LSM0805472V
LSM0805472V
    VCC
    发光二极管/LED 黄色 0805 正贴
LSM0805472V 数据手册
LSM0805 Series 0805 SMD LED Package 2.0 x1.25x 0.8 mm SMD Chip LED LSM0805472V Yellow SMD LED. Low Profile Surface Mount LED with High intensity light output and low power consumption Application • Wearable and Portable Devices • Automotive Features • Navigations Systems • Home and Smart Appliance • Backlit Keypads • Medical Devices • Health Care Application • Industrial Control Systems • Status Indicator Key Features • 2.0 x 1.25 mm [.079 x .049 in] (0805 package/2012 metric) Chip SMD LED • 0.8 mm [.031 in] in thickness • Low power consumption • Rectangle flat top LED • Wide viewing angle (120°) • Optimized light coupling by inter reflector • GaInP technology • Top emitting package • Small 0805 LED package, flexible application with small space required. • Available in a range of colors: red, white, green, blue and yellow making it ideal for status indication • Cost-efficient solution for low-power and compact electronic equipment designs • Compatible with automatic placement equipment and available in automation-friendly tape and reel • Ideal for special configurations for automated PC board assembly and space-sensitive applications • Pb-free • Moisture sensitivity level: 3 • Package 3,000 pieces per reel • Compliant with RoHS and REACH vcclite.com | 1.800.522.5546 LSM0805472V | 05/19 | Page 1 of 8 Ordering Data Product Dimensions 1.25 [.049] R0.20 [.008] 1.40 [.055] Polarity 2.0 [.079] 1.20 [.047] 0.8 [.031] 0.50 [.02] Recommended Soldering Pattern 1.1 [.043] 1.0 [.039] 1.35 [.053] 0.40 [.016] 0.40 [.016] 2.0 [.079] Notes: 1. All dimensions are in mm [in] 2. Tolerance is ±0.1 mm [.004 in] unless otherwise noted 3. The specifications, characteristics and technical data described in the datasheet are subject to change without prior notice. vcclite.com | 1.800.522.5546 LSM0805472V | 05/19 | Page 2 of 8 Product Specifications Absolute Maximum Ratings (ta=25˚C) Notes: 1. Tolerance of Luminous Intensity ±3% 2. Tolerance of Dominant Wavelength ±1nm 3. Tolerance of Forward Voltage ±0.03V vcclite.com | 1.800.522.5546 LSM0805472V | 05/19 | Page 3 of 8 Product Specifications Typical Electrical-Optical Characteristics Curves vcclite.com | 1.800.522.5546 LSM0805472V | 05/19 | Page 4 of 8 Reliability Data The reliability of products shall be satisfied with items listed below. Confidence level: 90% LTPD: 10% vcclite.com | 1.800.522.5546 LSM0805472V | 05/19 | Page 5 of 8 Recommended Reflow Soldering Profile Reflow Soldering Use the conditions shown in the figure below for PB-Free Reflow Soldering. • Reflow soldering should not be done more than two times. • Stress on the LEDs should be avoided during heating in soldering process. • After soldering, do not handle the product before its temperature drops down to room temperature. vcclite.com | 1.800.522.5546 LSM0805472V | 05/19 | Page 6 of 8 Precautions • Storage Moisture proof and anti-electrostatic package with moisture absorbent material are used, to keep moisture to a minimum. Before opening the package, the product should be kept at 30°C or less and humidity less than 60%Rh, and be used within a year. After opening the package, the product should be stored at 30°C or less and humidity less than 10%RH, and be soldered within 24 hours. It is recommended that the product be operated at the workshop condition of 30°C or less and humidity less than 60%RH. If the moisture absorbent material has faded away or the LEDs have exceeded the storage time. Baking should be performed based on the following condition: (60+5C) for 12 hours • Static Electricity Static electricity or surge voltage damages the LEDs. Damaged LEDs will show some unusual characteristics such as the forward voltage becomes lower, or the LEDs do not light at the low current, even not light. All devices, equipment, and machinery must be properly grounded. At the same time, it is recommended that wristbands or anti-electrostatic gloves, anti-electrostatic containers be used when dealing with the LEDs. Circuit Design Notes • Design Consideration In designing a circuit, the current through each LED must not exceed the absolute maximum rating specified for each LED. In the meanwhile, resistors for protection should be applied, otherwise slight voltage shift will cause big current change, burn out may happen. It is recommended to use Circuit A which regulates the current flowing through each LED rather than Circuit B in forward Voltage (Vf) of the LEDs. In the worst case, some LED may be subjected to stresses in excess of the Absolute Maximum Rating • Thermal Design Is paramount importance because heat generation may result in the Characteristics decline, such as brightness decreased, Color changed and so on. Please consider the heat generation of the LEDs when making the system design. vcclite.com | 1.800.522.5546 LSM0805472V | 05/19 | Page 7 of 8 Tape and Reel Specifications Notes: 1. All dimensions are in mm [in] 2. Tolerance is ±0.1 mm [.004 in] unless otherwise noted 3. The specifications, characteristics and technical data described in the datasheet are subject to change without prior notice. Compliances and Approvals vcclite.com | 1.800.522.5546 LSM0805472V | 05/19 | Page 8 of 8
LSM0805472V 价格&库存
很抱歉,暂时无法提供与“LSM0805472V”相匹配的价格&库存,您可以联系我们找货
LSM0805472V
  • 1+3.174871+0.41204
  • 10+2.1584810+0.28014
  • 100+1.52767100+0.19827
  • 500+1.24138500+0.16111
  • 1000+1.146831000+0.14884
库存:4525
LSM0805472V
  • 3000+1.024933000+0.13302
  • 6000+0.962696000+0.12494
  • 9000+0.930759000+0.12080
  • 15000+0.8946715000+0.11611
  • 21000+0.8731921000+0.11333
  • 30000+0.8522330000+0.11061
库存:4525
LSM0805472V
  • 1+3.14215
  • 30+3.03380
  • 100+2.81710
  • 500+2.60040
  • 1000+2.49205
