SIG7793-ITSP16-RL
SIG7793-ITSP16-RL
    SIGNALMICRO(信格勒)
    TSSOP-16
    4通道, 4.17SPS至890SPS, 24位ADC, 带低噪声PGA和低温漂基准
SIG7793-ITSP16-RL 数据手册
SIG7792/7793 4-Channel 16/24-bit Sigma-Delta ADC with PGA and Reference FEATURES DESCRIPTION Programmable Gain: 1/2/4/8/16/32/64/128 Data Rates: 4.17SPS to 890SPS RMS Noise: 20nV at 4.17SPS (Gain=128) 63nV at 16.7SPS (Gain=128) 21.0 noise-free bits at 4.17SPS (Gain=1) Offset Drift: 5nV/°C (Gain=128) Gain Drift: 1ppm/°C 1.17V/2.5V Internal Reference with 4ppm/°C Drift Integral Non-Linearity: 2ppm 4 Differential Inputs Internal or External Clock Simultaneous 50Hz/60Hz Rejection Reference Detect Programmable Current Sources On-chip Bias Voltage Generator Burnout Current Sources Power Supply AVDD: 2.7V to 5.25V DVDD: 2.7V to 5.25V Current: 470uA Package: 16-lead TSSOP The SIG7792/7793 are low noise, low drift, and high-resolution 16/24-bit analog-to-digital converter (ADC) with integrated programmable gain amplifier (PGA) and low drift on-chip voltage reference that offers high-accuracy measurement solutions for bridge sensors, thermocouples, and resistance temperature devices (RTD). The device contains a low noise PGA with gains selected from 1, 2, 4, 8 16, 32, 64, and 128, a delta-sigma (Δ-Σ) modulator, and digital filter. A low drift 1.17V or 2.5V reference is integrated on chip and two matched excitation current sources (IEXCs) are provided for accurate RTD measurement. The output data rate from the device can be configured from 4.17SPS up to 890SPS. 50Hz/60Hz simultaneous rejection option is also provided. Burnout current sources are provided at the analog inputs for sensor connection diagnosis. Offset and gain calibration registers are provided with calibration command or direct register write to calibrate the ADC errors or overall system errors. SPI-compatible interface is used for device configuration. The on-chip oscillator or an external clock can be used as the clock source to the device. The SIG7792/7793 are available in 16-lead TSSOP packages and are fully specified over the -40°C to +125°C temperature range. APPLICATIONS Weigh Scales Strain Gauges Temperature Measurement Industrial Process Control Pressure Sensors Function Block Diagram AVDD REFIN1+/AIN3+ TSSOP-16 DVDD REFIN1-/AIN3- VBIAS INTREF SCLK 1 16 DIN CLK 2 15 DOUT/DRDYn CSn 3 14 DVDD IOUT1/AIN4- 4 13 AVDD AIN1+ 5 12 GND AIN1- 6 11 IOUT2/AIN4+ AIN2+ 7 10 REF-/AIN3- AIN2- 8 9 REF+/AIN3+ REF MUX REFERENCE DETECT Gain=1,2,4,8, 16,32,64,128 AIN1+ AIN1AIN2+ MUX AIN2- PGA BUF ΔΣ ADC Digital Filter Serial Interface And Control Logic CSn DIN DOUT/DRDYn SCLK AIN4+/I2 AIN4-/I1 SIG7792/SIG7793 TEMP Sensor SIG7792: 16-BIT SIG7793: 24-BIT Internal Oscillator CLK GND May 2022 SIG7792/7793 TSSOP-16 Signal Micro Incorporated http://www.signal-micro.cn SIG7792/7793 PIN CONFIGURATION and DESCRIPTIONS TOP VIEW (Not To Scale) PIN NO. NAME 1 SCLK 2 CLK SCLK 1 16 DIN CLK 2 15 DOUT/DRDYn CSn 3 14 DVDD IOUT1/AIN4- 4 13 AVDD AIN1+ 5 12 GND AIN1- 6 11 IOUT2/AIN4+ AIN2+ 7 10 REF-/AIN3- AIN2- 8 9 REF+/AIN3+ SIG7792/7793 TSSOP-16 FUNCTION DESCRIPTION Serial data clock. Master clock input or internal clock output depending on MODE Register bits CLK[1:0]. Serial chip select. Active low. 3 CSn Digital Input Digital Input/Output Digital Input 4 5 IOUT1/AIN4AIN1+ Analog Input Analog Input Internal excitation current output 1/Analog negative input channel 4. Analog positive input channel 1. 6 7 AIN1AIN2+ Analog Input Analog Input Analog negative input channel 1. Analog positive input channel 2. 8 9 AIN2REF+/AIN3+ Analog Input Analog Input Analog negative input channel 2. Positive reference input/Analog positive input channel 3. 10 11 REF-/AIN3IOUT2/AIN4+ Analog Input Analog Input Negative reference input/Analog negative input channel 3. Internal excitation current output 2/Analog positive input channel 4. 12 GND Analog 13 AVDD Analog 14 15 DVDD DOUT/DRDYn Digital Digital Output 16 DIN Digital Input May 2022 Ground reference point. Positive analog power supply. 