UB10.241
UB10.241
    PULS
    DIN导轨UPS控制24V 3.9-40AH
UB10.241 数据手册
UB10.241 24V, 10A, DC-UPS U–Series DC-UPS CONTROL UNIT • • • • • • • • • PRODUCT DESCRIPTION This uninterruptible power supply (UPS) controller UB10.241 is an addition to standard 24V power supplies to bridge power failures or voltage fluctuations. Expensive downtimes, long restart cycles and loss of data can be avoided. The DC-UPS includes a professional battery management system which charges and monitors the battery to achieve the longest battery service life as well as many diagnostic functions that ensure a reliable operation of the entire system. A unique feature of the UB10.241 is that only one 12V battery is required to buffer the 24V output. This makes matching batteries unnecessary and allows a precise battery charging and testing. The UB10.241 requires one external 12V battery for which two preassembled battery modules are available. A lightweight 7Ah battery which can be mounted on the DIN rail and a 26Ah module that can be panel mounted for longer buffer times. In addition to the UB10.241, the UBC10.241 UPS includes the same controller with an integrated 5Ah battery. ORDER NUMBERS Requires Only One 12V Battery for a 24V Output Stable Output Voltage in Buffer Mode Superior Battery Management for Longest Battery Life Comprehensive Diagnostic and Monitoring Functions Replace Battery Signal Included Electronically Overload and Short Circuit Protected 50% Power Reserves Selectable Buffer Time Limiter 3 Year Warranty SHORT-FORM DATA Input voltage range Output current Output voltage nom. 24Vdc 22.5-30Vdc min.15A min.10A typ. 0.23V lower as input voltage 22.25V 3.9Ah to 40Ah -25 to +70°C Normal mode Buffer mode Normal mode Buffer mode, 10A VRLA lead acid Operational +60°C to +70°C Derating 0.43A/°C normal mode Dimensions 49x124x117mm WxHxD Buffer time typ. 6’45” 7Ah battery module (at 10A) typ. 55’ 26Ah battery module Typical setup of a DC-UPS system with the UB10.241: Allowed batteries Temperature range DC AC 24V Power Supply e.g.: Dimension 24V DC-UPS 12V Battery 24V Load UB10.241 e.g.: UZK12.xxx e.g.: PLC MAIN APPROVALS For details and the complete approval list, see chapter19. DC-UPS UB10.241 Standard controller Accessory UZK12.072 Battery module 12V 7Ah UZO12.072 Mounting kit w/o battery UZK12.261 Battery module 12V 26Ah UZO12.26 Mounting kit w/o battery ZM1.WALL Panel/Wall mount bracket ZM10.WALL Panel/Wall mount bracket UL 508 UL 60950-1 Marine Marine Aug. 2021 / Rev. 1.5 DS-UB10.241-EN All parameters are specified at an input voltage of 24V, 10A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. It is assumed that the input power source can deliver a sufficient output current. www.pulspower.com Phone +49 89 9278 0 Germany Class I Div 2 1/30 UB10.241 24V, 10A, DC-UPS U–Series INDEX 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. PAGE Intended Use ............................................................. 3 Installation Instructions ............................................ 3 Input .......................................................................... 5 Output in Normal Mode .......................................... 6 Output in Buffer Mode ............................................ 7 Battery Input ............................................................. 8 Buffer Time ............................................................... 9 Efficiency and Power Losses................................... 11 Functional Diagram ................................................ 12 Check Wiring and Battery Quality Tests ............... 13 Relay Contacts and Inhibit Input ........................... 14 Front Side User Elements ....................................... 16 Terminals and Wiring ............................................. 18 Reliability ................................................................ 18 EMC.......................................................................... 19 Environment ........................................................... 20 INDEX PAGE 17. 18. 19. 20. 21. 22. 23. Protection Features ................................................ 20 Safety Features ....................................................... 21 Approved, Fulfilled or Tested Standards .............. 22 Regulatory Product Compliance............................ 23 Physical Dimensions and Weight .......................... 24 Installation Notes ................................................... 25 Accessories ......................................................... ….26 23.1. Battery Modules……………………………26 23.2. ZM1.WALL - Wall mounting bracket……26 23.3. ZM10.WALL - Wall mounting bracket…..27 24. Application Notes………………………………………28 24.1. Battery Replacement Intervals……………28 24.2. Parallel and Serial Use……………………..29 24.3. Using the Inhibit Input…………………….30 24.4. Troubleshooting……………………………30 TERMINOLOGY AND ABREVIATIONS DC-UPS Uninterruptible power supply with DC-Input. Normal mode Describes a condition where the battery is charged, the input voltage is in range and the output is loaded within the allowed limits. Buffer mode Describes a condition where the input voltage is below the transfer threshold level, the unit is running on battery (buffering) and the output is loaded within the allowed limits. Charging mode Describes a condition where the battery is being charged, the input voltage is in range and the output is loaded within the allowed limits. Inhibit mode Describes a condition where buffering is disabled on purpose by using the inhibit input of the DCUPS. (e.g. for service actions, or to save battery capacity) Buffer time Same as the term “hold-up time”. t.b.d. To be defined, value or description will follow later. DISCLAIMER The information presented in this document is believed to be accurate and reliable and may change without notice. Some parts of this unit are patent by PULS (US patent No 091662,063, Des. 424,529, …). No part of this document may be reproduced or utilized in any form without permission in writing from the publisher. Aug. 2021 / Rev. 1.5 DS-UB10.241-EN All parameters are specified at an input voltage of 24V, 10A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. It is assumed that the input power source can deliver a sufficient output current. www.pulspower.com Phone +49 89 9278 0 Germany 2/30 UB10.241 24V, 10A, DC-UPS U–Series 1. INTENDED USE This device is designed for installation in an enclosure and is intended for commercial use, such as in industrial control, process control, monitoring and measurement