FX18-40P-0.8SV
FX18-40P-0.8SV
    HRS(广濑)
    SMD,P=0.8mm
    板对板连接器 立贴 针脚数:40Pin 间距:0.8mm 排数:2
FX18-40P-0.8SV 数据手册
High Speed Transmission, 0.8 mm Pitch Connectors for PCB Connections FX18 Series ■Features The FX18 series utilizes guideposts on both sides of the connector. These guide posts double as multi-functional contacts as well as an aligning structure. 1) Enhanced ground connections between PCB’s 2) Capable of being used as power source lines (3 A/line) 3) A sequenced 3-level structure that contains signal contacts ● Effective mating length of 2 mm (Signal contact) This connector utilizes a 2.0 mm effective mating length for its signal contacts and provides a sufficient amount of margin for its mating sequence. (MF contact A: 2.5 mm/ MF contact B: 1.5 mm) H^\cVa 8dciVXi ● Resistant to excess mating force The structure is equipped with dip contacts that help prevent damage caused by excessive mating forces and provides stability to both sides of the connector. B;8dciVXi6 ● Simplified mating with large guides Generous lead-in shape simplifies the mating operation. (lead in opening amount: ± 1 mm). The guides also prevent inverse mating. B;8dciVXi7 ■High speed transmission characteristics 60 ● ICR  (Insertion-loss-to-Crosstalk-Ratio) 40 Impedance ICR 110 50 ● Differential impedance data Z (Ohms) 105 ICR (dB) Enough margin with regulated ICR data of IEEE802.3ap 10 Gbps transmission standard. 30 100 20 95 10 With a strict time of Tr = 35ps, its contact structure matches 100 Ohm ±10% differential impedance. 0 ICR IEEE spec 0 2 Inner row 4 6 Frequency (GHz) 8 90 10 0 0.2 0.4 0.6 Time (ns) 0.8 1 ■Mating variation diagram Parallel connection type (3 piece) FX18-**P-0.8SV** Coplanar connection type Right angle connection type Parallel connection type (2 piece) FX18-**PS-0.8H15 10∼30 7.8 FX18-**P-0.8SH FX18-**S-0.8SH FX18-**P-0.8SV** 35∼45 15.15 10.85 20.3 9.5 Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ● 0.8 mm pitch ● Connection type: Coplanar /right angle / parallel (height: 10 to 45 mm) ● No of pos.: 40, 60, 80, 100, 120, 140 ● MF (multi-functional) contact FX18-**S-0.8SV** FX18-**P-0.8SV FX18-**S-0.8SH In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. FX18-**S-0.8SV** 2014.1 ② 1 FX18 Series●High Speed Transmission, 0.8 mm Pitch Connectors for PCB Connections ■Product Specifications Rated Current 0.5 A (signal contacts ) (Note 3) 3.0 A (MF contact ) AC100V Ratings Rated Voltage Item 1. Contact Resistance 2. Insulation Resistance 3. Withstanding Voltage 4. Durability Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 5. Vibration Resistance 6. Shock Resistance 7. Humidity Resistance 8. Temperature Cycles Operating Temperature Range : ‒55∼85℃ (Note 1) Storage Temperature Range : -10∼60℃ (Note 2) Specifications Conditions Maximum of 90 mø Measured with 100 mA Minimum of 1,000 Mø Measured with DC 250 V No flashover or breakdown Electrification for 1 minutes at AC 300 V Contact Resistance: Maximum of 100 mø 500 mating cycles No electrical discontinuity of 1 µ or greater No electrical discontinuity of 1 µ or greater Contact Resistance:Maximum of 100 mø Insulation Resistance: Minimum of 1,000 Mø Contact Resistance: Maximum of 100 mø Insulation Resistance: Minimum of 1,000 Mø 10 cycles each for the three axial directions (1 cycle = 5 minutes) at frequency 10-55 Hz, half amplitude 0.75 mm 2 Acceleration: 490 m/s , Retention time: 11 