SLVU2.8-4.TBT
SLVU2.8-4.TBT
    UMW(友台)
    SO8_150MIL
    ESD抑制器/TVS二极管 SO8_150MIL 双向 4通道 VRWM=2.8V IPP=10A
SLVU2.8-4.TBT 数据手册
SLVU2.8-4.TBT 2.8V TVS Array For ESD and Latch-Up Protection Description The SLVU2.8-4.TBT is designed to protect low voltage,CMOS semiconductors from transients caused by electrostatic discharge(ESD),cable discharge events(CDE), lightning and other induced voltage surges. Low capacitance compensation diode is integrated into the TVS to lower the typical capacitance to 6pF per line. The complies with the IEC 61000-4-2 SLVU2.8-4 (ESD) standard with ±30kV air and ±30kV contact discharge. The SLVU2.8-4.TBT is assembled into a 8-pin lead-free SO-8 package. The combination of low leakage, signal integrity and flow through design makes the SLVU2.8-4.TBT an ideal application such as 10/100/1000 Ethernet. Mechanical Characteristics        Features  100W peak pulse power(8/20µs)  Protects two line pairs(four lines)  Ultra low leakage:nA level Package: SOP-8 Lead Finish: Matte Tin Case Material: “Green” Molding Compound. UL Flammability Classification Rating 94V-0 Moisture Sensitivity: Level 3 per J-STD-020 Terminal Connections: See Diagram Below Marking Information: See Below  Low operating voltage:2.8V Low capacitance Ultra low clamping voltage JEDEC SO-8 package Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV – IEC61000-4-4 (EFT) 40A (5/50ns) – IEC61000-4-5 (Lightning) 10A (8/20µs)  RoHS Compliant     Applications        Base Station Analog Inputs Switch Systems 10/100/1000 Ethernet WAN/LAN Equipment Desktops, Servers, and Notebooks Low Voltage Interfaces www.umw-ic.com Circuit and Pin Schematic 1 友台半导体有限公司 SLVU2.8-4.TBT 2.8V TVS Array For ESD and Latch-Up Protection Absolute Maximum Ratings (TA=25°C unless otherwise specified) Parameter Symbol Value Unit Peak Pulse Power(8/20µs) Ppk 100 W Peak Pulse Current(8/20µs) IPP 10 A ESD per IEC 61000−4−2 (Air) ±30 VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range Storage Temperature Range kV ±30 TJ −40 to +125 °C Tstg −55 to +150 °C Electrical Characteristics (TA=25°C unless otherwise specified) Parameter Reverse Working Voltage Symbol Min Typ VRWM Punch-Through Voltage VPT 3.5 Snap-Back Voltage VSB 2.8 3.8 Max Unit 2.8 V 4.3 V Test Condition IPT = 2µA ISB = 50mA Reverse Leakage Current IR 1.0 µA VRWM = 2.8V Clamping Voltage VC 5.5 V IPP = 1A (8 x 20µs pulse) Clamping Voltage VC 10 V IPP = 10A (8 x 20µs pulse) Variation in capacitance with 1.3 reverse bias Junction Capacitance www.umw-ic.com CJ 4.5 2 pF 6 pF Pins 1,8 to 2,7 and pins 3,6 to 4,5 VR = 0 to 2.8V, f = 1MHz Pins 1,8 to 2,7 and pins 3,6 to 4,5 VR = 2.8V, f = 1MHz 友台半导体有限公司 SLVU2.8-4.TBT 2.8V TVS Array For ESD and Latch-Up Protection Typical Performance Characteristics (T A=25°C unless otherwise Specified) Non-Repetitive Peak Pulse Power vs. Pulse Time Clamping Voltage vs. Peak Pulse Current 10 9 Clamping Voltage - VC (V) Peak Pulse Power - PPP (kW) 10 1 0.1 8 7 6 5 4 3 Waveform Parameters: tr = 8μs td = 20μs 2 1 0.01 0.1 1 10 0 100 0 Pulse Duration - tp (us) 2 4 6 8 10 12 Peak Pulse Current - IPP (A) Typical Insertion Loss (S21) Normalized Junction Capacitance vs. Reverse Voltage CH1 S21 LOG 6 dB / REF 0 dB 1: -1.8892 dB 800 MHz 2 Cj(VR) / Cj(VR=0V) 1.8 1.6 0 dB 1.4 -6 dB 2: -2.1247 dB 900 MHz 12 3: -6.9338 dB 1.8 GHz 3 1.2 -12 dB 1 -18 dB 5 0.8 4: -15.047 dB 2.5 GHz 4 -24 dB 0.6 -30 dB 0.4 0.2 -36 dB f = 1 MHz 0 -42 dB 0 0.5 1 1.5 2 2.5 3 -48 dB Reverse Voltage (VR) 1 MHz 10 MHz 100 MHz STOP 3000. 000000 MHz START . 030 MHz ESD Clamping (-8kV Contact per IEC 61000-4-2) ESD Clamping (8kV Contact per IEC 61000-4-2) Note: Data is taken with a 10x attenuator www.umw-ic.com 3 1 GHz GHz Note: Data is taken with a 10x attenuator 3 友台半导体有限公司 SLVU2.8-4.TBT SO-8 Package Outline Drawing 2.8V TVS Array For ESD and Latch-Up Protection DIMENSIONS MIN 1.35 0.10 1.25 0.31 0.17 NOM MAX 1.75 0.25 1.65 0.51 0.25 MIN 0.053 0.004 0.049 0.012 0.007 NOM MAX 0.069 0.010 0.065 0.020 0.010 D 4.80 4.90 5.00 0.189 0.193 0.197 E1 3.80 3.90 4.00 0.150 0.154 0.157 E e h 0.25 L 0.40 SYM Land Pattern INCHES SY M A A1 A2 b c L1 N θ1 aaa bbb ccc Suggested MILLIMETERS 6.00 BSC 1.27 BSC 0.236 BSC 0.050 BSC 0.72 0.50 0.010 1.04 0.016 (1.04) 8 0.020 0.028 0.041 (0.041) 8 0° 8° 0° 0.10 0.25 0.20 8° 0.004 0.010 0.008 DIMENSIONS MILLIMETERS INCHES C (5.20) 0.205 G 3.00 0.118 P 1.27 0.050 X 0.60 0.024 Y 2.20 0.087 Z 7.40 0.291 Marking Information YYXX= Date Code Dot denotes Pin1 Ordering Information Part Number UMW SLVU2.8-4.TBT www.umw-ic.com Marking Base qty SLVU2.8-4 500 4 Delivery mode Tape & Reel 友台半导体有限公司
SLVU2.8-4.TBT 价格&库存
很抱歉,暂时无法提供与“SLVU2.8-4.TBT”相匹配的价格&库存,您可以联系我们找货