equipment or the like. Do not use this device in equipment where malfunction may cause severe personal injury or threaten human life. 2. INSTALLATION INSTRUCTIONS Risk of electrical shock, fire, personal injury or death. - Turn power off before working on the device and protect against inadvertent re-powering. Do not open, modify or repair the device. Use caution to prevent any foreign objects from entering into the housing. Do not use in wet locations or in areas where moisture or condensation can be expected. Do not touch during power-on, and immediately after power-off. Hot surface may cause burns. Obey the following installation instructions: This device may only be installed and put into operation by qualified personnel. This device does not contain serviceable parts. The tripping of an internal fuse is caused by an internal defect. If damage or malfunction should occur during installation or operation, immediately turn power off and send unit to the factory for inspection. Turn power off and disconnect the battery fuse before working on the device. Install the device in an enclosure providing protection against electrical, mechanical and fire hazards. Install the device onto a DIN rail according to EN 60715 with the input terminals on the top of the unit. The input can be powered from a regulated power supply or a similar DC source. The voltage between the input and ground must not exceed 60Vdc continuously. The ripple voltage in the low frequency range between 50Hz and 10kHz must be negligible when used in marine applications. The input must be powered from a PELV or SELV source or an “Isolated Secondary Circuit” in order to maintain a SELV or PELV output. Use an appropriately sized 24V power supply, which can deliver the additional internal current consumption, required to charge the battery. Use only VRLA lead acid batteries with a capacity between 3.9Ah and 40Ah. Check for correct input and battery polarity. The device will not operate when the voltage is reversed. Make sure that the wiring is correct by following all local and national codes. Use appropriate copper cables that are designed for a minimum operating temperature of 60°C for ambient temperatures up to +45°C, 75°C for ambient temperatures up to +60°C and 90°C for ambient temperatures up to +70°C. Ensure that all strands of a stranded wire enter the terminal connection. Do not use wires smaller than 2.5mm2 (or AWG 12) and not longer than 2x1.5m between the battery and the DC-UPS controller. Longer or smaller gauge wires can change performance of the system. Use a 30A fuse (ATOF® 287 030 from Little fuse or an UL listed fuse with the same characteristics) in the battery circuit. The battery fuse protects the wires between the battery and the DC-UPS and shall be located close to the battery. The device is designed for pollution degree 2 areas in controlled environments. No condensation or frost is allowed. The device is designed as “Class of Protection III” equipment according to IEC 61140. The enclosure of the device provides a degree of protection of IP20. A disconnecting means shall be provided for the input and the battery input of the device. The device is designed for convection cooling and does not require an external fan. Do not obstruct airflow and do not cover ventilation grid! Aug. 2021 / Rev. 1.5 DS-UB10.241-EN All parameters are specified at an input voltage of 24V, 10A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. It is assumed that the input power source can deliver a sufficient output current. www.pulspower.com Phone +49 89 9278 0 Germany 3/30 UB10.241 24V, 10A, DC-UPS U–Series Keep the following minimum installation clearances: 40mm on top, 20mm on the bottom, 5mm left and right side. Increase the 5mm to 15mm in case the adjacent device is a heat source. When the device is permanently loaded with less than 50%, the 5mm can be reduced to zero. The device is designed for altitudes up to 6000m (19685ft). The maximum surrounding air temperature is +70°C (+158°F). The operational temperature is the same as the ambient or surrounding air temperature and is defined 2cm below the device. The device is designed to operate in areas between 5% and 95% relative humidity. Installation Instructions for Hazardous Location Areas The device is suitable for use in Class I Division 2 Groups A, B, C, D locations and for use in Group II Category 3 (Zone 2) environments. Hazardous Location Classification: ATEX: EPS 15 ATEX 1 025 X, II 3G EX ec nC IIC T3 Gc EXPLOSION HAZARDS! Substitution of components may impair suitability for this environment. Do not disconnect the device or change unit settings unless power has been switched off or the area is known to be non-hazardous. A suitable enclosure must be provided for the end-product which has a minimum protection of IP54 and fulfils the requirements of the EN 60079-0. Aug. 2021 / Rev. 1.5 DS-UB10.241-EN All parameters are specified at an input voltage of 24V, 10A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. It is assumed that the input power source can deliver a sufficient output current. www.pulspower.com Phone +49 89 9278 0 Germany 4/30 UB10.241 24V, 10A, DC-UPS U–Series 3. INPUT Input voltage Input voltage ranges nom. nom. DC 24V 22.5 - 30Vdc 30 - 35Vdc 35Vdc 0 - 22.5Vdc Allowed input voltage ripple max. Allowed voltage between input and earth (ground) Turn-on voltage max. Input current **) typ. 1.5Vpp 1Vpp 60Vdc or 42.4Vac 22.8Vdc max. typ. typ. 23Vdc 120mA 1.1A External capacitors on the input Continuous operation, see Fig. 3-1 Temporarily allowed, no damage to the DC-UPS *) Absolute maximum input voltage with no damage to the DC-UPS The DC-UPS switches into buffer mode and delivers output voltage from the battery if the input was above the turn-on level before and all other buffer conditions are fulfilled. Bandwidth 3A or when long battery cables are used. For all other situations, use curve C. Step 3 Use the determined current from Step 2 to find the appropriate curve in Fig. 7-2. The buffer time (Discharging Time) can be found where this curve meets the dotted line. This is the point where the DCUPS stops buffering due to the under-voltage lockout. Step 4 Depending on Fig. 7-2, the buffer time needs to be reduced to take aging effects or guaranteed values into account. Example: The buffer current is 7.5A and a battery according Fig. 7-2 is used. The cable between the battery and the DC-UPS is 1m and has a cross section of 2.5mm2. How much is the maximum achievable buffer time. Answer:  According to Fig. 6-1, the battery current is 18A. Curve A is used since the battery current is > 3A and the length of the cable is one meter.  