2.7V to 5.25V relative to GND. AVDD is independent of DVDD. Digital power supply, 2.7V to 5.25V. DVDD is independent of AVDD. Serial data output and data ready indicator. Serial data input. Signal Micro Incorporated http://www.signal-micro.cn 2 SIG7792/7793 PACKAGE/ORDERING INFORMATION MODEL PACKAGE DESCRIPTION SPECIFIED TEMPERATURE RANGE ORDERING NUMBER PACKING OPTION SIG7792 TSSOP-16 -40°C to +125°C SIG7792-ITSP16-RL Reel, 5000 SIG7793 TSSOP-16 -40°C to +125°C SIG7793-ITSP16-RL Reel, 5000 SPECIFICATIONS Absolute Maximum Ratings Over operating free-air temperature range, unless otherwise noted.(1) AVDD to GND Voltage Current Temperature MIN MAX UNIT –0.3 6.5 V DVDD to GND –0.3 6.5 V Analog input –0.3 VAVDD + 0.3 V Digital input –0.3 VDVDD + 0.3 V Input current –10 10 mA Junction (TJ) –50 150 °C Storage (Tstg) -60 150 °C (1) Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. ESD Ratings SYMBOL PARAMTER CONDITION VALUE UNIT HBM Human-body Model CDM Charged-device model ANSI/ESDA/JEDEC JS-001 ±6000 V JEDEC EIA/JS-002-2022 ±2000 V This integrated circuit can be damaged by ESD. Signal Micro recommends that all integrated circuits be handled with appropriate precautions. Failure to observe proper handling and installation procedures can cause damage. ESD damage can range from subtle performance degradation to complete device failure. Precision integrated circuits may be more susceptible to damage because very small parametric changes could cause the device not to meet its published specifications. May 2022 Signal Micro Incorporated http://www.signal-micro.cn 3 SIG7792/7793 Electrical Characteristics Minimum/Maximum specifications apply from -40˚C to +125˚C. Typical specifications are at +25˚C. All specification are at VAVDD=5V, VDVDD=3.3V, VGND =0V, VREF=2.5V, fCLK=1.024MHz, data rate=16.7SPS, and PGA Gain=1, unless otherwise noted. PARAMETER TEST CONDITION OR NOTES MIN(1) TYP MAX(1) UNITS V ANALOG INPUTS Differential Input Voltage VIN = VINP – VINN –VREF/Gain +VREF/Gain Absolute Input Voltage Buffer Off Buffer On – 0.05 + 0.2 Common Mode Input Range Buffer On 0.2 + |VINMAX|·Gain/2 VAVDD + 0.05 VAVDD – 0.2 VAVDD – 0.2 – |VINMAX|·Gain/2 Absolute Input Current Buffer off Buffer On ±10 ±1 V V nA nA SYSTEM PERFORMANCE PGA Gain Resolution 16 Buffer Off ±10 ppm ±2 ppm Chop Off ±400/Gain μV Chop On Gain Error(2) All PGA gains Gain Drift vs. Temperature All PGA gains fIN = 50/60Hz, ±2%, data rate=16.7SPS fIN = 50Hz, data rate = 470SPS AVDD Power Supply Rejection (PSRR) SPS Buffer On All PGA gains Common Mode Rejection (CMRR) Bits 890 See Noise Table Offset Drift vs. Temperature Normal Mode Rejection (NMRR) Bits 4.17 Noise Offset Error V/V 24 SIG7792 Data Rate Integral Nonlinearity (INL) 1/2/4/8/16/32/64/128 SIG7793 DVDD EXTERNAL REFERENCE INPUTs Differential Reference Voltage VREF = VREFP – VREFN (VREF) Absolute Negative Reference Voltage (VREFN) Absolute Positive Reference Voltage (VREFP) Average Voltage Input Current ±1 μV ±400/Gain ± 2 nV/°C -0.05 ±0.005 0.05 % -3 ±1 +3 ppm/°C See Table 17 dB 100 120 dB 85 105 dB 90 110 dB 0.5 2.5 VAVDD + 0.1 V – 0.05 VREFP – 0.5 V VREFN + 0.5 VAVDD + 0.05 V ±1 uA INTERNAL VOLTAGE REFERENCE Reference Voltage 1.17/2.5 V Initial Accuracy(2) -0.05% ±0.005% +0.05% Temperature Drift -20 ±4 +20 ppm/°C EXCITATION CURRENT SOURCES (IEXC1 and IEXC2) Output Current Compliance Voltage(2) Accuracy Current Mismatch IEXC1=IEXC2 May 2022 10/50/100/210/250/500/1000 uA IEXC = 50uA -2% ±1% +2% IEXC = 10uA -3.0% ±0.60% +3.0% IEXC = 50uA -1.5% ±0.25% +1.5% Signal Micro Incorporated http://www.signal-micro.cn V 4 SIG7792/7793 IEXC = 100uA -1.2% ±0.20% +1.2% IEXC = 210uA, 250uA -1.0% ±0.18% +1.0% IEXC = 500uA -0.8% ±0.12% +0.8% IEXC = 1000uA -0.6% ±0.1% +0.6% Temperature Drift -90 ±20 +90 ppm/°C Temperature Drift Mismatch -30 ±5 +30 ppm/°C Burnout Current Sources Current Setting 500 nA ADC CLOCK External Clock