CONDUCTIVE POLYMER HYBRID ALUMINUM ELECTROLYTIC CAPACITORS
Surface Mount
HXA
Series
・High reliability and high voltage are realized by hybrid electrolyte
・Endurance with ripple current : 4,000 hours at 125℃
・For high temperature and high reliability applications.
(Automotive equipment, Base station equipment, etc.)
・RoHS Compliant
・Halogen Free
・AEC-Q200 compliant : Please contact Chemi-Con for more details, test data, information.
HXA
Higher temperature
HXB P78
◆SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
-55 to +125℃
16 to 80Vdc
±20% (M)
I=0.01CV
Where, I : Max. leakage current (μA)
, C: Nominal capacitance(μF), V : Rated voltage(V)
Rated voltage(Vdc)
16V
25V
35V
50V
63V
80V
tanδ
0.16
0.14
0.12
0.10
0.08
0.08
(Max.)
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
Endurance
◆MARKING
Code : A
EX) 35V47µF
Vent for JA0
26A
Size Code
F61
F80
HA0
JA0
P
C±0.2
B±0.2
φD±0.5
W
0.3max.
L±0.3 (Note)
φD
6.3
6.3
8
10
L
A
B
C
5.8 6.6 6.6 7.2
7.7 6.6 6.6 7.2
10.0 8.3 8.3 9.0
10.0 10.3 10.3 11.0
A±0.2
◆PART NUMBERING SYSTEM
2
3
4
5
6
7
8
9
10
A RA
11
12
13
14
M
15
16
17
W
0.5 to 0.8
0.5 to 0.8
0.7 to 1.1
0.7 to 1.1
P
1.9
1.9
3.1
4.5
47
V HA
●Rated
voltage symbol
Rated voltage (Vdc)
16
25
35
50
63
80
Note : L±0.5 for HA0 and JA0
1
(at 20℃, 120Hz)
(at 100kHz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated
ripple current is applied (the peak voltage shall not exceed the rated voltage) for 4,000 hours at 125℃.
Capacitance change
≦±30% of the initial value
D.F. (tanδ)
≦ 200% of the initial specified value
ESR
Leakage current
≦ The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 125℃
without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to item 4.1 of JIS
C 5101-4.
Capacitance change
D.F. (tanδ)
ESR
Leakage current
◆DIMENSIONS [mm]
H HXA
(at 20℃ after 2 minutes)
Z(-25℃)/Z(+20℃)≦1.5
Z(-55℃)/Z(+20℃)≦2.0
Shelf Life
●Terminal
(at 20℃, 120Hz)
18
G
Symbol
C
E
V
H
J
K
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 47µF:470, 100µF:101)
Taping code
Terminal code
Voltage code (ex. 35V:350, 50V:500)
Series code
Category
Please refer to "Product code guide (conductive polymer hybrid type)"
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
76
CAT. No. E1001Q
Surface Mount
HXASeries
◆STANDARD RATINGS
WV
(Vdc)
16
25
35
50
63
80
Cap
(µF)
Size code
ESR
(mΩmax./20℃, 100kHz)
Rated ripple current
(mArms/125℃, 100kHz)
Part No.
82
150
270
470
47
56
68
100
150
220
270
330
27
47
47
68
100
150
150
270
10
15
22
33
33
47
56
68
100
6.8
10
10
22
22
33
33
56
22
39
F61
F80
HA0
JA0
F61
F61
F80
F80
HA0
HA0
JA0
JA0
F61
F61
F80
F80
HA0
HA0
JA0
JA0
F61
F80
F61
F80
HA0
HA0
JA0
HA0
JA0
F61
F61
F80
F80
HA0
HA0
JA0
JA0
HA0
JA0
45
27
22
18
50
50
30
30
27
27
60
35
35
27
27
40
80
40
30
30
25
30
25
120
120
80
80
40
40
30
30
45
35
950
1,450
1,700
2,100
900
900
1,400
1,400
1,600
1,600
2,000
2,000
900
900
1,400
1,400
1,600
1,600
2,000
2,000
750
1,100
750
1,100
1,250
1,250
1,600
1,250
1,600
700
700
900
900
1,100
1,100
1,400
1,400
1,100
1,200
HHXA160ARA820MF61G
HHXA160ARA151MF80G
HHXA160ARA271MHA0G
HHXA160ARA471MJA0G
HHXA250ARA470MF61G
HHXA250ARA560MF61G
HHXA250ARA680MF80G
HHXA250ARA101MF80G
HHXA250ARA151MHA0G
HHXA250ARA221MHA0G
HHXA250ARA271MJA0G
HHXA250ARA331MJA0G
HHXA350ARA270MF61G
HHXA350ARA470MF61G
HHXA350ARA470MF80G
HHXA350ARA680MF80G
HHXA350ARA101MHA0G
HHXA350ARA151MHA0G
HHXA350ARA151MJA0G
HHXA350ARA271MJA0G
HHXA500ARA100MF61G
HHXA500ARA150MF80G
HHXA500ARA220MF61G
HHXA500ARA330MF80G
HHXA500ARA330MHA0G
HHXA500ARA470MHA0G
HHXA500ARA560MJA0G
HHXA500ARA680MHA0G
HHXA500ARA101MJA0G
HHXA630ARA6R8MF61G
HHXA630ARA100MF61G
HHXA630ARA100MF80G
HHXA630ARA220MF80G
HHXA630ARA220MHA0G
HHXA630ARA330MHA0G
HHXA630ARA330MJA0G
HHXA630ARA560MJA0G
HHXA800ARA220MHA0G
HHXA800ARA390MJA0G
77
CAT. No. E1001Q
很抱歉,暂时无法提供与“HHXA630ARA100MF61G”相匹配的价格&库存,您可以联系我们找货