ms, Semisinusoidal 3 axes both directions 3 times each. 96 hours at temperature: 40ç and humidity: 90~95% Temperature -55 ç ➞ 85ç Time 30 ➞ 30 minutes 5 cycles (Note 1) Includes the temperature rise of power lines (Note 2) The term “storage” refers to the long-term storage condition of unused products before PCB mounting. (Note 3) Rated current is per contact. ■Materials ●Right angle receptacle/right angle header/straight header Component Insulator Materials Polyamide resin Signal Contact Phosphorous bronze MF Contact Phosphorous bronze Color/Finish Black Contact part: Gold plating Mounting part: Gold plating Contact part: Gold plating Mounting part: Pure tin plating Specifications UL94V-0 ----------------------------- ●Straight header 10 mm height /Straight receptacle 15 mm and 20 mm heights Component Insulator Materials Polyamide resin Signal Contact Phosphorous bronze MF Contact Copper alloy Color/Finish Black Contact part: Gold plating Mounting part: Gold plating Contact part: Gold plating Mounting part: Pure tin plating Specifications UL94V-0 Color/Finish Black Contact part: Gold plating Mounting part: Gold plating Contact part: Gold plating Mounting part: Pure tin plating Specifications UL94V-0 Color/Finish Black Contact part: Gold plating Contact part: Gold plating Specifications UL94V-0 ----------------------------- ----------------------------- ●Straight receptacle 10 mm height Component Insulator Materials Polyamide resin Signal Contact Copper alloy MF Contact Copper alloy ----------------------------- ●Interposer 15 mm height Component Insulator Signal Contact MF Contact 2 Materials Polyamide resin/PBT resin Copper alloy Copper alloy FX18 Series●High Speed Transmission, 0.8 mm Pitch Connectors for PCB Connections ■Product Number Structure Refer to the charts below for determining specific part number characteristics. Please select connectors listed in this catalog when placing orders and be sure to check the latest delivery specifications at the time of ordering the product. ●Right angle receptacle ●Straight receptacle FX18 - 60 S - 0.8 SH ❶ ❷ ❸ ❹ FX18 - 60 S - 0.8 SV 15 ❺ ❶ ●Right angle header ❷ ❸ ❹ ❶ Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FX18 - 60 P - 0.8 SV 10 ❷ ❸ ❹ ❺ ❻ FX18 - 60 PS - 0.8 H 15 ❺ ●Straight header ❶ ❸ ● Interposer FX18 - 60 P - 0.8 SH ❶ ❷ ❹ ❺ ❻ ❷ ❶ Series Name ❷ No. of Contacts ❸ Connector Type ❹ Contact Pitch ❺ Product Shape ❸ ❹ ❺ ❻ : FX18 S: Receptacle type P: Header type : 0.8 mm SH: Right angle type SV: Straight type H: Interposer type ❻ Stacking Height ■FX18 Series Mating Diagram ORight angle receptacle ORight angle header 【 FX18-**S-0.8SH 】 【 FX18-**P-0.8SH 】 Coplanar connection OStraight receptacle OStraight header 【 FX18-**S-0.8SV10 】 Right angle connection 【 FX18-**P-0.8SV 】 Parallel connection 【 FX18-**S-0.8SV15 】 (2 piece) 【 FX18-**P-0.8SV10 】 【 FX18-**S-0.8SV20 】 Parallel connection (3 piece) 【 FX18-**PS-0.8H15 】 Fixed mating side Interface mating/unmating side 3 FX18 Series●High Speed Transmission, 0.8 mm Pitch Connectors for PCB Connections ■2 piece Parallel Connection Type Straight header FX18-**P-0.8SV** Stack height variation table (2 piece) Straight receptacle FX18-**S-0.8SV** FX18-**P-0.8SV FX18-**P-0.8SV10 FX18-**S-0.8SV10 10mm 20mm FX18-**S-0.8SV15 15mm 25mm FX18-**S-0.8SV20 20mm 30mm ■3 piece parallel connection type Straight header FX18-**P-0.8SV** Stack height variation table (3 