NEW
ZE05 Series
●High Vibration Resistance Terminal Design
①Double-Layered Spring Design
Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Suppresses outer vibration by increasing
the contact force
Double-Layered
Spring
■Features
1. Space-saving (0.5 size terminal, 2mm pitch)
Space-saving design that contributes to size
reduction of end product
2. High Heat Resistance : up to 125℃
Suitable for use in 125℃ environments.
②3-point contact design
the contact force
1 spring+ 2 beats= 3 contact points
3. High Vibration Resistance
Can be used in vehicle environments in which
intense vibration is applied.
4. Rated Current : 5A (Mono-Pole Power
Supply/ 2A (All-Pole Power Supply)
5. Retainer Guarantees 40N Tensile
Strength
1 Spring
Durable against cable routing
2 Beats
*The terminal is flipped upside down so the beat
is easier to see.
●High Tensile Strength due to Retainer
Tensile
Strength of
40N Secured
2020.4
1
ZE05 Series●High Heat and Vibration Resistance, 0.5 Size, 2mm pitch Automotive Interface Connector
■Product Specifications
Operating Temperature : -40 to +125℃
Rated Current : 2A (all-pole power supply)
5A (mono-pole power supply) Storage Temperature Range : -10 to +60℃ (Note 1)
Ratings
Storage Relative Humidity Range : 85% RH or less
(No condensation) (Note 1)
Rated Voltage : 60V AC/DC
Items
Specifications
1. Contact Resistance
Conditions
10mΩ Max.
Measured at 1A DC
2. Insulation Resistance
100MΩ Min.
Measured at 500V DC
3. Withstanding Voltage
There shall be no dielectric
breakdown.
Voltage of 1000V AC for 1 min.
4. Mating Durability
Contact Resistance : 20mΩ Max.
30 Insertion/Extraction cycles
5. Vibration Resistance
No electrical discontinuity of 1μs or
more.
6. Lock Strength
100N Min.
Frequency : 20 to 200Hz (Constant Acceleration
of 88m/s2)
1 Cycle 3 min. (round trip), 3 hours in 3 directions
Lock breaking strength measured when pulling in
mating axis direction
7.Humidity Resistance
Insulation Resistance : 100MΩ
Min.
Left for 96 hours at a temperature of 60℃ and a
relative humidity humidity 90 to 95%
8. Thermal Shock
Temperature : -40°
C → Room temperature →
125°
Time: 30 → 5 → 30 → 5 minutes for 1000 cycles
9. Heat Resistance
Left at 140℃ for 120 hours
10.Cold Resistance
Left at -40℃ for 120 hours
Left in sulfuric acid gas at room temperature with
a concentration of 25ppm and 75% or more RH
for 96 hours while unmated
11.Sulfuric Acid Gas Resistance
Note 1 : This storage temperature and humidity is for long-term storage of unused products.
■Materials / Finish
Component
Part
Material
Housing
Receptacle
Terminal
Plug
Crimp Terminal
2
Finish
UL Standard
PA Resin
Black
UL94V-0
Brass
Tin Plating
Solder Tabs
Brass
Tin Plating
Housing
PA Resin
Black
UL94V-0
Retainer
PA Resin
Natural
UL94V-0
Terminal
Copper Alloy
Tin Plating
Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
●Receptacle
❶Series Name
❷Solder Tabs
ZE05 H - 12 D P - 2 H
❶
❷
❸
❹
❺
❻
❸No. of Pos.
❼
❹Rows
●Plug
ZE05 - 12 D S - HU/R
❶
❸
❹
❺
●Crimp Terminal
❷
P:Receptacle S:Plug
❻Pitch
2:2mm
H : Right Angle
V : Straight
HU/R : Housing/Retainer
❶Series Name
:ZE05
❷Applicable Cable Size 2022 :20, 22 AWG (0.3-0.5SQ)
ZE05 - 2022 SCF
❶
:2、4、5、8、
12、
16、20、24
D:2 Rows N/A : 1 Row
❺Connector Type
❼Part Type
❼
:ZE05
H:SMT N/A:DIP
❸Form Type/ Packaging SCF :Female terminal, Reel
❸
Combination Chart
●Receptacle
ZE05H-**P-2H
●Plug
●Crimp Contact
ZE05-**P-2H
ZE05-**S-HU/R
ZE05-2022SCF
ZE05H-**P-2V
ZE05-**P-2V
3
■Right Angle Receptacle, SMT Solder Tabs
14.8±0.5
A±0.2
1±0.2
D±0.3
C±0.3
B±0.3
Unit : mm
HRS No.