Internal Oscillator Frequency Range 0.5 Duty Cycle 40% Nominal Frequency 1.024 1.1 60% 1.024 Accuracy –3% High-level Output Voltage (VOH) IOH = 4mA 0.8·VDVDD Low-level Output Voltage (VOL) IOL = –4mA MHz MHz ±0.5% 3% DIGITAL INPUT/OUTPUT High-level Input Voltage (VIH) 0.7·VDVDD Low-level Input Voltage (VIL) 0 Input Hysteresis V 0.2·VDVDD V VDVDD V 0.3·VDVDD V ±10 μA 0.5 Input Leakage V POWER SUPPLY AVDD Voltage (VAVDD) 2.7 5.25 V DVDD Voltage (VDVDD) 2.7 5.25 V AVDD Current (IAVDD) DVDD Current (IDVDD) Total Power Dissipation Buffer Off 150 200 uA Buffer On 350 450 uA 200 μA Sleep Mode 1 Active Mode 120 Sleep Mode 20 μA μA Buffer Off 1.15 mW Buffer On 2.15 mW Sleep Mode 0.10 mW TEMPERATURE RANGE Specified temperature range –40 125 °C Operating temperature range –50 125 °C Storage temperature range –60 150 °C (1) Compliance to datasheet limits is assured by one or more methods: production test, characterization and/or design. (2) MIN and MAX values listed for gain error are for +25˚C room temperature only. May 2022 Signal Micro Incorporated http://www.signal-micro.cn 5 SIG7792/7793 Timing Requirements: Serial Interface Over the operating ambient temperature range and DVDD = 2.7V to 5.25V, unless otherwise noted. t7 CSn t6 t1 t5 B7 DOUT B6 B4 B5 B3 B2 B1 B0 t2 t8 t3 SCLK t4 t9 t10 DIN B7 B6 B5 B4 B3 B2 B0 B1 Figure 1. Serial Interface Timing Requirements SYMBOL t1 t2 t3 t4 DESCRIPTION CSn falling edge to DOUT/DRDYn driven: propagation delay(1) SCLK falling edge to valid DOUT/DRDYn: propagation delay(1) SCLK low pulse width MIN SCLK high pulse width 100 SCLK period MAX 50 50 100 200 UNIT ns ns ns ns 106 ns 40 ns t5 CSn rising edge to DOUT high impedance: propagation delay t6 Last SCLK rising edge to CSn rising edge: delay time 50 ns t7 CSn high pulse width 50 ns 50 ns time(2) t8 CSn falling edge to first SCLK falling edge: setup t9 Valid DIN to SCLK rising edge: setup time 50 ns t10 Valid DIN to SCLK rising edge: hold time 25 ns (1) DOUT load = 20pF || 100k Ω to GND. (2) CSn can be tied low. May 2022 Signal Micro Incorporated http://www.signal-micro.cn 6 SIG7792/7793 NOISE PERFORMANCE The noise performance of the ADC is affected by PGA gain, data rate, and digital filter setting. The following tables show the rms noise and peak-to-peak noise for different data rate with chop enabled. The effective number of bits (ENOB) and noise-free bits are also listed according to Equation (1) and Equation (2): ENOB= log 2 (2×VREF ⁄Gain⁄VRMS ) (1) Noise Free Bits= log 2 �2×VREF ⁄Gain⁄Vp-p � (2) The noise data listed in the table are typical and are generated from continuous ADC readings with differential input voltage of 0 V. With chop disabled, the noise increases by 30%. External Reference Table 1. ADC Noise in µVRMS (µVPP) at TA = 25°C, VAVDD = 5 V, VREF = 2.5 V, Chop Enabled FS[3:0] 1111 1110 1101 1100 1011 1010 1001 1000 0111 0110 0101 0100 0011 0010 0001 0000 Data Rate (SPS) 4.17 6.25 8.33 10 12.5 16.7 16.7 19.6 33.2 39 50 62 123 242 470 890 PGA GAIN 1 0.510(2.10) 0.658(2.72) 0.806(3.33) 0.931(3.84) 1.14(4.71) 1.61(6.66) 1.56(6.56) 1.87(9.24) 2.55(13.7) 2.39(10.4) 2.70(15.2) 3.65(15.8) 5.48(29.5) 8.90(67.9) 22.7(127) 236(1360) 2 0.326(1.46) 0.420(1.89) 0.515(2.31) 0.595(2.67) 0.728(3.27) 1.03(4.62) 1.00(4.32) 1.06(6.26) 1.36(6.56) 1.75(7.60) 2.11(10.4) 2.20(12.1) 3.28(19.1) 4.82(30.2) 11.7(87.5) 112(746) 4 0.170(0.872) 0.220(1.13) 0.269(1.38) 0.311(1.59) 0.380(1.95) 0.538(2.76) 0.522(2.46) 0.732(2.98) 0.764(4.47) 0.863(3.80) 1.06(4.69) 1.27(5.81) 1.49(8.12) 2.37(14.3) 5.98(37.9) 58.5(395) 8 0.084(0.412) 0.109(0.532) 0.133(0.652) 0.154(0.753) 0.188(0.922) 0.266(1.30) 0.245(1.16) 0.334(1.34) 0.412(2.20) 0.468(2.35) 0.664(3.32) 0.729(4.17) 0.905(4.69) 1.48(7.49) 3.14(19.0) 28.2(266) 16 0.057(0.236) 0.073(0.304) 0.090(0.373) 0.103(0.430) 0.127(0.527) 0.179(0.745) 0.177(0.838) 0.193(1.04) 0.242(1.27) 0.268(1.38) 0.354(1.70) 0.473(1.99) 0.564(3.73) 0.721(3.93) 1.55(8.68) 13.6(103) 32 0.036(0.165) 