SIG1232A-ITSP24-RL
SIG1232A-ITSP24-RL
    SIGNALMICRO(信格勒)
    TSSOP24
    模数转换器(ADC) TSSOP24 3ppm 10/80SPS 24bit 2.7V~5.25V -40℃~+125℃
SIG1232A-ITSP24-RL 数据手册
SIG1232A SIG1232A: 10/80SPS, 24-bit Sigma-Delta ADC with PGA FEATURES DESCRIPTION PGA Gain: 1, 2, 64, and 128 Data Rates: 10SPS and 80SPS RMS Noise: 19nV at 10SPS Offset Drift: 5nV/°C Gain Drift: 1ppm/°C Internal or External Clock Parity Check Power Supply AVDD: 2.7V to 5.25V DVDD: 2.7V to 5.25V Current: 1.5mA Package: 24-lead TSSOP The SIG1232A is a low noise, low drift, and high-resolution 24bit analog-to-digital converter (ADC) with integrated programmable gain amplifier (PGA) that offers high-accuracy measurement solutions for bridge sensors. The device contains a low noise PGA with gains selected from 1, 2, 64, and 128, a delta-sigma (Δ-Σ) modulator, and a SINC4 digital filter. Two data rates are provided from the device: 10SPS and 80SPS. SPI-compatible interface is used for device configuration and parity check is provided for data integrity. The on-chip oscillator, an external clock, or an external crystal can be used as the clock source to the device. The SIG1232A is available in 24-lead TSSOP package and is fully specified over the -40°C to +125°C temperature range. APPLICATIONS Weigh Scales Strain Gauges Pressure Sensors Industrial Process Control TSSOP-24 Function Block Diagram AVDD REFP REFN DVDD 1 24 DOUT/DRDYn DGND 2 23 SCLK CLKIN/XTAL1 3 22 PDWNn PDWNn XTAL 4 21 SPEED SPEED DGND 5 20 GAIN1 DOUT/DRDYn SCLK DGND 6 19 GAIN0 TEMP 7 18 AVDD A0 8 17 AGND NC 9 16 REFP NC 10 15 REFN AINP1 11 14 AINP2 AINN1 12 13 AINN2 DVDD BUF MUX AINP1 AINN1 AINP2 PGA ΔΣ ADC Digital Filter Serial Interface AINN2 Gain=1, 2, 64, and 128 Internal Oscillator TEMP A0 GAIN1 GAIN0 AGND May 2022 Clock Mux DGND XTAL2 CLKIN/XTAL1 Signal Micro Incorporated http://www.signal-micro.cn SIG1232A TSSOP-24 SIG1232A PIN CONFIGURATION and DESCRIPTIONS PACKAGE TSSOP-24ld TOP VIEW (Not To Scale) DVDD 1 24 DOUT/DRDYn DGND 2 23 SCLK CLKIN/XTAL1 3 22 PDWNn XTAL 4 21 SPEED DGND 5 20 GAIN1 DGND 6 19 GAIN0 TEMP 7 18 AVDD A0 8 17 AGND NC 9 16 REFP NC 10 15 REFN AINP1 11 14 AINP2 12 13 AINN2 AINN1 PIN NO. NAME FUNCTION SIG1232A TSSOP-24 DESCRIPTION 1 DVDD Digital Digital power supply, 2.7V to 5.25V. 2 DGND Digital Digital ground reference point. 3 CLKIN/XTAL1 Digital Input 4 XTAL2 Digital Input 1) Internal oscillator: Connect to DGND. 2) External clock: Connect to external clock input. 3) Crystal oscillator connection 1 Crystal oscillator connection 2 5,6 DGND Digital No connection (float) or connect to DVDD/DGND. 7 TEMP Digital Input Temperature sensor enable bit: On-chip temperature sensor is enabled if this pin is connected to DVDD. The measurement for internal temperature sensor is about 113uV at 27°C with sensitivity of 0.337uV/°C. GAIN=1 is needed to have correct temperature measurement. 8 A0 Digital Input Input channel control: DGND for INP1/INN1 and DVDD for INP2/INN2. 9,10 NC Digital 11 AINP1 Analog Input Positive analog input channel 1. 12 AINN1 Analog Input Negative analog input channel 1. 13 AINN2 Analog Input Negative analog input channel 2. 14 AINP2 Analog Input Positive analog input channel 2. 15 REFN Analog Input Negative reference input. 16 REFP Analog Input Positive reference input. 