No. of Pos.
A
B
C
ZE05H-2P-2H
Part No.
752-2109-0
2
2
12.32
13.7
ZE05H-4P-2H
752-2110-0
4
6
16.32
17.7
ZE05H-5P-2H
752-2120-0
5
8
18.32
19.7
ZE05H-8DP-2H
752-2112-0
8
10
18.52
19.9
ZE05H-12DP-2H
752-2113-0
12
14
22.52
23.9
ZE05H-16DP-2H
752-2114-0
16
29.9
ZE05H-20DP-2H
752-2115-0
34.52
35.9
ZE05H-24DP-2H
752-2116-0
24
30
38.52
39.9
D
8.34
8.84
■Right Angle Receptacle, DIP Solder Tabs
14.8±0.5
A±0.2
1±0.2
2.1
D±0.3
B±0.3
C±0.3
Unit : mm
HRS No.
No. of Pos.
A
B
C
ZE05-2P-2H
Part No.
752-2100-0
2
2
12.32
9.9
ZE05-4P-2H
752-2101-0
4
6
16.32
13.9
ZE05-5P-2H
752-2121-0
5
8
18.32
15.9
ZE05-8DP-2H
752-2103-0
8
10
18.52
16.1
ZE05-12DP-2H
752-2104-0
12
14
22.52
20.1
ZE05-16DP-2H
752-2105-0
16
26.1
ZE05-20DP-2H
752-2106-0
34.52
32.1
ZE05-24DP-2H
752-2107-0
24
30
38.52
36.1
Note 1 : The sales unit is 1 reel (300pcs/ reel). Please order by number of reels.
4
D
8.34
8.84
■Straight Receptacle, SMT Solder Tabs
C±0.3
B±0.2
D±0.5
2±0.2
2±0.2
A±0.2
Unit : mm
HRS No.
No. of Pos.
A
B
C
ZE05H-2P-2V
Part No.
752-2309-0
2
2
14.6
ZE05H-4P-2V
752-2310-0
4
6
18.6
ZE05H-8DP-2V
752-2312-0
8
10
8
20.8
ZE05H-12DP-2V
752-2313-0
12
14
12
24.8
ZE05H-24DP-2V
752-2316-0
24
30
28
40.8
■Straight Receptacle, DIP Solder Tabs
D
10
E
13.22
17.22
19.42
10.5
23.42
39.42
B±0.2
D±0.5
2±0.2
2±0.2
A±0.2
13.2±0.3
E±0.3
C±0.3
2.1
13.2±0.3
E±0.3
Unit : mm
HRS No.
No. of Pos.
A
B
C
ZE05-2P-2V
Part No.
Under Development (Note 3)
2
2
10.8
ZE05-4P-2V
4
6
14.8
ZE05-8DP-2V
8
10
8
17
ZE05-12DP-2V
12
14
12
21
ZE05-24DP-2V
24
30
28
37
D
10
E
13.22
17.22
19.42
10.5
23.42
39.42
Note 1 : The sales unit is 1 reel (250pcs/ reel). Please order by number of reels.
Note 2 : Suction tape is attached as a standard.
Note 3 : Pin counts with the HRS No. left blank are currently under development. For details contact a Hirose sales representative.
5
C±0.3
15.3±0.5
■Plug
0.6±0.3
B±0.5
A±0.5
Unit : mm
HRS No.
No. of Pos.
No. of Packages
A
ZE05-2S-HU/R
Part No.
752-2200-0
2
350
8.8
ZE05-4S-HU/R
752-2201-0
4
350
12.8
ZE05-5S-HU/R
752-2211-0
5
350
14.8
ZE05-8DS-HU/R
752-2203-0
8
385
13.6
ZE05-12DS-HU/R
752-2204-0
12
350
17.6
ZE05-16DS-HU/R
752-2205-0
16
280
23.6
ZE05-20DS-HU/R
752-2206-0
29.6
ZE05-24DS-HU/R
752-2207-0
24
210
33.6
Note 1 : The product is sold in sets so please order based on number of sets.
