CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS
Radial Lead
Upgrade!
@Super low ESR, high temperature resistance and high ripple current capability
@Rated voltage range : 2.5 to 16Vdc
@2,000 hours at 105C
@Suitable for DC-DC converters, voltage regulators and decoupling applications
for computer motherboards
@RoHS Compliant
?SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
-55 to +105C
Rated Voltage Range
Capacitance Tolerance
Surge Voltage
Leakage Current
*Note
2.5 to 16Vdc
P20% (M)
Rated voltage(V)B1.15
I=0.2CV (max.)
Where, I : Leakage current (MA), C : Nominal capacitance (MF), V : Rated voltage (Vdc)
Dissipation Factor
(tane)
0.08 max.
Low Temperature
Characteristics
Endurance
Bias Humidity Test
Surge Voltage Test
Failure Rate
(at 20C, 120Hz)
(at 105C)
(at 20C after 2 minutes)
(at 20C, 120Hz)
Max. impedance ratio at 100kHz to the 20C value
Z(-25C)/Z(+20C)[1.15
Z(-55C)/Z(+20C)[1.25
The following specifications shall be satisfied when the capacitors are restored to 20C after the rated voltage is applied for 2,000 hours
at 105C.
Appearance
No significant damage
Capacitance change
[P20% of the initial measured value
D.F. (tanE)
[150% of the initial specified value
ESR
Leakage current
[The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20C after subjecting them to DC voltage at 60C,
90 to 95% RH for 1,000 hours.
Appearance
Capacitance change
D.F. (tanE)
ESR
Leakage current
The capacitors shall be subjected to 1,000 cycles each consisting of charge with the surge voltage specified at 105C for 30 seconds
through a protective resistor(R=1kO) and discharge for 5 minutes 30 seconds.
Appearance
Capacitance change
D.F. (tanE)
ESR
Leakage current
1% per 1,000 hours maximum (Confidence level 60% at 105C)
*Note : If any doubt arises, measure the leakage current after the following voltage treatment.
Voltage treatment : DC rated voltage is applied to the capacitors for 120 minutes at 105C.
?DIMENSIONS [mm]
?MARKING
@Terminal Code : E
FP0.5
EX) 4V560MF
FD+0.5max.
Fd
Coated Case
L'
15min.
4min.
A 292
560
4V
fD
fd
L'
F
(1/2)
6.3
0.5
L+0.3max
2.5
8
10
0.8
L+1.5max
3.5
5
CAT. No. E1001E
Radial Lead
Upgrade!
?PART NUMBERING SYSTEM
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
A PSA AAA E AA AAA M AAA S
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 270MF:271,1000MF:102)
Lead forming·Taping code
Terminal code
Voltage code (ex. 4V:4R0,6.3V:6R3,10V:100)
Series code
Category
Please refer to "A guide to global code (conductive polymer type)"
?STANDARD RATINGS
WV(Vdc)
2.5
4
6.3
10
16
Cap(mF)
Case size
fDbL(mm)
ESR
(momax/20c, 100k to 300kHz)
Rated ripple current
(mArms/105c, 100kHz)
390
680
820
1,000
270
390
560
820
220
330
390
680
47
68
100
150
270
470
100
6.3B10.5
8B11.5
8B11.5
10B11.5
6.3B10.5
6.3B10.5
8B11.5
10B11.5
6.3B10.5
6.3B10.5
8B11.5
10B11.5
6.3B10.5
6.3B10.5
6.3B10.5
6.3B10.5
8B11.5
10B11.5
6.3B10.5
7
6
7
6
8
7
25
25
25
25
9
8
25
3,160
5,580
5,580
5,860
3,160
3,300
5,580
5,860
3,160
3,190
5,080
5,860
2,820
2,820
2,820
2,820
4,710
5,650
2,820
Part No.
APSA2R5ESS391MFA5G
APSA2R5ESS681MHB5S
APSA2R5ESS821MHB5S
APSA2R5ESS102MJB5S
APSA4R0ESS271MFA5G
APSA4R0ESS391MFA5G
APSA4R0ESS561MHB5S
APSA4R0ESS821MJB5S
APSA6R3ESS221MFA5G
APSA6R3ESS331MFA5G
APSA6R3ESS391MHB5S
APSA6R3ESS681MJB5S
APSA100ESS470MFA5G
APSA100ESS680MFA5G
APSA100ESS101MFA5G
APSA100ESS151MFA5G
APSA100ESS271MHB5S
APSA100ESS471MJB5S
APSA160ESS101MFA5G
SS : Lead forming code and taping code
(2/2)
CAT. No. E1001E
很抱歉,暂时无法提供与“APSA6R3ELL681MJB5S”相匹配的价格&库存,您可以联系我们找货
