FC68148
FC68148
    CLIFF
    CONN_14X9MM_TM
    电源连接器 CONN_14X9MM_TM
FC68148 数据手册
CLIFF DC Power Connectors The CLIFF ® range of DC Power Connectors comprise several different models for chassis mounting and horizontal or vertical PCB mounting. Our products are manufactured to strict quality and performance standards. All plastic parts are minimum UL-94HB for toughness and durability. The standard colour is Black and some models are available with a choice of pin diameters and switched contacts. Typical applications include portable equipment of all types, signal processors, power supplies etc. DC-8 PCB mounting pin ring type. Rated 12V / 1A. Minature version for PCB mounting. 1.3mm dia. pin. PC LAYOUT DC-8 (FC68145) DC-9 PCB mounting pin ring type with switch. Rated 12V / 5A. DC9 with 2.1mm dia. pin. DC9A with 2.5mm dia. pin. PC LAYOUT DC-9 (FC68146) DC-9A (FC681461) DC-10 PCB mounting pin / ring type with switch. Rated 12V / 5A. DC10A with 2.1mm dia. pin. DC10B with 2.5mm dia. pin. PC LAYOUT DC-10A (FC68148) DC-10B (FC68149) SCD-026 chassis mounting. SCD - 026 with 2.1mm dia. pin. SCD - 026A with 2.5mm dia. pin. SCD-026 (FC681445) SCD-026A (FC681446) Cliff Electronic Components, Ltd. 76 Holmethorpe Avenue, Holmethorpe Ind. Est. Redhill, Surrey RH1 2PF. England Tel: +44 (0) 1737 771375 Fax: +44 (0) 1737 766012 Email: sales@cliffuk.co.uk Visit us online at: w w w. cl i f f u k . c o . u k CLIFF DC Power Connectors DC-12A PCB mounting pin / ring type with switch. Rated 12V / 5A. With 2.1mm dia. pin. PC LAYOUT DC-12A (FC681485) DC-13 panel mounting pin / ring type with switch. Rated 12V / 5A. DC-13A with 2.1mm dia. pin. DC-13B with 2.5mm dia. pin. DC-13A (FC681492) DC-13B (FC681493) DCPP1 DC Line connector. Rated 12V / 5A. DCPP1 with 2.1mm dia. pin. DCPP2 with 2.5mm dia. pin. FOR DIMENSIONS AND VARIANTS, SEE INDIVIDUAL PRODUCT DRAWINGS. DCPP3 DC Line connector. Rated 12V / 5A. With 1.3mm dia. pin DCPP3 (FA67555) CCB-1 9V Battery connector. Cable length 220mm. Tough molded body. CCB-1A ‘T’ Type Cable length 220mm. CCB-1 (FC6830) CCB-1A (FC6831) c 2003 CLIFF ® Please note we can also supply DC Plugs moulded onto cable as custom products. Drawings available on request. Contact sa l e s@c l i f f u k . c o. u k
FC68148 价格&库存
很抱歉,暂时无法提供与“FC68148”相匹配的价格&库存,您可以联系我们找货
FC68148
  • 1+11.195541+1.44949
  • 10+9.5140810+1.23179
  • 25+8.9125125+1.15391
  • 50+8.4858050+1.09866
  • 100+8.08116100+1.04627
  • 300+7.47745300+0.96811
  • 500+7.21245500+0.93380
  • 1000+6.868131000+0.88922
  • 2500+6.438282500+0.83357
库存:2217
