EC200UAUAA-N05-SGNSA
    QUECTEL(移远)
    MODULE_31X28MM_SM
    IoT/M2M优化的LTE Cat 1模块 MODULE_31X28MM_SM
EC200UAUAA-N05-SGNSA 数据手册
IoT/ M2M-optimized LTE Cat 1 Module 28.0 mm Quectel EC200U Series 31.0 mm 2.4 mm Quectel EC200U is a series of the latest LTE Cat 1 module optimized specially for M2M and IoT applications. It delivers maximum data rates up to 10 Mbps downlink and 5 Mbps uplink. Designed in the compact and unified form factor, EC200U series is compatible with Quectel multi-mode LTE Standard EC20-CE, EC200S series, EC21 series, EC25 series, EG21-G and EG25-G, ensuring that it can easily migrate among compatible modules. EC200U series also supports standard Mini PCIe packages to meet the needs of different industry applications. EC200U series contains three variants: EC200U-CN, EC200U-EU and EC200U-AU, which meets the frequency band coverage of different countries and regions. Adopting laser engraving process, EC200U series features a more fashionable appearance, strong metallic texture, better heat dissipation capability and durable label information, which makes it ideally suited for automation requirement. A rich set of Internet protocols, industry-standard interfaces and abundant functionalities (USB drivers for Windows 7/ 8/ 8.1/ 10/ 11, Linux, Android) extend the applicability of EC200U series to a wide range of M2M and IoT applications such as POS, POC, ETC, shared equipment, data card, energy control and monitoring, security and protection, and industrial PDA. Key Features LTE Cat 1 module optimized for M2M and IoT applications Worldwide LTE, GSM/ GPRS coverage LTE Cat 1 Max. 10 Mbps (DL) Max. 5 Mbps (UL) LCC Package FOTA Bluetooth (Optional) USB 2.0 High Speed Interface Wi-Fi Scan (Optional) Embedded Abundant Protocols Abundant functional interfaces Support analog audio Built-in GNSS (optional) GNSS (Optional) Feature refinements: support Wi-Fi Scan (optional), Bluetooth (optional) and FOTA High performance Version: 1.2 EMAIL US: info@quectel.com Quectel Enhanced AT Commands Status: Released VISIT US: www.quectel.com Quectel EC200U Series LTE Cat 1 EC200U-CN EC200U-EU EC200U-AU Region/ Operator China EMEA Australia/ Latin America Dimensions (mm) 28.0 × 31.0 × 2.4 28.0 × 31.0 × 2.4 28.0 × 31.0 × 2.4 Weight (g) Approx. 4.1 Approx. 4.1 Approx. 4.1 -35 °C to +75 °C -40 °C to +85 °C -35 °C to +75 °C -35 °C to +75 °C -40 °C to +85 °C -40 °C to +85 °C LTE-FDD B1/ 3/ 5/ 8 B1/ 3/ 5/ 7/ 8/ 20/ 28 B1/ 2/ 3/ 4/ 5/ 7/ 8/ 28/ 66 LTE-TDD B34/ 38/ 39/ 40/ 41 B38/ 40/ 41 B38/ 40/ 41 GSM B3/ 8 B2/ 3/ 5/ 8 B2/ 3/ 5/ 8 GNSS GPS/ BDS/ Galileo/ GLONASS/ QZSS GPS/ BDS/ Galileo/ GLONASS/ QZSS GPS/ BDS/ Galileo/ GLONASS/ QZSS Bluetooth Bluetooth 4.2 (BR/ EDR) Bluetooth 4.2 (BR/ EDR) Bluetooth 4.2 (BR/ EDR) Wi-Fi Scan 2.4 GHz 11b (Rx) 2.4 GHz 11b (Rx) 2.4 GHz 11b (Rx) Bandwidth 1.4/ 3/ 5/ 10/ 15/ 20 MHz 1.4/ 3/ 5/ 10/ 15/ 20 MHz 1.4/ 3/ 5/ 10/ 15/ 20 MHz Regulatory China: SRRC/ NAL/ CCC Europe: CE Australia/New Zealand: RCM America: FCC Brazil: Anatel Carrier China: China Telecom/ China Mobile/ China Unicom Temperature Range Operating Temperature Extended Temperature Frequency Bands Certifications Max. Data Rate LTE-FDD (Mbps) 10 (DL)/ 5 (UL) 10 (DL)/ 5( UL) 10 (DL)/ 5( UL) LTE-TDD (Mbps) 8.96 (DL)/ 3.1 (UL) 8.96 (DL)/ 3.1 (UL) 8.96 (DL)/ 3.1 (UL) GSM (kbps) 85.6 (DL)/ 85.6 (UL) 85.6 (DL)/ 85.6 (UL) 85.6 (DL)/ 85.6 (UL) (U)SIM ×2 ×2 ×2 UART ×3 ×3 ×3 USB 2.0 ×1 ×1 ×1 Audio Digital (PCM) ×1 ×1 ×1 Audio Analog × 2 (Microphone, Loudspeaker) × 2 (Microphone, Loudspeaker) × 2 (Microphone, Loudspeaker) ADC ×3 ×3 ×3 SPI ×1 ×1 ×1 SD Card ×1 ×1 ×1 RESET_N ×1 ×1 ×1 PWERKEY ×1 ×1 ×1 I2C ×2 ×2 ×2 LCM × 1 (QuecOpen®) × 1 (QuecOpen®) × 1 (QuecOpen®) Camera × 1 (QuecOpen®) × 1 (QuecOpen®) × 1 (QuecOpen®) Matrix Keyboard (4 × 4) ① × 1 (QuecOpen®) × 1 (QuecOpen®) × 1 (QuecOpen®) Wi-Fi Scan/ Bluetooth Antenna ×1 ×1 ×1 GNSS Antenna ×1 ×1 ×1 Main Antenna ×1 ×1 ×1 ● ○ ○ ○ ● ● ● ● ● ● ○ ○ ○ ● ● ● ● ● ● ○ ○ ○ ● ● ● ● ● TCP/ UDP/ PPP/ NITZ/ PING/ FILE/ MQTT/ NTP/ HTTP/ HTTPS/ SSL/ FTP/ FTPS/ CMUX/ MMS Android 4.x–12.x Windows 7/ 8/ 8.1/ 10/ 11, Linux 2.6–5.18 Android 4.x–12.x TCP/ UDP/ PPP/ NITZ/ PING/ FILE/ MQTT/ NTP/ HTTP/ HTTPS/ SSL/ FTP/ FTPS/ CMUX/ MMS Android 4.x–12.x Windows 7/ 8/ 8.1/ 10/ 11, Linux 2.6–5.18 Android 4.x–12.x TCP/ UDP/ PPP/ NITZ/ PING/ FILE/ MQTT/ NTP/ HTTP/ HTTPS/ SSL/ FTP/ FTPS/ CMUX/ MMS Android 4.x–12.x Windows 7/ 8/ 8.1/ 10/ 11, Linux 2.6–5.18 Android 4.x–12.x Linux 2.6–5.18 Windows 7/ 8/ 8.1/ 10/ 11, Linux 2.6–5.18, Android 4.x–12.x Linux 2.6–5.18 Windows 7/ 8/ 8.1/ 10/ 11, Linux 2.6–5.18, Android 4.x–12.x Linux 2.6–5.18 Windows 7/ 8/ 8.1/ 10/ 11, Linux 2.6–5.18, Android 4.x–12.x 3.3–4.3 V, Typ. 3.8 V 31 μA @ Power Off 1.4 mA @ LTE Sleep (PF = 128) 1.2 mA @ LTE Sleep (PF = 256) 28.7 mA @ Idle (PF = 64, USB Connected) 12.7 mA @ Idle (PF = 64, USB Disconnected) 3.3–4.3 V, Typ. 3.8 V 31 μA @ Power Off 1.5 mA @ LTE Sleep (PF = 128) 1.4 mA @ LTE Sleep (PF = 256) 27.9 mA @ Idle (PF = 64, USB Connected) 12.7 mA @ Idle (PF = 64, USB Disconnected) 3.3–4.3 V, Typ. 3.8 V 30 μA @ Power Off 1.4 mA @ LTE Sleep (PF = 128) 1.2 mA @ LTE Sleep (PF = 256) 27.8 mA @ Idle (PF = 64, USB Connected) 12.5 mA @ Idle (PF = 64, USB Disconnected) Interfaces Enhanced Features FOTA BLE (Bluetooth 4.2) Wi-Fi Scan GNSS Audio Playback/ Audio Recording QuecLocator® QuecPython® QuecFile® (U)SIM Card Detection Software Features Protocols RIL Driver USB RNDIS Driver Driver GNSS Driver USB ECM Driver USB Serial Driver Electrical Features Supply Voltage Range Power Consumption (Typical) NOTE: 1. ●: Supported. 2. ○: Optional. 3. ①: GNSS function is optional. If the chosen module variant supports GNSS function, 4 × 4 matrix keyboard is supported; Otherwise 4 × 6 matrix keyboard is supported. Copyright © 2022 Quectel Wireless Solutions Co., Ltd. All Rights Reserved http://www.quectel.com HQ address: Building 5, Shanghai Business Park Phase III (Area B), No.1016 Tianlin Road, Minhang District, Shanghai 200233, China Tel: +86 21 51086236 Email: info@quectel.com
