BK13C06-32DP/2-0.35V(800) 数据手册
0.35mm Pitch, 0.6mm Mated Height, 1.9mm Width, Power & Signal Hybrid FPC-to-Board Connector Supporting 5A
BK13C Series
High Current (5A)
Conventional Product
(P=0.35mm)
Signal 64pos.
Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
13.7mm
BK13C
Signal 32pos.+
Power 2pos.
43% Reduced
5.85mm
Reduced
■ Features
1. High Power Supply Capacity and
Space-saving Design
Equipped with two power contacts capable of handling up to
5A, reducing the number of signal contacts to save mounting
space. (Fig.1)
5A
Power Contact
7.85mm
Power lines typically diverted to multiple signal contacts
are concentrated into 2 power contacts (Up to 5A/line)
Fig.1
Full Armored Design
Only Partially Covered
with Metal
No metal
2. Robust Design
Exposed
Housing
Fully armored guides prevent housing damage
due to incorrect mating. (Fig.2)
3. Enhanced PCB Peeling Strength
Both the header and receptacle have 3 soldering areas at each
power contact for greater PCB peeling strength. (Fig.3)
Housing
Covered by
Metal
4. High Contact Reliability
Both power and signal contacts have a two-point contact
design, ensuring high contact reliability.
5. Superior Mating
Wide self-alignment range with metal guides offers enhanced
mating operation.
(0.3mm in pitch direction, 0.22mm in width direction)
Additionally, a clear tactile click generated by the unique
locking contact design secures complete mating.
Back Side of the
Receptacle
6. Halogen-Free
All materials and substances used to produce this product
comply with Halogen-free standards.
*As defined by IEC 61249-2-21
Br : 900ppm max., Cl : 900ppm max.,
Br+Cl : 1,500ppm max.
5A
Power Contact
A'
Fig.2
< A' >
A
Back Side of the
Header
B'
B
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
3 Soldering Areas
on Each Power Contact
2021.05 ①
< B' >
Fig.3
1
BK13C Series ● 0.35mm Pitch, 0.6mm Mated Height, 1.9mm Width, Power & Signal Hybrid FPC-to-Board Connector Supporting 5A
■ Product Specifications
Rated Current : Signal
Contact : 0.3A (Note 1)
Power Contact : 5A
Ratings
Rated Voltage : 30V AC/DC
Items
Operating Humidity Range : 20 to 80%
(Note 4)
Specifications
Storage Temperature : -10 to +60°C
(Note 3)
Storage Humidity Range : 40 to 70%
(Note 3, 4)
Conditions
1. Contact Resistance
Signal Contact : 90mΩ Max.
Power Contact : 30mΩ Max.
Measured at 20mV AC, 1 kHz, 1mA
3. Withstanding Voltage
No flashover or insulation breakdown
100V AC for 1 min.
2. Insulation Resistance
Operating Temperature : -55 to +85°C
(Note 2)
50MΩ Min.
Measured at 100V DC
4. Mating Durability
Contact Resistance : Signal Contact : 90mΩ Max.
5. Vibration
No electrical discontinuity of 1µs or more
6. Shock Resistance
7. Humidity
(Moisture Resistance)
8. Rapid Change of
Temperature
Insulation Resistance : 50MΩ Min.
No damage, crack or looseness of parts
9. Sulphur Dioxide
10 mating cycles
Frequency : 10 to 55Hz,
single amplitude 0.75mm in 3 axis directions for
5 min., 10 cycles
Acceleration : 490m/s2, duration of pulse :
11ms at 3 times for 3 directions.
96 hours at temperature of 40±2°C and
humidity range from 90 to 95%
-55℃ for 30 min. → +85℃ for 30 min. for 5 Cycles.
(Stabilizing Time In Chamber : Within 2 to 3 min.)
Exposed in 25 PPM for 96h at 25℃, 75±5%RH.
(Test standard : JIS C 60068)
Note 1 : The total current capacity for connectors with 40 or more signal contacts is 12A for all contacts.(Signal contact only)
Note 2 : Includes temperature rise caused by current flow.