pieces) Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Interface mating/ unmating side FX18-**PS-0.8H15 Interposer FX18-**PS-0.8H15 Fixed mating side FX18-**P-0.8SV FX18-**P-0.8SV10 FX18-**S-0.8SV10 25mm 35mm FX18-**S-0.8SV15 30mm 40mm FX18-**S-0.8SV20 35mm 45mm Straight receptacle FX18-**S-0.8SV** BSI Data ●Contact assignment We recommend the following contact configuration to match 100 ohm differential impedance and reduce crosstalk. Contact assignment (40 pos.) Coplanar connection type showing signal contact shape Contact No.1 Contact No. 20 Contact No.21 Contact No. 40 Outer row Inner row Signal pin Diff pair Inner row Ground pin Outer row ● Impedance Satisfies 100 ø ±10% at Tr = 35 ps Outer row 110 105 105 Z (Ohms) Z (Ohms) Inner row 110 100 95 100 95 Outer row 90 4 4 0 0.2 0.4 0.6 Time (ns) 0.8 Inner row 1 90 0 0.2 0.4 0.6 Time (ns) 0.8 1 FX18 Series●High Speed Transmission, 0.8 mm Pitch Connectors for PCB Connections ●Insertion loss Maintains a good insertion loss of up to 10 GHz Outer row Inner row 0 -0.5 -1 -1 S (dB) -0.5 -1.5 -1.5 -2 -2 -2.5 -2.5 Outer row -3 0 2 4 6 Frequency (GHz) 8 Inner row -3 10 0 2 4 6 Frequency (GHz) 8 10 ● Return loss Enough margin to satisfy IEEE802.3ap 10 Gbps transmission protocol. Outer row Inner row 0 -10 -10 -20 -20 RL (dB) RL (dB) 0 -30 -40 -30 -40 RL IEEE Spec -50 0 5 10 Frequency (GHz) 15 RL IEEE Spec -50 20 0 5 10 Frequency (GHz) 15 20 ●NEXT Lower crosstalk up to 10 GHz Outer row 0 Inner row 0 S12 S12 -10 -10 -20 -20 S (dB) S (dB) Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. S (dB) 0 -30 -30 -40 -40 -50 -50 -60 0 2 4 6 Frequency (GHz) 8 10 -60 0 2 4 6 Frequency (GHz) 8 10 5 FX18 Series●High Speed Transmission, 0.8 mm Pitch Connectors for PCB Connections Contact assignment (40 pos.) Contact assignment (40 pos.) 8dciVXi Cd#'% 8dciVXi Cd#& Outer row 8dciVXi Cd#'% 8dciVXi Cd#& Outer row Inner row Inner row 8dciVXi Cd#)% 8dciVXi Cd#'& 8dciVXi Cd#)% 8dciVXi Cd#'& Signal pin Signal pin Diff pair Diff pair Ground pin Ground pin Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Fig 1. Fig 2. ●FEXT Lower crosstalk up to 10 GHz Outer row 0 Inner row 0 S14 -10 -10 -20 -20 S (dB) S (dB) S14 -30 -30 -40 -40 -50 -50 -60 0 2 4 6 Frequency (GHz) 8 -60 10 0 2 4 6 Frequency (GHz) 8 10 8 10 ●ICR-FEXT Enough margin to satisfy IEEE802.3ap 10 Gbps transmission protocol. Outer row 50 50 40 40 30 20 6 30 20 10 0 Inner row 60 ICR (dB) ICR (dB) 60 10 ICR IEEE spec 0 2 4 6 Frequency (GHz) 8 10 0 ICR IEEE spec 0 2 4 6 Frequency (GHz) FX18 Series●High Speed Transmission, 0.8 mm Pitch Connectors for PCB Connections 6¤%#' E2%#-¤%#&* ●Right angle receptacle %#'*¤%#& (#+¤%#&* *#&¤%#' 7¤%#' 8¤%#&* Cd#; &&#.¤%#' Cd#= 9¤%#'* :¤%#'* &#*¤%#&* &#'¤%#&* &#'¤%#&* +#%*¤%#'* )#,*¤%#'* -#*¤%#'* Unit: mm Part No. ★ FX18-40S-0.8SH ★ FX18-60S-0.8SH ★ FX18-80S-0.8SH ★ FX18-100S-0.8SH ★ FX18-120S-0.8SH ★ FX18-140S-0.8SH HRS No. A B C D E F G H (No. of contacts) CL579-0009-4 15.2 27.9 25.0 18.4 24.65 20 21 40 CL579-0010-3 23.2 35.9 33.0 26.4 32.65 30 31 60 CL579-0011-6 31.2 43.9 41.0 34.4 40.65 40 41 80 CL579-0012-9 39.2 51.9 49.0 42.4 48.65 50 51 100 CL579-0013-1 47.2 59.9 57.0 50.4 56.65 60 61 120 CL579-0014-4 55.2 67.9 65.0 58.4 64.65 70 71 140 ★Indicates products that are currently available. Other contact counts may be under development, contact your local rep for details %#'*¤%#& 7¤%#' *#)¤%#' -#)¤%#' .