17 AVSS Analog Negative analog power supply. 18 AVDD Analog 19 GAIN0 Digital Input 20 GAIN1 Digital Input 21 SPEED Digital Input 22 PDWNn Digital Input 23 24 SCLK DOUT/DRDYn Digital Input Digital Output Positive analog power supply. 2.7V to 5.25V relative to AVSS. PGA gain control bits: GAIN1 GAIN0 GAIN 0 0 1 0 1 2 1 0 64 1 1 128 Date rate select: DGND for 10SPS and DVDD for 80SPS. Power-Down signal. Active low. ADC enters power-down mode if holding pin low. Serial data clock. Serial data output and data ready indicator. May 2022 No connection (float) or connect to DVDD/DGND. Signal Micro Incorporated http://www.signal-micro.cn 2 SIG1232A PACKAGE/ORDERING INFORMATION MODEL PACKAGE DESCRIPTION SPECIFIED TEMPERATURE RANGE ORDERING NUMBER PACKING OPTION SIG1232A TSSOP-24 -40°C to +125°C SIG1232A-ITSP24-RL Reel, 3000 SPECIFICATIONS Absolute Maximum Ratings Over operating free-air temperature range, unless otherwise noted.(1) Voltage Current Temperature MIN MAX UNIT AVDD to AVSS –0.3 6.5 V AVSS to DGND –0.3 0.3 V DVDD to DGND –0.3 6.5 V Analog input VAVSS – 0.3 VAVDD + 0.3 V Digital input VDGND – 0.3 VDVDD + 0.3 V Input current –10 10 mA Junction (TJ) –50 150 °C Storage (Tstg) -60 150 °C (1) Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. ESD Ratings SYMBOL PARAMTER CONDITION VALUE UNIT HBM Human-body Model ANSI/ESDA/JEDEC JS-001 ±4000 V CDM Charged-device model JEDEC EIA/JS-002-2022 ±2000 V This integrated circuit can be damaged by ESD. Signal Micro recommends that all integrated circuits be handled with appropriate precautions. Failure to observe proper handling and installation procedures can cause damage. ESD damage can range from subtle performance degradation to complete device failure. Precision integrated circuits may be more susceptible to damage because very small parametric changes could cause the device not to meet its published specifications. May 2022 Signal Micro Incorporated http://www.signal-micro.cn 3 SIG1232A Electrical Characteristics Minimum/Maximum specifications apply from -40˚C to +125˚C. Typical specifications are at +25˚C. All specification are at VAVDD=5V, VAVSS=0V, VDVDD=3.3V, VREF=2.5V, fCLK=1.536MHz, data rate=10SPS, unless otherwise noted. PARAMETER TEST CONDITION OR NOTES MIN(1) TYP MAX(1) UNITS ANALOG INPUTS Differential Input Voltage Absolute Input Voltage –0.5·VREF/Gain +0.5·VREF/Gain V GAIN=1 VAVSS – 0.05 VAVDD + 0.05 GAIN=2/64/128 VAVSS + 0.5 VAVSS + 0.5 + |VINMAX|·Gain VAVDD – 0.5 VAVDD – 0.5 – |VINMAX|·Gain V V VIN = VINP – VINN Common Mode Input Range GAIN=2/64/128 Absolute Input Current GAIN=1 GAIN=2/64/128 ±20 ±1 V nA nA SYSTEM PERFORMANCE PGA Gain 1/2/64/128 V/V Resolution 24 Bits 10/80 SPS Data Rate Noise See Noise Table 1 Integral Nonlinearity (INL) ±15 Offset Error Offset Drift vs. Temperature Gain Error Gain Drift vs. Temperature ppm ±256/GAIN μV ±128/GAIN ± 3 nV/°C -0.05 ±0.01 0.05 % -5 ±1 +5 ppm/°C Normal Mode Rejection (NMRR) Common Mode Rejection (CMRR) fIN=50/60Hz, ±2%, data rate=10SPS 100 110 dB fIN=50/60Hz, data rate=10SPS 100 120 dB Power Supply Rejection(2) (PSRR) AVDD 75 90 dB DVDD 80 120 dB REFERENCE INPUT Differential Reference Voltage (VREF) Absolute Negative Reference Voltage (VREFN) Absolute Positive Reference Voltage (VREFP) VREF = VREFP – VREFN VAVSS + 0.5 VAVDD + 0.1 V