0.047(0.213) 0.057(0.261) 0.066(0.301) 0.081(0.368) 0.114(0.521) 0.111(0.587) 0.133(0.522) 0.208(1.04) 0.204(0.903) 0.265(1.14) 0.243(1.09) 0.355(1.97) 0.488(3.10) 0.943(5.62) 7.42(49.5) 64 0.027(0.115) 0.035(0.148) 0.043(0.182) 0.049(0.210) 0.060(0.257) 0.085(0.363) 0.081(0.372) 0.091(0.405) 0.108(0.536) 0.116(0.563) 0.157(0.722) 0.191(1.02) 0.261(1.36) 0.358(1.95) 0.583(3.86) 3.60(24.7) 128 0.020(0.095) 0.026(0.122) 0.032(0.150) 0.036(0.173) 0.045(0.212) 0.063(0.300) 0.063(0.291) 0.072(0.321) 0.093(0.449) 0.096(0.403) 0.120(0.538) 0.168(0.687) 0.195(1.18) 0.287(1.59) 0.421(2.55) 1.86(12.8) Table 2. ADC ENOB (Noise Free Bits) at TA = 25°C, VAVDD = 5 V, VREF = 2.5 V, Chop Enabled FS[3:0] 1111 1110 1101 1100 1011 1010 1001 1000 0111 0110 0101 0100 0011 0010 0001 0000 May 2022 Data Rate (SPS) 4.17 6.25 8.33 10 12.5 16.7 16.7 19.6 33.2 39 50 62 123 242 470 890 1 23.2(21.0) 22.8(20.6) 22.5(20.4) 22.3(20.1) 22.0(19.9) 21.5(19.4) 21.6(19.4) 21.2(19.2) 21.1(18.8) 20.9(18.8) 20.4(18.1) 20.5(18.4) 19.8(17.3) 19.3(16.5) 17.7(15.0) 14.4(11.5) 2 22.9(20.7) 22.5(20.3) 22.2(20.0) 22.0(19.8) 21.7(19.5) 21.2(19.0) 21.3(19.1) 21.2(18.6) 20.8(18.5) 20.4(18.3) 20.2(17.9) 20.1(17.7) 19.5(17.0) 19.0(16.3) 17.7(14.8) 14.4(11.7) 4 22.8(20.5) 22.4(20.1) 22.1(19.8) 21.9(19.6) 21.6(19.3) 21.1(18.8) 21.2(19.0) 20.7(18.7) 20.6(18.1) 20.5(18.3) 20.2(18.0) 19.9(17.7) 19.7(17.2) 19.0(16.4) 17.7(15.0) 14.4(11.6) PGA GAIN 8 16 22.8(20.5) 22.4(20.3) 22.5(20.2) 22.0(20.0) 22.2(19.9) 21.7(19.7) 22.0(19.7) 21.5(19.5) 21.7(19.4) 21.2(19.2) 21.2(18.9) 20.7(18.7) 21.3(19.0) 20.8(18.5) 20.8(18.8) 20.6(18.2) 20.5(18.1) 20.3(17.9) 20.3(18.0) 20.2(17.8) 19.8(17.5) 19.8(17.5) 19.7(17.2) 19.3(17.3) 19.4(17.0) 19.1(16.4) 18.7(16.3) 18.7(16.3) 17.6(15.0) 17.6(15.1) 14.4(11.2) 14.5(11.6) Signal Micro Incorporated http://www.signal-micro.cn 32 22.0(19.9) 21.7(19.5) 21.4(19.2) 21.2(19.0) 20.9(18.7) 20.4(18.2) 20.4(18.0) 20.2(18.2) 19.5(17.2) 19.5(17.4) 19.2(17.1) 19.3(17.1) 18.7(16.3) 18.3(15.6) 17.3(14.8) 14.4(11.6) 64 21.5(19.4) 21.1(19.0) 20.8(18.7) 20.6(18.5) 20.3(18.2) 19.8(17.7) 19.9(17.7) 19.7(17.6) 19.5(17.2) 19.4(17.1) 18.9(16.7) 18.6(16.2) 18.2(15.8) 17.7(15.3) 17.0(14.3) 14.4(11.6) 128 20.9(18.7) 20.5(18.3) 20.2(18.0) 20.0(17.8) 19.7(17.5) 19.2(17.0) 19.2(17.0) 19.0(16.9) 18.7(16.4) 18.6(16.6) 18.3(16.1) 17.8(15.8) 17.6(15.0) 17.1(14.6) 16.5(13.9) 14.4(11.6) 7 SIG7792/7793 Internal Reference Table 3. ADC Noise in µVRMS (µVPP) at TA = 25°C, VAVDD = 5 V, Internal 1.17V Reference, Chop Enabled FS[3:0] 1111 1110 1101 1100 1011 1010 1001 1000 0111 0110 0101 0100 0011 0010 0001 0000 Data Rate (SPS) 4.17 6.25 8.33 10 12.5 16.7 16.7 19.6 33.2 39 50 62 123 242 470 890 PGA GAIN 1 1.05(4.23) 1.36(5.47) 1.66(6.70) 1.92(7.73) 2.35(9.47) 3.33(13.4) 3.01(13.5) 2.90(12.1) 3.94(16.9) 4.24(18.8) 5.62(23.7) 4.98(28.0) 7.95(42.7) 11.8(69.2) 18.9(125) 111(735) 2 0.484(2.18) 0.625(2.81) 0.766(3.44) 0.884(3.98) 1.08(4.87) 1.53(6.89) 1.48(6.87) 1.59(7.60) 2.12(9.28) 2.31(9.83) 2.77(11.9) 2.95(13.3) 5.12(26.1) 6.21(32.5) 10.2(63.4) 55.1(390) 4 0.250(1.13) 0.323(1.46) 0.396(1.79) 0.457(2.06) 0.560(2.53) 0.792(3.58) 0.752(3.56) 0.847(4.18) 1.19(5.26) 1.40(7.29) 1.60(8.19) 1.42(7.67) 2.55(12.0) 3.22(17.8) 5.13(31.9) 25.7(163) 8 0.117(0.546) 0.151(0.705) 0.185(0.863) 0.213(0.997) 0.261(1.22) 0.369(1.73) 0.394(1.69) 0.420(1.90) 0.560(2.48) 0.678(2.91) 0.814(3.85) 0.987(4.64) 1.09(5.46) 1.63(8.39) 2.69(14.9) 13.0(78.7) 16 0.079(0.328) 0.102(0.423) 0.125(0.519) 0.144(0.599) 0.176(0.733) 0.249(1.04) 0.246(1.09) 0.303(1.20) 0.367(1.63) 0.361(1.56) 0.440(2.22) 0.468(2.00) 0.777(4.44) 1.02(5.99) 1.43(8.47) 6.74(50.9) 32 0.042(0.190) 0.054(0.245) 0.067(0.301) 0.077(0.347) 0.094(0.425) 0.133(0.601) 0.129(0.591) 0.156(0.658) 0.175(0.752) 0.200(0.859) 0.308(1.61) 0.309(1.72) 0.420(2.36) 0.596(4.33) 0.929(5.30) 3.49(20.7) 64 0.025(0.113) 0.032(0.145) 0.039(0.178) 0.045(0.206) 0.055(0.252) 0.078(0.356) 0.078(0.353) 0.091(0.431) 0.122(0.540) 0.141(0.671) 