#*¤%#&* 8¤%#&* Cd#& Cd#; *#&¤%#' 6¤%#%' E2%#-¤%#&* ●Right angle header (#**¤%#&* Cd#= Cd#< %#&* &#(* À%#'* Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Cd#< %#&* &#(* À%#'* .#*¤%#&* Cd#& 9¤%#'*  :¤%#'* &#'¤%#&* &#*¤%#&* '#**¤%#'* &#'¤%#&* )#,*¤%#'* *¤%#'* Unit: mm Part No. ★ FX18-40P-0.8SH ★ FX18-60P-0.8SH ★ FX18-80P-0.8SH ★ FX18-100P-0.8SH ★ FX18-120P-0.8SH ★ FX18-140P-0.8SH HRS No. A B C D E F G H (No. of contacts) CL579-0002-5 15.2 27.9 24.95 18.4 24.65 20 21 40 CL579-0003-8 23.2 35.9 32.95 26.4 32.65 30 31 60 CL579-0004-0 31.2 43.9 40.95 34.4 40.65 40 41 80 CL579-0005-3 39.2 51.9 48.95 42.4 48.65 50 51 100 CL579-0006-6 47.2 59.9 56.95 50.4 56.65 60 61 120 CL579-0007-9 55.2 67.9 64.95 58.4 64.65 70 71 140 ★Indicates products that are currently available. Other contact counts may be under development, contact your local rep for details 7 FX18 Series●High Speed Transmission, 0.8 mm Pitch Connectors for PCB Connections ●Straight header 6¤%#' 7¤%#' E2%#-¤%#&* %#'*¤%#& Cd#= ,#-¤%#' Cd#< Cd#& Cd#; 8¤%#&* %#&* &#(* À %#'* -#+* (#**¤%#&* Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 9¤%#'* :¤%#'* &¤%#&* &#'¤%#&* *#&¤%#' Unit: mm Part No. ★ FX18-40P-0.8SV ★ FX18-60P-0.8SV ★ FX18-80P-0.8SV ★ FX18-100P-0.8SV ★ FX18-120P-0.8SV ★ FX18-140P-0.8SV HRS No. A B C D E F G H (No of contacts) CL579-0016-0 27.9 15.2 24.95 18.4 24.65 20 21 40 CL579-0017-2 35.9 23.2 32.95 26.4 32.65 30 31 60 CL579-0018-5 43.9 31.2 40.95 34.4 40.65 40 41 80 CL579-0019-8 51.9 39.2 48.95 42.4 48.65 50 51 100 CL579-0020-7 59.9 47.2 56.95 50.4 56.65 60 61 120 CL579-0021-0 67.9 55.2 64.95 58.4 64.65 70 71 140 ★Indicates products that are currently available. Other contact counts may be under development, contact your local rep for details 6¤%#' 7¤%#' ● Straight header (10 mm stack height) E2%#-¤%#&* %#(*¤%#& Cd#= ,#-¤%#' Cd#< Cd#& Cd#; (#**¤%#&*  )#.¤%#' &#'¤%#&* &#'¤%#&* )#.¤%#' '¤%#' 9¤%#'* :¤%#'* '¤%#' &#(* −%#( +%#&* &-#+*¤%#( 8¤%#&* Unit: mm ★ ★ ★ ★ ★ ★ Part No. HRS No. A B C D E F G H (No of contacts) FX18-40P-0.8SV10 CL579-0022-2 27.9 15.2 24.95 18.4 24.65 20 21 40 FX18-60P-0.8SV10 CL579-0023-5 35.9 23.2 32.95 26.4 32.65 30 31 60 FX18-80P-0.8SV10 CL579-0024-8 43.9 31.2 40.95 34.4 40.65 40 41 80 FX18-100P-0.8SV10 CL579-0034-1 51.9 39.2 48.95 42.4 48.65 50 51 100 FX18-120P-0.8SV10 CL579-0025-0 59.9 47.2 56.95 50.4 56.65 60 61 120 FX18-140P-0.8SV10 CL579-0035-4 67.9 55.2 64.95 58.4 64.65 70 71 140 ★Indicates products that are currently available. Other contact counts may be under development, contact your local rep for details 8 FX18 Series●High Speed Transmission, 0.8 mm Pitch Connectors for PCB Connections A±0.2 ●Straight receptacle (10 mm stack height) C±0.2 No.H No.G 7.8±0.2 P=0.8±0.15 0.35±0.1 3.6±0.15 5.1±0.2 B±0.15 No.1 0.15 1.35 + −0.3 6.7±0.3 No.F D±0.25 1.2±0.15 1.2±0.15 2±0.2 4.9±0.2 4.9±0.2 2±0.2 Unit: mm Part No. HRS No. A B C D E F G H (No. of contacts) FX18-40S-0.8SV10 --------------- 27.9 25 15.2 18.4 26.05 20 21 40 FX18-60S-0.8SV10 --------------- 35.9 33 23.2 26.4 34.05 30 31 60 FX18-80S-0.8SV10 --------------- 43.9 41 31.2 34.4 42.05 40 41 80 FX18-100S-0.8SV10 --------------- 51.9 49 39.2 42.4 50.05 50 51 100 --------------- 59.9 57 47.2 50.4 58.05 60 61 120 CL579-0060-1 67.9 65 55.2 58.4 66.05 70 71 140 FX18-120S-0.8SV10 ★ FX18-140S-0.8SV10 Cd#< ,#-¤%#' Cd#= *#&¤%#' ● Straight receptacle (15 mm stack height) 6¤%#' 7¤%#&* 8¤%#' E2%#-¤%#&* %#(*¤%#& (#+¤%#&* ★Indicates products that are currently available. Other contact counts may be under development, contact your local rep for details Cd#& &#'¤%#&* )#.