ALNICO500 4X19MM
ALNICO500 4X19MM
    STANDEX-MEDER(斯丹麦德)
    磁性器件 Alnico 5(铝镍钴) 0.157" 直径 x 0.748" 高(4.00mm x 19.0mm)
ALNICO500 4X19MM 数据手册
0 4 -0,1 19 ±0,2 a N S Magnetic values (according to DIN IEC 60404-8-1 / IEC-404-8-1 / equivalent standard of country of origin) Energy product (BH)max Remanence Br Min. Typ. 35 39,8 1120 Revers. temp. coeff. of Br 1240 mT -0,02 %/K 47 51,3 kA/m Coercitivity HcJ 48 51,7 kA/m Revers. temp. coeff. of HcJ N/A %/K Density 7,4 g/cm³ Operating temperature Remarks Tolerance Unit kJ/m³ Coercitivity HcB 450 Magnetic moment (MS150) Application Max. Surface 22 °C µVs*cm AlNiCo 500 code acc. to DIN 17410: 35/5 Scale: 2:1 Weight: Material: AlNiCo500 created: 21.10.2015 wkovacs checked: 21.10.2015 Sheet size: A4 mreizner Round magnet AlNiCo500, 4x19.0mm MAGNETIZATION AXIAL dimensions in: mm 02 a tol. of diameter was +0/-0,2 mm 21.10.2015 w.k. new issue by swx layout; last rev. 04, 21.10.2015 w.k. 01 archived in Navision data base Rev. state change date name StandexMeder Electronics GmbH Robert-Bosch-Str.4 78224 Singen Tel.:+49(0)7731/8399-0 Fax:+49(0)7731/8399-30 Art.Nr./DrawingNr. 4003004003 Tool Nr. www.standexmeder.com PROPRIETARY AND CONFIDENTIAL THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF StandexMeder Electronics GmbH. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF StandexMeder Electronics GmbH IS PROHIBITED. page 1 of 1
ALNICO500 4X19MM 价格&库存
很抱歉,暂时无法提供与“ALNICO500 4X19MM”相匹配的价格&库存,您可以联系我们找货
