DF14-2628SCF
DF14-2628SCF
    HRS(广濑)
    TERMINAL_4.9X1MM
    端子 Crimp TERMINAL_4.9X1MM 30mΩ 100V 100mA -35℃~+85℃
DF14-2628SCF 数据手册
The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. 1.25mm Pitch Super Low profile Crimping Connector ■Features 1. Super Low Profile This is a connector special for right angle which has pursued a low profile on the board. Board mounting height: 2.5mm A signal can be fetched from the area where there is no board to board space. (Refer to fig.1) Offset type is available. Board mounting height: 1.6mm (Refer to fig.2) Board Mounting Figure 2. Correspond to Automatic Mounting The header has the vacuum mount face which enables the vacuum absorption and the automatic mounting by the embossed tape packaging.In addition, the tube packaging can be selected. 3. Four Wall Type Without Friction to Board by Socket The header has the box structure to prevent from being twisted and has the perfect mis-insertion prevention method. Moreover the header has the wall on the board side and doesn't have any trouble resulted from the friction to board by socket. In addition, the metal fitting is attached to prevent the solder peel. ■Applications Board Mounting Figure (7.3) (1) (1.6) LCD, Note PC, Mobile Terminal Small business equipment, Video camera DF14H B234 fig.1 DF14(A) (2.4) Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF14 Series fig.2 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose RoHS search at www.hirose-connectors.com, or contact your HiroseConnector sales representative. DF14website Series●1.25mm Pitch Super Low profile Crimping ■Product Specifications Current rating Rating 1A Operating Temperature Range -35 to +85ç (Note 1) Storage Temperature Range -10 to +60ç (Note 2) Voltage rating 150V AC Operating Moisture Range Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Item 40 to 80% Storage Moisture Range Specification 40 to 70% (Note 2) Condition 1. Insulation Resistance 500M ohms Min 100V DC 2. Withstanding voltage No flashover or insulation breakdown. 500V AC/1 minute 3. Contact Resistance 30m ohms Max 100mA 4. Insertion/Extraction Force MIN0.15N (15gf), MAX3N (300gf) Measure at the square steel pin of 0.3±0.002mm 5. Vibration Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions. No electrical discontinuity of 1µs or more 6. Humidity (Steady state) Contact resistance: 30m ohms Max Insulation resistance:500M ohms Min 7. Temperature Cycle 96 hours at temperature of 40ç and humidity of 90% to 95% (-25ç: 30 minutes➝5 to 35ç: 10 minutes➝85ç: 30 minutes➝ Contact resistance: 30m ohms Max Insulation resistance: 500M ohms Min 5 to 35ç: 10 minutes) 5 cycles 8. Durability (Mating/un-mating) Contact resistance: 30m ohms Max 9. Resistance to Soldering heat Tin plating: 30 cycles Gold plating: 50 cycles Reflow: At the recommended temperature profile No deformation of components affecting performance. Manual soldering: 300ç for 3 seconds Note 1: Includes temperature rise caused by current flow. Note 2: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation. Note 3: Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. ■Material Product Part Crimping Socket Insulator Crimping Contact for Socket Contact Insulator Contact Fitting Pin Header Material Finish Remarks Polyamide Beige UL94V-0 Phosphor Copper Tin-copper plated or gold plated ––––––– Polyamide Beige UL94V-0 Brass Tin-copper plated or gold plated ––––––– Phosphor copper Tin-copper plated ––––––– ■Ordering Information ●Connector DF 14 # - * S - 1.25 C 1 1 Series Name: DF14 2 Blank: Standard, with boss 2 3 4 4 6 Connector Type S: Single row socket P: Single row pin header A: on-board, without boss H: offset 3 5 Number of Contacts: 2 to 10, 15, 20, 25, 30 5 Contact Pitch: 1.25mm 6 Contact Type C: Crimping socket H: Right angle SMT ●Contact DF14 - 2628 SCF A 1 1 Applicable cable size 2 2 2628: AWG26 to 28 3032: AWG30 to 32 3 Packaging Type SCF: Socket contact/reel 3 Plating Type Blank: Tin plated A: Gold plated B235 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or willSuper be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. DF14 Series●1.25mm Pitch Low profile Crimping Connector ■Crimping Socket Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Photo: Contact insertion state Unit: mm Part Number DF14- 2S-1.25C DF14- 3S-1.25C DF14- 4S-1.25C DF14- 5S-1.25C DF14- 6S-1.25C DF14- 7S-1.25C DF14- 8S-1.25C DF14- 9S-1.25C DF14-10S-1.25C DF14-15S-1.25C DF14-20S-1.25C DF14-25S-1.25C DF14-30S-1.25C CL No. 538-0005-8 538-0006-0 538-0007-3 538-0008-6 538-0009-9 538-0010-8 538-0011-0 538-0013-6 538-0014-9 538-0054-3 538-0059-7 538-0064-7 538-0012-3 Number of Contacts 2 3 4 5 6 7 8 9 10 15 20 25 30 A 4.45 5.70 6.95 8.20 9.45 10.70 11.95 13.20 14.45 20.70 26.95 33.20 39.45 B 1.25 2.50 3.75 5.00 6.25 7.50 8.75 10.00 11.25 17.50 23.75 30.00 36.25 RoHS Yes Note 1.The quantity is delivered per bag(100 pcs). If needed, please order the products per bag. ■Socket Crimping Contact Part Number DF14-2628SCF DF14-3032SCF DF14-2628SCFA DF14-3032SCFA CL No. 538-0001-7-** 538-0003-2-** 538-0002-0-** 538-0004-5-** Packaging Type Reel Reel Reel Reel Quantity RoHS Tin plated 10,000 KApplicable Cable (Tin plating Annealed copper wire) Conductor Size (Wire construction) AWG26(7 cores/0.16mm) AWG28(7 cores/0.127mm) AWG30(7 cores/0.1mm) AWG32(7 cores/0.08mm) Finish Jacket Diameter Ø0.54 to Ø1mm Yes Gold plated KRecommended Cable UL1571 KStrip Length 1.2 to 1.9mm Note:If other cables are used instead of the applicable cable, contact Hirose sales department. BApplicable Crimping Tool Type Applicator Press Main Unit Manual Crimping Tool Part Number AP105-DF14-2628S AP105-DF14-3032S CM-105 DF14-2628/CR-HT DF14-3032/CR-HT CL No. 901-4548-1 901-4544-0 901-0005-4 550-0261-1 550-0262-4 Applicable Contact DF14-2628SCF/SCFA DF14-3032SCF/SCFA --------------------------------------------DF14-2628SCF/SCFA DF14-3032SCF/SCFA Note 1.If a trouble has occurred due to tools, which are not designated by Hirose, Hirose won't guarantee any product. Note 2.Use the reel contact sequentially cut for manual crimping tool. B236 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose RoHS search at www.hirose-connectors.com, or contact your HiroseConnector sales representative. DF14website Series●1.25mm Pitch Super Low profile Crimping Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Right Angle Pin Header (SMT) Note 1."Without boss" indicates the style with no boss. BPCB mounting pattern BTube Packaging Dimensions [Specific No.]