0.174(0.891) 0.192(0.989) 0.292(1.56) 0.426(2.20) 0.565(3.20) 1.71(10.5) 128 0.022(0.099) 0.028(0.127) 0.034(0.156) 0.039(0.180) 0.048(0.221) 0.068(0.312) 0.067(0.305) 0.078(0.372) 0.091(0.369) 0.113(0.535) 0.147(0.659) 0.146(0.745) 0.181(1.11) 0.293(1.75) 0.389(2.31) 0.979(6.28) Table 4. ADC ENOB (Noise Free Bits) at TA = 25°C, VAVDD = 5 V, Internal 1.17V Reference, Chop Enabled FS[3:0] 1111 1110 1101 1100 1011 1010 1001 1000 0111 0110 0101 0100 0011 0010 0001 0000 May 2022 Data Rate (SPS) 4.17 6.25 8.33 10 12.5 16.7 16.7 19.6 33.2 39 50 62 123 242 470 890 1 21.1(19.1) 20.7(18.7) 20.4(18.4) 20.2(18.2) 19.9(17.9) 19.4(17.4) 19.6(17.4) 19.6(17.6) 19.2(17.1) 19.1(16.9) 18.7(16.6) 18.8(16.3) 18.2(15.7) 17.6(15.0) 16.9(14.2) 14.4(11.6) 2 21.2(19.0) 20.8(18.7) 20.5(18.4) 20.3(18.2) 20.0(17.9) 19.5(17.4) 19.6(17.4) 19.5(17.2) 19.1(16.9) 19.0(16.9) 18.7(16.6) 18.6(16.4) 17.8(15.5) 17.5(15.1) 16.8(14.2) 14.4(11.5) 4 21.2(19.0) 20.8(18.6) 20.5(18.3) 20.3(18.1) 20.0(17.8) 19.5(17.3) 19.6(17.3) 19.4(17.1) 18.9(16.8) 18.7(16.3) 18.5(16.1) 18.6(16.2) 17.8(15.6) 17.5(15.0) 16.8(14.2) 14.5(11.8) PGA GAIN 8 16 21.3(19.0) 20.8(18.8) 20.9(18.7) 20.5(18.4) 20.6(18.4) 20.2(18.1) 20.4(18.2) 20.0(17.9) 20.1(17.9) 19.7(17.6) 19.6(17.4) 19.2(17.1) 19.5(17.4) 19.2(17.0) 19.4(17.2) 18.9(16.9) 19.0(16.9) 18.6(16.5) 18.7(16.6) 18.6(16.5) 18.5(16.2) 18.3(16.0) 18.2(15.9) 18.3(16.2) 18.0(15.7) 17.5(15.0) 17.5(15.1) 17.1(14.6) 16.7(14.3) 16.6(14.1) 14.5(11.9) 14.4(11.5) Signal Micro Incorporated http://www.signal-micro.cn 32 20.7(18.6) 20.4(18.2) 20.1(17.9) 19.9(17.7) 19.6(17.4) 19.1(16.9) 19.1(16.9) 18.8(16.8) 18.7(16.6) 18.5(16.4) 17.9(15.5) 17.9(15.4) 17.4(14.9) 16.9(14.0) 16.3(13.8) 14.4(11.8) 64 20.5(18.3) 20.1(17.9) 19.8(17.6) 19.6(17.4) 19.3(17.1) 18.8(16.6) 18.8(16.7) 18.6(16.4) 18.2(16.0) 18.0(15.7) 17.7(15.3) 17.5(15.2) 16.9(14.5) 16.4(14.0) 16.0(13.5) 14.4(11.8) 128 19.7(17.5) 19.3(17.1) 19.0(16.8) 18.8(16.6) 18.5(16.3) 18.0(15.8) 18.1(15.9) 17.8(15.6) 17.6(15.6) 17.3(15.1) 16.9(14.8) 16.9(14.6) 16.6(14.0) 15.9(13.4) 15.5(12.9) 14.2(11.5) 8 SIG7792/7793 ON-CHIP REGISTER MAPS There are total eight registers inside the device which is 8-bit, 16-bit, or 24-bit wide. These registers are used to configure and control the ADC to the desired mode of operation. These registers can be accessed through the SPIcompatible serial interface by using register read and write commands. At power-on or reset, the registers default to their initial settings, as shown in the Reset Value column of Table 5. Table 5. SIG7793/SIG7792 register map ADDR. NAME DIR. RESET VALUE BIT 7 3’b000 STATUS R 80 DRDYn 3’b001 MODE R/W 000A 3’b010 CONFIG R/W 0710 3’b011 DATA R 000000 /(0000) (1) 3’b100 3’b101 ID IO R R/W XA/(XB)(1) 00 3’b110 OFFSET R/W 800000 /(8000)(1) BIT 6 ERR MD[2:0] CLK[1:0] VBIAS[1:0] REFSEL[1:0] x IEXCEN[2] x 0 BIT 5 BIT 4 BIT 3 NOREF BIT 2 0 24-bit IEXC_PAIR 0 0 0 CHOPn BURN FORMAT 0 REFDET BUF 0 DATA[23:16] (SIG7793 only) DATA[15:8] DATA[7:0] x x 1 0 0 0 IEXCDIR[1:0] OFFSET[23:16] (SIG7793 only) BIT 1 CHD[2:0] 0 FS[3:0] PGA[2:0] CH[2:0] 1 BIT 0 FAST_ST 1/0 IEXCEN[1:0] OFFSET[15:8] OFFSET[7:0] GAIN[23:16] (SIG7793 only) 3’b111 GAIN R/W 555555 /(5555)(1) GAIN[15:8] GAIN[7:0] (1) The values in bracket are the default reset value for SIG7792. STATUS Register Table 6. STATUS Register (Address = 3’b000) BIT 7 BIT 6 BIT 5 BIT 4 BIT 3 DRDYn ERR NOREF 0 24-bit BIT 2 BIT 1 BIT 0 CHD[2:0] Power-On/Reset Value = 0x80(SIG7792)/ 0x88(SIG7793) Bits Bit Name Access Reset Description 7 DRDYn R 1’b1 ADC Ready Bit: This bit is cleared when new data is written to the ADC data register. It is set automatically after the ADC data register is read. In addition to this bit, DOUT/DRDYn pin can also be used as an alternative to monitor the update of new ADC data. 6 ERR R 1’b0 ADC Error Bit. This bit is written at the same time as new data update. Error sources include input overrange, input underrange, or lower than expected reference voltage. 