According to Fig. 7-2, a buffer time (Discharging Time) of 30 Minutes can be determined. It is recommended to reduce this figure to approximately 24 minutes for a guaranteed value and to cover aging effects. Aug. 2021 / Rev. 1.5 DS-UB10.241-EN All parameters are specified at an input voltage of 24V, 10A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. It is assumed that the input power source can deliver a sufficient output current. www.pulspower.com Phone +49 89 9278 0 Germany 10/30 UB10.241 24V, 10A, DC-UPS U–Series 8. EFFICIENCY AND POWER LOSSES Efficiency Power losses typ. typ. typ. typ. 97.8% 2.9W 5.5W 5.0W typ. 2.1W typ. 18.5W Normal mode, 10A output current, battery fully charged Normal mode, 0A output current, battery fully charged Normal mode, 10A output current, battery fully charged During battery charging, 0A output current During battery charging, to be added to power losses in normal mode, Fig. 8-2 Buffer mode, 10A output current Fig. 8-1 Efficiency at 24V, typ. Efficiency vs. output current in normal mode 98% 97.5 97.0 96.5 96.0 95.5 95.0 94.5 Output Current 3 5 7 9 11 13 15A Fig. 8-2 Losses at 24V, typ. Fig. 8-3 Losses, typ. Power losses in buffer mode, typ. Power losses versus output current in normal mode 8W 7 6 5 4 3 2 1 0 20W 15 10 5 Output Current 0 2.5 5 7.5 10 12.5 15A 0 Output Current 0 2 4 6 8 Aug. 2021 / Rev. 1.5 DS-UB10.241-EN All parameters are specified at an input voltage of 24V, 10A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. It is assumed that the input power source can deliver a sufficient output current. www.pulspower.com Phone +49 89 9278 0 Germany 10A 11/30 UB10.241 24V, 10A, DC-UPS U–Series 9. FUNCTIONAL DIAGRAM Fig. 9-1 Functional diagram DC-UPS Control Unit + 24V Power Supply Input - 12V Battery + - Input Fuse & Reverse Polarity Protection Battery Tester Electronic Current Limiter * Step-up Converter - Output Buffered Load - Battery Charger Status LED (green) Diagnosis LED (yellow) Controller + Battery + Check Wiring LED (red) Cut-off Relay Buffer-time Limiter 10s, 30s, 1m, 3m, 10m, End-of-charge Voltage (7) (8) (1) (2) (3) (4) (5) Inhibit + Inhibit - (6) Ready Buffering Replace Contact Contact Battery Contact *) Return current protection; This feature utilizes a MOSFET instead of a diode in order to minimize the voltage drop and power losses. Aug. 2021 / Rev. 1.5 DS-UB10.241-EN All parameters are specified at an input voltage of 24V, 10A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. It is assumed that the input power source can deliver a sufficient output current. www.pulspower.com Phone +49 89 9278 0 Germany 12/30 UB10.241 24V, 10A, DC-UPS U–Series 10. CHECK WIRING AND BATTERY QUALITY TESTS The DC-UPS is equipped with an automatic “Check Wiring” and “Battery Quality” test. “Check Wiring” test: Under normal circumstances, an incorrect or bad connection from the battery to the DC-UPS or a missing (or blown) battery fuse would not be recognized by the UPS when operating in normal mode. Only when back up is required would the unit not be able to buffer. Therefore, a “check wiring” test is included in the DC-UPS. This connection is tested every 10 seconds by loading the battery and analysing the response from the battery. If the resistance is too high, or the battery voltage is not in range, the unit displays “Check Wiring” with the red LED. At the same time the green “Ready” LED will turn off. “State of Health” (SoH) test: The battery has a limited service life and needs to be replaced in a fixed interval which is defined by the specified service life (acc. to the Eurobat guideline), based on the surrounding temperature and the number of charging/discharging cycles. If the battery is used longer than the specified service life, the battery capacity will degrade. Details can be found in chapter 24.1. The battery SoH test can not determine a gradual loss in capacity. However, it can detect a battery failure within the specified service life of the battery. Therefore, a SoH is included in the DC-UPS. The battery quality test consists of different types of tests:   During charging: If the battery does not reach the ready status (see chapter 12) within 30h, it is considered to be defective. The reason could be a broken cell inside the battery. During operation: Once the battery is fully charged, a voltage drops test and a load test is performed alternately every 8 hours. Three of the tests must consecutively produce negative results to indicate a battery problem. A battery problem is indicated with the yellow LED (replace battery pattern) and the relay contact “Replace Battery”. Please note that it can take up to 50 hours (with the largest size of battery) until a battery problem is reported. This should avoid nuisance error messages as any urgent battery problems will be reported by the “Check Wiring” test and create a warning signal. The battery tests require up to 50h uninterrupted operation. Any interruptions in the normal operation of the DC-UPS may result in the “Replace Battery” test cycle to start over. When “Replace battery” is indicated, it is recommended to replace battery as soon as possible. Aug. 2021 / Rev. 1.5 DS-UB10.241-EN All parameters are specified at an input voltage of 24V, 10A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. It is assumed that the input power source can deliver a sufficient output current. www.pulspower.com Phone +49 89 9278 0 Germany 13/30 UB10.241 24V, 10A, DC-UPS U–Series 11. RELAY CONTACTS AND INHIBIT INPUT The DC-UPS is equipped with relay contacts and signal inputs for remote monitoring and controlling of the unit. Relay contacts: Ready: Contact is closed when battery is charged more than 85%, no wiring failure are recognized, input voltage is enough and inhibit signal is not active. Buffering: Contact is closed when unit is buffering. Replace Battery: Contact is closed when the unit is powered from the input and the battery quality test (SOH test) reports a negative result. Relay contact ratings Isolation voltage max. min. max. 60Vdc 0.3A, 30Vdc 1A, 30Vac 0.5A resistive load 1mA at 5Vdc min. 500Vac, signal port to power port Signal input: Inhibit: Signal voltage Signal current Inhibit threshold Isolation The inhibit input disables buffering. In normal mode, a static signal is required. In buffer mode, a pulse with a minimum length of 250ms is required to stop buffering. The inhibit