SIG5530A-ITSP20-RL
SIG5530A-ITSP20-RL
    SIGNALMICRO(信格勒)
    TSSOP20_6.5X4.4MM
    2通道, 1.6SPS至1920SPS, 24位ADC, 带超低噪声PGA
SIG5530A-ITSP20-RL 数据手册
SIG5530A/5530C 24-bit Sigma-Delta ADC with Gain=64 Ultra-Low-Noise Amplifier FEATURES DESCRIPTION Amplifier Gain: 64 Selectable Data Rates: 1.875 to 1920SPS (SIG5530A) 1.875 to 240SPS (SIG5530C) RMS Noise: 16nV at 7.5SPS 20.4 Noise-Free Bits at 1.875SPS Offset Drift: 5nV/°C Gain Drift: 1ppm/°C Integral Non-Linearity: 3ppm Internal or External Clock Burnout Current Sources Parity Check Power Supply AVDD: 4.75V to 5.25V or ±2.5V DVDD: 2.7V to 5.25V Current: 4.0mA Package: 20-lead TSSOP The SIG5530A is a low noise, low drift, and high-resolution 24bit analog-to-digital converter (ADC) with integrated gain amplifier that offers high-accuracy measurement solutions for bridge sensors. APPLICATIONS The SIG5530A is available in 20-lead TSSOP package. These devices are fully specified over the -40°C to +125°C temperature range. The device contains an ultra-low-noise amplifier with fixed gain 64, a delta-sigma (Δ-Σ) modulator, and a programmable SINC3/SINC1 digital filter. For SIG5530A, the output data rate can be configured to 1.875, 3.75, 7.5, 15, 30, 60, 120, 240, 480, 960, and 1920SPS. Burnout current sources are provided at the analog inputs for sensor connection diagnosis. Offset and gain calibration registers are provided with calibration command or direct register write to calibrate the ADC errors or overall system errors. SPI-compatible interface is used for device configuration and parity check is provided for data integrity. The on-chip oscillator, an external clock, or an external crystal can be used as the clock source to the device. The device can operate with bipolar ±2.375V to ±2.625V analog power supplies, or with a single 4.75V to 5.25V analog power supply. Weigh Scales Strain Gauges Pressure Sensors Industrial Process Control The SIG5530C is low cost version of SIG5530A and only supports data rate among1.875, 3.75, 7.5, 15, 30, 60, 120, and 240SPS. Function Block Diagram AVDD VREF+ VREF- TSSOP-20 DVDD AIN1+ 1 20 AIN2+ AIN1- 2 19 AIN2- C1 3 18 VREF+ C2 4 17 VREF- VA+ 5 16 DGND VA- 6 15 VD+ A0/PDSW 7 14 CSn A1 8 13 SDI OSC2 9 12 SDO OSC1 10 11 SCLK REFERENCE DETECT BUF AIN1+ MUX AIN1AIN2+ AIN2- PGA Digital Filter Internal Oscillator A0/PDSW AVSS C1 C2 CSn DIN DOUT/DRDYn SCLK SIG5530A/C TSSOP-20 A1 Gain=64 TEMP Sensor May 2022 ΔΣ ADC Serial Interface And Control Logic Clock Circuitry OSC2 OSC1 DGND Signal Micro Incorporated http://www.signal-micro.cn SIG5530A/5530C PIN CONFIGURATION and DESCRIPTIONS TOP VIEW (Not To Scale) PIN AIN1+ 1 20 AIN2+ AIN1- 2 19 AIN2- C1 3 18 VREF+ 17 VREF- 16 DGND C2 4 AVDD 5 SIG5530A/C TSSOP-20 AVSS 6 15 DVDD A0/PDSW 7 14 CSn A1 8 13 DIN OSC2 9 12 DOUT/DRDYn OSC1 10 11 SCLK No. 1 2 NAME AIN1+ AIN1- FUNCTION DESCRIPTION Analog Input Analog Input 3 C1 Analog Output 4 C2 Analog Output 5 AVDD Analog Positive analog input channel 1. Negative analog input channel 1. Amplifier analog output. Connect a COG cap with size 4.7~22nF between C1 and C2. Amplifier analog output. Connect a COG cap with size 4.7~22nF between C1 and C2. Positive analog power supply. 