6
B
C
9.7
5.3
10.2
6.44
■Crimp Terminal for Plug
1.33±0.3
16.44±0.5
13.24±0.5
1.3±0.3
5.6±0.1
Part No.
HRS No.
Type
Quantity
Finish
ZE05-2022SCF
752-2001-0
Reel Terminal
10,000pcs/reel
Tin Plating
Note 1 : Please consult with a Hirose sales representative when considering cables other than the applicable cables.
Note 2 : Contact a Hirose sales representative regarding the usability of crimping tools made by other companies.
■Applicable Crimping Tool
Type
Hirose Crimping Tool
Applicator for
Japan Automatic Machine
Applicator (Note 1)
Hand Tool (Note 2)
HRSNo.
Applicable Cable
Applicable Contact
CM-105C
901-0001-0
AP105-ZE05-2022S
901-5239-0
Part No.
ZE05-2022SCF
CHX022700H
HT802/ZE05-2022S
780-0045-0
0.3sq, 0.5sq (Note 3)
ZE05-2022SCF (Note 4)
Retainer Release Tool
(No
t
e 5)
ZE05-2DC-HU/R/RE-MD
902-5144-0
ZE05-12DC-HU/R/RE-MD
902-5143-0
Terminal Extraction Tool
ZE05/RE-MD
902-5145-0
ZE05-2022SCF
Note 1 : Contact Japan Automatic Machine (J.A.M) regarding crimping failure relating to applicable J.A.M. applicators or for
other applicator inquiries via the J.A.M. website. (URL : http://www.jam-net.co.jp)
Note 2 : Hand tools are developed as a prototype tool during product development. Use an applicator for mass production.
Note 3 : Applicable cables are limited to those listed in the table.
Note 4 : Cut the reel terminal for use with the hand tool.
Applicable contacts are limited to those listed in the table.
Note 5 : Contact a Hirose representative about the retainer release tool for 20 and 24pos.
ZE05-2DC-HU/R/RE-MD …Single row products only (2, 4, 5pos.)
ZE05-12DC-HU/R/RE-MD …2 row products only (8, 12, 16pos.)
Note 6 : Conduct crimping based on the "Crimping Standards" and "Crimping Conditions Table".
Note 7 : Problems with tools not specified by Hirose are outside the scope of warranty.
7
Usage Precautions
1. Excessive pull force during unmating may damage the connector. If it is difficult to remove, push in lightly once and then
release the lock.
2. Always make sure to turn off the power before reseating the connector.
3. Do not have direct contact on the terminal when electricity is flowing since it is extremely dangerous.
4. Contact a Hirose representative for harness procedures or handling manuals.
Temperature(℃)
・Recommended Temperature Profile (Right Graph)
Reflow Heating Method Used
: Far infrared, air atmosphere or nitrogen
Reflow Cycles
: 2 times
Peak Temperature
: 250℃
230℃ Min.
: 20 to 40s
Preheat Temperature : 150 to 180℃
90 to 120s
・Hand Solder/ Solder Iron Temperature
: 280 to 300℃ for 2 seconds or less
・Terminal co-planarity is 0.1mm Max.
・Recommended board thickness : T=1.6mm
・Recommended solder thickness : 0.15mm
8
250
230
200
30±10s
180
150
90 to 120s
100
Time(s)
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose.com
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 04/2020. Contents are subject to change without notice for the purpose of improvements.
很抱歉,暂时无法提供与“ZE05H-8DP-2H”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+15.595851+1.95135
- 10+13.2469410+1.65746
- 25+12.4203225+1.55403
- 50+11.8244550+1.47948
- 100+11.25942100+1.40878
- 国内价格 香港价格
- 300+9.84736300+1.23210
- 600+9.75865600+1.22100
- 900+9.66993900+1.20990
- 1200+9.624321200+1.20420
- 1500+9.581221500+1.19880
- 国内价格 香港价格
- 300+11.22114300+1.40399
- 600+10.68552600+1.33697
- 900+10.38423900+1.29928
- 1500+10.016721500+1.25329
- 2100+9.781872100+1.22391
- 3000+9.538933000+1.19351
- 7500+8.942367500+1.11887
