
6.92 0
775-0038-3
No. of
A
B
C
D
GT11
GT25H-12DP-2.2H
Material/
Plating
Color
+0.05
HRS No.
10.17 0
Part No.
GT36
GT16
16.9
+0.1
3.6 0
1.1±0.05
GT25H-*DP-2.2H
B
GT13
0.4
BRecommended PCB Pattern
8
GT16
PO5G
18±0.05
23.43±0.05
22
2.2
0.4
0.8
23.43
18
4.3
0.1
1.4
GT19
9.5
4.7
9.65
8
GT21
2
1.
GT26
φ
GT25-8P-2.2H(70)
HRS No.
Color
Material/Plating
Packaging
RoHS
775-0001-3 70
Light
Gray
PPS
Brass/
Tin plating
200pcs/reel
YES
2 rows
3.6+0.1
D
GT17
1.1±0.05
0.75±0.03
GT25-*DP-2.2H
2+0.1
φ
E
0.64
0.4
0.8
4.3
8
GT8E
GT25
GT18W
GT10
C
1.4
2.2
0.1
3
4
GT7
12.7
GT3
A
B
.05
+00
1.2
7.4+0.1
(8) 8.9±0.05
4.3±0.05
8
17
GT32
3
0.4
0.64
GT11
GT36
Part No.
Part No.
GT9
198
HRS No.
Color
Material/
Plating
No. of
A
B
C
D
Contacts imension imension imension imension
E
imension
GT25-8DP-2.2H
775-0004-1
8
17.65
13.2
14.63
7.7±0.05
14.63±0.05
GT25-12DP-2.2H
775-0005-4
12
22.05
17.6
19.03
12.1±0.05
19.03±0.05
GT25-16DP-2.2H
775-0006-7
16
26.45
22.0
23.43
16.5±0.05
23.43±0.05
24
35.25
30.8
32.23
25.3±0.05
32.23±0.05
GT25-28DP-2.2H(01) 775-0040-5 01
28
39.65
35.2
36.63
29.7±0.05
36.63±0.05
GT25-32DP-2.2H
775-0008-2
32
44.05
39.6
41.03
34.1±0.05
41.03±0.05
GT25-40DP-2.2H
775-0003-9
40
52.85
48.4
49.83
42.9±0.05
49.83±0.05
GT25-24DP-2.2H
GT15
Interface Connector
.1
+00
26.75
.3
Ø1
22
.1
+0 0
.2
Ø1
4±0.05
8 positions, 1 row
7.4±0.05
Right-angle Type
2.2±0.05
1.2±0.05
GT25-8P-2.2H
8±0.05 8.6±0.05
4
3±0 05
4.3±0.05
1.7
0.6
15.4±0.05
3.6 +0.1
■ M connector (PCB type)
18
GT13
GT5
775-0007-0
Note : (01) is tray package.
Light
Gray
PPS
Brass/
Tin plating
Packaging RoHS
200 pcs/reel
YES
or
1/tray
6.48 3.23
10.17
7.4 +0.1
4.3±0.05
3
12.9
1.5
GT16
0.6
2.2
φ1
6.92
5
+0.0
2 rows
GT13
Straight Type
GT25-*DP-2.2V
E
2.2±0.05
1.2±0.05
1.5
A
B
GT5
F
18.8
4.3
0.2
0.8
4.3
4.825
1.4
0.4
C
D
GT21
GT26
Color
GT25-16DP-2.2V(01)
775-0020-8 01
GT25-24DP-2.2V(01)
775-0021-0 01
GT25-32DP-2.2V(01)
775-0022-3 01
GT25-40DP-2.2V(01)
775-0014-5 01
Light
Gray
Material/
Plating
No. of
A
B
C
D
PPS
Brass/
Tin plating
E
Dimension
F
Dimension
16
26.75
22.3
15.4
23.73
15.4±0.05
23.73±0.05
24
35.55
31.1
24.2
32.53
24.2±0.05
32.53±0.05
32
44.35
39.9
33.0
41.33
33±0.05
41.33±0.05
40
53.15
48.7
41.8
50.13
41.8±0.05
50.13±0.05
Packaging RoHS
1/tray
YES
GT17
HRS No.
GT32
B Crimping tools
User manuals are available. Please contact your Hirose Electric account representative.
Item
Picture reference only
Specification
Stroke Length
30mm
Number of strokes
200spm (50Hz)
Weight
75kg
Remarks
240spm (60Hz)
0.2kw
Crimping speed
2,000 to 4,000 pcs/hour
AC100V
GT10
Motor
GT18W
Terminal Product No.
Terminal HRS No.
Tool Part No.
GT25
Part No. CM-105C
Tool HRS No.
775-0039-6
AP105-GT25H-2024S
901-5206-3
GT25HB-2428SCF
775-0070-6
AP105-GT25HB-2428S
901-5230-8
Note : Crimp height setting tables are available for each cable type. Pleace contact your nearest Hirose Electric account representative.
Different cables will require different crimp height settings.
tooling
GT9
● Hand
GT8E
GT25H-2024SCF
HRS No.
Part No.
HT304/GT25H-2024S
Applicable wire
GT25H-2024SCF
Note : HT304/GT25H-2024S is rated for 0.3SQ (22 AWG) or 0.5SQ (20 AWG) cable only.
HT304/GT25H-2024S can not terminate 0.2SQ (24 AWG) cable.
GT15
780-0044-1 00
199
Interface Connector
1.5tons
GT7
Press capacity
GT3
Specifications
Automatic Crimping Machine
GT11
Part No.
GT36
GT19
Powered by TCPDF (www.tcpdf.org)
PO5G
9.65
A
很抱歉,暂时无法提供与“GT25HB-2428SCF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.81432
- 50+0.79683
- 150+0.78516
