ESD101-B1-02EL
ESD101-B1-02EL
    LEIDITECH(雷卯电子)
    DFN1006
    ESD抑制器/TVS二极管 Ppp=110W Vrwm=5V Vbr=6V Vc=12V Ipp=1A Cj=0.22pF
ESD101-B1-02EL 数据手册
ESD101-B1-02EL ULTRA LOW CAPACITANCE BIDIRECTIONAL TVS DIODE Features ● ● ● ● ● Ultra low leakage: nA level Operating voltage: 5V Low clamping voltage Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV – IEC61000-4-4 (EFT) 40A (5/50ns) – IEC61000-4-5 (Lightning) 4.5A (8/20 μs) RoHS Compliant Dimensions DFN1006 Pin Configuration Applications ● ● ● ● ● ● Smart phones Display Ports MDDI Ports USB Ports Digital Video Interface (DVI) PCI Express and Serial SATA Ports Mechanical Characteristics ● Package: DFN1006 ● Lead Finish: Lead Free ● UL Flammability Classification Rating 94V-0 ● Quantity Per Reel:10,000pcs ● Reel Size:7 inch ● Device Marking: 21 Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Value Ppp 110 VESD ± 30 Unit W Kv ± 30 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +150 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 03.07.2021 1/4 www.leiditech.com ESD101-B1-02EL Electrical Characteristics(TA=25°C unless otherwise specified) Parameter Reverse Working Voltage Breakdown Voltage Symbol Test Condition Min Typ VRWM VBR Max Unit 5 V 6 IT = 1mA V Reverse Leakage Current IR VRWM = 5V 0.5 µA Clamping Voltage VC IPP = 1A (8 x 20 μs pulse) 12 V Clamping Voltage VC IPP = 4.5A (8 x 20 μ s pulse) 23 V Junction Capacitance CJ VR = 0V, f = 1MHz Rev : 03.07.2021 2/4 0.22 pF www.leiditech.com ESD101-B1-02EL Typical Performance Characteristics (TA=25°C unless otherwise Specified) Vc-Clamping Voltage(V) CJ-Junction Capacitance (pF) 0.4 0.35 0.3 0.25 0.2 0.15 0.1 25 20 15 10 5 0.05 0 0 0 1 2 3 4 1 5 VR—Reverse Voltage(V) 2 3 4 Ipp-Peak Pulse Current(A) Clamping Voltage vs. Peak Pulse Current Junction Capacitance vs. Reverse Voltage 1 Voltage (V) Peak Power_Ppp(kW) 10 0.1 0.01 0.1 1 10 -20 100 0 20 120 120 100 100 80 60 40 20 0 50 75 100 125 150 100 80 60 40 20 0 -20 -20 Ambient Temperature_Ta(℃) 0 20 40 60 T-Time(us) Power Derating Curve Rev : 03.07.2021 80 IEC61000−4−2 Pulse Waveform Ipp-Peak Pulse Current-%of Ipp % of Rated Power Peak Pulse Power vs. Pulse Time 25 60 Time (nS) Pulse Duration_tp(uS) 0 40 8 X 20us Pulse Waveform 3/4 www.leiditech.com ESD101-B1-02EL DFN1006 Package Outline Drawing e D h h - b E - L A1 c A Bottom View A DIMENSIONS MILLIMETERS INCHES MIN NOM MAX MIN NOM MAX 0.45 0.50 0.55 0.018 0.020 0.022 A1 0.00 0.02 0.05 0.000 0.001 0.002 b 0.45 0.50 0.55 0.018 0.020 0.022 c 0.12 0.15 0.18 0.005 0.006 0.007 D 0.95 1.00 1.05 0.037 0.039 0.041 SYM e 0.65 BSC 0.026 BSC E 0.55 0.60 0.65 0.022 0.024 0.026 L 0.20 0.25 0.30 0.008 0.010 0.012 h 0.07 0.12 0.17 0.003 0.005 0.007 Suggested Land Pattern ╋ Y3 SYM Y1 Y2 Z ╋ DIMENSIONS MILLIMETERS INCHES X 0.60 0.024 Y1 0.50 0.020 Y2 0.30 0.012 Y3 0.80 0.032 Z 1.30 0.052 X Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 03.07.2021 4/4 www.leiditech.com
ESD101-B1-02EL 价格&库存
很抱歉,暂时无法提供与“ESD101-B1-02EL”相匹配的价格&库存,您可以联系我们找货
