IRF7469TR
IRF7469TR
    VBSEMI(微碧)
    SO8_150MIL
    MOSFETs SO8_150MIL N-沟道 VDS=40V ID=10A
IRF7469TR 数据手册
IRF7469TR www.VBsemi.com N-Channel 40-V (D-S) MOSFET FEATURES PRODUCT SUMMARY RDS(on) (Ω) ID (A)d 0.014 at VGS = 10 V 10 0.016 at VGS = 4.5 V 9 VDS (V) 40 • Halogen-free According to IEC 61249-2-21 Definition • TrenchFET® Power MOSFET • 100 % Rg Tested • 100 % UIS Tested • Compliant to RoHS directive 2002/95/EC Qg (Typ.) 15 nC APPLICATIONS • Synchronous Rectification • POL, IBC - Secondary Side SO-8 S 1 8 D S 2 7 D S 3 6 D G 4 5 D D G Top View S N-Channel MOSFET ABSOLUTE MAXIMUM RATINGS TA = 25 °C, unless otherwise noted Parameter Drain-Source Voltage Gate-Source Voltage Continuous Drain Current (TJ = 150 °C) Pulsed Drain Current Avalanche Current Avalanche Energy TC = 25 °C TC = 70 °C TA = 25 °C TA = 70 °C L = 0.1 mH TC = 25 °C Continuous Source-Drain Diode Current TA = 25 °C TC = 25 °C TC = 70 °C Maximum Power Dissipation TA = 25 °C TA = 70 °C Operating Junction and Storage Temperature Range Symbol VDS VGS Limit 40 ± 20 10 8 10.4a, b 8.8a, b 50 15 11 5 2.1a, b 6 3.8 2.5a, b 1.6a, b - 55 to 150 ID IDM IAS EAS IS PD TJ, Tstg Unit V A mJ A W °C THERMAL RESISTANCE RATINGS Parameter Maximum Junction-to-Ambienta, c Maximum Junction-to-Foot (Drain) t ≤ 10 s Steady State Symbol RthJA RthJF Typical 37 17 Maximum 50 21 Unit °C/W Notes: a. Surface Mounted on 1" x 1" FR4 board. b. t = 10 s. c. Maximum under Steady State conditions is 85 °C/W. d. Based on TC = 25 °C. 服务热线:400-655-8788 1 IRF7469TR www.VBsemi.com SPECIFICATIONS TJ = 25 °C, unless otherwise noted Parameter Symbol Test Conditions Min. VDS VGS = 0 V, ID = 250 µA 40 Typ. Max. Unit Static Drain-Source Breakdown Voltage VDS Temperature Coefficient ΔVDS/TJ VGS(th) Temperature Coefficient ΔVGS(th)/TJ Gate-Source Threshold Voltage V 40 ID = 250 µA mV/°C -6 VGS(th) VDS = VGS , ID = 250 µA 3 V Gate-Source Leakage IGSS VDS = 0 V, VGS = ± 20 V ± 100 nA Zero Gate Voltage Drain Current IDSS VDS = 40 V, VGS = 0 V 1 VDS = 40 V, VGS = 0 V, TJ = 55 °C 5 On-State Drain Currenta ID(on) Drain-Source On-State Resistancea Forward Transconductancea RDS(on) gfs VDS ≥ 5 V, VGS = 10 V 1 µA A 50 VGS = 10 V, ID = 12.4 A 0.014 VGS = 4.5 V, ID = 10.8 A 0.016 VDS = 15 V, ID = 12.4 A 56 Ω S b Dynamic Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss Total Gate Charge Qg Gate-Source Charge Qgs Gate-Drain Charge Qgd Gate Resistance Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Rg 2000 VDS = 20 V, VGS = 0 V, f = 1 MHz td(off) pF 150 VDS = 10 V, VGS = 10 V, ID = 12.4 A VDS = 10 V, VGS = 4.5 V, ID = 12.4 A 33 50 15 23 6.7 f = 1 MHz VDD = 20 V, RL = 2 Ω ID ≅ 10 A, VGEN = 4.5 V, Rg = 1 Ω 1.4 2.1 25 40 12 20 25 40 tf 10 15 td(on) 10 15 15 25 30 45 10 15 tr td(off) nC 5.1 td(on) tr 260 VDD = 20 V, RL = 2 Ω ID ≅ 10 A, VGEN = 10 V, Rg = 1 Ω tf Ω ns Drain-Source Body Diode Characteristics Continuous Source-Drain Diode Current IS Pulse Diode Forward Current ISM Body Diode Voltage VSD Body Diode Reverse Recovery Time trr Body Diode Reverse Recovery Charge Qrr Reverse Recovery Fall Time ta Reverse Recovery Rise Time tb TC = 25 °C 30 50 IS = 10 A, VGS = 0 V IF = 10 A, dI/dt = 100 A/µs, TJ = 25 °C A 0.8 1.2 V 30 60 ns 26 52 nC 17.5 12.5 ns Notes: a. Pulse test; pulse width ≤ 300 µs, duty cycle ≤ 2 % b. Guaranteed by design, not subject to production testing. Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. 服务热线:400-655-8788 2 IRF7469TR www.VBsemi.com TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted 50 10 VGS = 10 V thru 5 V 8 ID - Drain Current (A) ID - Drain Current (A) 40 30 20 4V 10 6 TC = 25 °C 4 TC = 125 °C 2 3V 0 0 0.4 0.8 1.2 1.6 0 0.0 2.0 TC = - 55 °C 0.5 1.0 1.5 Output Characteristics 3.0 3.5 35 40 125 150 Transfer Characteristics 2400 0.024 Ciss 2000 0.019 VGS = 4.5 V C - Capacitance (pF) RDS(on) - On-Resistance (Ω) 2.5 VGS - Gate-to-Source Voltage (V) VDS - Drain-to-Source Voltage (V) 0.014 VGS = 10 V 1600 1200 800 0.009 Coss 400 0.004 0 10 20 30 40 Crss 0 50 0 5 10 15 20 25 30 ID - Drain Current (A) VDS - Drain-to-Source Voltage (V) On-Resistance vs. Drain Current and Gate Voltage Capacitance 10 1.8 VDS = 20 V ID = 12.4 A 8 1.6 R DS(on) - On-Resistance (Normalized) VGS - Gate-to-Source Voltage (V) 2.0 6 4 2 VGS = 10 V ID = 12.4 A 1.4 1.2 1.0 0.8 0 0 5 10 15 20 25 Qg - Total Gate Charge (nC) Gate Charge 服务热线:400-655-8788 30 35 0.6 - 50 - 25 0 25 50 75 100 TJ - Junction Temperature (°C) On-Resistance vs. Junction Temperature 3 IRF7469TR www.VBsemi.com TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted 60 0.030 ID = 12.4 A RDS(on) - On-Resistance (Ω) I S - Source Current (A) 0.025 TJ = 150 °C 10 TJ = 25 °C 1 0.0 0.020 125 °C 0.015 0.010 25 °C 0.005 0.000 0.2 0.4 0.6 0.8 1.0 0 1.2 2 4 6 8 10 VSD - Source-to-Drain Voltage (V) VGS - Gate-to-Source Voltage (V) Source-Drain Diode Forward Voltage On-Resistance vs. Gate-to-Source Voltage 2.4 50 ID = 250 µA 2.2 40 30 Power (W) V GS(th) (V) 2.0 1.8 1.6 20 1.4 10 1.2 1.0 - 50 - 25 0 25 50 75 100 125 0 0.001 150 0.01 0.1 1 10 100 TJ - Temperature (°C) Time (s) Threshold Voltage Single Pulse Power (Junction-to-Ambient) 100 Limited by RDS(on)* 100 µs 10 I D - Drain Current (A) 600 1 ms 1 10 ms 100 ms 1s 10 s 0.1 0.01 0.1 BVDSS Limited TA = 25 °C Single Pulse 1 DC 10 100 VDS - Drain-to-Source Voltage (V) * VGS > minimum VGS at which R DS(on) is specified Safe Operating Area, Junction-to-Ambient 服务热线:400-655-8788 4 IRF7469TR www.VBsemi.com TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted 6 25 5 Power Dissipation (W) I D - Drain Current (A) 20 15 10 5 4 3 2 1 0 0 0 25 50 75 100 TC - Case Temperature (°C) Current Derating* 125 150 25 50 75 100 125 150 TC - Case Temperature (°C) Power Derating * The power dissipation PD is based on TJ(max) = 150 °C, using junction-to-case thermal resistance, and is more useful in settling the upper dissipation limit for cases where additional heatsinking is used. It is used to determine the current rating, when this rating falls below the package limit. 