CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS
Surface Mount
@Super low ESR, impedance and high heat resistance have been obtained by using
conductive polymer as electrolyte.
(ESR and rated ripple current values are improved from PXA series.)
@Rated voltage range : 2.5 to 16Vdc, Capacitance range : 27 to 470MF
@Case size range : F5B5.7L to F8B6.7L
@Suitable for DC-DC converters, voltage regulators and decoupling applications used to
computer motherboards etc.
@RoHS Compliant
?SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Surge Voltage
Leakage Current
-55 to +105C
2.5 to 16Vdc
P20% (M)
Rated voltage(V)B1.15
I=0.2CV (max.)
I : Max. leakage current (MA), C : Nominal capacitance (MF), V : Rated voltage (Vdc)
Dissipation Factor
(tane)
0.12 max.
Low Temperature
Characteristics
(Max. Impedance Ratio)
Z(-25C)/Z(+20C)[1.15
Z(-55C)/Z(+20C)[1.25
(at 20C, 120Hz)
(at 105C)
(at 20C after 2 minutes)
(at 20C, 120Hz)
(at 100kHz)
The following specifications shall be satisfied when the capacitors are restored to 20C after the rated voltage is applied for 1,000 hours
at 105C.
Appearance
No significant damage
Capacitance change
[P20% of the initial value
DF (tanE)
[150% of the initial specified value
ESR
Leakage current
[The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20C after subjecting them to the DC rated voltage at
60C, 90 to 95% RH for 500 hours.
Appearance
Capacitance change
DF (tanE)
ESR
Leakage current
The capacitors shall be subjected to 1,000 cycles each consisting of charge with the surge voltage specified at 105C for 30 seconds
through a protective resistor(R=1kO) and discharge for 5 minutes 30 seconds.
Appearance
Capacitance change
DF (tanE)
ESR
Leakage current
1% per 1,000 hours maximum (Confidence level 60% at 105C)
Endurance
Bias Humidity
Surge Voltage
Failure Rate
*Note : If any doubt arises, measure the leakage current after following voltage treatment.
Voltage treatment : DC rated voltage are applied to the capacitors for 120 minutes at 105C.
?DIMENSIONS [mm]
?MARKING
@Terminal Code : A
EX) 4V220MF
P
CP0.2
BP0.2
FDP0.5
W
0.3max.
LP0.3
2
3
4
5
6
fD
5
6.3
8
L
5.7
5.7
6.7
A
5.3
6.6
8.3
B
5.3
6.6
8.3
C
5.9
7.2
9.0
W
0.5 to 0.8
0.5 to 0.8
0.7 to 1.1
P
1.4
1.9
3.1
C28M
220
4V
AP0.2
?PART NUMBERING SYSTEM
1
Size code
E60
F60
H70
7
8
9
10
11
12
13
14
15
16
17
18
A PXC AAA A RA AAA M AAA G
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 27MF:270,100MF:101)
Taping code
Terminal code
Voltage code (ex. 6.3V:6R3,10V:100)
Series code
Category Please refer to "A guide to global code (conductive polymer type)"
(1/2)
CAT. No. E1001F
Surface Mount
?STANDARD RATINGS
ESR(momax/20c)
WV(Vdc)
2.5
4
6.3
10
16
Cap(mF)
180
270
470
150
220
330
100
180
220
56
82
150
27
39
82
Size code
E60
F60
H70
E60
F60
H70
E60
F60
H70
E60
F60
H70
E60
F60
H70
100kHz
300kHz(Ref. value)
30
30
21
18
35
22
18
40
23
25
25
22
18
16
22
19
17
26
19
17
31
21
19
35
23
23
(2/2)
Rated ripple current
(mArms/100k to 300kHz)
-55 to +105c
2,000
2,700
3,420
2,000
2,640
3,300
1,780
2,580
3,300
1,660
2,400
3,160
1,570
2,300
2,830
Part No.
APXC2R5ARA181ME60G
APXC2R5ARA271MF60G
APXC2R5ARA471MH70G
APXC4R0ARA151ME60G
APXC4R0ARA221MF60G
APXC4R0ARA331MH70G
APXC6R3ARA101ME60G
APXC6R3ARA181MF60G
APXC6R3ARA221MH70G
APXC100ARA560ME60G
APXC100ARA820MF60G
APXC100ARA151MH70G
APXC160ARA270ME60G
APXC160ARA390MF60G
APXC160ARA820MH70G
CAT. No. E1001F
很抱歉,暂时无法提供与“APXC160ARA270ME60G”相匹配的价格&库存,您可以联系我们找货