¤%#' 9¤%#'* :¤%#'* &#'¤%#&* '¤%#' %#&* &#(* "%#( &&#)*¤%#( Cd#; )#.¤%#' '¤%#' Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. E±0.25 Unit: mm ★ ★ ★ ★ ★ ★ Part No. HRS No. A B C D E F G H (No. of contacts) FX18-40S-0.8SV15 CL579-0026-3 27.9 25 15.2 18.4 26.05 20 21 40 FX18-60S-0.8SV15 CL579-0027-6 35.9 33 23.2 26.4 34.05 30 31 60 FX18-80S-0.8SV15 CL579-0028-9 43.9 41 31.2 34.4 42.05 40 41 80 FX18-100S-0.8SV15 CL579-0036-7 51.9 49 39.2 42.4 50.05 50 51 100 FX18-120S-0.8SV15 CL579-0029-1 59.9 57 47.2 50.4 58.05 60 61 120 FX18-140S-0.8SV15 CL579-0037-0 67.9 65 55.2 58.4 66.05 70 71 140 ★Indicates products that are currently available. Other contact counts may be under development, contact your local rep for details 9 Cd#< ,#-¤%#' Cd#= *#&¤%#' 6¤%#' 7¤%#&* 8¤%#' E2%#-¤%#&* %#(*¤%#&  ●Straight receptacle (20 mm stack height) (#+¤%#&* FX18 Series●High Speed Transmission, 0.8 mm Pitch Connectors for PCB Connections Cd#; Cd#&  %#&* &+#)*¤%#(  ★ ★ ★ ★ ★ ★ )#.¤%#' &#(* "%#( &#'¤%#&* '¤%#' &#'¤%#&*  )#.¤%#' '¤%#' Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 9¤%#'* :¤%#'* Unit: mm Part No. HRS No. A B C D E F G H (No. of contacts) FX18-40S-0.8SV20 CL579-0030-0 27.9 25 15.2 18.4 26.05 20 21 40 FX18-60S-0.8SV20 CL579-0031-3 35.9 33 23.2 26.4 34.05 30 31 60 FX18-80S-0.8SV20 CL579-0032-6 43.9 41 31.2 34.4 42.05 40 41 80 FX18-100S-0.8SV20 CL579-0038-2 51.9 49 39.2 42.4 50.05 50 51 100 FX18-120S-0.8SV20 CL579-0033-9 59.9 57 47.2 50.4 58.05 60 61 120 FX18-140S-0.8SV20 CL579-0039-5 67.9 65 55.2 58.4 66.05 70 71 140 4.4±0.15 ★Indicates products that are currently available. Other contact counts may be under development, contact your local rep for details 3.9±0.15 A±0.2 B±0.2 P=0.8±0.15 ●Interposer (15 mm height) 19.7±0.3 C±0.15 No.1 No.F No.E No.G P=0.8±0.15 B±0.2 D±0.15 Unit: mm HRS No. A B C D E F G (No. of contacts) FX18-40PS-0.8H15 --------------- 27.9 15.2 24.95 25 20 21 40 FX18-60PS-0.8H15 --------------- 35.9 23.2 32.95 33 30 31 60 FX18-80PS-0.8H15 --------------- 43.9 31.2 40.95 41 40 41 80 FX18-100PS-0.8H15 --------------- 51.9 39.2 48.95 49 50 51 100 FX18-120PS-0.8H15 --------------- 59.9 47.2 56.95 57 60 61 120 CL579-0054-9 67.9 55.2 64.95 65 70 71 140 Part No. ★ FX18-140PS-0.8H15 ★Indicates products that are currently available. Other contact counts may be under development, contact your local rep for details 10 FX18 Series●High Speed Transmission, 0.8 mm Pitch Connectors for PCB Connections Recommended Land Pattern Dimensions (PCB thickness: t = 1.6 mm/Metal mask thickness: t = 0.12 mm) A B C 15.2 18.4 24.65 23.2 26.4 32.65 31.2 34.4 40.65 39.2 42.4 48.65 47.2 50.4 56.65 55.2 58.4 64.65 A B C FX18-40P-0.8SV 15.2 18.4 24.65 FX18-60P-0.8SV 23.2 26.4 32.65 FX18-80P-0.8SV 31.2 34.4 40.65 FX18-100P-0.8SV 39.2 42.4 48.65 %#& % FX18-120P-0.8SV 47.2 50.4 56.65 '#& FX18-140P-0.8SV 55.2 58.4 64.65 Part No. A B C FX18-40P-0.8SV10 15.2 18.4 24.65 FX18-60P-0.8SV10 23.2 26.4 32.65 FX18-80P-0.8SV10 31.2 34.4 40.65 FX18-100P-0.8SV10 39.2 42.4 48.65 %#&  % FX18-120P-0.8SV10 47.2 50.4 56.65 '#& ●Right angle receptacle/right angle header Part No. FX18-140P-0.8SV10 55.2 58.4 64.65 Part No. A B C FX18-40S-0.8SV10/15/20 15.2 18.4 26.05 FX18-60S-0.8SV10/15/20 23.2 26.4 34.05 FX18-80S-0.8SV10/15/20 31.2 34.4 42.05 FX18-100S-0.8SV10/15/20 39.2 42.4 50.05 FX18-120S-0.8SV10/15/20 