NO.:FLY-CR2477T-A0
第1页 共6页
产 品 规 格 确 认 书
Specification Approval Sheet
客户名称:
Customer name
产品名称:
CR2477T 3.0V
Model Name
物料编码:
FLY.CR2477T
Model Numbe
送样日期:
Date
出厂签章:
工程部
品质部
业务部
批准
黄烈清
王仁树
王培
陈远洪
送样数量:
确认书份数:
客户确认签章:
审 核
批 准
确认签章
效 率 服 务 创 造 品 牌
诚 信 品 质 铸 就 未 来
电话:0769-83269986 地址:东莞市寮步镇松湖智谷产业园A4栋4F
-1-
Lithium Manganese Dioxide Battery
Model CR2477T
Specifications
Nominal Discharge current
Nominal Voltage
Nominal Capacity
Continuous standard load
Maximum pulse current
Operating temperature
Weight
UL Recognition
Storage temperature
range
Storage humidity range
0.6mA
3V
1000(mAh)
4.7(kΩ)
25mA
-40℃~85℃
10.5 (g)
MH29853
0 C- 3 0 ℃
35%~75%
Characteristics
< WARNING>
( 1 ) Never charge the battery. Charging the battery may cause seethe of thebattery electrolyte or increase of the battery internal pressure. Leakage, heating,
explosion or ignition of the battery may be caused as a result of it.
( 2 ) Keep away from infants. If infant happens to swallow the battery, consult a doctor Immediately
( 3 ) Note: if the temperature is higher than the continuous use + 7 0 C or below - 2 0 C. Please contact the Power Glory
-2-
■Characteristics :
[TABLE 1]
TEST ITEMS
TEMPERATURE
INITIAL
AFTER 12 MONTHS
Open- circuit
Voltage
20±2℃
3.0V TO 3.4V
3.0V TO 3.4V
Closed- circuit
Voltage
20±2℃
3.0V TO 3.4V
3.0V TO 3.4V
REMARKS
Standard Load Resistance .
0.8 Sec.
[ TABLE 2 ]
TEST ITEMS
TEMPERATURE
INITIAL
AFTER 12 MONTHS
20±2℃
See graph for
details
≥ 98% of initial
capacity
Service Life
REMARKS
Continuous
Discharge
Under
Standard Load to 2 . 0 V End-
Voltage
[ TABLE 3 ]
TEST ITEM
Service Life After
Storage At High
Temperature
STORAGE TEMP STORAGE PERIOD REQUIREMENT
60 ±2℃
20 Days
≥ 98% of initial
capacity
REMARKS
Continuous Discharge At 2 0 ±
2 ℃ Under Standard Load To
2 . 0 V End- Voltage After
Storage.
[ TABLE 4 ]
TEST ITEM
REQUIREMENT
Leakage Characteristics
No Leakage
TEST CONDITIONS
Temperature: 45 ± 2℃ , Relative Humidity: 75%
Storage: 30 Days
Shall Be Inspected By Visual Means
[ TABLE 5 ]
TEST ITEM
REQUIREMENT
Self- discharge
2% or Below
TEST CONDITIONS
Continuous Discharge Under Standard Load To 2 . 0 V End- voltage
After 12 Months Storage At 20 ℃ .
( To Obtain From The Mean Value Of The Same Lot )
-3-
■Mark!ngs:
Markings on batteries :
5. 1. 1 Battery type :
CR2477T
Omnergy
5. 1.2 Brand of battery:
5. 1.3 Polarity :
+ [(-) shall not be indicated]
5. 1.4 Manufacturing marks : The year and month of production shall be
marked on the negative (-) terminal side
o o
T
T Type
Month of production ( 1 letter)
Year of production ( The last number of Christian era)
[[Example] 61T...... Manufactured in January 2016
6XT
Manufactured in October 2016
6YT
Manufactured in November 2016
6ZT
Manufactured in December 2016
Month of production.
