S2A THRU S2M SMA
Surface Mount General Purpose Silicon Rectifiers
Pinning
Reverse Voltage - 50 to 1000 V
1.Cathode
Forward Current - 2 A
2.Anode
1
FEATURES
For surface mounted applications
Low profile package
Glass Passivated Chip Junction
Ideal for automated placement
2
DO-214AC/SMA
Marking Code
Lead free in comply with EU RoHS 2011/65/EU directives
MECHANICAL DATA
Case: DO-214AC/SMA
Terminals: Solderable per MIL-STD-750, Method 2026
Approx. Weight: 0.07g / 0.002oz
Maximum Ratings and Electrical characteristics
S2A
S2A
S2B
S2B
S2D
S2D
S2G
S2G
S2J
S2J
S2K
S2K
S2M
S2M
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
S2A
S2B
S2D
S2G
S2J
S2K
S2M
Units
Maximum Repetitive Peak Reverse Voltage
VRRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
VRMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
VDC
50
100
200
400
600
800
1000
V
Maximum Average Forward Rectified Current
at Tc = 125 °C
IF(AV)
2
A
Peak Forward Surge Current 8.3 ms Single
Half Sine Wave Superimposed on Rated Load
IFSM
60
A
Maximum Instantaneous Forward Voltage at 2 A
VF
1.1
V
IR
5
50
μA
Cj
30
pF
RθJA
50
°C/W
Tj, Tstg
-55 ~ +150
°C
Parameter
Maximum DC Reverse Current Ta = 25 °C
at Rated DC Blocking Voltage
Ta=125 °C
Typical Junction Capacitance(1)
Typical Thermal Resistance (2)
Operating and Storage Temperature Range
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
www.yfwdiode.com
1/3
Dongguan YFW Electronics Co, Ltd.
S2A THRU S2M SMA
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current(μ A)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
2.5
2.0
1.5
1.0
0.5
0.0
25
50
75
100
125
150
175
100
T J =125°C
10
1.0
T J =25°C
0.1
00
Case Temperature (°C)
40
60
80
100
120
140
Fig.4 Typical Junction Capacitance
Fig.3 Typical Forward Characteristic
10
Junction Capacitance ( pF)
Instaneous Forward Current (A)
percent of Rated Peak Reverse Voltage (%)
1.0
100
T J =25°C
10
T J =25°C
0.1
0.4
1
0.6
0.8
1.0
1.2
1.4
1.6
1.8
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
Fig.5 Maximum Non-Repetitive Peak
75
60
45
30
15
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
www.yfwdiode.com
2/3
S2A THRU S2M SMA
DO-214AC SMA
Package Outline
A
A
Plastic surface mounted package; 2 leads
c
a
VM
e
A
HE
g
e
E
A
D
E
HE
c
e
g
max
2. 42
4.5
2. 80
5.2
0.31
1.6
1.5
min
1.98
4.0
2. 54
4.7
0.15
1.3
0.9
max
96
181
1 10
205
12
63
59
min
78
157
100
185
6
51
35
UNIT
mm
mil
g
e
A
D
a
0.3
12
The recommended mounting pad size
2.4
(94)
1.8
(71)
1.8
(71)
1.8
(71)
mm
Unit :
(mil)
Summary of Packing Options
Package
DO-214AC SMA
www.yfwdiode.com
Packing Description
Packing Quantity
Industry Standard
Tape/Reel,11”reel
5000
EIA-481-1
Tape/Reel,7”reel
2000
EIA-481-1
3/3
很抱歉,暂时无法提供与“S2M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.11697
- 200+0.09481
- 600+0.08249
- 5000+0.07059
- 10000+0.06412
- 20000+0.06065
