RN32768016
RN32768016
    TROQ(创捷)
    SMD3215_2P
    无源晶振 32.768kHz ±20ppm 12.5pF 70Ω -40℃~+85℃
RN32768016 数据手册
TROQ Electronic Co.,Ltd. CRYSTAL UNIT SPECIFICATIONS Customer Production Name Tuning Fork MD38 TROQ P/N RN32768016 Revision A Print Date 2023/5/11 Drawn Checked Approved No.777 Xianhua South Street Jinhua,Zhejiang,China TEL:86-579-83921892 FAX:86-579-83921880 http://www.troq.com page 1 6 TROQ P/N: ● RN32768016 REV: A ELECTRICAL PARAMETERS 谐振器产品技术指标 1.Holder Type(型号规格) Min Fundamental 32.768000 KHZ 12.5 pF 4.Load Capacitance (CL)(负载电容) 5.Shunt Capacitance (Co)(静态电容) 0 6.Equivalent Resistance(谐振电阻) 7.Frequency Tolerance at 25℃(调整频差) -20 8.Stability over operation temperance(温度频差) 9.Insulation Resistance (at DC 100V)(绝缘电阻) Units Tuning Fork MD38 2.Mode of Oscillation(振动模式) 3.Frequency(标称频率) Max 1 pF 70 kΩ 20 ppm ppm ± 20 MΩ 500 10.Drive Level(激励功率) uw 100 11.Operating Temperature Range(工作温度范围) -40 85 ℃ 12.Storage Temperature Range(储存温度范围) -55 125 ℃ ppm/year 13.Aging(老化率) ±5 OUTLINE DIMENSIONS(UNIT:mm)外形尺寸(单位:mm) Racsing Unit:3000pcs/reel No.777 Xianhua South Street Jinhua,Zhejiang,China TEL:86-579-83921892 FAX:86-579-83921880 http://www.troq.com page 2 TROQ P/N: ● RN32768016 REV: A SUGGESTED REFLOW PROFILE (回流焊曲线图) Total time:200sec.Max. (总时间:200秒 最大) Solder melting point:220℃(熔点220 ℃ ) Profiles Feature(特性) Pb-Free Assembly Average Ramp-up Rate(Ts max to Tp)  平均升温速度 3℃/second Max Preheat 预热 ■ Temperature Min (Ts min) 最低温度 125℃ ■ Temperature Max (Ts max) 最高温度 200℃ ■ Time (ts min to ts max ) 从最低到最高时间 Time maintained above 维持上述时间 ■ Temperature(T1) 温度 217℃ ■ Time(tp) 时间 (60~150) seconds Peak/Classification Temperature(Tp) 最高点温度 Time within 5℃ of actual Peak Temperature(tp) 高温维持时间 (20~40) seconds Ramp-down rate 降温速度 6℃/second max Time 25℃ to Peak Temperature 从25℃到最高温度的时间 8 minutes max Suggest reflow times 建议 reflow次数 (60~180) seconds 260 ℃ 3 Times max No.777 Xianhua South Street Jinhua,Zhejiang,China TEL:86-579-83921892 FAX:86-579-83921880 http://www.troq.com page 4 TROQ P/N: RN32768016 REV: A ● PACKING(包装) No.777 Xianhua South Street Jinhua,Zhejiang,China TEL:86-579-83921892 FAX:86-579-83921880 http://www.troq.com page 4
RN32768016 价格&库存
很抱歉,暂时无法提供与“RN32768016”相匹配的价格&库存,您可以联系我们找货
RN32768016
    • 5+1.19610
    • 50+0.93701
    • 150+0.82599
    • 500+0.68742
    • 3000+0.60254
    • 6000+0.56560
    库存:1912
    RN32768016
    • 1+0.86929
    库存:50
