規 格 承 認 書
PECIFICATION FOR APPROVAL
客 戶
CUSTOMER
項 目
ITEM
型 號
TYPE
DESCRIPTION :
客戶料號
CUSTOMER NO. :
規 格 書 號
立创
后进声硅微麦克风(MEMS MIC)
GMA3730H11-B38
L3.76 x W3.0xH1.1 mm
-38 dB
S/N: ≥58 dBA
SPECIFICATION NO.:
版 本
EDITION NO.
日 期
DATE
V1.0
2020-2-26
客戶承認
CUSTOMER CONFIRM AND SIGN
檢查
TESTED BY
審核
CHECKED BY
承認
APPROVED BY
東莞市赢海電子有限公司
DONGUAN INGHAI ELECTRONICS CO.,LTD
製作
ISSUED BY
審查
CHECKED BY
周明
刘承成
確認
APPROVED BY
地址:广东省东莞市长安镇上沙第五工业区新春路 1 号新春科技园
電話 / TEL:0769-83060958
傳真 / FAX: 0769-81608993
網址:HTTP://WWW.INGHAI.COM
1/9
A. GENERAL DESCRIPTION
GMA3730H11-B42 is a Silicon Microphone with analog output and bottom inlet for sound input. It
is a cost-effective alternative to traditional electret condenser microphone(ECM). Provided on
tap-and-reel, it is ideally suited for high volume applications. And it can be processed directly to
customer’s PCB using standard automatic pick-and-place equipment and surface mounted via
standard solder reflow equipment..
B. ABSOLUTE MAXIMUM RATINGS
Supply voltage :VDD to GND…………-0.3V~5V
ESD Tolerance
The Lid Mode…………………………8kV
The I/O Pin Mode…………………….4kV
TEMPERATURE CHARACTERISTICS
Parameter
Conditions
Max
Unit
-40
+85
Solder on PC board
-40
+105
In Tape and Reel
-10
+50
Operating Temperature
Storage Temperature
Min
Typ
C. ACOUSTIC & ELECTRICAL SPECIFICATIONS
Unless otherwise specified, test conditions are: Supply voltage VDD = 2.2V Input sound pressure PIN = 94dB
SPL@1kHZ Test room temperature Ta = 25℃,Room Humidity = 50% A-weighting filter applied for noise floor
measurement
PERFORMANCE
Parameter
Conditions
Directivity
Min
Typ
Max
Unit
Omni-Directional
Sensitivity
@1KHz (0 dB = 1V/Pa)
-41
-38
-35
dB
Signal-to-Noise Ratio
62
Total Harmonic Distortion
(THD) @ 100dB SPL
@1KHz
0.2
0.5
(THD) @ 115dB SPL
@1KHz
0.5
1
Max Input Sound Pressure
@1KHz, THD < 10%
130
Power Supply Rejection
(PSR)
217Hz,100m Vpp square wave
-84
dB
dB SPL
-79
dB
2/9
INPUT CHARACTERISTICS
Power supply Voltage
1.6
Sensitivity Loss Across
Power Supply Voltage
Change in sensitivity from
1.6V to 3.6V power supply
voltage
Total Operation Current
1.6V-3.6V power supply
voltage
Standby Current
voltage
3.6
No change
160
V
dB
200
uA
2
uA
100
pF
200
Ω
OUTPUT CHARACTERISTICS
LOAD Capacitance
Output Impedance
@1KHz (0 dB = 1 V/Pa)
D. FREQUENCY RESPONSE CURVE
. Typical free field frequency response (Normalized to 1 KHz)
E.MECHANICAL SPECIFIONS
3/9
ITEM
DIMENSION
TOLERANCE
UNITS
LENGTH(L)
3.76
WIDTH(W)
3.00
±0.10
mm
HEIGHT(H)
1.10
±0.10
mm
ACOUSTIC
PORT(AP)
Φ0.25
±0.05
mm
±0.10
mm
PIN OUTPUT
PIN#
FUNCTION
1
OUTPUT
2
GROUND
3
GROUND
4
POWER(Vdd)
5
GROUND
6
GROUND
Dimensions are in millimetre unless otherwise specified.
