APSA100ELL271MHB5S
APSA100ELL271MHB5S
    NCC(贵弥功)
    插件
    270 µF 10 V 铝聚合物电容器 径向,Can 9 毫欧 105°C 时为 2000 小时
APSA100ELL271MHB5S 数据手册
CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS Radial Lead Upgrade! @Super low ESR, high temperature resistance and high ripple current capability @Rated voltage range : 2.5 to 16Vdc @2,000 hours at 105C @Suitable for DC-DC converters, voltage regulators and decoupling applications for computer motherboards @RoHS Compliant ?SPECIFICATIONS Items Characteristics Category Temperature Range -55 to +105C Rated Voltage Range Capacitance Tolerance Surge Voltage Leakage Current *Note 2.5 to 16Vdc P20% (M) Rated voltage(V)B1.15 I=0.2CV (max.) Where, I : Leakage current (MA), C : Nominal capacitance (MF), V : Rated voltage (Vdc) Dissipation Factor (tane) 0.08 max. Low Temperature Characteristics Endurance Bias Humidity Test Surge Voltage Test Failure Rate (at 20C, 120Hz) (at 105C) (at 20C after 2 minutes) (at 20C, 120Hz) Max. impedance ratio at 100kHz to the 20C value Z(-25C)/Z(+20C)[1.15 Z(-55C)/Z(+20C)[1.25 The following specifications shall be satisfied when the capacitors are restored to 20C after the rated voltage is applied for 2,000 hours at 105C. Appearance No significant damage Capacitance change [P20% of the initial measured value D.F. (tanE) [150% of the initial specified value ESR [150% of the initial specified value Leakage current [The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20C after subjecting them to DC voltage at 60C, 90 to 95% RH for 1,000 hours. Appearance No significant damage Capacitance change [P20% of the initial measured value D.F. (tanE) [150% of the initial specified value ESR [150% of the initial specified value Leakage current [The initial specified value The capacitors shall be subjected to 1,000 cycles each consisting of charge with the surge voltage specified at 105C for 30 seconds through a protective resistor(R=1kO) and discharge for 5 minutes 30 seconds. Appearance No significant damage Capacitance change [P20% of the initial measured value D.F. (tanE) [150% of the initial specified value ESR [150% of the initial specified value Leakage current [The initial specified value 1% per 1,000 hours maximum (Confidence level 60% at 105C) *Note : If any doubt arises, measure the leakage current after the following voltage treatment. Voltage treatment : DC rated voltage is applied to the capacitors for 120 minutes at 105C. ?DIMENSIONS [mm] ?MARKING @Terminal Code : E FP0.5 EX) 4V560MF FD+0.5max. Fd Coated Case L' 15min. 4min. A 292 560 4V fD fd L' F (1/2) 6.3 0.5 L+0.3max 2.5 8 10 0.8 L+1.5max 3.5 5 CAT. No. E1001E CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS Radial Lead Upgrade! ?PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 A PSA AAA E AA AAA M AAA S Supplement code Size code Capacitance tolerance code Capacitance code (ex. 270MF:271,1000MF:102) Lead forming·Taping code Terminal code Voltage code (ex. 4V:4R0,6.3V:6R3,10V:100) Series code Category Please refer to "A guide to global code (conductive polymer type)" ?STANDARD RATINGS WV(Vdc) 2.5 4 6.3 10 16 Cap(mF) Case size fDbL(mm) ESR (momax/20c, 100k to 300kHz) Rated ripple current (mArms/105c, 100kHz) 390 680 820 1,000 270 390 560 820 220 330 390 680 47 68 100 150 270 470 100 6.3B10.5 8B11.5 8B11.5 10B11.5 6.3B10.5 6.3B10.5 8B11.5 10B11.5 6.3B10.5 6.3B10.5 8B11.5 10B11.5 6.3B10.5 6.3B10.5 6.3B10.5 6.3B10.5 8B11.5 10B11.5 6.3B10.5 20 7 7 6 20 24 7 6 20 28 8 7 25 25 25 25 9 8 25 3,160 5,580 5,580 5,860 3,160 3,300 5,580 5,860 3,160 3,190 5,080 5,860 2,820 2,820 2,820 2,820 4,710 5,650 2,820 Part No. APSA2R5ESS391MFA5G APSA2R5ESS681MHB5S APSA2R5ESS821MHB5S APSA2R5ESS102MJB5S APSA4R0ESS271MFA5G APSA4R0ESS391MFA5G APSA4R0ESS561MHB5S APSA4R0ESS821MJB5S APSA6R3ESS221MFA5G APSA6R3ESS331MFA5G APSA6R3ESS391MHB5S APSA6R3ESS681MJB5S APSA100ESS470MFA5G APSA100ESS680MFA5G APSA100ESS101MFA5G APSA100ESS151MFA5G APSA100ESS271MHB5S APSA100ESS471MJB5S APSA160ESS101MFA5G SS : Lead forming code and taping code (2/2) CAT. No. E1001E
APSA100ELL271MHB5S 价格&库存
很抱歉,暂时无法提供与“APSA100ELL271MHB5S”相匹配的价格&库存,您可以联系我们找货