4.75V to 5.25V relative to AVSS. 6 7 8 AVSS A0/PDSW A1 Negative analog power supply. Analog logic output or bridge power down switch. Analog logic output. 9 OSC2 10 OSC1 Analog Analog Output Analog Output Digital Input/Output Digital Input 11 12 SCLK DOUT/DRDYn Digital Input Digital Output Serial data clock. Serial data output and data ready indicator. 13 14 DIN CSn Digital Input Digital Input 15 16 DVDD DGND Digital Digital 17 18 REFREF+ Analog Input Analog Input Negative reference input. Positive reference input. 19 20 AIN2AIN2+ Analog Input Analog Input Negative analog input channel 2. Positive analog input channel 2. May 2022 Master clock input or Crystal Connection. Crystal Connection. Serial data input. Serial chip select. Active low. Digital power supply, 2.7V to 5.25V. DVDD is independent of AVDD. Digital ground reference point. Signal Micro Incorporated http://www.signal-micro.cn 2 SIG5530A/5530C PACKAGE/ORDERING INFORMATION MODEL PACKAGE DESCRIPTION SPECIFIED TEMPERATURE RANGE ORDERING NUMBER PACKING OPTION SIG5530A TSSOP-20 -40°C to +125°C SIG5530A-ITSP20-RL Reel, 4500 SIG5530C TSSOP-20 -40°C to +125°C SIG5530C-ITSP20-RL Reel, 4500 SPECIFICATIONS Absolute Maximum Ratings Over operating free-air temperature range, unless otherwise noted.(1) AVDD to AVSS Voltage Current Temperature MIN MAX UNIT –0.3 6.5 V AVSS to DGND –3 0.3 V DVDD to DGND –0.3 6.5 V Analog input VAVSS – 0.3 VAVDD + 0.3 V Digital input VDGND – 0.3 VDVDD + 0.3 V Input current –10 10 mA Junction (TJ) –50 150 °C Storage (Tstg) -60 150 °C (1) Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. ESD Ratings SYMBOL PARAMTER CONDITION HBM Human-body Model ANSI/ESDA/JEDEC JS-001 VALUE ±4000 UNIT V CDM Charged-device model JEDEC EIA/JS-002-2022 ±2000 V This integrated circuit can be damaged by ESD. Signal Micro recommends that all integrated circuits be handled with appropriate precautions. Failure to observe proper handling and installation procedures can cause damage. ESD damage can range from subtle performance degradation to complete device failure. Precision integrated circuits may be more susceptible to damage because very small parametric changes could cause the device not to meet its published specifications. May 2022 Signal Micro Incorporated http://www.signal-micro.cn 3 SIG5530A/5530C Electrical Characteristics Minimum/Maximum specifications apply from -40˚C to +125˚C. Typical specifications are at +25˚C. All specification are at VAVDD=5V, VAVSS=0V, VDVDD=3.3V, VREF=2.5V, fCLK=4.9152MHz, data rate=60SPS, unless otherwise noted. PARAMETER TEST CONDITION OR NOTES MIN(1) TYP MAX(1) UNITS +VREF/(2xGain) VAVDD – 0.5 VAVDD – 0.5 – |VINMAX|·32 V V ANALOG INPUTS Differential Input Voltage Absolute Input Voltage VIN = VINP – VINN Common Mode Input Range GAIN=64 –VREF/(2xGain) VAVSS + 0.5 VAVSS + 0.5 + |VINMAX|·32 Absolute Input Current ±2 V nA SYSTEM PERFORMANCE Amplifier Gain 64 V/V Resolution 24 Bits Data Rate SIG5530A 