TNC-J-P-H-RA-TH1
TNC-J-P-H-RA-TH1
    SAMTEC(申泰)
    RF-CONN_31.1X9.68MM_TM
    射频连接器 50Ω 镀金 RF-CONN_31.1X9.68MM_TM 直插
TNC-J-P-H-RA-TH1 数据手册
50 Ω TNC TO 6 GHz TNC Cable Assemblies - SERIES RF174, RF178, RF316, RS316, RF058 - END 1 CONNECTOR RF174 END 2 CONNECTOR - –“XXXX” –05SP3 = RG 174 Cable = TNC Straight Plug (RF058 not available) RF178 = Overall Length in millimeters –05BJ3 = RG 178 Cable = TNC Straight Bulkhead Jack (RS316 & RF058 not available)) RF316 OVERALL LENGTH –0100 (100 mm) 3.94” minimum –05SR3 = RG 316 Cable, Single Braid Shield = TNC Straight Plug, Reversed Polarity (RF058 only) RS316 = RG 316 Cable, Double Shielded ALSO AVAILABLE RF058 = RG 58 Cable 50 W: MCX, MMCX, SMA, SMB, BNC, N Type = RF174, RF178, RF316 50 W: MCX, MMCX, SMA, BNC = RS316 50 W: SMA, N Type = RF058 TNC Cable Connectors TNC-CA CONNECTORS FOR INDUSTRY STANDARD CABLES (29.80) 1.173 TNC-P-C-GN-ST-CA1 RG 174/316 Cable TNC-P-C-GN-ST-CA2 RG 178 Cable TNC-P-C-GN-SR-C10 RG 58 Cable TNC-J-C-GN-ST-BH1 RG 174/316 Cable, Bulkhead TNC-J-C-GN-ST-BH2 RG 178 Cable, Bulkhead (17.50) .689 Hex. -J (25.00) .984 P-C = Cable Plug Supplied with pins, washers, nuts and ferrules. See website for dimensions. TNC Board Connectors TNC-TH Cable Mates: RF174, RF178, RF316, RS316, RF058 , GRF1H-C (14.50) .571 J-C = Cable Jack GN = Plating (10 µ” Gold on contact, Nickel on body) ST = Straight -P SR = Straight Reverse Polarity TNC - GENDER –J = Jack - TYPE –P = PCB Mount - - PLATING ORIENTATION –H - TERMINATION –RA = 30 µ" (0.76 µm) Gold center contact, Nickel on shell = Right-angle –TH1 = Through-hole (31.10) 1.224 (18.00) .709 (3.00) .118 (1.00) .039 DIA samtec.com/TNC Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-221 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Samtec: TNC-J-P-H-RA-TH1 TNC-J-C-GN-ST-BH1 TNC-J-C-HN-ST-BH1 TNC-P-C-GN-SR-C10 TNC-P-C-GN-ST-CA1
TNC-J-P-H-RA-TH1 价格&库存
很抱歉,暂时无法提供与“TNC-J-P-H-RA-TH1”相匹配的价格&库存,您可以联系我们找货
TNC-J-P-H-RA-TH1
  • 1+220.362851+28.48173
  • 10+204.0740910+26.37642
  • 25+188.9308025+24.41916
  • 50+184.0008550+23.78197