47.2 50.4 58.05 FX18-140S-0.8SV10/15/20 55.2 58.4 66.05 FX18-60S-0.8SH FX18-60P-0.8SH 8.4±0.05 㸩0.1 㸩0.1 (TH) 1ࠉ0 FX18-40P-0.8SH 㸩0.1 2.1ࠉ0 㸩0.1 1 ࠉ0 (TH) 2 ࠉ0 (TH) 2 +0.1 (TH) 0 4.75±0.05 6.5±0.05 FX18-40S-0.8SH FX18-80S-0.8SH FX18-80P-0.8SH 2.1 㸩0.1 ࠉ0 A±0.05 B±0.05 2±0.05 .5 R0 (TH) 1.7 +0.1 0 4.05±0.05 P=0.8±0.05 FX18-100P-0.8SH FX18-120S-0.8SH FX18-120P-0.8SH PCB EDGE C±0.05 FX18-140S-0.8SH FX18-140P-0.8SH Part No. %#& % #* G% *#&¤%#%* %#& &#'I= % -#)¤%#%* %#& &I= % '#& %#& &I= % %#& 'I= % %#& &#-I= % ●Straight header E2%#-¤%#%* %#) 6¤%#%* %#%* % 7¤%#%* 8¤%#%* %#& % I= %#& '#&  % %#& % I= #* G% E2%#-¤%#%* %#* %#%*  % '¤%#%* -#)¤%#%* ' & &#) %%#& (I=) )#.¤%#%* ' '¤%#%* %#& % I= & %#& %(I=) ●Straight header (SV 10 mm height ) 6¤%#%* 7¤%#%* 8¤%#%* %#& %(I=) %#* +%#%* % '#& +%#& % E2%#-¤%#%* '¤%#%* #* G% (I=) &#) %%#& -#)¤%#%* %#& % I= '#& +%#& % & %#& % I= ' & '¤%#%* ' %#& % I= ●Straight receptacle (SV10/SV15/SV20 mm heights ) )#.¤%#%* Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FX18-100S-0.8SH 㸩0.05 0.4 ࠉ0 6¤%#%* 7¤%#%* 8¤%#%* 11 FX18 Series●High Speed Transmission, 0.8 mm Pitch Connectors for PCB Connections Packaging tray (dimensions and quantities) ●Right angle receptacle/right angle header ('* )* '(* (% E2), Part No. 6 ;M&-"+%E$H"%#-H= FX18-40S-0.8SH FX18-40P-0.8SH FX18-60P-0.8SH FX18-80S-0.8SH FX18-80P-0.8SH ''* &+' Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. E2&- FX18-60S-0.8SH FX18-100S-0.8SH FX18-100P-0.8SH FX18-120S-0.8SH FX18-120P-0.8SH FX18-140S-0.8SH FX18-140P-0.8SH Quantity 70 60 50 40 40 40 3EH1 FIN#+% ●Straight header/Straight receptacle for 10 mm stack height ('* '(%¤%#* (&#* ),#* E2)+ 6 ''* &+' E2&- ;M&-"+%E"%#-HK FIN#+% 12 3EH1 Part No. Quantity FX18-40P-0.8SV FX18-40S-0.8SV10 70 FX18-60P-0.8SV FX18-60S-0.8SV10 60 FX18-80P-0.8SV FX18-80S-0.8SV10 50 FX18-100P-0.8SV FX18-100S-0.8SV10 40 FX18-120P-0.8SV FX18-120S-0.8SV10 40 FX18-140P-0.8SV FX18-140S-0.8SV10 40 FX18 Series●High Speed Transmission, 0.8 mm Pitch Connectors for PCB Connections ●Straight header 10 mm/Straight receptacle 15 mm/Straight receptacle 20 mm ('* '(% (&#* ),#* Part No. E2)+ ;M&-"+%H"%#-HK'% A Quantity FX18-40P-0.8SV10 ;M&-"+%E"%#-HK&% FX18-40S-0.8SV15 60 FX18-40S-0.8SV20 E2&- FX18-60P-0.8SV10 FX18-60S-0.8SV15 60 FX18-60S-0.8SV20 &+' ''* FX18-80S-0.8SV15 50 FX18-80S-0.8SV20 FX18-100P-0.8SV10 FX18-100S-0.8SV15 40 FX18-100S-0.8SV20 FX18-120P-0.8SV10 FX18-120S-0.8SV15 FIN#+% 3EH1 40 FX18-120S-0.8SV20 FX18-140P-0.8SV10 FX18-140S-0.8SV15 30 FX18-140S-0.8SV20 ●Interposer 15 mm height (('*) ('(%) ((&#*) (),#*) Part No. ;M&-"+%EH"%#-=&* (E2&-) A (E2)+) (&+') (''*) Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FX18-80P-0.8SV10 FIN#+% Quantity FX18-40PS-0.8H15 60 FX18-60PS-0.8H15 60 FX18-80PS-0.8H15 50 FX18-100PS-0.8H15 40 FX18-120PS-0.8H15 40 FX18-140PS-0.8H15 30 3EH1 13 FX18 Series●High Speed Transmission, 0.8 mm Pitch Connectors for PCB Connections Temperature Profile This temperature profile was tested under the following conditions, and any attempt to recreate will vary depending on the external conditions. (Peak temperature: 250ç MAX) 260 (Applicable Conditions) 240 220ç 220 200ç Temperature (ç) 200 180 160 150ç 140 (Note 1)This temperature profile contains recommended values and is for reference only. 0 (Note 2)Reflow process should not exceed 2 times. (Note 3)Cream solder type: Will differ due to the amount used and manufacturer (Maximum of 