DS1013-06SSIB1-B-0
DS1013-06SSIB1-B-0
    CONNFLY(晨翔)
    CONN_15.22X9.1MM_TM
    IDC连接器 6Pin 2.54mm 2排 直插 黑色
DS1013-06SSIB1-B-0 数据手册
2.54 C 2.54 Ø1 .02 NOTES: 1. Electrical characteristics: 1.1 Contact resistance: 20mΩ Max. Initial. 1.2 Dielectric withstanding voltage: 500V AC(rms) for 1 minute. 1.3 Insulation resistance: 1000MΩ Min. 1.4 Current rating:3A. Recommend PCB Layout(Tolerance:±0.05) 2.9 2.54 2. Environment characteristics: Temperature range: -40°C~+105°C. 3. Product number code: E H 0.30 □0.64±0.05 3.0 2.54 13.8 2.54 8.8 Housing material 0: PBT UL94 V-0 9: PA-9T Plating level 3A: Level B: Level B XXP 9.1 9.1 V/T type R/A type DIM. H type(For elevator only) 1: 7.50 2: 9.50 9.1 Elevator type DIM. E type(For V/T only) 1: 3.10 2: 8.00 C±0.25 2.54±0.1 Dimension Position A B C 06 15.22 13.02 5.08 08 17.76 15.56 7.62 N: Level N Housing color U: Blue B: Black A: Gray W: White Contact plating Si: Full gold flash 10 20.30 18.10 10.16 B±0.2 12 22.84 20.64 12.70 30 45.70 43.50 35.56 A±0.3 14 25.38 23.18 15.24 34 50.78 48.58 40.64 16 27.92 25.72 17.78 40 58.40 56.20 48.26 20 33.00 30.80 22.86 50 71.10 68.90 60.96 24 38.08 35.88 27.94 60 83.80 81.60 73.66 26 40.62 38.42 30.48 64 88.88 86.68 78.74 Mounting type S: V/T type R: R/A type E: Elevator type No.of contacts 06 08 10 12 14 16 20 24 26 30 34 40 50 60 64 晨翔电子有限公司 (Series Image-Reference Only) CONNFLY ELECTRONIC CO. LTD C±0.2 □0.64±0.05 12.0 NOTES: 6.0 2.54±0.1 2.54±0.1 B±0.2 2. Environment characteristics: Temperature range: -40°C~+105°C. 8.8 10.2 1.5 A±0.3 1.1 Contact resistance: 20mΩ Max. Initial. 1.2 Dielectric withstanding voltage: 500V AC(rms) for 1 minute. 1.3 Insulation resistance: 1000MΩ Min. 1.4 Current rating:3A. 9.5 10.4 8.8 1. Electrical characteristics: 3. Product number code: Plating level 3A: Level 3A B: Level B Dimension XXP C 1.30 5.00 11.20 2.54 Recommend PCB Layout Tolerance:±0.05 Position A B C 06 15.22 13.02 5.08 08 17.76 15.56 7.62 10 20.30 18.10 10.16 12 22.84 20.64 12.70 Pick up support S: W/ Pick up 14 25.38 23.18 15.24 X: W/O Pick up 16 27.92 25.72 17.78 20 33.00 30.80 22.86 Contact plating Si: Full gold flash 24 38.08 35.88 27.94 26 40.62 38.42 30.48 30 45.70 43.50 35.56 34 50.78 48.58 40.64 40 58.40 56.20 48.26 50 71.10 68.90 60.96 60 83.80 81.60 73.66 64 88.88 86.68 78.74 Packing type A: Tube R: Tape on reel Mounting type M: SMT type No.of contacts 06 08 10 12 14 16 20 24 26 30 34 40 50 60 64 晨翔电子有限公司 (Series Image-Reference Only) CONNFLY ELECTRONIC CO. LTD
DS1013-06SSIB1-B-0 价格&库存
很抱歉,暂时无法提供与“DS1013-06SSIB1-B-0”相匹配的价格&库存,您可以联系我们找货
DS1013-06SSiB1-B-0
  • 5+0.57057
  • 50+0.45144
  • 150+0.39194
  • 360+0.34733
  • 2520+0.31169
  • 5040+0.29376
库存:2055