Note 3 : The term “storage” refers to long-term-storage of unused items before they are mounted on the PCB.
Operating temperature / humidity range applies to the product in a temporary storage state such as non-powered after
mounting on the PCB, during transportation, etc.
Note 4 : Range identified without condensation.
■ Material / Finish
Product
Part
Material
Finish
Signal Contact
Copper Alloy
Gold Plated over Nickel Underplating
Insulator
Header,
Receptacle
LCP
Power Contact
Black
Copper Alloy
■ Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalogue when placing orders.
Header / Receptacle
BK 13C 06 - ## DP / 2 - 0.35 V (8##)
1
2
1 Series Name:BK
3
4
2 Series No. : 13C
3 Mated Height : 0.6mm
4
Number of Signal Contacts :
10, 32, 40, 50, 60pos.
5 Connector Type
DP:Double-row Header
DS:Double-row Receptacle
2
5
6
7
8
9
6 Number of Power Contacts:2pos.
7 Contact Pitch : 0.35mm
8 Terminal Type
V : SMT Vertical Mounting Type
9 Specifications
(800) : Standard,
Embossed tape packaging (20,000pcs/reel)
(895) : Embossed tape packaging (1,000pcs/reel)
Remarks
UL94V-0
■ Header
Unit : mm
Part No.
HRS No.
No. of Pos.
CL0480-0663-0-##
32
BK13C06-10DP/2-0.35V(8##)
CL0480-0719-0-##
BK13C06-40DP/2-0.35V(8##)
CL0480-0665-0-##
BK13C06-32DP/2-0.35V(8##)
BK13C06-50DP/2-0.35V(8##)
BK13C06-60DP/2-0.35V(8##)
CL0480-0725-0-##
CL0480-0727-0-##
Note : This connector has no polarity.
A
B
C
D
10
3.05
1.40
1.6
2.365
40
8.30
6.65
1.8
7.615
50
60
6.90
10.05
11.80
5.25
8.40
10.15
1.8
1.8
1.8
6.215
9.365
Purchase Unit
## : 00
## : 95
20,000pcs
per reel
1,000pcs
per reel
11.115
3
Recommended PCB Layout
Recommended Metal Mask Dimensions (Mask Thickness : 0.08mm)
Part No.
HRS No.
No. of Pos.
CL0480-0663-0-##
32
CL0480-0719-0-##
CL0480-0665-0-##
CL0480-0725-0-##
CL0480-0727-0-##
Note 1 : This connector has no polarity.
4
B
E
F
G
H
Unit : mm
I
10
1.40
2.82
2.26
1.8
1.06
0.23
40
6.65
8.07
7.51
2.1
1.26
0.28
50
60
5.25
8.40
10.15
6.67
9.82
11.57
6.11
9.26
11.01
2.1
2.1
2.1
1.26
1.26
1.26
0.28
0.28
0.28
■ Receptacle
Unit : mm
Part No.
HRS No.
No. of Pos.
CL0480-0664-0-##
32
BK13C06-10DS/2-0.35V(8##) (Note1)
CL0480-0720-0-##
BK13C06-40DS/2-0.35V(8##)
CL0480-0666-0-##
BK13C06-32DS/2-0.35V(8##)
BK13C06-50DS/2-0.35V(8##)
BK13C06-60DS/2-0.35V(8##)
CL0480-0726-0-##
CL0480-0728-0-##
A
B
C
10
4.00
1.40
2.32
40
9.25
6.65
7.57
50
60
7.85
11.00
12.75
5.25
8.40
10.15
Note 1 : BK13C06-10DS/2-0.35V(8##) has a metal reinforcement in the center of the product.
Note 2 : This connector has no polarity.
6.17
9.32
Purchase Unit
## : 00
## : 95
20,000pcs 1,000pcs
per reel
per reel
11.07
5
Part No.
HRS No.
No. of Pos.
