山东晶导微电子有限公司
MM1W3V3 THRU MM1W330
Jingdao Microelectronics
Silicon Planar Zener Diodes
PINNING
PIN
FEATURES
• Total power dissipation: Max. 1 W.
• Wide zener reverse voltage range 3.3V to 330V.
• Small plastic package suitable for surface mounted design.
DESCRIPTION
1
Cathode
2
Anode
2
MECHANICAL DATA
▪ Case: SOD-123
1
• Terminals: Solderable per MIL-STD-750, Method 2026
Simplified outline SOD-123 and symbol
Absolute Maximum Ratings And Characteristics (Ta = 25 °C)
Symbol
Value
Unit
Power Dissipation at T L =75°C
PD
1
W
Forward Voltage at I F = 200 mA
VF
1.2
V
RθJA
300
°C/W
T j , T stg
-55 ~ +150
°C
Parameter
Typical thermal resistance juncting to ambient
Operating and Storage Temperature Range
(1)
Fig.1 Maximum Continuous Power Derating
1.2
Power Dissipation ( W )
1.0
0.8
0.6
0.4
0.2
0.0
25
50
75
100
125
T c ,Case Temperature (°C)
2016.10
150
175
Transient Thermal Impedance( °C /W)
(1) Thermal resistance from junction to ambient at P.C.B. mounted with 2. 0" X 2.0" (5 X 5 cm) copper areas pads.
Fig.2 Typical Transient Thermal Impedance
200
100
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
SOD123-W-MM1W3V3~MM1W330-1W
Page 1 of 3
Characteristics at Ta = 25°C
Dynamic
Impedance
Zener Voltage Range (1)
Type
Marking
V ZT(at I ZT)
Reverse Current
I ZT
Z ZT(at I ZT)
IR
at V R
Admissible
Zener Current
Min(V)
Nom(V)
Max(V)
(mA)
Max (Ω)
Max(μA)
(V)
I ZM (mA)
MM1W3V3
FHD
3.10
3.3
3.50
75
10
100
1
285
MM1W3V6
FHE
3.40
3.6
3.80
69
10
100
1
263
MM1W3V9
FHF
3.70
3.9
4.10
64
9.0
50
1
243
MM1W4V3
FHG
4.06
4.3
4.56
58
9.0
25
1
219
MM1W4V7
FHJ
4.50
4.7
4.93
53
8.0
10
1
203
MM1W5V1
FHK
4.84
5.1
5.36
49
7.0
10
1
186
MM1W5V6
FHL
5.32
5.6
5.92
45
5.0
10
2
170
MM1W6V2
FHN
5.86
6.2
6.51
41
2.0
10
3
154
MM1W6V8
FHO
6.46
6.8
7.18
37
3.5
10
4
140
MM1W7V5
FHQ
7.12
7.5
7.88
34
4.0
10
5
127
MM1W8V2
FHR
7.79
8.2
8.67
31
4.5
10
6
116
MM1W9V1
FHT
8.60
9.1
9.59
28
5.0
10
7
104
MM1W10
FHU
9.50
10
10.5
25
7.0
10
7
95
MM1W11
FHV
10.4
11
11.6
23
8.0
5
8
86
MM1W12
FHW
11.4
12
12.6
21
9.0
5
9
79
MM1W13
FHX
12.4
13
14.1
19
10
5
10
71
MM1W15
FHZ
13.8
15
15.8
17
14
5
11
63
MM1W16
FJA
15.2
16
17.1
16
16
5
12
58
MM1W18
FJF
16.8
18
19.2
14
13
52
MM1W20
FJG
19.0
13
22
5
15
47
MM1W22
FJK
20.8
22
23.3
12
23
5
17
43
MM1W24
FJL
22.8
24
26.0
11
25
5
18
38
MM1W27
FJN
25.3
27
28.9
9.5
35
5
21
35
MM1W30
FJQ
28.2
30
32.0
8.5
40
5
23
31
MM1W33
FJR
31.3
33
34.9
7.5
45
5
25
28
MM1W36
FJS
34.2
36
37.9
7.0
50
5
27
26
MM1W39
FJT
37.2
39
41.5
6.5
60
5
30
24
MM1W43
FLG
40.9
43
45.6
6.0
70
1
32
22
MM1W47
FLJ
44.9
47
49.8
5.5
80
1
35
MM1W51
FLK
48.6
51
54.0
5.0
95
1
38
18
MM1W56
FLL
53.6
56
58.8
4.5
110
1
42
17
MM1W62
FLN
58.9
62
65.6
4.0
125
1
47
15
MM1W68
FLO
64.6
68
71.7
3.7
150
1
52
14
MM1W75
FLQ
71.2
75
78.8
3.3
175
1
56
12
MM1W82
FLR
77.9
82
87.0
3.0
200
1
62
11
MM1W91
FLT
86.0
91
96.0
2.8
250
1
69
10
MM1W100
FLU
95.0
100
105
2.5
350
1
76
9.5
MM1W110
FLV
104
110
116
2.3
450
1
84
8.6
MM1W120
FLW
114
120
127
2.0
550
1
91
7.8
MM1W135
FLX
125
135
142
1.9
700
1
100
7.0
MM1W150
FLZ
140
150
157
1.7
900
1
110
6.3
MM1W165
FPA
155
165
172
1.6
1100
1
120
5.8
MM1W180
FPF
170
180
191
1.4
1200
1
135
5.2
MM1W200
FPG
189
200
211
1.2
1400
1
150
4.7
MM1W220
FPK
209
220
231
1.0
1600
1
165
4.3
MM1W240
FPL
229
240
251
1.0
1800
1
180
3.9
MM1W260
FPM
249
260
271
1.0
2000
1
190
3.7
MM1W280
FPN
269
280
291
1.0
2100
1
205
3.4
MM1W300
FPQ
289
300
315
1.0
2300
1
230
3.1
MM1W330
FLR
313
330
346
1.0
2500
1
250
2.8
(1) V ZT is tested with pulses (20 ms)
www.sdjingdao.com
Page 1 of 3
山东晶导微电子有限公司
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-123
A
D
b
E
A1
C
∠ALL ROUND
L1
E1
SOD-123 mechanical data
A
C
D
E
E1
L1
b
A1
max
1.3
0.22
1.8
2.8
3.9
0.45
0.7
0.2
min
0.9
0.09
1.5
2.5
3.6
0.25
0.5
max
51
8.7
71
110
154
18
28
min
35
3.5
59
98
142
10
UNIT
mm
9°
8
mil
The recommended mounting pad size
2.0
(79)
1.2
(47)
1.2
(47)
1.2
(47)
Unit: mm
(mil)
2016.10
www.sdjingdao.com
Page 1 of 3
很抱歉,暂时无法提供与“MM1W12”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.19762
- 300+0.15038
- 1200+0.14812
- 3000+0.14368
- 国内价格
- 20+0.25968
- 300+0.21374
- 1200+0.21160
- 国内价格
- 20+0.28329
- 200+0.23318
- 600+0.20531