1.875 1920 SPS SIG5530C 1.875 240 SPS Noise See Noise Table Integral Nonlinearity (INL) ±3 Offset Error ±3 μV Offset Drift vs. Temperature ±5 nV/°C Gain Error Gain Drift vs. Temperature Common Mode Rejection (CMRR) Power Supply Rejection(2) (PSRR) REFERENCE INPUT Differential Reference Voltage (VREF) Absolute Negative Reference Voltage (VREFN) Absolute Positive Reference Voltage (VREFP) Average Voltage Input Current ppm ±0.1 fIN=50/60Hz, data rate=960SPS AVDD, AVSS -5 ±1 100 120 % 5 ppm/°C dB 75 90 dB DVDD 80 120 dB VREF = VREFP – VREFN 0.5 VAVDD – VAVSS + 0.1 V VAVSS – 0.05 VREFP – 0.5 V VREFN + 0.5 VAVDD + 0.05 V 300 nA 1 μA Burnout Current Sources Current Setting ADC CLOCK External Clock Internal Oscillator Frequency Range Duty Cycle 1 4.9152 40% Nominal Frequency 5 4.9152 Accuracy –3% High-level Output Voltage (VOH) IOH = 4mA 0.8·VDVDD Low-level Output Voltage (VOL) IOL = –4mA MHz 60% ±0.5% MHz 3% DIGITAL INPUT/OUTPUT V 0.2·VDVDD V High-level Input Voltage (VIH) 0.7·VDVDD VDVDD V Low-level Input Voltage (VIL) VDGND 0.3·VDVDD V ±10 μA V Input Hysteresis 0.5 Input Leakage V POWER SUPPLY AVSS Voltage (VAVSS) –2.625 0 AVDD Voltage (VAVDD) VAVSS + 4.75 VAVSS + 5.25 V DVDD Voltage (VDVDD) 2.7 5.25 V 4.5 mA AVDD, AVSS Current (IAVDD) May 2022 Active Mode 3.6 Signal Micro Incorporated http://www.signal-micro.cn 4 SIG5530A/5530C DVDD Current (IDVDD) Total Power Dissipation μA Sleep Mode 1 Active Mode 0.4 Sleep Mode 40 μA Active Mode 20 mW Sleep Mode 0.15 mW 0.6 mA TEMPERATURE RANGE Specified temperature range –40 125 °C Operating temperature range –50 125 °C Storage temperature range –60 150 °C (1) Compliance to datasheet limits is assured by one or more methods: production test, characterization and/or design. (2) Power supply rejection is specified DC change in voltage. May 2022 Signal Micro Incorporated http://www.signal-micro.cn 5 SIG5530A/5530C Timing Requirements: Serial Interface Over the operating ambient temperature range and DVDD = 2.7V to 5.25V, unless otherwise noted. t7 CSn t1 t5 B7 DOUT B6 B5 B4 B3 B2 B1 B0 t2 t8 t6 t3 SCLK t4 t9 t10 DIN B7 B6 B5 B4 B3 B2 B1 B0 Figure 1. Serial Interface Timing Requirements SYMBOL t1 t2 t3 t4 DESCRIPTION CSn falling edge to valid DOUT/DRDYn: propagation delay(1) SCLK falling edge to valid DOUT/DRDYn: propagation delay(1) SCLK high pulse width MIN MAX 20 20 50 UNIT ns ns ns SCLK low pulse width 50 ns SCLK period 100 106 ns 20 ns t5 CSn rising edge to DOUT high impedance: propagation delay t6 Last SCLK falling edge to CSn rising edge: delay time 20 ns t7 CSn high pulse width 50 ns 50 ns time(2) t8 CSn falling edge to first SCLK rising edge: setup t9 Valid DIN to SCLK rising edge: setup time 20 ns t10 Valid DIN to SCLK rising edge: hold time 20 ns (1) DOUT load = 20pF || 100k Ω to DGND. (2) CSn can be tied low. May 2022 Signal Micro Incorporated http://www.signal-micro.cn 6 SIG5530A/5530C NOISE PERFORMANCE The noise performance of the ADC is affected by amplifier gain, data rate, and digital filter setting. The following tables show the rms noise and peak-to-peak noise