CL0480-0664-0-##
32
BK13C06-10DS/2-0.35V(8##) (Note 1)
CL0480-0720-0-##
CL0480-0666-0-##
CL0480-0726-0-##
CL0480-0728-0-##
10
1.40
40
6.65
50
60
6
B
5.25
8.40
10.15
D
Unit : mm
E
4.245
2.12
9.495
7.37
8.095
11.245
12.995
5.97
9.12
10.87
Embossed Tape Dimensions
Header
Embossed Carrier Tape Dimensions
Reel Dimensions
Part No.
HRS No.
No. of Pos.
CL0480-0663-0-00
32
BK13C06-10DP/2-0.35V(800)
CL0480-0719-0-00
BK13C06-40DP/2-0.35V(800)
CL0480-0665-0-00
BK13C06-50DP/2-0.35V(800)
BK13C06-60DP/2-0.35V(800)
Part No.
CL0480-0725-0-00
CL0480-0727-0-00
24.0
50
60
32
CL0480-0665-0-95
BK13C06-60DP/2-0.35V(895)
40
CL0480-0663-0-95
BK13C06-40DP/2-0.35V(895)
BK13C06-50DP/2-0.35V(895)
16.0
No. of Pos.
CL0480-0719-0-95
BK13C06-32DP/2-0.35V(895)
10
HRS No.
BK13C06-10DP/2-0.35V(895)
CL0480-0725-0-95
CL0480-0727-0-95
A
11.5
24.0
11.5
24.0
A
16.0
40
24.0
60
7.5
24.0
10
50
B
11.5
11.5
B
D
E
H
I
3.16
17.5
21.5
380
80
8.41
25.5
29.5
380
80
7.01
10.16
11.91
C
25.5
25.5
25.5
D
29.5
29.5
29.5
E
380
380
380
H
80
80
80
I
7.5
3.16
17.5
21.5
180
60
11.5
8.41
25.5
29.5
180
60
24.0
11.5
24.0
11.5
24.0
C
Unit : mm
11.5
7.01
10.16
11.91
25.5
25.5
25.5
29.5
29.5
29.5
180
180
180
60
60
60
7
Receptacle
Reel Dimensions
Part No.
No. of Pos.
CL0480-0664-0-00
32
BK13C06-10DS/2-0.35V(800)
CL0480-0720-0-00
BK13C06-40DS/2-0.35V(800)
CL0480-0666-0-00
BK13C06-32DS/2-0.35V(800)
BK13C06-50DS/2-0.35V(800)
BK13C06-60DS/2-0.35V(800)
Part No.
CL0480-0726-0-00
CL0480-0728-0-00
24.0
50
60
32
CL0480-0666-0-95
BK13C06-60DS/2-0.35V(895)
40
CL0480-0664-0-95
BK13C06-40DS/2-0.35V(895)
BK13C06-50DS/2-0.35V(895)
16.0
No. of Pos.
CL0480-0720-0-95
CL0480-0726-0-95
CL0480-0728-0-95
A
10
HRS No.
BK13C06-10DS/2-0.35V(895)
BK13C06-32DS/2-0.35V(895)
8
HRS No.
11.5
24.0
11.5
24.0
A
16.0
40
24.0
60
7.5
24.0
10
50
B
11.5
11.5
B
D
E
H
I
4.10
17.5
21.5
380
80
9.35
25.5
29.5
380
80
7.95
11.10
12.85
C
25.5
25.5
25.5
D
29.5
29.5
29.5
E
380
380
380
H
80
80
80
I
7.5
4.10
17.5
21.5
180
60
11.5
9.35
25.5
29.5
180
60
24.0
11.5
24.0
11.5
24.0
C
Unit : mm
11.5
7.95
11.10
12.85
25.5
25.5
25.5
29.5
29.5
29.5
180
180
180
60
60
60
Precautions
1. Recommended Solder
Temperature Profile
[Conditions]
1. Peak Temperature
2. Heated Section
3. Preheated Section
4. Number of Reflow Cycles
2. Recommended Manual
Soldering Conditions
3. Recommended Screen
Thickness and Open Area
Ratio to PCB Pattern Area
4. PCB Warpage
5. Cleaning
6. Notes
: Maximum of 250℃
: 220℃ Min., within 60 seconds
: 150 to 180℃, 90 to 120 seconds
: Maximum of 2 cycles
Note 1 : The temperature is the surface temperature of the PCB in the vicinity of the
connector lead part.