Tolerance ±0.15mm unless otherwise specified Figure 2. Detailed mechanical drawings
F.RECOMMENDED CUSTOMER LANDING PATTERN
Recommended landing pattern on customer ‘s PCB
4/9
G. RECOMMENDED INTERFACE CIRCUIT
. Recommended interface circuit for customers’ applications
H. PACKAGING SPECIFICATIONS
D0
1.5±0.1
W
12.0±0.30
D1
1.5±0.1
E
1.75±0.10
A0
4.06±0.10
F
5.50±0.10
P0
4.00±0.10
P1
8.00±0.10
P2
2.00±0.10
B0
K0
T
3.30±0.10
1.35±0.10
0.3±0.05
Notes:
(1) Tape & Reel Per EIA-481 standard;
(2) Label applied to external package and direct to reel
Order Part Number
GMA3730H11-B42
Reel Diameter
13”
Qty per Reel
5,000
5/9
5,000PCS PRODUCTS/1 reel
Figure 6. Reel Specification5,000PCS PRODUCTS/1 reel
6/9
50,000 Pieces of Products per Carton
7/9
I. RECOMMENDED REFLOW PROFILE
Profile Feafure
Average Ramp-up rate (TSMAX to TP)
Preheat Temperature Min (TSMIN) Temperature Max (TSMAX)
Time (TSMIN to TSMAX) (tS)
Time maintained above: Temperature (TL) Time (tL)
Peak Temperature (TP)
Time within 5℃ of actual Peak Temperature (tP)
Pb-Free
3℃/second max.
150℃ 200℃ 60-180 seconds
217℃ 60-150 seconds
260℃
20-40 seconds
Ramp-down rate(TP to TSMAX)
6℃/second max
Time 25℃ to Peak Temperature
8 minutes max
Notes:
1. Vacuuming over acoustical hole of the microphone is not allowed, because the
device can be damaged by vacuum.
2. To wash the board after reflow process is not allowed, because board washing and
Cleaning agents can damage the device. A device should not be exposed to ultrasonic
processing or cleaning.
3. Recommended number of reflow is no more than 5 Times.
8/9
N. RELIABILITY SPECIFICATIONS
Test item
Detail
standard
Reflow Simulation
Refer to Sec.9 for solder reflow
profile, total 5 times
Low Temperature Bias
Conditions:-40℃
Duration:168 hours while under
bias
IEC 60068-2-2 Test Aa
High Temperature Bias
Conditions: 105℃
bias
IEC 60068-2-2 Test Ba
Thermal Shock
Conditions: 100 cycles of
air-air thermal shock from
-40 ℃ to 125 ℃ with
15-minute soaks
IEC 60068-2-4
Temperature/Humidity Bias
Conditions: 85 ℃ /85%RH
environment while under bias
for 168 hours
JESD 22-A101A-B
Mechanical Shock
Conditions:3 pulses of 10,000g
in the X,Y and Z direction
JEC 60068-2-27 Test Ea
Vibration Test
Test axis: X,Y,Z
Conditions:2~400Hz 1 oct/min
Test time:15mins per axis Use
fixture during the testing
IEC 60068-2-6
Drop Test
Conditions: 1.8-meter height
onto a concrete surface each
time at three directions in state
of packaging
IEC 60068-2-32
ESD
Conditions: ±8KV direct
contact to the lid when unit is
grounded,±4KV direct
contact to the I/O pins. 10 times
IEC 61000-4-2
Note: Immediately after reliability test, the samples shall be stored under climatic conditions such as that
normally exists in ordinary rooms or laboratories. Unless otherwise noted , the recovery period shall be
2 hours at least before performance testing. After test condition is performed, the sensitivity of the
microphone shall not deviate more than 3dB from its initial value.
9/9
很抱歉,暂时无法提供与“GMA3730H11-B38”相匹配的价格&库存,您可以联系我们找货