5 NOREF R 1’b0 No External Reference Bit: The function of this bit is only enabled by setting the REFDET bit in the CONFIG Register to 1. While the REFDET bit is 1 and the selected reference voltage is below a specified threshold, which is about 0.4V, this bit is set and conversion results are clamped to all 1s. 4 RESERVED R 1’b0 Reserved 3 24-bit R 1’b0(7792) 1’b1(7793) 24-Bit Device Indicator. This bit indicates whether this device is 16bit (SIG7792) or 24-bit (SIG7793). CHD[2:0] R 3’b000 Data Channel Number: These bits indicate the corresponding channel to the ADC data in data register (see Table 9). 2:0 May 2022 Signal Micro Incorporated http://www.signal-micro.cn 9 SIG7792/7793 MODE Register Table 7. MODE Register (Address = 3’b001) BIT 15 BIT 14 BIT 13 BIT 12 BIT 11 BIT10 BIT 9 BIT 8 BIT 7 BIT 6 BIT 5 BIT 4 BIT 3 BIT 2 BIT 1 BIT 0 0 IEXC_PAIR 0 0 FAST_ST 0 CHOPn MD[2:0] CLK[1:0] FS[3:0] Power-On/Reset Value = 0x000A Bits Bit Name Access Reset Description 15:13 MD[2:0] R/W 3’b000 Mode Select Bits: These bits select the operating mode of the device. 000: Continuous conversion mode. (default) 001: Single conversion mode. ADC first wakeup if in idle or sleep mode; resets the filter to perform one conversion; and enters sleep mode. The conversion result remains in the data register with DOUT/DRDYn as low. 010: Idle mode. The digital filter is in reset state with ADC free running. 011: Sleep mode. Most of circuitry is turned off to save the power. 100: Internal zero-scale calibration. 101: Internal full-scale calibration. 110: System zero-scale calibration. 111: System full-scale calibration. For each above calibration mode, DOUT/DRDYn goes high when the calibration is initiated and returns low when the calibration is complete. The ADC is automatically placed in idle mode after the calibration. The measured offset/full-scale coefficient is placed in the offset/full-scale register of the selected channel. 12 RESERVED R/W 1’b0 Reserved Always write 1’b0 11 IEXC_PAIR R/W 1’b0 IEXC PAIR Enable Bit: Set this bit while both IEXC1 and IEXC2 are used as a pair to improve the IEXC matching and measurement accuracy. 0: Disabled (default) 1: Enabled 10, 9 RESERVED R/W 2’b00 Reserved Always write 2’b00 8 FAST_ST R/W 1’b0 Fast Startup Bit: When FAST_ST is set, the internal bandgap stays on during sleep mode for fast startup if internal reference is selected or excitation current sources are used. 7:6 CLK[1:0] R/W 2’b10 Clock Select Bits: This bits select the clock source for SYSCLK. 00: Internal 1.024MHz clock with CLK tristated. (default) 01: Internal 1.024MHz clock with its output on CLK pin. 10: External clock applied to the CLK pin. 11: External clock applied to the CLK pin. 5 RESERVED R/W 1’b0 Reserved Always write 1’b0 4 CHOPn R/W 1’b0 Chop Disable Bit: When chop is enabled with bit clear to logic 0, the offset and offset drift of the ADC are dramatically improved with settling time doubled. All output data are fully settled data. For default data rate settling of 16.7SPS, the conversion time is 60ms for all output data with chop disabled. If chop is enabled, the conversion time is 120ms for the first data and 60ms thereafter. 3:0 FS[3:0] R/W 4’b1010 Data Rate Configuration: Selects the ADC data rate. 0000: 890SPS 0001: 470SPS May 2022 Signal Micro Incorporated http://www.signal-micro.cn 10 SIG7792/7793 0010: 242SPS 0011: 123SPS 0100: 62SPS 0101: 50SPS 0110: 39SPS 0111: 33.2SPS 1000: 19.6SPS 1001: 16.7SPS 1010: 16.7SPS (default) 1011: 12.5SPS 1100: 10SPS 1101: 8.33SPS 1110: 6.25SPS 1111: 4.17SPS CONFIG Register Table 8. CONFIG Register (Address = 3’b010) BIT 15 BIT 14 BIT 7 BIT 13 BIT 6 BIT 12 BIT 11 BIT10 BIT 2 BIT 9 BIT 8 BIT 1 BIT 0 BIT 5 BIT 4 BIT 3 VBIAS[1:0] BURN FORMAT 0 PGA[2:0] REFSEL[1:0] REFDET BUF 0 CH[2:0] Power-On/Reset Value = 0x0710 Bits Bit Name Access Reset Description 15:14 VBIAS[1:0] R/W 2’b00 Bias Voltage Generator Enable Bits: The negative terminal of the analog inputs can be biased at the level of middle analog supply AVDD/2. 