NTF3055-100T1G
www.VBsemi.com
N-Channel 60-V (D-S) MOSFET
FEATURES
PRODUCT SUMMARY
VDS (V)
0.076 at VGS = 10 V
60
• Halogen-free
ID (A)a
RDS(on) (Ω)
Qg (Typ.)
4.5
0.085 at VGS = 4.5 V
• TrenchFET® Power MOSFET
RoHS
10 nC
3.5
COMPLIANT
APPLICATIONS
• Load Switches for Portable Devices
D
SOT-223-3
D
G
G
D
S
S
N-Channel MOSFET
ABSOLUTE MAXIMUM RATINGS TA = 25 °C, unless otherwise noted
Parameter
Drain-Source Voltage
Gate-Source Voltage
Continuous Drain Current (TJ = 150 °C)
Symbol
VDS
VGS
TC = 25 °C
TC = 70 °C
TA = 25 °C
TA = 70 °C
Pulsed Drain Current
TC = 25 °C
TA = 25 °C
TC = 25 °C
TC = 70 °C
Maximum Power Dissipation
TA = 25 °C
TA = 70 °C
Operating Junction and Storage Temperature Range
Continuous Source-Drain Diode Current
Soldering Recommendations (Peak Temperature)e, f
ID
IDM
IS
PD
TJ, Tstg
Limit
60
± 20
Unit
V
4.5
3.2 a
2.7
2.3
2.1b, c
4.0
3.0
2.5b, c
1.6b, c
- 55 to 150
260
A
W
°C
THERMAL RESISTANCE RATINGS
Parameter
Symbol
Maximum
Unit
Typical
t≤5s
RthJA
40
50
Maximum Junction-to-Ambienta, c, d
°C/W
RthJF
15
Steady State
Maximum Junction-to-Foot (Drain)
Notes:
a. Package limited, TC = 25 °C.
b. Surface Mounted on 1" x 1" FR4 board.
c. t = 10 s.
d. Maximum under Steady State conditions is 95 °C/W.
e. See Reliability Manual for profile. The ChipFET is a leadless package. The end of the lead terminal is exposed copper (not plated) as a result
of the singulation process in manufacturing. A solder fillet at the exposed copper tip cannot be guaranteed and is not required to ensure
adequate bottom side solder interconnection.
f. Rework Conditions: manual soldering with a soldering iron is not recommended for leadless components.
服务热线:400-655-8788
1
NTF3055-100T1G
www.VBsemi.com
SPECIFICATIONS TJ = 25 °C, unless otherwise noted
Parameter
Symbol
Test Conditions
Min.
VDS
VGS = 0 V, ID = 250 µA
60
Typ.
Max.
Unit
Static
Drain-Source Breakdown Voltage
ΔVDS /TJ
VDS Temperature Coefficient
VGS(th) Temperature Coefficient
ΔVGS(th)/TJ
Gate-Source Threshold Voltage
ID = 250 µA
VGS(th)
VDS = VGS , ID = 250 µA
Gate-Source Leakage
IGSS
VDS = 0 V, VGS = ± 12 V
Zero Gate Voltage Drain Current
IDSS
On-State Drain Currenta
ID(on)
Drain-Source On-State Resistancea
Forward Transconductancea
RDS(on)
gfs
V
25
mV/°C
- 4.0
1.0
2.5
V
± 100
nA
VDS = 60 V, VGS = 0 V
1
VDS = 60 V, VGS = 0 V, TJ = 55 °C
10
VDS ≥ 5 V, VGS = 4.5 V
µA
A
30
VGS = 10 V , ID = 4.0 A
0.076
VGS = 4.5 V, ID = 3.0 A
0.085
VDS = 10 V, ID = 4.0 A
45
Ω
S
b
Dynamic
Input Capacitance
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Gate Resistance
Turn-on Delay Time
Rise Time
Turn-Off Delay Time
Fall Time
Turn-on Delay Time
Rise Time
Turn-Off Delay Time
Fall Time
810
Ciss
Rg
VDS = 30V , VGS = 0 V, f = 1 MHz
VDS = 30 V, VGS = 10 V, ID = 4.0 A
VDS = 30 V, VGS = 4.5 V, ID = 3.0 A
td(off)
pF
22
33
10
15
2.5
f = 1 MHz
VDD =30V, , RL = 1.5 Ω
ID ≅ 4.0 A, VGEN = 4.5 V, Rg = 1 Ω
Ω
2.4
15
25
10
15
35
55
tf
12
td(on)
10
15
tr
td(off)
nC
1.7
td(on)
tr
120
100
VDD = 30V , RL = 1.5 Ω
ID ≅ 4.0 A, VGEN = 10 V, Rg = 1 Ω
tf
12
40
10
15
ns
Drain-Source Body Diode Characteristics
IS
Pulse Diode Forward Current
ISM
Body Diode Voltage
VSD
Body Diode Reverse Recovery Time
trr
Body Diode Reverse Recovery Charge
Qrr
Reverse Recovery Fall Time
ta
Reverse Recovery Rise Time
tb
7.2
TC = 25 °C
30
IS = 4.0 A, VGS = 0 V
IF = 4.0 A, dI/dt = 100 A/µs, TJ = 25 °C
A
0.8
1.2
V
ns
10
nC
10
10
ns
Notes:
a. Pulse test; pulse width ≤ 300 µs, duty cycle ≤ 2 %
b. Guaranteed by design, not subject to production testing.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
服务热线:400-655-8788
2
NTF3055-100T1G
www.VBsemi.com
TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted
VGS =10thru 5 V
TC = - 55 °C
8
I D - Drain Current (A)
10
8
VGS = 4V
6
6
TC = 125 °C
4
4
2
TC = 25 °C
VGS =2.5 V
0.5
1.0
1.5
VGS = 3.5 V
2.5
2.0
3.0
0.5
1.5
2.0
VGS - Gate-to-Source Voltage (V)
VDS - Drain-to-Source Voltage (V)
Output Characteristics
Transfer Characteristics
1000
0.014
0.013
Ciss
800
0.012
C - Capacitance (pF)
RDS(on) - On-Resistance (Ω)
1.0
0.011
0.010
VGS = 4 . 5 V
0.009
0.008
600
400
Coss
200
VGS = 1 0 V
0.007
Crss
12
18
24
15
45
60
ID - Drain Current (A)
On-Resistance vs. Drain Current
Capacitance
10
1.6
ID = 6.3 A
ID = 6.3 A
8
VGS = 4.5 V, 10 V
VDS = 10 V
6
VDS = 16 V
4
2
(Normalized)
1.4
R DS(on) - On-Resistance
30
1.2
1.0
0.8
10
15
Qg - Total Gate Charge (nC)
Gate Charge
0.6
- 50
- 25
50
75
100
125
150
TJ - Junction Temperature (°C)
On-Resistance vs. Junction Temperature
服务热线:400-655-8788
3
NTF3055-100T1G
www.VBsemi.com
0.050
100
ID = 4.0 A
TJ = 150 °C
R DS(on) - On-Resistance (Ω)
I S - Source Current (A)
0.040
TJ = 25 °C
10
1
0.0
0.030
TJ = 125 °C
0.020
TJ = 25 °C
0.010
0.000
0.2
0.6
0.4
0.8
1.0
1.2
VSD - Source-to-Drain Voltage (V)
4
5
On-Resistance vs. Gate-to-Source Voltage
1.4
50
40
ID = 250 µA
Power (W)
1.2
V GS(th) (V)
3
Source-Drain Diode Forward Voltage
1.0
0.8
30
0.6
0.4
- 50
2
- 25
50
75
100
125
150
0.01
0.1
1
10
100
600
Time (s)
TJ - Temperature (°C)
Single Pulse Power
Threshold Voltage
100
10
10 µs
Limited by RDS(on)*
100 µs
1 ms
1
10 ms
100 ms, DC
0.1
TC = 25 °C
Single Pulse
0.01
0.1
BVDSS Limited
1
10
100
* VGS > minimum VGS at which RDS(on) is specified
Single Pulse Power, Junction-to-Case
服务热线:400-655-8788
4
NTF3055-100T1G
www.VBsemi.com
18
8
15
Power (W)
6
12
9
Package Limited
4
6
2
3
50
75
100
TC - Case Temperature (°C)
Current Derating*
125
150
25
50
75
100
125
150
Power Derating
* The power dissipation PD is based on TJ(max) = 150 °C, using junction-to-case thermal resistance, and is more useful in settling the upper
dissipation limit for cases where additional heatsinking is used. It is used to determine the current rating, when this rating falls below the package
limit.
服务热线:400-655-8788
5
NTF3055-100T1G
www.VBsemi.com
2
1
Duty Cycle = 0.5
ffecti
0.2
Notes:
0.1
PDM
0.1
0.05
t1
t2
1. Duty Cycle, D =
t1
t2
2. Per Unit Base = RthJA = 80 °C/W
0.02
3. TJM - TA = PDMZthJA(t)
Single Pulse
4. Surface Mounted
0.01
10-4
10-3
10-2
10-1
1
Square Wave Pulse Duration (s)
10
100
600
Normalized Thermal Transient Impedance, Junction-to-Ambient
2
Normalized Effective Transient
Thermal Impedance
1
Duty Cycle = 0.5
0.2
0.1
0.1
0.05
0.02
Single Pulse
0.01
10-4
10-3
10-2
10-1
1
10
Normalized Thermal Transient Impedance, Junction-to-Foot
服务热线:400-655-8788
6
NTF3055-100T1G
www.VBsemi.com
SOT-223 (HIGH VOLTAGE)
B
D
A
3
0.08 (0.003)
B1
C
0.10 (0.004) M C B M
A
4
3
H
E
0.20 (0.008) M C A M
L1
1
2
3
4xL
3xB
e
θ
e1
4xC
MILLIMETERS
INCHES
DIM.
MIN.
MAX.
MIN.
MAX.
A
1.55
1.80
0.061
0.071
0.033
B
0.65
0.85
0.026
B1
2.95
3.15
0.116
0.124
C
0.25
0.35
0.010
0.014
D
6.30
6.70
0.248
0.264
E
3.30
3.70
0.130
e
2.30 BSC
e1
4.60 BSC
0.181 BSC
H
6.71
7.29
0.264
L
0.91
0.036
L1
θ
0.061 BSC
0.146
0.0905 BSC
0.287
0.0024 BSC
10'
10'
ECN: S-82109-Rev. A, 15-Sep-08
DWG: 5969
Notes
1. Dimensioning and tolerancing per ASME Y14.5M-1994.
2. Dimensions are shown in millimeters (inches).
3. Dimension do not include mold flash.
4. Outline conforms to JEDEC outline TO-261AA.
服务热线:400-655-8788
7
NTF3055-100T1G
www.VBsemi.com
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to the
product.(www.VBsemi.com)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability,
including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
RoHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