- January to September -- 1- 9
- Oct, Nov, Dec, -------X, Y, Z
■ Precautions
in Designing a Memory Backup Circuit
A primary lithium battery is not rechargeable. When used for memory backup in combination with
another power source, current may flow into the battery from the other source. To prevent this,
include a protection diode and resistor in the circuit so that no battery charging or over discharging
can occur. Allowable Range of Diode Back- Leakage Current . To prevent the battery from being
charged by the main power source, be sure to use a back-current prevention diode and a protection
resistor. Select a silicon diode or a Schottky diode with minimum leakage current, and design the
circuit so that the amount of charging due to leakage current does not exceed 1% of the nominal
battery capacity over the total period of use.
(-)Negative terminal
Gasket
(+)Positive terminal
-4-
■ Maximum Allowable Charge Current to Battery
Model
Maximum Abnormal
charging current
CR1216
CR1220
CR1225
CR1616
CR1620
CR1632
CR2016
CR2025
2.5mA
10mA
10mA
10mA
10mA
10mA
10mA
10mA
Model
Maximum Abnormal
charging current
CR2032
CR2330
CR2354
CR2430
CR2450
CR2477
CR3032
10mA
10mA
10mA
15mA
15mA
15mA
15mA
Maximum Abnormal
charging voltage
5V
Protection resistance R must exceed the value calculated in the following formula:
R ≧
■ Precautions
for Mounting
1 . Overlapping Batteries
Lithium Manganese Dioxide Battery is shaped as shown below. It has exposed positive(+)and
negative( - ) metallic surfaces with a thin cylindrical seal, called the gasket, inbetween them. When
the batteries are overlapped or mixed together in a disorderly way, their positive( + ) and negative( ) terminals touch each other, causing short- circuits.
2 . The Batteries Put in a Metallic Container or on a Metallic Plate
Similar to the overlapping battery problem, when the batteries are put in a metallic container or on a
metallic plate, their positive( + ) and negative( - ) terminals may short- circuit through the conductive
surface, depending on how the batteries are position.
3 . When The Battery is Held with Metallic Tweezers
When held with a pair of metallic tweezers as shown, the battery short-circuits through the
tweezers.
4 . When The Battery Lead Plates Touch Each Other
When the battery lead plates bend and touch each other or other either terminal, the battery shortcircuits.
5 . older Bridges
Solder may bridge between circuit board conductors, causing a short-circuit and draining the
battery.
6 . Short- circuits through Soldering Irons
Similar to solder bridging, when the circuit board wiring is short- circuited by a soldering iron for an
extended period the battery is drained and consumed. Complete short- circuits through soldering
irons within 5 seconds.
7 . Short- circuits through Piled Circuit Boards
When circuit boards with the batteries are piled on top of one another, their conductive traces may
touch and form a battery discharge circuit that consumes the battery' s power.
-5-
8 . Discharge through Conductive Electrostatic Prevention Mats
Conductive mats are widely used to prevent static electricity from destroying semiconductors. If a
circuit board with mounted battery is put on a conductive mat, the soldered conductors may touch
the mat,providing a discharge path for the battery.
9 . Improper Battery Mounting Polarity
When the battery' s positive ( + ) and negative ( - ) terminals are reversed with respect to the battery
mounting' s polarity marks, the battery may be discharged, depending on the type of electric circuit.
10. Solder
When the battery lead plates are dipped in a molten solder bath, the battery is temporarily shortcircuited. Therefore, complete dipping within 5 seconds.
Handling Precautions
Please read and observe the follwing precautions thoroughly.
Lithium Manganese Dioxide Battery contains flammable materials, such as organis solvent.
Improper battery handling may cause leakage, heating, explosion or ignition of the battery, which
may lead to injury or product failure.
PRECAUTIONS
1. Do not put the battery into microwave over or drying machine.
2 .Do not drop, apply excessive damage or deform the battery.
3 . Do not mix the used battery together with the new battery or different type of batteries.
4 . Do not store the battery in high temperature and high humidity location and where the battery is
exposed to sunlight to avoid performance deterioration, swelling or leakage, of the battery.
-6-
很抱歉,暂时无法提供与“FLY.CR2477T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+7.87450
- 10+7.36647
- 200+6.09639
- 1000+5.84237