is stored and can be reset by cycling the input voltage. See also chapter 24.1 for application hints. max. max. min. max. nom. 7+ 3mA Inhibit 8- 5,1V 35Vdc 6mA, current limited 6Vdc, buffering is disabled above this threshold level 10Vdc 500Vac, signal port to power port Restriction apply when using the signal and relay contacts in a Haz-Loc environment: The Buffering, Ready and Replace Battery contact is intended to be used for a separately investigated nonincendive field wiring and/or field wiring apparatus. The DC-UPS may be located in a Class I, Division 2 (Group A, B, C or D) hazardous (classified) location. Associated apparatus must be installed in accordance with its manufacturer's control drawing and Article 504 of the National Electrical Code (ANSI/NFPA 70) for installation in the United States, or chapter 18 of the Canadian Electrical Code for Installations in Canada. Selected associated apparatus must be third part listed as providing nonincendive field circuits for the application, and have Voc not exceeding Vmax, Isc not exceeding Imax. Non associated non incendive field wiring apparatures shall not be connected in parallel unless this is permitted by the associated non incendive field wiring apparatures approval. Aug. 2021 / Rev. 1.5 DS-UB10.241-EN All parameters are specified at an input voltage of 24V, 10A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. It is assumed that the input power source can deliver a sufficient output current. www.pulspower.com Phone +49 89 9278 0 Germany 14/30 UB10.241 24V, 10A, DC-UPS U–Series - Input DCUPS + + Fig. 11-1 Contact control drawing for use in Haz-Loc environments - Output 1 Ready 2 3 Buffering Replace Battery Battery + Hazardous Location - 4 5 6 Non Hazardous Location Isc Voc Isc Voc Isc Voc Apparatus Selected barriers must have entity parameters such that Voc < V max, Isc < I max, Ca > Ci + C-cable, La > Li + L-cable For C-cable and L-cable, if the capacitance per foot or the inductance per foot is not known, then the following values shall be used: C-cable = 60pF/foot and L-cable = 0.2µH/foot. Contact current : I max = 50mA Contact voltage : V max. = 35V (DC or AC) Max. associated circuit capacitance Ci = 0 Max. assoc*) Minimum value includes 20% aging of the battery and a cable length of 1.5m with a cross section of 2.5mm2 between the battery and the DC-UPS and requires a fully charged (min. 24h) battery. **) Typical value includes 10% aging of the battery and a cable length of 0.3m with a cross section of 2.5mm2 between the battery and the DC-UPS and requires a fully charged (min. 24h) battery.iated circuit inductance Li = 0 No polarity requirement Aug. 2021 / Rev. 1.5 DS-UB10.241-EN All parameters are specified at an input voltage of 24V, 10A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. It is assumed that the input power source can deliver a sufficient output current. www.pulspower.com Phone +49 89 9278 0 Germany 15/30 UB10.241 24V, 10A, DC-UPS U–Series 12. FRONT SIDE USER ELEMENTS A Power Port Quick-connect spring-clamp terminals, connection for input voltage, output voltage and battery B Signal Port Plug connector with screw terminals, inserted from the bottom. Connections for the Ready, Buffering, Replace Battery relay contacts and for the Inhibit input. See details in chapter 11. C Green Status LED Ready: Battery is charged > 85%, no wiring failure is recognized, input voltage is enough and inhibit signal is not active. Charging: Battery is charging, and the battery capacity is below 85%. Buffering: Unit is in buffer mode. Flashing pattern of the green status LED: D ON OFF Ready ON OFF Charging ON OFF Buffering Yellow Diagnosis LED Overload: Output has switched off due to long overload in buffer mode or due to high temperatures. Replace battery: Indicates a battery which failed the battery quality test (SoH test). Battery should be replaced soon. Buffer-time expired: Output has switched off due to settings of Buffertimer Limiter. This signal will be displayed for 15 minutes. Inhibit active: Indicates that buffering is disabled due to an active inhibit signal. Flashing pattern of the yellow diagnosis LED: ON OFF Overload ON OFF Replace Battery ON OFF Buffer time expired ON OFF Inhibit active Aug. 2021 / Rev. 1.5 DS-UB10.241-EN All parameters are specified at an input voltage of 24V, 10A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. It is assumed that the input power source can deliver a sufficient output current. www.pulspower.com Phone +49 89 9278 0 Germany 16/30 UB10.241 24V, 10A, DC-UPS U–Series E Red Check Wiring LED This LED indicates a failure in the installation (e.g. too low input voltage), wiring, battery or battery fuse. F Buffer-time Limiter: User accessible dial which limits the maximum buffer time in a buffer event to save battery energy. When the battery begins to recharge after a discharging event, the process is completed much faster since only the energy which was taken out of the battery needs to be “refilled”. The following times can be selected: 10 seconds, 30 seconds, 1 minute, 3 minutes, 10 minutes or infinity (until battery is flat) which allows buffering until the deep discharge protection stops buffering. G End-of-charge-voltage Selector: The end-of-charge-voltage shall be set manually according to the expected temperature in which the battery is located. The dial on the front of the unit allows a continuously adjustment between +10 and +40°C. 10°C will set the end-of-charge-voltage to 13.9V, 25°C13.65V and 40°C13.4V. If in doubt about the expected temperature, set the unit to 40°C. Aug. 2021 / Rev. 1.5 DS-UB10.241-EN All parameters are specified at an input voltage of 24V, 10A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. It is assumed that the input power source can deliver a sufficient output current. www.pulspower.com Phone +49 89 9278 0 Germany 17/30 UB10.241 24V, 10A, DC-UPS U–Series 13. TERMINALS AND WIRING Type Solid wire Stranded wire AWG Ferrules Pull-out force Tightening torque Wire stripping length Power terminals Bi-stable, quick-connect springclamp terminals. IP20 Fingertouch-proof. Suitable for fieldand factory installation. Shipped in open position. 0.5-6mm2 0.5-4mm2 20-10AWG Allowed, but not required 10AWG:80N, 12AWG:60N, 14AWG:50N, 16AWG:40N according to UL486E Not applicable 10mm / 0.4inch Signal terminals Plug connector with screw terminal. Finger-touch-proof construction with captive screws for 3.5mm slotted screwdriver. Suitable for field- and factory installation. Shipped in open position. To meet GL requirements, unused terminal compartments should be closed. 