for SINC3 and SINC1 filters. The effective number of bits (ENOB) and noise-free bits are also listed according to Equation (1) and Equation (2): ENOB= log 2 (2×VREF ⁄Gain⁄VRMS ) Noise Free Bits= log 2 �2×VREF ⁄Gain⁄Vp-p � (1) (2) The noise data listed in the table are typical and are generated from continuous ADC readings with differential input voltage of 0 V. Table 1. ADC Noise in µVRMS (µVPP) at TA = 25°C, VAVDD = 5 V, VAVSS = 0 V, VREF = 2.5 V, SINC3 Filter Data Rate(SPS) 1.875 3.75 7.5 15 30 60 120 240 480 960 1920 GAIN=64 0.008(0.050) 0.011(0.070) 0.016(0.099) 0.023(0.140) 0.032(0.198) 0.045(0.280) 0.064(0.396) 0.091(0.561) 0.128(0.793) 0.182(1.12) 0.255(1.55) Table 2. ADC ENOB (Noise Free Bits) at TA = 25°C, VAVDD = 5 V, VAVSS = 0 V, VREF = 5 V, SINC3 Filter Data Rate(SPS) 1.875 3.75 7.5 15 30 60 120 240 480 960 1920 May 2022 GAIN=64 23.2(20.4) 22.7(19.9) 22.2(19.4) 21.7(18.9) 21.2(18.4) 20.7(17.9) 20.2(17.4) 19.7(16.9) 19.2(16.4) 18.7(15.9) 18.2(15.3) Signal Micro Incorporated http://www.signal-micro.cn 7 SIG5530A/5530C Table 3. ADC Noise in µVRMS (µVPP) at TA = 25°C, VAVDD = 5 V, VAVSS = 0 V, VREF = 2.5 V, SINC1 Filter Data Rate(SPS) 1.875 3.75 7.5 15 30 60 120 240 480 960 1920 GAIN=64 0.010(0.062) 0.014(0.088) 0.020(0.125) 0.029(0.176) 0.041(0.249) 0.057(0.352) 0.081(0.498) 0.115(0.705) 0.163(0.996) 0.230(1.41) 0.317(2.20) Table 4. ADC ENOB (Noise Free Bits) at TA = 25°C, VAVDD = 5 V, VAVSS = 0 V, VREF = 5 V, SINC1 Filter Data Rate(SPS) 1.875 3.75 7.5 15 30 60 120 240 480 960 1920 May 2022 GAIN=64 22.8(20.1) 22.3(19.6) 21.8(19.1) 21.3(18.6) 20.8(18.1) 20.3(17.6) 19.8(17.1) 19.3(16.6) 18.8(16.1) 18.3(15.6) 17.9(15.0) Signal Micro Incorporated http://www.signal-micro.cn 8 SIG5530A/5530C REGISTER MAPS There are total three 24-bit registers inside the device. These registers are used to configure and control the ADC to the desired mode of operation. These registers can be accessed through the SPI-compatible serial interface by using register read and write commands. At power-on or reset, the registers default to their initial settings, as shown in the Reset Value column of Table 5. Table 5. Register map ADDR. RS[2:0] NAME RESET VALUE 3’b001 OFFSET 0x00000000 3’b010 GAIN 0x01000000 3’b011 CONF 0x00000000 BIT 31 BIT 23 BIT 15 BIT 7 BIT 30 BIT 22 BIT 14 BIT 6 BIT 29 BIT 21 BIT 13 BIT 5 BIT 28 BIT 27 BIT 20 BIT 19 BIT 12 BIT 11 BIT 4 BIT 3 OFFSET[31:24] OFFSET[23:16] OFFSET[15:8] OFFSET[7:0] GAIN[23:16] GAIN[23:16] GAIN[15:8] GAIN[7:0] BIT26 BIT18 BIT10 BIT 2 BIT 25 BIT 17 BIT 9 BIT 1 BIT 24 BIT 16 BIT 8 BIT 0 PSS PDW RS RV SHORT A0_PSW VRS A0 0 0 0 FRS FILTER TPS 0 0 CHKSUM DR[3] LATENCY DR[2] CLK1 DR[1] CLK0 DR[0] CS1] FORMAT CS[0] BCS 0 DT 0 A1 OFFSET Register Table 6. OFFSET Register (Address = 3’b001) BIT 31 BIT 30 BIT 29 BIT 28 BIT 27 BIT26 BIT 25 BIT 24 BIT 23 BIT 22 BIT 21 BIT 20 BIT 19 BIT18 BIT 17 BIT 16 BIT 15 BIT 14 BIT 13 BIT 12 BIT 11 BIT10 BIT 9 BIT 8 BIT 7 BIT 6 BIT 5 BIT 4 BIT 3 BIT 2 BIT 1 BIT 0 