VAVSS – 0.05 VREFP – 0.5 V VREFN + 0.5 VAVDD + 0.05 V Average Voltage Input Current 150 nA ADC CLOCK External Clock Internal Oscillator Crystal Oscillation Frequency Range Duty Cycle 1 40% Nominal Frequency Accuracy Frequency Range 1.536 1.6 60% 1.536 MHz –3% ±0.5% 3% 1 1.536 1.6 Start-up time MHz 20 MHz ms DIGITAL INPUT/OUTPUT High-level Output Voltage (VOH) IOH = 4mA Low-level Output Voltage (VOL) IOL = –4mA 0.8·VDVDD V 0.2·VDVDD V High-level Input Voltage (VIH) 0.7·VDVDD VDVDD V Low-level Input Voltage (VIL) VDGND 0.3·VDVDD V ±10 μA Input Hysteresis 0.5 Input Leakage V POWER SUPPLY AVSS Voltage (VAVSS) AVDD Voltage (VAVDD) May 2022 0 2.7 Signal Micro Incorporated http://www.signal-micro.cn V 5.25 V 4 SIG1232A DVDD Voltage (VDVDD) AVDD, AVSS Current (IAVDD) 5.25 V Normal Mode, GAIN=1 2.7 0.3 0.5 mA Normal Mode, GAIN=2/64/128 1.3 1.8 mA Standby Mode Power-down Mode DVDD Current (IDVDD) Total Power Dissipation μA 1 μA 1 180 Standby Mode 20 Power-down Mode 1 μA Normal Mode, GAIN=1 2 mW Normal Mode, GAIN=2/64/128 7 mW 0.1 mW Standby Mode 300 μA Normal Mode μA TEMPERATURE RANGE Specified temperature range –40 125 °C Operating temperature range –50 125 °C Storage temperature range –60 150 °C (1) Compliance to datasheet limits is assured by one or more methods: production test, characterization and/or design. (2) Power supply rejection is specified DC change in voltage. May 2022 Signal Micro Incorporated http://www.signal-micro.cn 5 SIG1232A Timing Requirements: Serial Interface Over the operating ambient temperature range and DVDD = 2.7V to 5.25V, unless otherwise noted. B7 B6 B5 B4 B3 B2 B1 B0 DESCRIPTION SCLK rising edge to valid DOUT/DRDYn: propagation delay(1) SCLK high pulse width SCLK low pulse width MIN MAX 50 UNIT ns ns ns SCLK period 200 106 ns DOUT t2 t3 SCLK t4 Figure 1. Serial Interface Timing Requirements SYMBOL t2 t3 t4 100 100 (1) DOUT load = 20pF || 100k Ω to DGND. May 2022 Signal Micro Incorporated http://www.signal-micro.cn 6 SIG1232A NOISE PERFORMANCE Table 1 and Table 2 show ADC noise performance in root mean square (RMS) value, peak-to-peak values, effective number of bits (ENOB), and noise-free bits. The ENOB and noise-free bits listed in the tables are calculated using Equation (1) and Equation (2): ENOB= log 2 (VREF ⁄Gain⁄VRMS ) (1) Noise Free Bits= log 2 �VREF ⁄Gain⁄Vp-p � (2) The noise data listed in the table are typical and are generated from continuous ADC readings with differential input voltage of 0 V. Table 1. ADC Noise in µVRMS (µVPP) at TA = 25°C, VAVDD = 5 V, VREF = 5 V Data Rate Gain RMS Noise(nV) Peak-to-Peak Noise(nV) ENOB(RMS) Noise-Free Bits 10SPS 1 350 1500 23.8 21.7 10SPS 2 190 900 23.6 21.4 10SPS 64 23 110 21.7 19.4 10SPS 128 19 95 21.0 18.6 80SPS 1 1000 6200 22.3 19.6 80SPS 2 560 3600 22.1 19.4 80SPS 64 66 380 20.2 17.6 80SPS 128 54 310 19.5 16.9 Table 2. ADC Noise in µVRMS (µVPP) at TA = 25°C, VAVDD = 3 V, VREF = 3 V Data Rate Gain RMS Noise(nV) Peak-to-Peak Noise(nV) ENOB(RMS) Noise-Free Bits 10SPS 1 350 1500 23.0 20.9 10SPS 2 190 900 22.9 20.7 10SPS 64 23 110 21.0 18.7 10SPS 128 19 95 20.2 17.9 80SPS 1 1000 6200 21.5 18.9 80SPS 2 560 3600 21.4 18.7 80SPS 64 66 380 19.4 16.9 80SPS 128 54 310 18.7 16.2 May 2022 Signal Micro Incorporated http://www.signal-micro.cn 7 SIG1232A CIRCUIT DESCRIPTION