0.2-1.5mm2 0.2-1.5mm2 22-14AWG Allowed, but not required Not applicable 0.4Nm, 3.5lb.in 6mm / 0.24inch Fig. 13-1 Spring-clamp terminals, connecting a wire Instructions: a) Use appropriate copper cables, that are designed for an operating temperature of 60°C b) Follow national installation codes and regulations! c) Ensure that all strands of a stranded wire enter the terminal connection! d) Up to two stranded wires with the same cross section are permitted in one connection point 14. RELIABILITY Lifetime expectancy MTBF SN 29500, IEC 61709 MTBF MIL HDBK 217F min. min. min. 137 400h > 15 years > 15 years 886 000h 1 482 000h 397 900 545 000 At 10A output current, 40°C At 5A output current, 40°C At 10A output current, 25°C At 10A output current, 40°C At 10A output current, 25°C At 10A output current, 40°C, ground benign GB40 At 10A output current, 25°C, ground benign GB25 The Lifetime expectancy shown in the table indicates the operating hours (service life) and is determined by the lifetime expectancy of the built-in electrolytic capacitors. Lifetime expectancy is specified in operational hours. Lifetime expectancy is calculated according to the capacitor’s manufacturer specification. The prediction model allows a calculation of up to 15 years from date of shipment. MTBF stands for Mean Time Between Failure, which is calculated according to statistical device failures and indicates reliability of a device. It is the statistical representation of the likelihood of a unit to fail and does not necessarily represent the life of a product. Aug. 2021 / Rev. 1.5 DS-UB10.241-EN All parameters are specified at an input voltage of 24V, 10A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. It is assumed that the input power source can deliver a sufficient output current. www.pulspower.com Phone +49 89 9278 0 Germany 18/30 UB10.241 24V, 10A, DC-UPS U–Series 15. EMC The unit is suitable for applications in industrial environment as well as in residential, commercial and light industry environment without any restrictions. CE mark is in conformance with EMC guideline 89/336/EEC and 93/68/EEC and the low-voltage directive (LVD) 73/23/EEC, 93/68/EEC. A detailed EMC Report is available on request. EMC Immunity Electrostatic discharge EN 61000-6-1, EN 61000-6-2 EN 61000-4-2 Electromagnetic RF field Fast transients (Burst) EN 61000-4-3 EN 61000-4-4 Surge voltage EN 61000-4-5 Conducted disturbance EN 61000-4-6 Contact discharge Air discharge 80MHz-1GHz Out- and input lines Signal lines**) Output +  Input +  + / -  housing 0,15-80MHz Generic standards 8kV 15kV 10V/m 2kV 2kV 500V 500V 500V 10V Criterion A*) Criterion A*) Criterion A Criterion A Criterion A Criterion A Criterion A Criterion A Criterion A *) DIN rail earthed **) Tested with coupling clamp EMC Emission Conducted emission EN 61000-6-3, EN 61000-6-4 Generic standards EN 55032 Input lines Class B*) EN 55032 Output lines Class B*) Radiated emission EN 55011, EN 55032 Class B This device complies with FCC Part 15 rules. Operation is subjected to the following two conditions: (1) this device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation. *) Informative measurement with voltage probe Switching frequencies Switching frequency of boost converter Switching frequency of electronic output current limitation Switching frequency of battery charger The DC-UPS has three converters with three different switching frequencies included. 100kHz Constant frequency 78kHz Constant frequency 19.5kHz Constant frequency Aug. 2021 / Rev. 1.5 DS-UB10.241-EN All parameters are specified at an input voltage of 24V, 10A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. It is assumed that the input power source can deliver a sufficient output current. www.pulspower.com Phone +49 89 9278 0 Germany 19/30 UB10.241 24V, 10A, DC-UPS U–Series 16. ENVIRONMENT Operational temperature -25°C to +70°C (-13° to +158°F) Derating 0.43A/°C 0.25A/°C Storage temperature Humidity -40 to +85°C (-40° to +185°F) 5 to 95% r.H. Vibration sinusoidal Shock Altitude Over-voltage category 2-17.8Hz: ±1.6mm; 17.8-500Hz: 2g 30g 6ms, 20g 11ms 0 to 6000m II II 2 Degree of pollution For the DC-UPS control unit. Keep battery in a cooler environment! +60°C to +70°C (+140°F to +158°F), normal mode see Fig. 16-1 +60°C to +70°C (+140°F to +158°F), buffer mode see Fig. 16-2 Storage and transportation, except battery IEC 60068-2-30 Do not energize while condensation is present IEC 60068-2-6 IEC 60068-2-27 Approvals apply only up to 2000m EN 50178 EN 50178 above 2000m altitude EN 50178, not conductive Fig. 16-1 Output current vs. ambient temperature Fig. 16-2 Output current vs. ambient temperature Allowable Output Current in Normal Mode Allowable Output Current in Buffer Mode 15A 15A continuous 12.5 10 10 7.5 7.5 5 5 2.5 2.5 0 -25 Ambient Temperature 0 20 40 for typ. 5s 12.5 60 70°C 0 -25 continuous Ambient Temperature 0 20 40 60 70°C The ambient temperature is defined 2cm below the unit. 17. PROTECTION FEATURES Output protection Output over-voltage protection in buffer mode Degree of protection Penetration protection Reverse battery polarity protection Wrong battery voltage protection Battery deep discharge protection Over temperature protection Input over-voltage protection Internal input fuse Electronically protected against overload, no-load and short-circuits typ. 32Vdc In case of an internal defect, a redundant circuitry max. 35Vdc limits the maximum output voltage. The output automatically shuts-down and makes restart attempts. IP20 EN/IEC 60529 > 3.5mm E.g. screws, small parts yes Max. –35Vdc; yes Max. +35Vdc (e.g. 24V battery instead of 12V battery) yes The limit is battery current dependent yes Output shutdown with automatic restart yes Max. 35Vdc, no harm or defect of the unit 25A, blade type No user accessible part, no service part Aug. 2021 / Rev. 1.5 DS-UB10.241-EN All parameters are specified at an input voltage of 24V, 10A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. It is assumed that the input power source can deliver a sufficient output current. www.pulspower.com Phone +49 89 9278 0 Germany 20/30 UB10.241 24V, 10A, DC-UPS U–Series 18. SAFETY FEATURES Output voltage Class of protection Isolation resistance Dielectric strength Touch current (leakage current) SELV IEC/EN 60950-1 PELV EN 60204-1, EN 50178, IEC 60364-4-41 Max. allowed voltage between any input, output or signal pin and ground: 60Vdc or 42.4Vac III PE (Protective Earth) connection