COS12A12511
COS12A12511
    COSINE(科山芯创)
    MSOP8_3X3MM
    高压、单电源和双电源PDT模拟开关
COS12A12511 数据手册
COS12A12511 High Voltage, Single and Dual Supply SPDT Analog Switch Features General Description ■ Single and Dual Supply Operation The COS12A12511 is a high voltage single - ±1.5V to ±8V channel, bidirectional, single-pole double-throw +3V to +16V (SPDT) CMOS analog switch. The device can ■ Low ON-State Resistance: pass signals with swings of 0 to 16 V or -8V to - 2.8Ω with 16V Supply +8V. This switch conducts equally well in both - 3.6Ω with 12V Supply directions when it is on. - - 11Ω with 5V Supply ■ Low Leakage Currents - 1 nA Off-Leakage at 25oC - 1 nA On-Leakage at 25oC ■ Fast Switching Speed tON=70ns, tOFF=50ns (12V Supply) ■ Break-Before-Make Operation ■ Rail-to-Rail Operation ■ TTL/CMOS Logic Compatible ■ Packaging: MSOP8 and SOP8 Pin Diagram Rev1.0 Copyright@2018 Cosine Nanoelectronics Inc. All rights reserved The information provided here is believed to be accurate and reliable. Cosine Nanoelectronics assumes no reliability for inaccuracies and omissions. Specifications described and contained here are subjected to change without notice on the purpose of improving the design and performance. All of this information described herein should not be implied or granted for any third party. www.cosine-ic.com The COS12A12511 can operate continuously with a single supply between 3V and 16V or dual supply between ± 1.5V to ± 8V. It can handle rail-to-rail analog signals. The OFF/ON leakage current maximum is only 1nA at 25oC or 10nA at 85oC. The digital inputs have 0.8V to 2.4V logic thresholds, ensuring TTL/CMOS logic compatibility when using a +5V supply. Applications ■ Power routing applications ■ Audio and video signal switching ■ Precision automatic test equipment ■ Relay replacement ■ Automotive applications ■ Sample and hold systems ■ Telecom signal switching ■ Battery power systems 1 COS12A12511 1. Pin Configuration and Functions Figure 1 Pin Diagram Pin Description PIN FUNCTION NO. NAME I/O 1 COM I/O Common terminal. Can be an input or output 2 NC I/O Normally closed terminal. Can be an input or output 3 GND - Ground. 0V reference 4 V+ I Most positive power supply 5 N.C. - No connect. Not internally connected 6 IN I Logic control input 7 V- I Most negative power supply. This pin is only used in dual-supply applications and should be tied to ground in single-supply applications. 8 NO I/O Normally open terminal. Can be an input or output 2. Ordering Information Order Number COS12A12511 COS12A12511SR www.cosine-ic.com Package Package Option Marking Information MSOP8 Tape and Reel, 3000 COS12A12511 SOP8 Tape and Reel, 4000 COS12A12511SR 2 COS12A12511 3. Product Specification 3.1 Absolute Maximum Ratings (1) Min Max Unit 0 17 V V+ to GND -0.3 17 V V- to GND -8.5 0.3 V V- -0.5 V+ + 0.5 V Continuous current into any terminal ±20 mA Peak current into any terminal ±50 mA Continuous power dissipation 560 mW Parameter V+ to V- Analog voltage range (VNC, VNO, VCOM) Operating junction temperature -40 +125 °C Storage temperature -55 +150 °C (1) Stresses exceeding the absolute maximum ratings may damage the device. The device may not function or be operable above the recommended operating conditions and stressing the parts to these levels is not recommended. In addition, extended exposure to stresses above the recommended operating conditions may affect device reliability. The absolute maximum ratings are stress ratings only. 3.2 Thermal Data Parameter Rating Unit 206 (MSOP8) 155 (SOP8) °C/W Parameter Rating Unit V+ 0V ~ 16 V V- -8 ~ 0 V VI/O V- to V+ V VIN 0 ~ V+ V Package Thermal Resistance 3.3 Recommended Operating Conditions www.cosine-ic.com 3 COS12A12511 3.4 Electrical Characteristics for ±8V Dual Supply (Typical values are tested at TA=25 oC, V+=8V±10%, V-=-8V±10%, unless otherwise noted) Parameter Symbol Conditions Min. Typ. Max. Unit V+ V 3.2 6 Ω 1.0 3 Ω 50 nA 50 nA Analog Switch Analog signal range VCOM, VNO, VNC, On-state resistance RON On-state resistance flatness RON OFF leakage current (NO, NC) ON leakage current (NO, NC) INO(OFF), INC(OFF) INO(ON), INC(ON) VVNC or VNO = -4.5V to +4.5V, ICOM= -10mA VNC or VNO = -3.3V to +3.3V, ICOM= -10mA VNC or VNO = -4.5V to +4.5V, VCOM = -4.5V to +4.5V