AVDD REFP REFN DVDD PDWNn BUF SPEED AINN1 AINP2 AINN2 MUX AINP1 PGA ΔΣ ADC Digital Filter Serial Interface Internal Oscillator Clock Mux DOUT/DRDYn SCLK Gain=1, 2, 64, and 128 TEMP A0 GAIN1 GAIN0 AGND XTAL2 CLKIN/XTAL1 DGND Figure 2. SIG1232A Block Diagram OVERVIEW The SIG1232A is low noise, low drift, and high-resolution 24-bit analog-to-digital converter (ADC) with integrated programmable gain amplifier (PGA). The ADC provides high-accuracy measurement solutions for bridge sensors. Figure 2 shows the device block diagram. The ADC features a high input-impedance, low-noise, programmable gain amplifier (PGA). The PGA gain is selectable with 1, 2, 64, and 128 by GAIN1/GAIN0 input pins. A delta-sigma modulator measures the PGA output voltage according to the buffered reference voltage to provide high speed bitstream to the digital filter. Unlike SAR ADCs, this ADC is much easier to drive due to very high impedance at both analog and reference inputs. The digital filter provides SINC4 filter mode, allowing good line-cycle rejection. Two data rates are provided from the device: 10SPS and 80SPS. The SP-compatible serial interface is used to read the conversion data. The serial interface consists of two signals: SCLK and DOUT/DRDYn. The DOUT/DRDYn pin serves as dual function of register and ADC data output and also the indicator for data ready after the conversion is done. Parity check is provided for data integrity. The ADC has three clock options: internal oscillator, external clock, and external crystal. The nominal clock frequency is 1.536MHz. The ADC operates with a single analog power supply with range from 2.7V to 5.25V. The digital power supply range is 2.7 V to 5.25 V. May 2022 Signal Micro Incorporated http://www.signal-micro.cn 8 SIG1232A Programmable Gain Amplifier (PGA) The ADC features a low-drift, low-noise, high input impedance programmable gain amplifier (PGA). The PGA input is equipped with an electromagnetic-interference (EMI) filter consisting of two 350-Ω input resistors, and two 8pF filter capacitors, as shown in the Figure 3. 350Ω A1 8pF ADC A2 350Ω 8pF Figure 3. Simplified PGA Block Diagram The ADC full-scale voltage range is determined by the reference voltage and the PGA gain. Table 3 shows the fullscale voltage range verses gain for 5V reference voltage. Table 3. ADC Full-Scale Voltage Range with VREF = 5V FULL SCALE RANGE (V)(1) ±2.5 V ±1.25 V ±39 mV ±19.5 mV GAIN 1 2 64 128 (9) The full scale input range is proportional to VREF. Just like most amplifiers, there should be some headroom for the output of PGA to be away from the power supply (VAVDD) and ground (VAVSS) due to the limitation of voltage driving capability of PGA output device as shown in Figure 4. For correct linear operation, the absolute PGA output voltage must locate within the range [VAVSS + 0.5, VAVDD – 0.5]. The analog input common voltage must meet Equation (3): (VAVSS + 0.5 + VIN · Gain) ≤ VCM ≤ (VAVDD – 0.5 – VIN · Gain) (3) Where VIN = differential input voltage = VINP – VINN VCM = input common mode voltage = (VINP + VINN)/2 May 2022 Signal Micro Incorporated http://www.signal-micro.cn 9 SIG1232A PGA Input PGA Output VAV DD VAV DD – 0.5V VOUTP = VCM+VIN ×Gain VINP VCM VINN VOUTN = VCM–VIN ×Gain VAV SS + 0.5V VAV SS Figure 4. PGA