is not required > 5MOhm Power port to housing, 500Vdc 500Vac Power port to signal port 500Vac Power port / signal port to housing The leakage current which is produced by the DC-UPS itself depends on the input voltage ripple and need to be investigated in the final application. For a smooth DC input voltage, the produced leakage current is less than 100µA. Aug. 2021 / Rev. 1.5 DS-UB10.241-EN All parameters are specified at an input voltage of 24V, 10A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. It is assumed that the input power source can deliver a sufficient output current. www.pulspower.com Phone +49 89 9278 0 Germany 21/30 UB10.241 24V, 10A, DC-UPS U–Series 19. APPROVED, FULFILLED OR TESTED STANDARDS UL 508 UL Certificate Listed equipment for category NMTR - Industrial Control Equipment Applicable for US and Canada E-File: E198865 IEC 60950-1 CB Scheme Certificate General safety requirements for Information Technology Equipment (ITE) UL 60950-1 UL Certificate Recognized component for category QQGQ - Information Technology Equipment (ITE) Applicable for US and Canada E-File: E137006 ATEX Agency Certificate (Bureau Veritas) EN 60079-0 Explosive atmospheres - General requirements EN 60079-7, EN 60079-15 Equipment protection by type of protection "e" and "n" Certificate: EPS 15 ATEX 1 025 X Temperature Code: T3 Type of Protection: ec nC IECEx IECEx Certificate IEC 60079-0 Explosive atmospheres - General requirements IEC 60079-7, IEC 60079-15 Equipment protection by type of protection "e" and "n" Certificate: IECEx EPS 15.0049 X Temperature Code: T3 Type of Protection: ec nC Class I Div 2 CSA Certificate Power Supplies for Hazardous Location Applicable for Canada and US CSA Class: 5318-01 (Canada), 5318-81 (USA) Temperature Code: T3 Groups: A, B, C and D Class I Div. 2 UL Certificate Recognized component for category QQPX - Power Supplies for Use in Hazardous Locations Applicable for US and Canada E-File: E246846 Temperature Code: T3 Groups: A, B, C and D Marine (DNV) DNV Certificate DNV Type approved product Certificate: TAA00001ST Temperature: Class D Humidity: Class B Vibration: Class C EMC: Class A Enclosure: Class A Marine (ABS) ABS Design Assessment Certificate ABS (American Bureau of Shipment) assessed product Certificate: 17-HG1599236-PDA Aug. 2021 / Rev. 1.5 DS-UB10.241-EN All parameters are specified at an input voltage of 24V, 10A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. It is assumed that the input power source can deliver a sufficient output current. www.pulspower.com Phone +49 89 9278 0 Germany 22/30 UB10.241 24V, 10A, DC-UPS U–Series IEC 60068-2-60 Manufacturer's Declaration (Online Document) Environmental Tests, Flowing Mixed Gas Corrosion Test Test Ke - Method 4 H2S: 10ppb NO2: 200ppb Cl2: 10ppb SO2: 200ppb Test Duration: 3 weeks, which simulates a service life of 10 years ISA-71.04 G3 Manufacturer's Declaration (Online Document) Airborne Contaminants Corrosion Test Severity Level: G3 Harsh H2S: 100ppb NOx: 1250ppb Cl2: 20ppb SO2: 300ppb Test Duration: 3 weeks, which simulates a service life of 10 years. VDMA 24364 Paint Wetting Impairment Substances Test (or LABS-Test) Tested for Zone 2 and test class C1 according to VDMA 24364-C1L/W for solvents and water-based paints 20. REGULATORY PRODUCT COMPLIANCE EU Declaration of Conformity REACH Directive WEEE Directive KC Korean Certificate EAC TR Registration The CE mark indicates conformance with the - EMC directive - Low-voltage directive - RoHS directive Manufacturer's Statement EU-Directive regarding the Registration, Evaluation, Authorization and Restriction of Chemicals Manufacturer's Statement EU-Regulation on Waste Electrical and Electronic Equipment Registered in Germany as business to business (B2B) products. KC Registration Korean registration of Broadcasting and Communication Equipment Registered under Clause 3, Article 58-2 of Radio Waves Act. EAC Certificate EAC EurAsian Conformity - Registration Russia, Kazakhstan and Belarus 8504408200, 8504409000 Aug. 2021 / Rev. 1.5 DS-UB10.241-EN All parameters are specified at an input voltage of 24V, 10A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. It is assumed that the input power source can deliver a sufficient output current. www.pulspower.com Phone +49 89 9278 0 Germany 23/30 UB10.241 24V, 10A, DC-UPS U–Series 21. PHYSICAL DIMENSIONS AND WEIGHT Width Height Depth Weight DIN rail 49mm / 1.93’’ 124mm / 4.88’’ Plus, height of signal connector plug 117mm / 4.61’’ Plus, depth of DIN rail 530g / 1.17lb Use 35mm DIN rails according to EN 60715 or EN 50022 with a height of 7.5 or 15mm. The DIN rail depth must be added to the depth (117mm) to calculate the total required installation depth. Electronic files with mechanical data can be downloaded at www.pulspower.com Fig. 21-1 Side view Fig. 21-2 Front view Aug. 2021 / Rev. 1.5 DS-UB10.241-EN All parameters are specified at an input voltage of 24V, 10A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. It is assumed that the input power source can deliver a sufficient output current. www.pulspower.com Phone +49 89 9278 0 Germany 24/30 UB10.241 24V, 10A, DC-UPS U–Series 22. INSTALLATION NOTES Mounting: The power terminal shall be located on top of the unit. An appropriate electrical and fire end-product enclosure should be considered in the end use application. Cooling: Convection cooled; no forced air cooling required. Do not obstruct air flow! Installation clearances: 40mm on top, 20mm on the bottom, 5mm on the left and right side are recommended when loaded permanently with full power. In case the adjacent device is a heat source, 15mm clearance are recommended. Risk of electrical shock, fire, personal injury or death! Turn power off and disconnect battery fuse before working on the DC-UPS. Protect against inadvertent re-powering. Make sure the wiring is correct by following all local and national codes. Do not open, modify or repair the unit. Use caution to prevent any foreign objects from entering the housing. Do not use in wet locations or in areas where moisture or condensation can be expected. Service parts: The unit does not contain any service parts. The tripping of an internal fuse is caused by an internal fault. If damage or malfunctioning should occur during operation, immediately turn power off and send unit to the factory for inspection! Wiring and installation instructions: (1) Connect the power supply to the input terminals of the DC-UPS. (2) Connect the battery to the battery terminals of the DC-UPS. It is