–**,(**) (25): Tin-copper plated tube packaging (26): Tin-copper plated embossed tape packaging (55): Gold plated tube packaging (56): Gold plated embossed tape packaging Note 2."Without boss" indicates that no hole is needed. Unit: mm With boss Part Number Without boss CL No. Part Number CL No. Number of Contacts A B C D Tube Packaging Quantity DF14- 2P-1.25H(**) 538-0021-4-** DF14A- 2P-1.25H(**) 538-0033-3-** 2 7.45 1.25 6.45 8.05 66 DF14- 3P-1.25H(**) 538-0022-7-** DF14A- 3P-1.25H(**) 538-0034-6-** 3 8.70 2.50 7.70 9.30 56 DF14- 4P-1.25H(**) 538-0023-0-** DF14A- 4P-1.25H(**) 538-0035-9-** 4 9.95 3.75 8.95 10.55 49 DF14- 5P-1.25H(**) 538-0024-2-** DF14A- 5P-1.25H(**) 538-0036-1-** 5 11.20 5.00 10.20 11.80 44 DF14- 6P-1.25H(**) 538-0025-5-** DF14A- 6P-1.25H(**) 538-0037-4-** 6 12.45 6.25 11.45 13.05 39 DF14- 7P-1.25H(**) 538-0026-8-** DF14A- 7P-1.25H(**) 538-0038-7-** 7 13.70 7.50 12.70 14.30 36 DF14- 8P-1.25H(**) 538-0027-0-** DF14A- 8P-1.25H(**) 538-0039-0-** 8 14.95 8.75 13.95 15.55 32 DF14- 9P-1.25H(**) 538-0028-3-** DF14A- 9P-1.25H(**) 538-0040-9-** 9 16.20 10.00 15.20 16.80 30 DF14-10P-1.25H(**) 538-0029-6-** DF14A-10P-1.25H(**) 538-0041-1-** 10 17.45 11.25 16.45 18.05 28 DF14-15P-1.25H(**) 538-0084-4-** DF14A-15P-1.25H(**) 538-0114-3-** 15 23.70 17.50 22.70 24.30 20 DF14-20P-1.25H(**) 538-0089-8-** DF14A-20P-1.25H(**) 538-0119-7-** 20 29.95 23.75 28.95 30.55 16 DF14-25P-1.25H(**) 538-0094-8-** DF14A-25P-1.25H(**) 538-0124-7-** 25 36.20 30.00 35.20 36.80 13 DF14-30P-1.25H(**) 538-0020-1-** DF14A-30P-1.25H(**) 538-0045-2-** 30 42.45 36.25 41.45 43.05 11 RoHS Yes Note 1.Please order the tube packaging product, multiplying the packaging quantity (pcs.). Note 2.Please order the embossed tape packaging product according to reel number. (1000 pcs./reel) B237 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or willSuper be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. DF14 Series●1.25mm Pitch Low profile Crimping Connector ■Right Angle Pin Header (Offset, SMT) A Contact No. 1 P=1.25 5.7 1.6 0.3 B238 2.4 0.8 BPCB mounting pattern D +0.2 0 A±0.05 P=1.25±0.05 1.4±0.1 (0.4) (0.5) 0.7±0.05 [Specific No.]–**,(**) (56): Gold plated embossed tape packaging 6.7±0.1 (0.3) 3.6±0.1 (0.5) Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. B C 1.3 +0.2 0 Unit: mm Part Number CL No. Number of Contacts A B C D 6.8 10.1 7.2 DF14H-02P-1.25H(**) 538-0177-3-** 2 1.25 DF14H-20P-1.25H(**) 538-0167-0-** 30 23.75 29.3 32.6 29.7 DF14H-30P-1.25H(**) 538-0188-0-** 30 36.25 41.8 45.1 42.2 RoHS Note 1.Please order the embossed tape packaging product according to reel number. (1000 pcs./reel) Yes The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose RoHS search at www.hirose-connectors.com, or contact your HiroseConnector sales representative. DF14website Series●1.25mm Pitch Super Low profile Crimping BEmbossed Carrier Tape Dimensions (JIS-C-0806) Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■ 2 to 10 Contacts ■ 15, 20, 25, 30 Contacts Unit: mm Inserted Connector Number of Contacts A B C D DF14/14A- 2P-1.25H 2 16 7.5 16.4 ––– DF14/14A- 3P-1.25H 3 16 7.5 16.4 ––– DF14/14A- 4P-1.25H 4 24 11.5 24.4 ––– DF14/14A- 5P-1.25H 5 24 11.5 24.4 ––– DF14/14A- 6P-1.25H 6 24 11.5 24.4 ––– DF14/14A- 7P-1.25H 7 24 11.5 24.4 ––– DF14/14A- 8P-1.25H 8 24 11.5 24.4 ––– DF14/14A- 9P-1.25H 9 24 11.5 24.4 ––– DF14/14A-10P-1.25H 10 24 11.5 24.4 ––– DF14/14A-15P-1.25H 15 44 20.2 44.4 40.4 DF14/14A-20P-1.25H 20 44 20.2 44.4 40.4 DF14/14A-25P-1.25H 25 56 26.2 56.4 52.4 DF14/14A-30P-1.25H 