Note 2 : When using nitrogen reflow process, please mount the product with an oxygen
concentration at a minimum of 1,000[ppm].
Please contact a Hirose representative if the concentration is below 1,000[ppm]
Soldering iron temperature : 340±10℃
Soldering time : within 3 seconds
Thickness : 0.08mm
Aperture ratio : 100% on the header side, 100% on the receptacle side
A maximum of 0.02mm at the center of the connector with reference to both ends of the
connector.
Not recommended. If this product is cleaned, please evaluate the performance before using it.
Cleaning may cause a change in the mating/unmating properties as well as environmental
resistance.
Insertion
or removal prior to board mounting may result in contact deformation.
Avoid supporting the PCB only with the connectors. Support it by other means such as bolts,
screws, posts, etc.
■ Avoid excessive prying mating/unmating as it may result in damage.
■ During manual soldering, do not apply flux which will cause solder wicking.
■ This product may have slight color differences due to production lot variability, but this does
not have any effect on the performance.
■ Please refer to the next page for mating/unmating precautions.
■ It is advised to secure the mated connectors to the board with housings and cushioning
materials because the product can disengage if dropped, by other impact or by FPC routing.
■ Caution! Do not use the connector outside of the specifications.
(i.e., rated current, rated voltage, PCB design and operating environment, etc.).
Such usage could lead to material outgassing, ignition, or short-circuit, etc.
■ Please use a proper stiffener on the back of the FPC. We recommend using a glass
epoxy material with a minimum thickness of 0.3mm or a stainless steel material with
a minimum of thickness of 0.2mm.
9
Connector Mating Precautions
Header
Receptacle
Metal cover guide
(Outside)
Metal cover guide
(Inside)
1) Locate the guides and align the
connectors to the appropriate
mating position.
The connector has guide ribs on the
receptacle for proper mating
alignment.
Align the connectors with this guide.
(Please align the connectors)
2) When
the connector comes to the
appropriate position, the connector
will lower into place as indicated by
the change in mated height.
3) When
the connectors has lowered into
place, the connector pair will be
parallel to each other and cannot be
moved back and forth or left and right.
Please complete mating by applying
force in this condition.
4) Please
make sure connectors are
mated completely.
If one side is floating or the connectors
are mated at a slant, please unmate
and then repeat the mating procedure
following the steps described.
10
Connector Un-mating Precautions
1) It is recommended to remove the
connector by pulling perpendicular
to the connector mounted surface.
However, for unmating FPC-to-board
connectors, this becomes more
difficult as the pin count increases
and with thinner FPC.
2) If
is difficult to remove the
connector parallel to the mounting
surface, remove it diagonally towards
the pitch direction.
Do not remove the connector towards
the width direction as it may put a
large amount of stress on the contacts.
3) O
ther cautions
If the FPC is not rigid enough, there is a
possibility of solder peeling or
connector damage.
Please conduct repeated testing on
the FPC planned to be used several
times in an early stage build.
Please do not remove the FPC by
holding one corner and pulling at a
diagonal as this will put a great
11
While taking in consideration
Specifications mentioned in this catalog are reference values.
When considering to order or use this product, please confirm the "Drawing" and "Product Specifications" sheets.
Use an appropriate cable when using the connector in combination with cables.
If considering usage of a non-specified cable, please contact your sales representative.
If assembly process is done by jigs & tools which are not identified by Hirose assurance will not be given.
If considering usage for below mentioned applications, please contact your sales representative.
In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public infrastructure,
aerospace/ defense etc. Hirose must review before assurance of reliability can be given.
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
https://www.hirose.com/
12
The contents of this catalog are current as of date of 05/2021. Contents are subject to change without notice for the purpose of improvements.