recommended to install the battery outside the cabinet or in a place where the battery will not be heated up by adjacent equipment. Do not install the battery in airtight housings or cabinets. The battery should be installed according to EN50272-2, which includes enough ventilation. Batteries store energy and need to be protected against energy hazards. Use a 30A battery fuse typ ATO® 257 030 (Little fuse) or similar in the battery path. The battery fuse protects the wires between the battery and the DC-UPS. It also allows the disconnection of the battery from the DC-UPS which is recommended when working on the battery or DC-UPS. Disconnect battery fuse before connecting the battery. Please note: Too small or too long wires between the DC-UPS and the battery can shorten the buffer time or can result in a malfunction of the DC-UPS. Do not use wires smaller than 2.5mm2 (or 12AWG) and not longer than 2x1.5m (cord length 1.5m). Avoid voltage drops on this connection. (3) Connect the buffered load to the output terminals of the DC-UPS. The output is decoupled from the input allowing load circuits to be easily split into buffered and non buffered sections. Noncritical loads can be connected directly to the power supply and will not be buffered. The energy of the battery can then be used in the circuits which requires buffering. (4) Install the fuse when the wiring is finished. Fig. 22-1 Typical wiring diagram 24V unbuffered branch 24V buffered branch 24V Power supply N IN BAT OUT DC-UPS UB10.241 12V Battery - - Buffered load + - + - 24V 12V 24V + - + + - + + - Unbuffered load L PE Aug. 2021 / Rev. 1.5 DS-UB10.241-EN All parameters are specified at an input voltage of 24V, 10A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. It is assumed that the input power source can deliver a sufficient output current. www.pulspower.com Phone +49 89 9278 0 Germany 25/30 UB10.241 24V, 10A, DC-UPS U–Series 23. ACCESSORIES 23.1. BATTERY MODULES Two pre-assembled battery modules with a single 12V battery are available for different buffer times. As an option, the mounting brackets are also available without batteries. This option offers more flexibility in selecting an appropriate battery or can save shipping and logistic costs. See individual datasheets for detailed information. Battery type Service life Dimensions Weight DIN rail mountable Order number UZK12.072 Standard version 12V, 7Ah 3 to 5years 155x124x112mm 3.2kg yes UZK12.072 UZO12.072 UZB12.071 UZK12.261 High current version 12V, 26Ah 10 to 12years 214x179x158mm 9.9kg no UZK12.261 UZO12.26 UZB12.261 Fig. 23-1 UZK12.072 VRLA lead-acid maintenance free battery According to EUROBAT guideline Width x height x depth Battery module Mounting bracket without battery Replacement battery only Fig. 23-2 UZK12.261 23.2. ZM1.WALL - WALL MOUNTING BRACKET This bracket is used to mount specific Dimension units onto a flat surface without utilizing a DIN rail. The two aluminum brackets and the black plastic slider of the unit have to be removed, so that the two steel brackets can be mounted. Fig. 23-3 *) ZM1.Wall Wall mounting bracket*) Fig. 23-4 Wall mounting with DIN rail brackets*) PSU for illustration purpose only. Aug. 2021 / Rev. 1.5 DS-UB10.241-EN All parameters are specified at an input voltage of 24V, 10A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. It is assumed that the input power source can deliver a sufficient output current. www.pulspower.com Phone +49 89 9278 0 Germany 26/30 UB10.241 24V, 10A, DC-UPS U–Series 23.3. ZM10.WALL - WALL MOUNTING BRACKET This bracket is used to mount the devices on a wall/panel without utilizing the DIN rail. The bracket can be mounted without detaching the DIN rail brackets from the power supply. Product for illustration purpose only. Fig. 23-5 Fig. 23-6 Isometric view Fig. 23-8 Wall/panel mounting, side view Fig. 23-9 Isometric view Hole pattern for wall mounting Fig. 23-7 Fig. 23-10 Wall/panel mounting, side view Aug. 2021 / Rev. 1.5 DS-UB10.241-EN All parameters are specified at an input voltage of 24V, 10A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. It is assumed that the input power source can deliver a sufficient output current. www.pulspower.com Phone +49 89 9278 0 Germany Isometric view 27/30 UB10.241 24V, 10A, DC-UPS U–Series 24. APPLICATION NOTES 24.1. BATTERY REPLACEMENT INTERVALS Batteries have a limited lifetime. They degrade slowly beginning from the production and need to be replaced periodically. The design life figures can be found in the individual datasheets of the batteries and usually is specified according to the Eurobat guideline or according to the manufacturer’s specifications. The design life is the estimated life based on laboratory condition and is quoted at 20°C using the manufacturer’s recommended float voltage condition. According to the Eurobat guideline, design lives have been structured into the following different groups: 3 - 5 years: This group of batteries is very popular in standby applications and in small emergency equipment. This represents a 4 years design life with a production tolerance of ±1 year. 6 - 9 years: This group of batteries is usually used when an improved life is required. This represents a 7.5 years design life with a production tolerance of ±1.5 years. 10 - 12 years: This group of batteries is used when in applications where longest life and highest safety level are required. This represents a 11 years design life with a production tolerance of ±1 year. A battery failure within the specified design life of the battery usually results in a complete loss of the battery function (broken cell, defect connection, …) and will be detected and reported by the periodical battery tests which are included in the UB10.241 DC-UPS control unit. If the operational parameters differ from those which are specified for the design life, an earlier change of the battery might be necessary. The “real life” is called service life and is defined as the point at which the cell’s actual capacity has reached 80% of its nominal capacity. At the end of the service life the capacity degrades much faster, so that a further use of the battery is not recommended. Temperature effect: The temperature has the most impact in the service life. The hotter the temperature, the earlier the wear-out phase of the battery begins. The wear-out results in a degradation of battery capacity. See Fig. 24-1 for details. Effect of discharging cycles The number as well as the depth of discharging cycles is limited. A replacement of the battery might be necessary earlier than the calculated service life if the battery exceeds the numbers and values of Fig. 24-2. Other effects which shortens the service life  Overcharging and deep discharging shortens the service life and should be avoided. Thanks to the single battery concept of the UB10.241, the end-of-charge-voltage can be set very precisely to the required value a thereby avoiding unnecessary aging effects.  