CRYSTAL UNIT
AEC-Q200
YSX321SC
Applications
Features
‧ GPS Automotive
electronics
‧Dimensions:3.20 x 2.50 x 0.70 mm.
‧Standard Frequency: 8~66MHz
‧Low impedance performance.
‧AEC-Q200 qualified.
Specifications
Standard Frequency
8~66 MHz
Vibration Mode
AT Fundamental
Load Capacitance
8pF,12pF,or specify
Frequency Tolerance (at 25 )
±10ppm,±30ppm,or specify
Frequency Versus Temperature Characteristics
Operating Temperature
±50ppm,or specify
-40~+125℃,or specify
-55~+125℃ or specify
Storage Temperature
Shunt Capacitance
3 pF Max.
Level of Drive
1~200μWMax.(100uW typical)
Aging (at 25 ℃ )
±2ppm/year Max.
Equivalent Series Resistance(ESR)
8 ~ 9.9MHz
10 ~ 10.9 MHz
11 ~ 11.9 MHz
12 ~ 12.9 MHz
800
250
150
100
Fundamental
Ω Max.
Ω Max.
Ω Max.
Ω Max
Dimensions and Patterns [unit:mm]
13 ~ 15.9MHz
16 ~ 20.9 MHz
21 ~ 29.9 MHz
30 ~ 66.0 MHz
80
70
60
50
Ω Max.
Ω Max.
Ω Max.
Ω Max
Package Size – Dimensions (Unit: mm)
www.yxc.hk
第1页共2页
CRYSTAL UNIT
AEC-Q200
YSX321SC
Reflow Soldering Profile
Temperature
Pre Heating Temperature
Tp1 ~ Tp2 = + 170 °C
Heating Temperature
TMlt = + 220 °C
Peek Temperature
TMax. = + 260 °C
+260℃
TMax.
+220℃
Tmlt
Point of measuring
In case of Solder ability
Terminal.
In case of Resistance to soldering heat
Surface.
Tp2
Tp1
35s
100s
t(time)
Taping Specification(Unit: mm)
Size
A
B
C
D
E
F
G
H
SMD-3225
180±2.0
8.0±0.3
3.80±0.1
3.04±0.1
4.0±0.1
1.54±0.1
61.0±1.0
8.0±1.0
3000 pcs per reel
www.yxc.hk
第2页共2页
很抱歉,暂时无法提供与“XC322512MOB4SA-18”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.51200
- 50+1.20982
- 150+1.08044
- 500+0.91887
- 3000+0.82394
- 国内价格
- 1+1.08230
- 200+0.83160
- 1500+0.72310
- 3000+0.67340