Input and Output Range Digital Filter and Conversion Time A delta-sigma (Ʃ–Δ) ADC consists of a modulator followed by a programmable digital decimation filter to produce the final high-resolution data output. Caution must be taken to choose the type of filtering based on the consideration of tradeoffs between resolution, data rate, line cycle rejection, and conversion latency. This ADC only provides sinc4 filter. Figure 5 shows the frequency response of the SINC4 and SINC1 filters normalized to output data rate. 0 SINC1 -20 SINC4 Amplitude (dB) -40 -60 -80 -100 -120 -140 -160 0 1 2 3 4 5 6 7 Normalized Frequency 8 9 10 Figure 5. Frequency Response of SINC1/SINC4 Filter While the order of the SINC filter doesn’t affect the notch positions, the higher order SINC4 filter has wider notches resulting in better rejection in the band (±1 Hz) around the notches. The higher order SINC4 filter also gives better stop-band rejection with the tradeoff of longer settling time for the same output data rate. The SINC4 filter normally takes four conversion cycles to settle, while SINC1 filter settles in one conversion cycle. Clock Mode The on-chip oscillator, an external clock, or an external crystal can be used as the clock source to the device. Figure 6 illustrates the configuration for each clock mode. If the CLKIN pin is shorted to analog ground (AVSS), the internal oscillator is enabled. If an external clock is detected at the CLKIN pin, the ADC automatically selects the external clock. May 2022 Signal Micro Incorporated http://www.signal-micro.cn 10 SIG1232A C1 1.536MHz Clock XTAL1/CLKIN XTAL1/CLKIN XTAL1/CLKIN XTAL2 XTAL2 XTAL2 C2 Option (a) : Internal Oscillator Option (b): External Clock Option ©: Crystal Oscillator Figure 6. Clock Mode Configurations Power-On Reset (POR) The ADC has two power supplies, analog and digital. The analog power supply (AVDD) range is 2.7V to 5V. The digital supply (DVDD) range is 2.7V to 5V. Figure 7 shows the POR sequence. The internal POR circuitry forces the ADC in reset state if the digital supply voltage (VDVDD) is below POR voltage threshold which is about 1.3V. After the digital supply voltage (VDVDD) exceeds POR voltage threshold, additional 43 ms of waiting time is needed for power supply to be fully settled before sending any command, otherwise the command is ignored. VDVDD POR level: 1.3V typical fCLK Internal Reset ADC Reset ADC Normal Operation 43ms Figure 7. Power-On Reset Sequence SPI Interface The ADC provides a 2-wire SPI-compatible interface with SPI Mode 1 supported. Please see Timing Requirements: Serial Interface section for the timing information related to serial interface. SERIAL CLOCK (SCLK) The serial clock is a Schmitt-triggered input to make it noise immune. This pin is used to clock data into and out of the device. Output data on DOUT pin are updated on the rising edge of SCLK. DATA OUTPUT (DOUT/DRDYn) The DOUT/DRDYn pin is a dual-function output. This pin serves as the serial interface data output and also as an indicator for new data ready for retrieval. First, conversion or register data are shifted out on DOUT/DRDYn pin on the rising edge of SCLK. Second, while the SPI interface is at idle state, the DOUT/DRDYn pin goes low to indicate that new conversion data are ready for