ANT-868-USP410
ANT-868-USP410
    LINXTECHNOLOGIES(灵思)
    SMD,13.2x9.1mm
    RF天线 868MHz ISM,LoRaWAN,LPWA,Sigfox 芯片 RF 天线 862MHz~876MHz 0.7dBi 焊接 表面贴装型
ANT-868-USP410 数据手册
ANT-868-USP410 PCB Antenna, Single Band, LoRaWAN / LPWAN, Internal/Embedded Mount, Surface Mount, Solder, Omnidirectional, Single Port, Gain 0 < 3 dBi ANT-868-USP410  ACTIVE TE Internal #: L9000152-01 PCB Antenna, Single Band, LoRaWAN / LPWAN, Internal /Embedded Mount, Surface Mount, Solder, Omnidirectional, Single Port, Gain 0 < 3 dBi View on TE.com > Antennas Wireless Application: LoRaWAN, LPWAN, Wi-Fi Mounting Location: Internal/Embedded Mounting Type: Surface Mount Antenna Termination: Solder Antenna Type: PCB Features Product Type Features Antenna Termination Solder Configuration Features Antenna Style PCB Mounting Location Internal/Embedded Antenna Type PCB Band Type Single Band Port Configuration Single Port Electrical Characteristics VSWR (Max) EU RoHS Directive 2011/65/EU Compliant EU ELV Directive 2000/53/EC Not Yet Reviewed China RoHS 2 Directive MIIT Order No 32, 2016 No Restricted Materials Above Threshold EU REACH Regulation (EC) No. 1907/2006 Current ECHA Candidate List: JUNE 2023 (235) Not Yet Reviewed Halogen Content Not Yet Reviewed for halogen content Solder Process Capability Not reviewed for solder process capability Product Compliance Disclaimer This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge based on the information they provided. This information is subject to change. The part numbers that TE has identified as EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked.Additionally, the part numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulations, TE’s information on SVHC in articles for this part number is still based on the European Chemical Agency (ECHA) ‘Guidance on requirements for substances in articles’(Version: 2, April 2011), applying the 0.1% weight on weight concentration threshold at the finished product level. TE is aware of the European Court of Justice ruling of September 10th, 2015 also known as O5A (Once An Article Always An Article) stating that, in case of ‘complex object’, the threshold for a SVHC must be applied to both the product as a whole and simultaneously to each of the articles forming part of its composition. TE has evaluated this ruling based on the new ECHA “Guidance on requirements for substances in articles” (June 2017, version 4.0) and will be updating its statements accordingly.  For support call+1 800 522 6752 09/12/2023 08:21AM | Page 2 ANT-868-USP410 PCB Antenna, Single Band, LoRaWAN / LPWAN, Internal/Embedded Mount, Surface Mount, Solder, Omnidirectional, Single Port, Gain 0 < 3 dBi Compatible Parts TE Part # ANT-868-CHP-T TE Part # ANT-868-CPA TE Part # ANT-868-HESM TE Part # ANT-868-JJB-RA Antenna Chip T&R 868MHz SMT Antenna CER Patch 25mm Sq 868MHz Adh Antenna 1/4 Wave Coil 868MHz SMT Antenna Mini R-Angle 868MHz THM TE Part # ANT-868-JJB-ST TE Part # ANT-868-PW-LP TE Part # AEK-868-USP410 Antenna Mini Straight 868MHz THM Antenna 1/4 Wave 868MHz Screw #10 Eval Kit uSP410 868MHz Antenna Customers Also Bought TE Part #1558676-3 TE Part #4-2176345-2 TE Part #1740280-7 TE Part #L9000128-01 T9GS1L24-12 CRGCQ 1210 27K 1% HV100 CONNECTOR 90DEG 6,2MM Antenna FPC 868/915MHz 1.13 100 UFL  TE Part #2-1393216-6 TE Part #3-1768395-8 TE Part #5-1768384-4 TE Part #6-1768062-4 V23057-B3006-A101 LBF-5115411A-001 LBF-166950A02 LBF-204068A02 TE Part #8-1768064-3 TE Part #HUM-868-PRO LBF-142434A03 Module HUM-PRO 868MHz FHSS FM XCVR Documents For support call+1 800 522 6752 09/12/2023 08:21AM | Page 3 ANT-868-USP410 PCB Antenna, Single Band, LoRaWAN / LPWAN, Internal/Embedded Mount, Surface Mount, Solder, Omnidirectional, Single Port, Gain 0 < 3 dBi Documents Product Drawings Antenna uSP PCB RPC 410 868MHz SMT T&R English Datasheets & Catalog Pages Embedded 868 MHz LPWA Antenna English  For support call+1 800 522 6752 09/12/2023 08:21AM | Page 4
ANT-868-USP410 价格&库存
很抱歉,暂时无法提供与“ANT-868-USP410”相匹配的价格&库存,您可以联系我们找货