OFFSET[31] OFFSET[30] OFFSET[29] OFFSET[28] OFFSET[27] OFFSET[26] OFFSET[25] OFFSET[24] OFFSET[23] OFFSET[22] OFFSET[21] OFFSET[20] OFFSET[19] OFFSET[18] OFFSET[17] OFFSET[16] OFFSET[15] OFFSET[14] OFFSET[13] OFFSET[12] OFFSET[11] OFFSET[10] OFFSET[9] OFFSET[8] OFFSET[7] OFFSET[6] OFFSET[5] OFFSET[4] OFFSET[3] OFFSET[2] OFFSET[1] OFFSET[0] Power-On/Reset value = 0x00000000 Bits Bit Name Access Reset Description 31:0 OFFSET[31:0] R/W 0x00000000 Offset Calibration Bits: The 32-bit word is signed number in 2’s complement format. See Calibration section for more information. GAIN Register Table 7. GAIN Register (Address = 3’b010) BIT 31 BIT 30 BIT 29 BIT 28 BIT 27 BIT26 BIT 25 BIT 24 BIT 23 BIT 22 BIT 21 BIT 20 BIT 19 BIT18 BIT 17 BIT 16 BIT 15 BIT 14 BIT 13 BIT 12 BIT 11 BIT10 BIT 9 BIT 8 BIT 7 BIT 6 BIT 5 BIT 4 BIT 3 BIT 2 BIT 1 BIT 0 GAIN[31] GAIN[30] GAIN[29] GAIN[28] GAIN[27] GAIN[26] GAIN[25] GAIN[24] GAIN[23] GAIN[22] GAIN[21] GAIN[20] GAIN[19] GAIN[18] GAIN[17] GAIN[16] GAIN[15] GAIN[14] GAIN[13] GAIN[12] GAIN[11] GAIN[10] GAIN[9] GAIN[8] GAIN[7] GAIN[6] GAIN[5] GAIN[4] GAIN[3] GAIN[2] GAIN[1] GAIN[0] Power-On/Reset value = 0x01000000 May 2022 Signal Micro Incorporated http://www.signal-micro.cn 9 SIG5530A/5530C Bits Bit Name Access Reset Description 31:0 GAIN[31:0] R/W 0x01000000 Gain Calibration Bits: The 32-bit word is unsigned positive number in binary format. See Calibration section for more information. Configuration Register (CONF) Table 8. CONF Register (Address = 3’b011) BIT 31 BIT 30 BIT 29 BIT 28 BIT 27 BIT26 BIT 25 BIT 24 BIT 23 BIT 22 BIT 21 BIT 20 BIT 19 BIT18 BIT 17 BIT 16 BIT 15 BIT 14 BIT 13 BIT 12 BIT 11 BIT10 BIT 9 BIT 8 BIT 7 BIT 6 BIT 5 BIT 4 BIT 3 BIT 2 BIT 1 BIT 0 PSS PDW RS RV SHORT A0_PSW VRS A1 A0 0 0 0 FRS FILTER TPS 0 0 DR[3] DR[2] DR[1] DR[0] FORMAT BCS DT CHKSUM LATENCY CLK1 CLK0 CS1] CS[0] 0 0 Power-On/Reset value = 0x00000000 Bits Bit Name Access Reset Description 31 PSS R/W 1’b0 Power Save Select: 0: Standby Mode (default) 1: Sleep Mode 30 PDW R/W 1’b0 Power Down Mode: 0: Normal Mode (default) 1: Power Down Mode 29 RS R/W 1’b0 Reset System: 0: Normal Operation (default) 1: Activate a Reset cycle. 28 RV R 1’bx Reset Indicator: Read only. Bit is cleared to logic zero after the CONF register is read. 0: Normal Operation (default) 1: System was reset. 27 SHORT R/W 1’b0 Input Short: 0: Normal Input (default) 1: Analog Inputs are disconnected from the pins and shorted internally to mid-supply (VAVDD+VAVSS)/2. 26 A0_PSW R/W 1’b0 Bridge Power-down Switch Function: When this bit is set to 1, the output latch bit A0 is served as the switch control bit. The switch is closed to short pin A0 to DVSS with low on-resistor of typical 3 Ohms if the output latch bit is set to 1. The switch is open if the output latch bit is cleared. The switch remains active in standby mode and is forced to open in sleep mode. 0: Disabled (default) 1: Enabled. 25 VRS R/W 1’b0 Voltage Reference Select: The input full-scale range is [-VREF/(2xgain), VREF/(2xgain)] with VRS=0, and is [-VREF/gain, VREF/gain] with VRS=1. 0: 2.5V
SIG5530A-ITSP20-RL 价格&库存
很抱歉,暂时无法提供与“SIG5530A-ITSP20-RL”相匹配的价格&库存,您可以联系我们找货
