TECHNICAL DATA SHEET
1/2
R125.812.001
MALE PROTECTIVE CAP
Series : SMA
WITH CHAIN
All dimensions are in mm.
pn
ao
COMPONENTS
BODY
CENTER CONTACT
OUTER CONTACT
INSULATOR
GASKET
OTHERS PARTS
PLATINGS (µm)
MATERIALS
STAINLESS STEEL
SILICONE RUBBER
STAINLESS STEEL
PASSIVATED .
PASSIVATED .
Issue : 0311 A
In the effort to improve our products, we reserve the right to make changes judged to be
necessary.
2/2
R125.812.001
MALE PROTECTIVE CAP
Series : SMA
WITH CHAIN
PACKAGING
Standard
100
Unit
‘W’ option
SPECIFICATION
Other
Contact us
ELECTRICAL CHARACTERISTICS
Impedance
Frequency
VSWR
NA +
Insertion loss
RF leakage
Voltage rating
Dielectric withstanding voltage
Insulation resistance
NA
NA
0.000
NA
NA
NA
NA
NA
Ω
GHz
x F(GHz) Maxi
√F(GHz) dB Maxi
- F(GHz)) dB Maxi
ENVIRONMENTAL
Operating temperature
Hermetic seal
Panel leakage
Veff Maxi
Veff mini
MΩ mini
OTHERS CHARACTERISTICS
Assembly instruction
Others :
MECHANICAL CHARACTERISTICS
Center contact retention
Axial force – Mating end
Axial force – Opposite end
Torque
NA N mini
NA N mini
NA N.cm mini
Recommended torque
Mating
Panel nut
100 N.cm
NA N.cm
Mating life
Weight
-65/+165 ° C
NA Atm.cm3/s
NA
500 Cycles mini
3.910 g
Issue : 0311 A
necessary.
NA
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Radiall:
R125812001
很抱歉,暂时无法提供与“R125812001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+112.65689
- 25+110.39709
- 50+108.18936