服务热线:400-655-8788 5 IRF7469TR www.VBsemi.com TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted Normalized Effective Transient Thermal Impedance 2 1 Duty Cycle = 0.5 0.2 Notes: 0.1 0.1 PDM 0.05 t1 t2 1. Duty Cycle, D = t1 t2 2. Per Unit Base = R thJA = 68 °C/W 0.02 0.01 3. T JM - TA = PDMZthJA(t) Single Pulse 10 -4 4. Surface Mounted 10 -3 10 -2 10 -1 1 Square Wave Pulse Duration (s) 10 100 600 Normalized Thermal Transient Impedance, Junction-to-Ambient 2 Normalized Effective Transient Thermal Impedance 1 Duty Cycle = 0.5 0.2 0.1 0.1 0.05 0.02 0.01 Single Pulse 10-4 10-3 10-2 10-1 1 10 Square Wave Pulse Duration (s) Normalized Thermal Transient Impedance, Junction-to-Foot 服务热线:400-655-8788 6 IRF7469TR www.VBsemi.com SOIC (NARROW): 8-LEAD JEDEC Part Number: MS-012 8 6 7 5 E 1 3 2 H 4 S h x 45 D C 0.25 mm (Gage Plane) A e B All Leads A1 q L 0.004" MILLIMETERS DIM Min INCHES Max Min Max A 1.35 1.75 0.053 0.069 A1 0.10 0.20 0.004 0.008 B 0.35 0.51 0.014 0.020 C 0.19 0.25 0.0075 0.010 D 4.80 5.00 0.189 0.196 E 3.80 4.00 0.150 e 0.101 mm 1.27 BSC 0.157 0.050 BSC H 5.80 6.20 0.228 0.244 h 0.25 0.50 0.010 0.020 L 0.50 0.93 0.020 0.037 q 0° 8° 0° 8° S 0.44 0.64 0.018 0.026 ECN: C-06527-Rev. I, 11-Sep-06 DWG: 5498 服务热线:400-655-8788 7 IRF7469TR www.VBsemi.com RECOMMENDED MINIMUM PADS FOR SO-8 0.172 (4.369) 0.028 0.022 0.050 (0.559) (1.270) 0.152 (3.861) 0.047 (1.194) 0.246 (6.248) (0.711) Recommended Minimum Pads Dimensions in Inches/(mm) 服务热线:400-655-8788 8 IRF7469TR www.VBsemi.com Disclaimer All products due to improve reliability, function or design or for other reasons, product specifications and data are subject to change without notice. Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or incomplete data contained in the table or any other any disclosure of any information related to the product.(www.VBsemi.com) Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability, including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties, including a particular purpose, non-infringement and merchantability guarantee. Statement on certain types of applications are based on knowledge of the product is often used in a typical application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific product features in the products described in the specification is appropriate for use in a particular application. Parameter data sheets and technical specifications can be provided may vary depending on the application and performance over time. All operating parameters, including typical parameters must be made by customer's technical experts validated for each customer application. Product specifications do not expand or modify Taiwan VBsemi purchasing terms and conditions, including but not limited to warranty herein. Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving, or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and other terms and conditions in writing. The information provided in this document and the company's products without a license, express or implied, by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product names and trademarks referred to herein are trademarks of their respective representatives will be all. Material Category Policy Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be RoHS compliant and meets the definition of restrictions under Directive of the European Parliament 2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com) Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive 2011/65 /. Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
IRF7469TR 价格&库存
很抱歉,暂时无法提供与“IRF7469TR”相匹配的价格&库存,您可以联系我们找货
