SI2310
SOT-23 Plastic-Encapsulate MOSFETS
30V N-Channel MOSFET
V(BR)DSS
SOT-23
105mΩ@10V
60V
3
ID Max
RDS(on)Typ
1. GATE
3A
125mΩ@4.5V
2. SOURCE
1
3. DRAIN
DESCRIPTION
2
The SI2310 uses advanced trench technology to provide excellent
RDS(ON) , low gate charge and operation with gate voltage as low as 2.5V.
This device is suitable for use as a battery protection or in other switching
application.
FEATURE
High power and current handing capability
Lead free product is acquired
Surface mount package
APPLICATION
Battery Switch
DC/DC Converter
MARKING
Equivalent circuit
D
CA2T
G
S
PACKAGE SPECIFICATIONS
Package Reel Size
SOT-23
Reel DIA.
(mm)
Q'TY/Reel
(pcs)
Box Size
(mm)
QTY/Box
(pcs)
178
3000
203×203×195
45000
7'
Carton Size Q'TY/Carton
(mm)
(pcs)
438×438×220
180000
Maximum Ratings and Thermal Characteristics (TA = 25°C unless otherwise noted)
Parameter
Symbol
Limit
Drain-Source Voltage
VDS
60
Gate-Source Voltage
VGS
±20
ID
3
A
IDM
10
A
PD
0.35
TJ
150
o
Tstg
-55 to 150
o
Continuous Drain Current
Pulsed Drain Current
1)
Maximum Power Dissipation
1) ,2)
0D[LPXP Junction 7HPSHUDWXUH
6WRUDJH7HPSHUDWXUH
Thermal Resistance from Junction-to-Ambient (t≤5s)
357
RθJA
Unit
V
W
C
C
o
C/W
Notes
1) Pulse width limited by maximum junction temperature.
2) Surface Mounted on FR4 Board, t v 5 sec.
The above data are for reference only.
DN:T21705A0
http://www.microdiode.com
Rev:2021A1
Page :1
SI2310
MOSFET ELECTRICAL CHARACTERISTICS
Ta =25 ℃ unless otherwise specified
Parameter
Symbol
Test Condition
Min
Typ
Max
Unit
STATIC CHARACTERISTICS
Drain-source breakdown voltage
V (BR)DSS
VGS = 0V, ID = 250µA
Zero gate voltage drain current
IDSS
VDS =60V,VGS = 0V
Gate-body leakage current
IGSS
VGS =±20V, VDS = 0V
Gate threshold voltage (note 3)
VGS(th)
VDS =VGS, ID =250µA
Drain-source on-resistance (note 3)
RDS(on)
60
V
1
µA
±100
nA
2
V
VGS =10V, ID = 3A
10
105
mΩ
VGS =4.5V, ID = 3A
12
125
mΩ
Forward tranconductance (note 3)
gFS
VDS =15V, ID =2A
Diode forward voltage (note 3)
VSD
IS=3A, VGS = 0V
0.5
S
1.4
1.2
V
DYNAMIC CHARACTERISTICS (note 4)
Input Capacitance
Ciss
247
pF
Output Capacitance
Coss
34
pF
Reverse Transfer Capacitance
Crss
19.5
pF
6
ns
VGS=10V,VDD=30V,
15
ns
ID=1.5A,RGEN=1Ω
15
ns
tf
10
ns
Total Gate Charge
Qg
6
nC
Gate-Source Charge
Qgs
1
nC
Gate-Drain Charge
Qgd
1.3
nC
VDS =30V,VGS =0V,f =1MHz
SWITCHING CHARACTERISTICS (note 4)
Turn-on delay time
Turn-on rise time
Turn-off delay time
Turn-off fall time
td(on)
tr
td(off)
VDS =30V,VGS =4.5V,ID =3A
Notes :
1.. Repetitive rating : Pulse width limited by junction temperature.
2.. Surface mounted on FR4 board , t≤10s.
3. Pulse Test : Pulse Width≤300µs, Duty Cycle≤0.5%.
4. Guaranteed by design, not subject to producting.
Rev:2021A1
Page :2
SI2310
Typical Characteristics
Transfer Characteristics
Output Characteristics
15
8
Pulsed
VDS=5.0V
Pulsed
(A)
DRAIN CURRENT
DRAIN CURRENT
VGS=2.5V
5
2
3
4
DRAIN TO SOURCE VOLTAGE
RDS(ON) ——
VDS
Ta=100℃
4
2
VGS=2.0V
Ta=25℃
6
ID
10
ID
(A)
VGS=5V、4V、3.0V
(V)
3
GATE TO SOURCE VOLTAGE
ID
140
RDS(ON)
400
4
VGS
(V)
VGS
Ta=25℃
Ta=25℃
(mΩ)
VGS=4.5V
300
RDS(ON)
100
ON-RESISTANCE
RDS(ON)
(mΩ)
120
ON-RESISTANCE
Pulsed
Pulsed
80
VGS=10V
60
200
ID=3A
100
40
2
4
6
DRAIN CURRENT
8
ID
10
IS —— VSD
10
2
4
6
8
(A)
VGS
10
(V)
Threshold Voltage
1.2
Ta=25℃
Pulsed
(V)
VTH
1
THRESHOLD VOLTAGE
SOURCE CURRENT
IS (A)
1.1
0.1
0.01
1.0
ID=250uA
0.9
0.8
0.7
0.6
1E-3
0.2
0.4
0.6
0.8
SOURCE TO DRAIN VOLTA
VOLTAGE
1.0
SD
(V)
1.2
0.5
25
50
75
JUNCTION TEMPERATURE
Rev:2021A1
100
TJ
125
Page :3
SI2310
Outlitne Drawing
SOT-23 Package Outline Dimensions
e
Suggested Pad Layout
0.037
0.95
0.037
0.95
L
L1
E
E1
Symbol
A
A1
b
c
D
E
E1
e
L
L1
θ
Dimensions In Millimeters
Min
Typ
Max
0.90
1.40
0.10
0.00
0.30
0.50
0.20
0.08
2.80
2.90
3.10
1.20
1.60
2.80
2.25
1.80
1.90
2.00
0.10
0.50
0.4
0°
0.55
10°
Note:
1.
Controlling
dimension:in/millimeters. 2.General
tolerance: ±0.05mm.
3.The pad layout is for reference purposes only.
0.079
2.0
0.035
0.9
0.031
0.8
inches
mm
Rev:2021A1
Page :4
很抱歉,暂时无法提供与“MDD2310”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.32015
- 100+0.27008
- 300+0.24503
- 3000+0.17328
- 6000+0.15830
- 9000+0.15075