VNC or VNO = -4.5V to +4.5V, VCOM = open Digital Control Input (IN) Input logic high VIH 5 V+ V Input logic low VIL 0 0.8 V Input leakage current IIH, IIL 0.05 μA 70 130 ns 50 75 ns VIN = 0 or V+ Switch Dynamic Characteristics Turn-on time tON Turn-off time tOFF Break-Before-Make Delay (COS4561 only) tBBM Charge Injection Q NO or NC off capacitance COFF COM off-capacitance (COS4514/COS4515 only) CCOM COM On-Capacitance CCOM Off-Isolation VISO Bandwidth BW VNO or VNC=3.3V, RL=300Ω, CL = 35pF, Figure 1 VNO or VNC=3.3V, RL=300Ω, CL = 35pF, Figure 1 VNO or VNC=3.3V, RL=300Ω, CL = 35pF, Figure 2 VNO=VNC=0V, RGEN=0, CL = 1.0nF, Figure 3 VNC=VNO = 0, f = 1MHz, VCOM = 0, f = 1MHz, VCOM = VNO, VNC = 0, f = 1MHz, RL = 50Ω, CL = 15pF, VNC = 1VRMS, f = 100kHz RL = 50Ω, CL = 15pF, VNC = 1VRMS, f = 100kHz 5 40 ns -110 pC 15 pF 65 pF 65 pF -85 dB 100 MHz Power Supply V+ supply current www.cosine-ic.com I+ VIN = 0 or V+ 0.1 μA 4 COS12A12511 3.5 Electrical Characteristics for 12V Single Supply (Typical values are tested at TA=25 oC, V+=11.4V to 12.6V, VINH=5V, VINL=0.8, unless otherwise noted) Parameter Symbol Conditions Min. Typ. Max. Unit V+ V 4.0 7.4 Ω 1.5 3 Ω 50 nA 50 nA Analog Switch Analog signal range VCOM, VNO, VNC, On-state resistance RON On-state resistance flatness RON OFF leakage current (NO, NC) ON leakage current (NO, NC) INO(OFF), INC(OFF) INO(ON), INC(ON) 0 VNC or VNO = 0V to 10.8V, ICOM= -10mA VNC or VNO = 3.3V to +7V, ICOM= -10mA VNC or VNO =0V to 10.8V, VCOM = 0V to 10.8V VNC or VNO = 0V to 10.8V, VCOM = open Digital Control Input (IN) Input logic high VIH 5 V+ V Input logic low VIL 0 0.8 V Input leakage current IIH, IIL 0.01 μA 70 130 ns 50 75 ns VIN = 0 or V+ Switch Dynamic Characteristics Turn-on time tON Turn-off time tOFF Break-Before-Make Delay (COS4561 only) tBBM Charge Injection Q NO or NC off capacitance COFF COM off-capacitance (COS4514/COS4515 only) CCOM COM On-Capacitance CCOM Off-Isolation VISO Bandwidth BW VNO or VNC=10V, RL=300Ω, CL = 35pF, Figure 1 VNO or VNC=10V, RL=300Ω, CL = 35pF, Figure 1 VNO or VNC=10V, RL=300Ω, CL = 35pF, Figure 2 VGEN =5V, RGEN=0, CL = 1.0nF, Figure 3 VNC=VNO = 0, f = 1MHz, VCOM = 0, f = 1MHz, VCOM = VNO, VNC = 0, f = 1MHz, RL = 50Ω, CL = 15pF, VNC = 1VRMS, f = 100kHz RL = 50Ω, CL = 15pF, VNC = 1VRMS, f = 100kHz 5 40 ns -110 pC 15 pF 65 pF 65 pF -85 dB 90 MHz Power Supply V+ supply current www.cosine-ic.com I+ VIN = 0 or V+ 0.1 μA 5 COS12A12511 3.6 Electrical Characteristics for 5V Single Supply (Typical values are tested at TA=25 oC, V+=4.5V to 5.5V, VINH=2.4V, VINL=0.8, unless otherwise noted) Parameter Symbol Conditions Min. Typ. Max. Unit V+ V 32 Ω 50 nA 50 nA Analog Switch Analog signal range VCOM, VNO, VNC, On-state resistance RON OFF leakage current (NO, NC) INO(OFF), ON leakage current (NO, NC) INC(OFF) INO(ON), INC(ON) 0 VNC or VNO = 0V to 4.5V, ICOM= -10mA VCOM=0V to 4.5V, VNO or VNC=0V to 4.5V VCOM=open, VNO or VNC=0V to 4.5V 11 Digital Control Input (IN) Input logic high VIH 2.4 V+ V Input logic low VIL 0 0.8 V Input leakage current IIH, IIL 0.01 μA 75 130 ns 45 70 ns VIN = 0 or V+ Switch Dynamic Characteristics Turn-on time tON Turn-off time tOFF Break-Before-Make Delay (COS4561 only) tBBM Charge Injection Q NO or NC Off Capacitance COFF COM Off-Capacitance (COS4514/COS4515 only) CCOM COM On-Capacitance CCOM Off-Isolation VISO Bandwidth BW VNO or VNC=3V, RL=300Ω, CL = 35pF, Figure 1 VNO or VNC=3V, RL=300Ω, CL = 35pF, Figure 1 VNO or VNC=3V, RL=300Ω, CL = 35pF, Figure 2 VGEN =2V, RGEN=0, CL = 1.0nF, Figure 3 VNC=VNO = 0, f = 1MHz, VCOM = 0, f = 1MHz, VCOM = VNO, VNC = 0, f = 1MHz, RL = 50Ω, CL = 15pF, VNC = 1VRMS, f = 100kHz RL = 50Ω, CL = 15pF, VNC = 1VRMS, f = 100kHz 5 40 ns -40 pC 15 pF 65 pF 65 pF -85 dB 60 MHz Power Supply V+ supply current www.cosine-ic.com I+ VIN = 0 or V+ 0.1 μA 6 COS12A12511 4. Test Circuits and Timing Diagrams Figure 1. Switching Time Figure 2. Break-Before-Make Interval Figure 3. Charge Injection www.cosine-ic.com 7 COS12A12511 5. Package Information 5.1 MSOP8 (Package Outline Dimensions) 5.2 SOP8 (Package Outline Dimensions) www.cosine-ic.com 8
COS12A12511 价格&库存
很抱歉,暂时无法提供与“COS12A12511”相匹配的价格&库存,您可以联系我们找货
COS12A12511
  • 1+3.79080
  • 10+3.08880
  • 30+2.74320
  • 100+2.39760
  • 500+2.18160
  • 1000+2.07360
库存:1862
