MK04-KIT
MK04-KIT
    STANDEX-MEDER(斯丹麦德)
    MK04P-1A66B(2242661054),MK04P-1A66C(2243711054),MK04P-1A66D(2244711054) MK04 近程,磁性 评估板 -xa0传感器
MK04-KIT 数据手册
Europe: +49 / 7731 8399 0 | Email: info@meder.com USA: +1 / 508 295 0771 | Email: salesusa@meder.com Asia: +852 / 2955 1682 | Email: salesasia@meder.com Item No.: 2240000000 Item: MK04-KIT Modifications in the sense of technical progress are reserved Designed at: Last Change at: 04/06/11 Designed by: Last Change by: MAPODACA Approval at: Approval at: 05/03/11 Approval by: Approval by: TLANE Rev. No.: 01 Europe: +49 / 7731 8399 0 | Email: info@meder.com USA: +1 / 508 295 0771 | Email: salesusa@meder.com Asia: +852 / 2955 1682 | Email: salesasia@meder.com Magnetic properties Pull-In Test equipment Conditions Item No.: 2240000000 Item: MK04-KIT Min Typ at 20°C Special Product Data Contact - form Contact rating Switching voltage Carry current Switching current Sensor-resistance Housing material Case color Sealing compound Max Unit Max Unit KMS-14 Conditions Min Typ A - NO not to exceed their individual max.'s DC or Peak AC DC or Peak AC DC or Peak AC measured with 40% overdrive Environmental data Shock Vibration Operating temperature Operating temperature Storage temperature Cable specification PBT glass fibre reinforced white Polyurethane Conditions Min Typ Max Unit Min Typ Max Unit Max Unit 1/2 sine, duration 11ms, in 3 axis from 10 - 2000 Hz cable not moved cable moved Conditions Cable type Cable material Cross section flat cable PVC 0,14 sq-mm Conditions General data Min " #$% & '" Disk ISO 7089 Tightening torque Mounting advice Typ ! over 5m cable, a resistor is recommended. Modifications in the sense of technical progress are reserved Designed at: Last Change at: 04/06/11 Designed by: Last Change by: MAPODACA Approval at: Approval at: 05/03/11 Approval by: Approval by: TLANE Rev. No.: 01
MK04-KIT 价格&库存
很抱歉,暂时无法提供与“MK04-KIT”相匹配的价格&库存,您可以联系我们找货
