MX27524ES
MX27524ES
    MAXINMICRO(无锡明芯微)
    MSOP-8-EP
    栅极驱动 5A峰值电流双通道低端栅极驱动器4.5V~18V EMSOP8_3X3MM_EP
MX27524ES 数据手册
MX27524 5A Peak Current Dual Channels Low Side Gate Driver GENERAL DESCRIPITION APPLICATIONS The MX27524 is a dual, high current, low side gate driver. Pulse laser for distance test Battery management systems Each of the two outputs is capable of sourcing and sinking DC-DC converters 5A peak current, and has a maximum voltage rating of 20V. Motor controllers Each channel has dual independent enable pins that default Power inverters Synchronous rectifier circuits to ON if not connected. Fast propagation delay times and fast rise and fall times make the MX27524 well suited for GENERAL INFORMATION high frequency applications. Ordering information In addition, the drivers feature matched internal propagation Part Number Description MX27524ES eMSOP8/Exposed Thermal Pad MX27524S SOP8 delays between A and B channels for applications requiring dual gate drivers with critical timing, such as synchronous Package dissipation rating rectifier. Package RθJA(℃/W) FEATURES eMSOP8 60 SOP8 130 ♦Two independent drivers, each capable of sourcing and Absolute maximum ratings sinking 5A Parameter Value VCC DC supply voltage -0.3 to 20V ♦CMOS and TTL compatible inputs ENA/ENB pins -0.3 to VCC+0.3V ♦Independent enable for each channel INA/INB pins -0.3 to VCC+0.3V ♦4.5V to 18V supply voltage range OUTA/OUTB pins(pulse UVLO 1 internal current consumption IDYN can be estimated using the 0 1 >UVLO 0 graphs of the typical performance characteristics to X 0 >UVLO 0 determine the current IDYN drawn from VCC under actual X X
MX27524ES 价格&库存
很抱歉,暂时无法提供与“MX27524ES”相匹配的价格&库存,您可以联系我们找货