60 seconds) Soldering time (220ç or above) (90 to 120 seconds) Preheating time (150 to 200ç) Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Test PCB Size Dimensions : 110 × 50 × 1.6 (mm) Material : Glass epoxy Solder composition : Sn- 3 Ag- 0.5 Cu Flux contained quantity : 11 wt% Metal mask thickness : 0.12 mm Washing conditions ●Washing with organic solvent Solvent IPA (Isopropyl alcohol) Washing in normal temperature Washing in heated condition ○ ○ ●Water based cleaning When using water based cleaning agents (including terpene, and alkali saponifiers), pay special attention to how the cleaning agent will react to specific metals and plastics before selecting one of them. Various cleaning agent manufacturers publish reaction tables for their cleaning agents. Do not leave connectors with moisture remaining on them. ●Cautions when washing The electrical performance may deteriorate if the flux or cleaning detergent is left on the connector after the cleaning. Check thoroughly to ensure that there is no residue left on any of the surfaces. No more than 1 mm Operating Precautions ●Mating gap permitted The effective mating length of the MF contact A is 2.5 mm, signal contact is 2 mm and MF contact B is 1.5 mm. The approved amount of gap between the header and receptacle should not exceed 1 mm. No more than 1 mm No more than 1 mm Interface Fixed mating No more than 1 mm Coplanar connection type Right angle connection type Parallel connection type (2 piece) Parallel connection type (3 piece) ● Provide another form of support to the PCB, this connector was not designed to be the main form of support. ● Do not mate the connectors at an angle, refer to the rotation mating/unmating guideline (TADC 4-210630). (For the guideline, please contact the sales representative of our company.) ● When using the 15 mm height interposer, be cautious of the items listed below. 1) The lock on the fixed mating side of the interposer is not designed to be the mate/unmate point. This section should not be mated/unmated more than 5 times. 2 When mating these connectors, make sure to mate the fixed mating side first then mate the interface mating/umating side to the header. 3) The effective mating length of the MF contact A is 2.5 mm, signal contact is 2 mm and MF contact B is 1.5 mm. 4) The approved amount of gap between the header and receptacle should not exceed 1 mm. 14 FX18 Series●High Speed Transmission, 0.8 mm Pitch Connectors for PCB Connections Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. MEMO : 15 Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FX18 Series●High Speed Transmission, 0.8 mm Pitch Connectors for PCB Connections USA: HIROSE ELECTRIC (U.S.A.), INC. Headquarters 2688 Westhills Court, Simi Valley, CA 93065-6235 Phone : +1-805-522-7958 Fax : +1-805-522-3217 http://www.hiroseusa.com USA: HIROSE ELECTRIC (U.S.A.), INC. San Jose Office 3255 Scott Boulevard, Building 7, Suite 101 Santa Clara, CA 95054 Phone : +1-408-253-9640 Fax : +1-408-253-9641 http://www.hiroseusa.com USA: HIROSE ELECTRIC (U.S.A.), INC. Detroit Office (Automotive) 37677 Professional Center Drive, Suite #100C Livonia, MI 48154 Phone : +1-734-542-9963 Fax : +1-734-542-9964 http://www.hiroseusa.com THE NETHERLANDS: HIROSE ELECTRIC EUROPE B.V. Hogehillweg #8 1101 CC Amsterdam Z-O Phone : +31-20-6557460 Fax : +31-20-6557469 http://www.hiroseeurope.com GERMANY: HIROSE ELECTRIC EUROPE