retrieval. Data Format The device provides 24 bits of conversion data output in binary 2’s complement format, left justified, MSB first. The ADC input is bipolar-differential and is scaled such that zero differential input results in an ideal code of 24’h000000, positive full scale input results in an ideal code of 24’h7FFFFF, and negative full scale input results in an ideal code of 24’h800000. The output clips if the signal exceeds full-scale. Table 4 lists the ideal output codes for different input signals. May 2022 Signal Micro Incorporated http://www.signal-micro.cn 11 SIG1232A Table 4. Ideal Output Code vs. Input Signal INPUT SIGNAL VIN = VINP – VINN ≥ FS (223 – 1) / 223 FS / 223 0 -FS / 223 ≤ –FS IDEAL OUTPUT CODE 24’h7FFFFF 24’h000001 24’h000000 24’hFFFFFF 24’h800000 Reading ADC Data As shown in Figure 8, the ADC data is 3 bytes long. Parity byte is appended to the conversion data bytes after more than 24 SCLKs is applied. Part of parity byte is formed by the checksum byte, which is the 8-bit sum of data conversion bytes plus an offset value, 8’h5B. The first and last bit of parity byte are forced with 1’b1. CHECKSUM [7:0] = DATA [23:16] + DATA [15:8] + DATA [7:0] + 8’h5B PARITY [7:0] = {1’b1, CHECKSUM [6:1], 1’b1} After four bytes are read, the data byte sequence is repeated when more SCLKs are sent. The repeating byte sequence starts with the first byte DATA [23:16]. The read operation needs to complete 2 system clock cycles before the next new data is ready, otherwise the retrieved data is corrupted by the updating of new data on DOUT/DRDYn pin. 1 9 17 25 8*n 33 SCLK Data Ready DOUT New Data Ready DATA[23:16] DATA[15:8] DATA[7:0] PARITY[7:0] DATA REPEAT Optional Figure 8. Reading Data Sequence Standby Mode In normal conversion mode, it is required to have SCLK low after data retrieval before the next new data is updating with DOUT/DRDYn pin going to high. If user holds SCLK high while the next new data is updating with DOUT/DRDYn pin going to high, the device will enter standby mode to save power with about only 20uA current used. To exit standby mode, set SCLK low. The first data after exiting standby mode is fully settled data after 4x time of data interval. May 2022 Signal Micro Incorporated http://www.signal-micro.cn 12 SIG1232A REVISION HISTORY The revision history provided is for informational purposes only and is believed to be accurate, but not warranted. Please go to web to make sure you have the latest revision. DATE REVISION May 20, 2022 CHANGE Initial release. DISCLAIMER Signal Micro reserves the right to make any change in circuit design, specification or other related things if necessary without notice at any time. All trademarks and registered trademarks are the property of their respective owners. May 2022 Signal Micro Incorporated http://www.signal-micro.cn 13 SIG1232A PACKAGE OUTLINE DIMENSIONS 0.30 0.19 0.65 0.10 M 13 24 0.15 NOM 4.50 4.30 6.60 6.20 0.25 o 0 -8 o 0.75 0.50 12 1 7.90 7.70 1.10 MAX 0.15 0.05 0.10 Seating Plane A. Compliant to JEDEC STARDARDS MO-153-AD. B. All linear dimensions are in millimeters. C. This drawing is subject to change without notice. May 2022 Signal Micro Incorporated http://www.signal-micro.cn 14
SIG1232A-ITSP24-RL 价格&库存
很抱歉,暂时无法提供与“SIG1232A-ITSP24-RL”相匹配的价格&库存,您可以联系我们找货
