MBR0540
MBR0540
    TWGMC(迪嘉)
    SOD-123
    肖特基二极管 SOD123 VRRM=40V IF=500mA
MBR0540 数据手册
MBR0540 PINNING PIN Features DESCRIPTION 1 Cathode 2 Anode 2  Low forward voltage  High conductance 1 Top View Simplified outline SOD-123 and symbol Absolute Maximum Ratings (Ta = 25 C) O Symbol Value Unit VRRM 40 V VR 40 V Average Rectified Forward Current IF(AV) 500 mA Non-Repetitive Peak Forward Surge Current (Half Wave, Single Phase, 60 Hz) IFSM 5.5 A Thermal Resistance Junction to Lead 1) RθJL 118 O RθJA 206 O Tj 125 O Tstg - 65 to + 150 O Symbol Max. Parameter Peak Repetitive Reverse Voltage Reverse Voltage Thermal Resistance Junction to Ambient 2) Operating Junction Temperature Range Storage Temperature Range C/W C/W C C 1) Device mounted on FR-4 PCB 0.013 mm. 2) 1 inch" pad size (1 X 0.5 inch for each lead ) on FR4 board. Characteristics at Ta = 25 C O Parameter Forward Voltage at IF = 0.5 A at IF = 1 A at IF = 0.5 A, Ta = 100 OC at IF = 1 A, Ta = 100 OC VF Reverse Current at VR = 20 V at VR = 40 V at VR = 20 V, Ta = 100 OC at VR = 40 V, Ta = 100 OC www.tw-gmc.com IR 1 0.51 0.62 0.46 0.61 10 20 5 13 Unit V µA µA mA mA MBR0540 Typical Characteristics 5 Reverse Current, IR [mA] Forward Current, IF [A] 5 2 1 25 C 100 C 0.5 0.2 0.1 0.05 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 Forward Voltage, VF [V] 0.9 1 100 C 0.1 75 C 0.01 0.001 0.0001 1 125 C 25 C 0 5 10 15 20 25 30 Reverse Voltage, VR[V] Total Capacitance, CT [pF] 120 T A = +25 C 100 80 60 40 20 0 5 10 15 20 25 30 Reverse Voltage, VR [V] 35 Figure 3. Total Capacitance www.tw-gmc.com 40 Figure 2. Reverse Current vs Reverse Voltage Figure 1. Forward Voltage Characteristics 0 35 1 2 40 MBR0540 PACKAGE OUTLINE Plastic surface mounted package; 2 leads www.tw-gmc.com SOD-123 1 3
MBR0540 价格&库存
很抱歉,暂时无法提供与“MBR0540”相匹配的价格&库存,您可以联系我们找货
MBR0540
    • 1+0.34980
    • 200+0.11660
    • 1500+0.07282
    • 3000+0.05775
    库存:7173
    MBR0540
    • 20+0.13462
    • 200+0.10691
    • 600+0.09152
    • 3000+0.07768
    • 9000+0.06967
    • 21000+0.06526
    库存:40315
    MBR0540
      • 3000+0.06380
      库存:3000
      MBR0540
      • 20+1.72550
      • 100+1.02920
      • 800+0.72050
      • 3000+0.51460
      • 6000+0.48890
      • 30000+0.45290