30 56 26.2 56.4 52.4 B239 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or willSuper be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. DF14 Series●1.25mm Pitch Low profile Crimping Connector BEmbossed Carrier Tape Dimensions (JIS-C-0806) DF14H-*P- 1.25H B240 2±0.1 12±0.1 0.3±0.1 0 0 .1 4±0.1 (3) .5 + B—B D±0.1 A±0.3 C B Unreeling direction C—C Ø1.5 Lead hole depth A Product name label Ø21± 0.8 Ø330±2 (Ø80) 3± 0.5 Unreeling direction 2±0.5 C +20 (C+6)MAX Unit: mm Inserted Connector Number of Contacts (3) 0.3±0.1 B±0.1 B±0.1 A±0.3 C Ø1 Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. B Ø1 .5 +0 0 .1 12±0.1 Ø1 2±0.1 4±0.1 1.75±0.1 ■ 20, 30 Contacts 1.75±0.1 ■ 2 Contacts A B C D DF14H- 2P-1.25H 2 24 11.5 24.4 –– – DF14H- 20P-1.25H 20 44 20.2 44.4 40.4 DF14H- 30P-1.25H 30 56 26.2 56.4 52.4 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose RoHS search at www.hirose-connectors.com, or contact your HiroseConnector sales representative. DF14website Series●1.25mm Pitch Super Low profile Crimping BPrecautions 1. Recommended Temperature Profile (SMT) Temperature 250ç Preheating area 150ç for 60 to 120 seconds Max. 240 220 200ç Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 150ç Powered by TCPDF (www.tcpdf.org) IR reflow condition 10s max. Soldering area 250 for 10 seconds max. 220ç min. 60 seconds max. 60s max. Soldering 60 to 120s Preheating 100ç Time 2. Recommended Manual Soldering Condition (SMT) 3. Recommended Screen Thickness (SMT) 4. Board Sled (SMT) 5. Cleaning Condition 6. Connection Condition 7. Precautions 8. Cautions Note 1.Up to 2 cycles of Reflow soldering are possible under the same conditions, provided that there is a return to normal temperature between the first and second cycle. Note 2.The temperature profile indicates the board surface temperature at the point of contacts with the connector terminals. Manual soldering: 290ç for 2 seconds 0.15 to 0.2mm Max 0.03mm at the connector center area, based on both connector edges Refer to Nylon Connector Use Hand book. Refer to Nylon Connector Use Hand book. ■Be careful to carry out the crimping operation according to the "Crimping Condition Sheet" and "Crimping Quality Reference", because the crimping contact style is too small. Refer to Nylon Connector Use Hand book. ■Be careful for an excessive scoop insertion/extraction, which will cause damage to the product. BPrecautions Precautions at Time of Insertion Precautions at Time of Disconnection Handling Handling Method: Lightly grasping the base of the cable, press the connector with your finger and insert it. Method: Grasp the cable so that the entire cable is pulled evenly and pull it out. Insertion Angle Angle of Removal [Caution] Do not insert at an angle of 30° or greater. Doing so will cause contact deformation or case damage. Method: Insert with the connector parallel. [Caution] Do not remove at an angle of 30° or greater. Doing so will cause contact deformation or case damage. Method: Remove with the connector parallel. Parallel Diagonal Parallel Diagonal Parallel Diagonal Parallel Diagonal B241
DF14-2628SCF 价格&库存
很抱歉,暂时无法提供与“DF14-2628SCF”相匹配的价格&库存,您可以联系我们找货
DF14-2628SCF
    • 100+0.15496
    • 1000+0.12191
    • 3000+0.10355
    库存:3788
    DF14-2628SCF
      • 100+0.15550
      • 500+0.12460
      • 10000+0.08860
      库存:450