B.V. German Branch Herzog-Carl-Strasse 4 D-73760 Ostfildern (Scharnhauser Park) Phone : +49-711-4560-02-1 Fax : +49-711-4560-02-299 http://www.hirose.de UNITED KINGDOM: HIROSE ELECTRIC EUROPE B.V. UK Branch 22 Vincent Avenue, Crownhill Business Centre, Crownhill, Milton Keynes, MK8 0AB Phone : +44-1908-305750 Fax : +44-1908-305768 http://www.hirose.co.uk CHINA: HIROSE ELECTRIC TRADING (SHANGHAI) CO., LTD. 1601,Henderson Metropolitan,NO.300 ,East Nanjing Road,Huangpu District, Shanghai,China 200001 Phone : +86-21-6391-3355 Fax : +86-21-6391-3335 http://www.hirose-china.com.cn CHINA: HIROSE ELECTRIC TRADING (SHANGHAI) CO., LTD. Beijing Branch A1001, Ocean International Center, Building 56# East 4th Ring Middle Road, Chao Yang District, Beijing, 100025 Phone : +86-10-5165-9332 Fax : +86-10-5908-1381 http://www.hirose-china.com.cn CHINA: HIROSE ELECTRIC TECHNOLOGIES (SHENZHEN) CO., LTD. Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre 5002, ShenNanDong Road, ShenZhen City, Guangdong Province, 518008 Phone : +86-755-8207-0851 Fax : +86-755-8207-0873 http://www.hirose-china.com.cn HONG KONG: HIROSE ELECTRIC HONGKONG TRADING CO., LTD. Room 1001, West Wing, Tsim Sha Tsui Centre, 66 Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong Phone : +852-2803-5338 Fax : +852-2591-6560 http://www.hirose-hongkong.com.hk TAIWAN: HIROSE ELECTRIC TAIWAN CO., LTD. 103 8F, No.87, Zhengzhou Rd., Taipei Phone : +886-2-2555-7377 Fax : +886-2-2555-7350 http://www.hirose-taiwan.com.tw KOREA: HIROSE KOREA CO., LTD. 1261-10, Jeoungwhang-Dong, Shihung-City, Kyunggi-Do 429-450 Phone : +82-31-496-7000,7124 Fax : +82-31-496-7100 http://www.hirose.co.kr SINGAPORE: INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. Bangalore Liaison office HIROSE ELECTRIC SINGAPORE PTE. LTD. 10 Anson Road #26-1 International Plaza Unit No.03, Ground Floor, Explorer Building International Tech Park Whitefield Road, Bangalore 560066 Karnataka, India 079903 Phone : +65-6324-6113 Phone : +65-6324-6113 Fax : +65-6324-6123 Fax : +65-6324-6123 http://www.hirose-singapore.com.sg http://www.hirose-singapore.com.sg INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD Delhi Liaison Office Suite No. 606 5th Floor SB Tower 1A/1 Sector 16 A Filmcity Noida 201301 Uttar Pradesh-India Phone : +91-120-4804917 Fax : +91-120-4804949 http://www.hirose.com/sg/ MALAYSIA: HIROSE ELECTRIC SINGAPORE PTE. LTD (Representative office) 1-10-07, Suntech @ Penang Cybercity (1164),Lintang Mayang Pasir 3,11950, Bayan Baru, Penang, Malaysia. Phone : +604-619-2564 Fax : +604-619-2574 http://www.hirose.com/sg/ ® 16 6-3,Nakagawa Chuoh-2-Chome,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 1/2014. Contents are subject to change without notice for the purpose of improvements.
FX18-40P-0.8SV 价格&库存
很抱歉,暂时无法提供与“FX18-40P-0.8SV”相匹配的价格&库存,您可以联系我们找货
FX18-40P-0.8SV
  • 1+48.570801+6.30210
  • 10+41.3001010+5.35870
  • 25+38.7488025+5.02770
  • 50+37.8744050+4.91420
  • 70+34.1972070+4.43710
  • 280+32.61610280+4.23200
  • 560+31.03500560+4.02680
  • 1050+29.633601050+3.84500
  • 2520+28.495702520+3.69730
FX18-40P-0.8SV
    • 1+34.087621+4.42395
    • 10+29.0376010+3.76855
    • 30+23.6131930+3.06456
    • 50+22.5335350+2.92444
    • 100+21.70637100+2.81709
    • 300+21.17525300+2.74816
    FX18-40P-0.8SV
      • 1+17.51760
      • 10+15.21720
      • 30+13.79160
      • 100+11.37240
      • 500+10.70280
      • 1000+10.42200