Charge retention is important to get the longest battery life. Stored batteries which are not fully charged age faster then charged batteries. Batteries which are not in use should be recharged at least once a year.  Excessive float charge ripple across the battery has an effect of reducing life and performance. The UB10.241 does not produce such a ripple voltage. This effect can be ignored when the battery is charged with the UB10.241. Guidelines for a long battery service life:  Place the battery in a cool location: E.g. near the bottom of the control cabinet.  Do not place the battery near heat generating devices.  Do not store discharged batteries.  Do not discharge the battery more than necessary. Set buffer time limiter to the required buffer time.  When choosing the battery capacity, always try to get the next higher capacity than required. The depth of discharge reduces the service life of the battery and limits the number of cycles. See Fig. 24-2. Aug. 2021 / Rev. 1.5 DS-UB10.241-EN All parameters are specified at an input voltage of 24V, 10A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. It is assumed that the input power source can deliver a sufficient output current. www.pulspower.com Phone +49 89 9278 0 Germany 28/30 UB10.241 24V, 10A, DC-UPS U–Series Example for calculating the service life and the required replacement cycle: Parameters for the example:  A 7Ah battery with a design life of 3-5 years is used (e.g. Yuasa battery from the battery module UZK12.072)  The average ambient temperature is 30°C  One buffer event consumes approx. 25% of the achievable buffer time.  One buffer event per day Calculation: Ambient temperature influence: According to Fig. 24-1 curve A, a 2 years service life can be expected for an ambient temperature of 30°C. Number of discharging cycles: 2 years * 365 cycles = 730cycles in 2 years. According to Fig. 24-2, curve C has to be used (only 25% of battery capacity is required). 730 cycles have only a negligible influence in a battery degradation and can be ignored. Result: The battery shall be replaced after 2 years. Please note that the battery degrading begins from the production date (check date code on the battery) which may shorten the replacement intervals. Fig. 24-1 Service life versus ambient temperatures, typ *) Cell Capacity Service Life in Years 10 9 8 7 6 5 4 3 2 1 20°C *) 120% Design Life of Battery A: 3-5 Years B: 6-9 Years C: 10-12 Years C B Fig. 24-2 Cell capacity degradation vs. discharging cycles *) C 100% 80% B A 60% Depth of discharge A: 100% B: 50% C: 30% 40% A 20% Ambient Temperature 25°C 30°C 35°C 40°C 45°C Number of Discharging Cycles 0 UZK12.071 200 UZK12.261 80 400 160 600 240 800 320 1000 1200 400 480 datasheet figures from battery manufacturer 24.2. PARALLEL AND SERIAL USE Do not use the DC-UPS in parallel to increase the output power. However, two units of the DC-UPS can be paralleled for 1+1 redundancy to gain a higher system reliability. Do not use batteries in parallel, since the battery quality test might create an error message. Do not connect two or more units in series for higher output voltages. Do not connect two or more units in a row to get longer hold-up times. Aug. 2021 / Rev. 1.5 DS-UB10.241-EN All parameters are specified at an input voltage of 24V, 10A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. It is assumed that the input power source can deliver a sufficient output current. www.pulspower.com Phone +49 89 9278 0 Germany 29/30 UB10.241 24V, 10A, DC-UPS U–Series 24.3. USING THE INHIBIT INPUT The inhibit input disables buffering. In normal mode, a static signal is required. In buffer mode, a pulse with a minimum length of 250ms is required to stop buffering. The inhibit is stored and can be reset by cycling the input voltage. For service purposes, the inhibit input can also be used to connect a service switch. Therefore, the inhibit signal can be supplied from the output of the DC-UPS. Fig. 24-3 Wiring example for inhibit input -- Output Power Supply Input N L PE + -+-+- IN BAT OUT 24V Buffered Load 12V 24V DC-UPS UB10.241 Signal Port Inhibit ++ - - 12V Battery + + + - Service Switch 24.4. TROUBLESHOOTING The LEDs on the front of the unit and relay contacts indicate about the actual or elapsed status of the DC-UPS. Please see also chapter 12. The following guidelines provide instructions for fixing the most common failures and problems. Always start with the most likely and easiest-to-check condition. Some of the suggestions may require special safety precautions. See notes in chapter 22 first. “Check wiring” LED is on Check correct wiring between the battery and the DC-UPS Check battery fuse. Is the battery fuse inserted or blown? Check battery voltage (must be typically between 7.4V and 15.1V) Check input voltage (must be typically between 22.8V and 30V) Check battery polarity DC-UPS did not buffer Inhibit input was set Battery did not have enough time to be charged and is still below the deep discharge protection limit. DC-UPS stopped buffering Buffer time limiter stopped buffering  set buffer time limiter to a higher value Deep discharge protection stopped buffering  use a larger battery, or allow enough time for charging the battery Output was overloaded or short circuit  reduce load Output has shut down Cycle the input power to reset the DC-UPS Let DC-UPS cool down, over temperature protection might have triggered. DC-UPS constantly switches between normal mode and buffer mode The supplying source on the input is too small and can not deliver enough current  Use a larger power supply or reduce the output load Aug. 2021 / Rev. 1.5 DS-UB10.241-EN All parameters are specified at an input voltage of 24V, 10A output load, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. It is assumed that the input power source can deliver a sufficient output current. www.pulspower.com Phone +49 89 9278 0 Germany 30/30
UB10.241 价格&库存
很抱歉,暂时无法提供与“UB10.241”相匹配的价格&库存,您可以联系我们找货
UB10.241
    • 1+2536.81200
    库存:20
    UB10.241
    • 1+3076.294341+398.25290
    库存:110
    UB10.241
    • 1+2697.11090
    库存:95
