1N4148WS
1N4148WS
    PSI(宝力芯)
    SOD-323
    开关二极管 VRRM=75V Io=150mA IF=Trr=4ns P=200mW SOD323
1N4148WS 数据手册
DATA SHEET 1N4148WS SURFACE MOUNT SWITCHING DIODES VOLTAGE 75 Volts POWER 200 mW FEATURES z FAST SWITCHING SPEED z SURFACE MOUNT PACKAGE IDEALLY SUITED FOR AUTOMATIC INSERTION z ELECTRICALLY IDENTICAL TO STANDARD JEDEC z HIGH CONDUCTANCE z LEAD FREE AND HALOGEN-FREE MECHANICAL DATA z CASE: SOD-323 z TERMINAL: SOLDERABLE PER MIL-STD-220, METHOD 208 z APPROX WEIGHT: 0.0043 GRAMS CASE: SOD-323 MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS RATINGS AT 25°C AMBIENT TEMPERATURE UNLESS OTHERWISE SPECIFIED. SYMBOL VALUE PEAK REPETITIVE PEAK REVERSE VOLTAGE PARAMETER VRRM 75 UNITS V NON-REPETITIVE PEAK REVERSE VOLTAGE VRM 100 V RMS REVERSE VOLAGE VRMS 53 V FORWARD CONTINUOUNS CURRENT IFM 300 mA AVERAGE RECTIFIED OUTPUT CURRENT IO 150 mA PEAK FORWARD SURGE CURRENT AT T =1.0μs T =1.0s THERMAL RESISTANCE JUNCTION TO AMBIENT POWER DISSIPATION STORAGE TEMPERATURE REANGE OPERATING JUNCTION TEMPERATURE IFSM 2 1 A RθJA 625 °C/W PD 200 mW TSTG - 65 TO + 150 °C TJ 125 °C VALUE UNITS ELECTRICAL CHARACTERISTICS (AT TA =25°C UNLESS OTHERWISE NOTED) PARAMETER SYMBOL IF = 1mA MAXIMUM FORWARD VOLTAGE IF = 10mA IF = 50mA 0.715 VF IF = 150mA MAXIMUM DC REVERSE CURRENT VR = 20V 0.855 1.0 V 1.25 IR 25 nA 1.0 μA JUNCTION CAPACITANCE (NOTE.1) CJ 2.0 pF MAXIMUM REVERSE RECOVERY TIME (NOTE.2) TRR 4.0 nS VR = 75V NOTE: 1. CJ AT VR =0V, f =1MHz 2. FROM IF =10mA TO IR =1mA, VR= 6V, RL=100Ω PAGE.1 Fig.1-TYPICAL FORWARD CHARACTERISTIC Fig.2-TYPICAL LEAKAGE CURRENT VS JUNCTION TEMPERATURE PAGE.2 SOD-323 DIMENSION Symbol L L1 W W1 H Dimensions In Millimeters Min Max 2.50 2.70 1.60 1.80 1.20 1.40 0.25 0.35 0.80 1.00 Dimensions In Inches Min Max 0.098 0.106 0.063 0.071 0.047 0.055 0.010 0.014 0.031 0.039 PAGE.3
1N4148WS 价格&库存
很抱歉,暂时无法提供与“1N4148WS”相匹配的价格&库存,您可以联系我们找货
