NDFH024-2442SA
NDFH024-2442SA
    HUAYING(德清华莹)
    SMD,1.1x0.9mm
    SAW滤波器 2.5dB FILTER_1.1X0.9MM_SM
NDFH024-2442SA 数据手册
DEQING HUAYING ELECTRONICS CO.,LTD. APPROVAL SHEET SAW BANDPASS FILTER PART NO.: NDFH024-2442SA Product Type: Customer: SAW Filter Part NO.: Customer Part NO.: NDFH024-2442SA Ver. Ctrl.: Issued Date: SFH024-2442SA-161018-v1.0 PREPARED BY Part No. Pages Data Revision : : : : CHECKED BY APPROVED BY NDFH024-2442SA 8 2016-10-18 SFH024-2442SA-161018-v1.0 Add (Deqing): 188 Zhiyuan North Rd.Wukang Town Deqing County Zhejiang Province 313200,P.R.China Phone : +86-572-8281127 Fax : +86-572-8281298 E-mail : sales@dqhuaying.com Website : http://www.dqhuaying.com NDFH024-2442SA Unbalanced Revision Date Description SFH024-2442SA-161018-v1.0 2016-10-18 First draft -1- 2442 MHz Remark NDFH024-2442SA Unbalanced 2442 MHz Features SAW filter for WIFI. 1 High stability and reliability with good performance. 2 Narrow and sharp pass band characteristics. RoHS compatible. 3 Low insertion loss and deep stop band attenuation for interference. 4 Low – loss SAW filter for WIFI transmission. 5 Package size 1.1mm*0.9mm Package Dimensions Ceramic Package: Unit:mm Pin Configuration 1 Input 4 Output 2,3,5 Ground Marking Top View, Laser Marking “aF”: Part number ” 1” Terminal1 “.” Dot marking, indicates input 1 The first “*”: Month Code (The code shown below varies in a 4-year-cycle) Code 2016/2020 2017/2021 2018/2022 2019/2023 1 n A N a 2 p B P b 3 q C Q c 4 r D R d 5 s E S e 6 t F T f 7 u G U g 8 v H V h 9 w J W i 10 x K X j 4th 5th 6th 7th 8th 9th 11 y L Y k 12 z M Z m The second “*”: Date Code data code data code data code 1st 2nd 3rd 10th A B C D E F G H J K 11th 12th 13th 14th 15th 16th 17th 18th 19th 20th L M N P Q R S T U V 21st 22nd 23rd 24th 25th 26th 27th 28th 29th 30th 31st W X Y Z a b d e f g h -2- NDFH024-2442SA Unbalanced 2442 MHz Maximum Ratings Rating Value Unit VDC 10 V RF Power (in BW) P 29 dBm Operating Temperature Range TA -30 ~ +85 °C Storage Temperature Range Tstg -40 ~ +85 °C ESD Voltage (HB) VESD >150 V Moisture Sensitivity Levels MSL DC Voltage (between any Terminals) 2A Electrical Characteristics: Item Minimum Typical Maximum Unit 2403 ….2471 MHz 1.2 2.2 dB 2458 …. 2476 MHz 1.2 1.8 dB 2463 …. 2481 MHz 1.6 2.5 dB 0.8 2.0 dB 1.2 2.0 IL Insertion Loss Pr Passband Ripple 2403 …. 2481 MHz Vswr VSWR 2401 …. 2483 MHz α Absolute Attenuation 800 …. 2000.00 MHz 25 27 dB 2000.00 …. 2300.00 MHz 25 27 dB 2300.00 …. 2370.00 MHz 27 30 dB 2370.00 …. 2380.00 MHz 18 30 dB 2500.00 …. 2502.00 MHz 7 42 dB 2502.00 …. 2570.00 MHz 12 41 dB 2570.00 …. 2620.00 MHz 29 34 dB 2620.00 …. 2690.00MHz 26 31 dB 2690.00 …. 4800.00 MHz 25 29 dB 4800.00 ….5825.00 MHz 27 35 dB 7200.00 ….7500.00 MHz 30 42 dB 50Ω//4.3nH Input / Output Impedance (Nominal) RoHS Compliant Electrostatic Sensitive Device Test Circuit 50Ω L=4.3 Nh -3- NDFH024-2442SA Unbalanced Typical Frequency Response S21 S11 Group Dealy -4- 2442 MHz NDFH024-2442SA Unbalanced Far side -5- 2442 MHz NDFH024-2442SA Unbalanced 2442 MHz Stability Characteristics Item No. Test Item Preconditioning STD Reference JESD22-A113 per lot Test Conditions 1) Temperature Cycling, 5 cycles -40℃ to 85℃ 2) Bake, 24 hrs @125±5℃; 3) Reflow, 3 reflow cycles 4) Drying, Room temperature 177 ambient -40 ℃ / +85 ℃ ,40min dwell, 4 minutes, 4X in each orientation, 20g peak acceleration 10 Mechanical Shock JESD22-B104 Y1 plane only, 5 pulses, 0.5 ms duration, 1500 g peak acceleration Requirements: The SAW filer shall remain within the electrical specifications after tests. -6- NDFH024-2442SA Unbalanced 2442 MHz Packing Information Carrier Tape U Reel Dimensions U U Outer Packing Type Quantity Dimension Carton Box Ⅰ 10000 200×200×100 Carton Box Ⅱ 20000 200×200×200 Description anti-static plastic bag & carton box 1 reel / bag 5 bags / box (50000 pcs) 10 bags / box (100000 pcs) Unit: mm Weight 0.85 1.80 Unit: kg -7- NDFH024-2442SA Unbalanced 2442 MHz Remarks  SAW devices should not be used in any type of fluid such as water, oil, organic solvent, etc.  Be certain not to apply voltage exceeding the rated voltage of components.  Do not operate outside the recommended operating temperature range of components.  Sudden change of temperature shall be avoided, deterioration of the characteristics can occur.  Be careful of soldering temperature and duration of components when soldering.  Do not place soldering iron on the body of components.  Be careful not to subject the terminals or leads of components to excessive force.  SAW devices are electrostatic sensitive. Please avoid static voltage during operation and storage.  Ultrasonic cleaning shall be avoided. Ultrasonic vibration may cause destruction of components. Recommended Soldering Profile C HUAYING 2016. All Rights Reserved. ○ A 1. 2. 3. 4. The specifications of this device are subject to change or obsolescence without notice. Typically, equipment utilizing this device requires emissions testing and government approval, which is the responsibility of the equipment manufacturer. Our liability is only assumed for the Surface Acoustic Wave (SAW) component(s) per se, not for applications, processes and circuits implemented within components or assemblies. For questions on technology, prices and delivery, please contact our sales offices or e-mail sales@dqhuaying.com. -8-
NDFH024-2442SA 价格&库存
很抱歉,暂时无法提供与“NDFH024-2442SA”相匹配的价格&库存,您可以联系我们找货