00: Bias voltage generator disabled 01: Bias voltage connected to AIN110: Bias voltage connected to AIN211: Bias voltage connected to AIN3- 13 BURN R/W 1’b0 Burnout Enable Bit: When this bit is enabled, a pair of 500nA current sources are applied to analog inputs to source positive input and sink negative input. 12 FORMAT R/W 1’b0 Data Format Bit: This bit sets the ADC data format. 0: Bipolar mode (default) 1: Unipolar mode 11 RESERVED R/W 1’b0 Reserved Always write 1’b0 10:8 PGA[2:0] R/W 3’b111 PGA Gain Configuration: Selects the PGA gain. If PGA gain is set to other than 1, the BUF bit setting is ignored with buffer always enabled. 000: Gain=1 001: Gain=2 010: Gain=4 011: Gain=8 100: Gain=16 101: Gain=32 110: Gain=64 111: Gain=128 (default) 7:6 REFSEL[1:0] R/W 2’b00 Reference Select Bits: Select the reference source for the ADC. 00: REF+, REF- (default) 01: Reserved 10: 1.17V internal reference May 2022 Signal Micro Incorporated http://www.signal-micro.cn 11 SIG7792/7793 11: 2.5V internal reference 5 REFDET R/W 1’b0 Reference Detection Enable Bit: When this bit is enabled, the NOREF bit in the STATUS register indicates when the reference input voltage is less than specified threshold, which is about 0.4V. 4 BUF R/W 1’b1 Buffer Enable Bit: When this bit is set, analog input is buffered. Otherwise the input buffer is bypassed. The buffer can only be disabled when the gin equals 1 or 2. For higher gains, the buffer is automatically enabled. 3 RESERVED R/W 1’b0 Reserved Always write 1’b0 CH[2:0] R/W 3’b000 Channel Select Bits: This bits select which channels are enabled for ADC conversion (see Table 9). When ADC finishes the conversion and places the data into data register with corresponding channel information in STATUS register. 2:0 Table 9. Channel Selection CHD[2:0] (1) (2) Positive Input AIN+ Negative Input AIN- Status Register Bits CHD[2:0] Calibration Register Pair 000 AIN1+ AIN1000 0 001 AIN2+ AIN2001 1 010 AIN3+ AIN3010 2 011 AIN1AIN1011 0 100 AIN4+ AIN4100 3 101 Reserved 101 110 Temperature Sensor(1) 110 Default Reset Values 111 AVDD Monitor(2) 111 Default Reset Values For temperature sensor measurement, PGA gain is internally forced to 1 with buffer on and internal 1.17V reference is used disregarding user register configuration. For AVDD monitor measurement, the AVDD is internally attenuated by 6, PGA gain is forced to 1 with buffer on and internal 1.17V reference is used disregarding user register configuration. DATA Register This register is 16 bits wide for SIG7792 and 24 bits wide for SIG7793. Table 10. DATA Register (Address = 3’b011) BIT 23 BIT 22 BIT 21 BIT 20 BIT 19 BIT18 BIT 17 BIT 16 BIT 15 BIT 14 BIT 13 BIT 12 BIT 11 BIT10 BIT 9 BIT 8 BIT 7 BIT 6 BIT 5 BIT 4 BIT 3 BIT 2 BIT 1 BIT 0 DATA[23] DATA[22] DATA[21] DATA[20] DATA[19] DATA[18] DATA[17] DATA[16] DATA[15] DATA[14] DATA[13] DATA[12] DATA[11] DATA[10] DATA[9] DATA[8] DATA[7] DATA[6] DATA[5] DATA[4] DATA[3] DATA[2] DATA[1] DATA[0] Power-On/Reset Value = 0x0000(SIG7792)/0x000000(SIG7793) Bits Bit Name Access Reset Description 23:0 DATA[23:0] R 0x000000 Data Bits: The 16-bit word for SIG7792 or 24-bit word for SIG7793 is signed number in 2’s complement format. See Data Format section for more information. May 2022 Signal Micro Incorporated http://www.signal-micro.cn 12 SIG7792/7793 ID Register Table 11. ID Register (Address = 3’b100) BIT 7 BIT 6 BIT 5 BIT 4 BIT 3 BIT 2 BIT 1 BIT 0 x x x x 1 0 1 0/1 Power-On/Reset Value = 0xXA(SIG7792)/0xXB(SIG7793) Bits Bit Name Access Reset Description 7:0 ID R 8’bxxxx101x ID Bits: Read only. IO Register Table 12. IO Register (Address = 3’b101) BIT 7 BIT 6 BIT 5 BIT 4 IEXCEN[2] 0 0 0 BIT 3 BIT 2 IEXCDIR[1:0] BIT 1 BIT 0 IEXCEN[1:0] Power-On/Reset Value = 0x00 Bits Bit Name Access Reset Description 7 IEXCEN[2] R/W 1’b0 IEXC Current Bit: This bit works together with IEXCEN[1:0] to select the value of the excitation current sources applied to the analog input pins. 6, 5, 4 RESERVED R/W 3’b000 Reserved Always write 3’b000 3:2 IEXCDIR[1:0] R/W 2’b00 Direction of Current Sources Select Bits: 00: Current source IEXC1 connected to Pin IOUT1, Current source IEXC2 connected to Pin IOUT2. 01: Current source IEXC1 connected to Pin IOUT2, Current source IEXC2 connected to Pin IOUT1. 10: Both current source IEXC1 and IEXC2 connected to Pin IOUT1. 11: Both current source IEXC1 and IEXC2 connected to Pin IOUT2. 1:0 IEXCEN[1:0] R/W 2’b00 IEXC Current Bits: Combined with IEXCEN[2], these three bits select the value of the excitation current sources applied to the analog input pins. 000: Off (default) 001: 10µA 010: 210µA 011: 1000µA 100: 50µA 101: 100µA 110: 250µA 111: 500µA May 2022 Signal Micro Incorporated http://www.signal-micro.cn 13 SIG7792/7793 OFFSET Register The device has four OFFSET registers, each channel has a dedicated OFFSET register (see Table 9). This register is 16 bits wide for SIG7792 and 24 bits wide for SIG7793. OFFSET register read is allowed anytime, but writing to OFFSET register is only allowed while the device is in idle or sleep mode. Table 13. OFFSET Register (Address = 3’b110) BIT 23 BIT 22 BIT 21 BIT 20 BIT 19 BIT18 BIT 17 BIT 16 BIT 15 BIT 14 BIT 13 BIT 12 BIT 11 BIT10 BIT 9 BIT 8 BIT 7 BIT 6 BIT 5 BIT 4 BIT 3 BIT 2 BIT 1 BIT 0 OFFSET[23] OFFSET[22] OFFSET[21] OFFSET[20] OFFSET[19] OFFSET[18] OFFSET[17] OFFSET[16] OFFSET[15] OFFSET[14] OFFSET[13] OFFSET[12] OFFSET[11] OFFSET[10] OFFSET[9] OFFSET[8] OFFSET[7] OFFSET[6] OFFSET[5] OFFSET[4] OFFSET[3] OFFSET[2] OFFSET[1] OFFSET[0] Power-On/Reset Value = 0x8000(SIG7792)/0x800000(SIG7793) Bits Bit Name Access Reset Description 23:0 OFFSET[23:0] R/W 0x800000 Offset Calibration Bits: The 24-bit word is signed number in offset binary format. See Calibration section for more information. GAIN Register The device has four GAIN registers, each channel has a dedicated GAIN register (see Table 9). This register is 16 bits wide for SIG7792 and 24 bits wide for SIG7793. GAIN register read is allowed anytime, but writing to GAIN register is only allowed while the device is in idle or sleep mode. Table 14. GAIN Register (Address = 3’b111) BIT 23 BIT 22 BIT 21 BIT 20 BIT 19 BIT18 BIT 17 BIT 16 BIT 15 BIT 14 BIT 13 BIT 12 BIT 11 BIT10 BIT 9 BIT 8 BIT 7 BIT 6 BIT 5 BIT 4 BIT 3 BIT 2 BIT 1 BIT 0 GAIN[23] GAIN[22] GAIN[21] GAIN[20] GAIN[19] GAIN[18] GAIN[17] GAIN[16] GAIN[15] GAIN[14] GAIN[13] GAIN[12] GAIN[11] GAIN[10] GAIN[9] GAIN[8] GAIN[7] GAIN[6] GAIN[5] GAIN[4] GAIN[3] GAIN[2] GAIN[1] GAIN[0] Power-On/Reset Value = 0x5555(SIG7792)/0x555555(SIG7793) Bits Bit Name Access Reset Description 23:0 GAIN[23:0] R/W 0x555555 Gain Calibration Bits: The 24-bit word is unsigned positive number in binary format. See Calibration section for more information. May 2022 Signal Micro Incorporated http://www.signal-micro.cn 14 SIG7792/7793 REVISION HISTORY The revision history provided is for informational purposes only and is believed to be accurate, but not warranted. Please contact to make sure you have the latest revision. DATE REVISION May 20, 2022 CHANGE Initial release. DISCLAIMER Signal Micro reserves the right to make any change in circuit design, specification or other related things if necessary without notice at any time. All trademarks and registered trademarks are the property of their respective owners. May 2022 Signal Micro Incorporated http://www.signal-micro.cn 15 SIG7792/7793 PACKAGE OUTLINE DIMENSIONS 0.30 0.19 0.65 16 0.10 M 9 0.15 NOM 4.50 4.30 6.60 6.20 0.25 0o-8o 0.75 0.50 8 1 5.10 4.90 1.10 MAX 0.15 0.05 0.10 Seating Plane A. Compliant to JEDEC STARDARDS MO-153-AD. B. All linear dimensions are in millimeters. C. This drawing is subject to change without notice. May 2022 Signal Micro Incorporated http://www.signal-micro.cn 16
SIG7793-ITSP16-RL 价格&库存
很抱歉,暂时无法提供与“SIG7793-ITSP16-RL”相匹配的价格&库存,您可以联系我们找货
