LCB CRBP.01-KXLX-3B6B-Y474
    AMSOSRAM(艾迈斯半导体)
    LED_3X3MM_SM
    发光二极管/LED 蓝色 475nm 正贴
LCB CRBP.01-KXLX-3B6B-Y474 数据手册
www.osram-os.com LCB CRBP.01 DATASHEET LCB CRBP.01 Datasheet   Published by ams-OSRAM AG Tobelbader Strasse 30, 8141 Premstaetten, Austria Phone +43 3136 500-0 ams-osram.com © All reserved | Version 1.1 | 2023-02-01 1 rights LCB CRBP.01 DATASHEET OSLON® Signal LCB CRBP.01 The OSLON® Signal combines a compact form factor with high efficiency and electrically insulated thermal pad. The square package matches the optical center with the mechanical center. This provides easy clustering flexibility and high packing density for a maximum flux density. The color bins are defined for best fit to most signaling norms. Applications - Dynamic Signaling Features - Package: SMD ceramic package with silicone lens - Chip technology: UX:3 - Typ. Radiation: 120°  - Color: Cx = 0.16, Cy = 0.12 acc. to CIE 1931 (● converted blue) - Corrosion Robustness Class: 3B - ESD: 8 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 3B)  - Bipolar, back to back (B2B) ESD: Minimum reverse voltage 5V 2 | Version 1.1 | 2023-02-01 LCB CRBP.01 DATASHEET Ordering Information  Type Luminous Flux 1) IF = 350 mA ΦV LCB CRBP.01-KXLX-3B6B-Y474   3 | Version 1.1 | 2023-02-01 71.0 ... 130.0 lm Ordering Code Q65113A4672 LCB CRBP.01 DATASHEET Maximum Ratings Parameter Symbol Operating Temperature Top min. max. -40 °C 125 °C Storage Temperature Tstg min. max. -40 °C 125 °C Junction Temperature Tj max. 150 °C Junction Temperature for short time applications* Tj max. 175 °C Forward current TS = 25 °C IF min. max. 30 mA 1000 mA Surge current t ≤ 10 µs; D = 0.005 ; TS = 25 °C IFS max. 2000 mA ESD withstand voltage acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 3B) VESD * The median lifetime (L70/B50) for Tj = 175°C is 100h.   4 | Version 1.1 | 2023-02-01 Values 8 kV LCB CRBP.01 DATASHEET Characteristics IF = 350 mA; TS = 25 °C Parameter Symbol Chromaticity Coordinate 2) Cx Cy typ. typ. 0.16 0.12 Viewing angle at 50% IV 2φ typ. 125 ° Forward Voltage 3) IF = 350 mA VF min. typ. max. 2.65 V 2.90 V 3.25 V Reverse voltage (ESD device) VR ESD min. 5V Reverse voltage  IR = 5 mA VR max. 7V Real thermal resistance junction/solderpoint 5) RthJS real typ. max. 9.4 K / W 11.2 K / W Electrical thermal resistance junction/solderpoint 5) with efficiency ηe = 62.4 % RthJS elec. typ. max. 3.5 K / W 4.2 K / W 4)   5 | Version 1.1 | 2023-02-01 Values LCB CRBP.01 DATASHEET Brightness Groups  Group Luminous Flux 1) IF = 350 mA min. ΦV Luminous Flux 1) IF = 350 mA max. ΦV Luminous Intensity 6) IF = 350 mA typ. Iv KX 71.0 lm 82.0 lm 22.3 cd KY 82.0 lm 97.0 lm 26.1 cd KZ 97.0 lm 112.0 lm 30.5 cd LX 112.0 lm 130.0 lm 35.3 cd Forward Voltage Groups  Group Forward Voltage 3) IF = 350 mA min. VF Forward Voltage 3) IF = 350 mA max. VF Y4 2.65 V 2.85 V 34 2.85 V 3.05 V 74 3.05 V 3.25 V   6 | Version 1.1 | 2023-02-01 LCB CRBP.01 DATASHEET Chromaticity Coordinate Groups Chromaticity Coordinate Groups  Group Cx Cy Group Cx Cy 3B 0.1297 0.0503 5B 0.1096 0.0868 0.1748 0.1131 0.1743 0.1581 0.1750 0.0985 0.1746 0.1369 0.1355 0.0399 0.1195 0.0688 0.1195 0.0688 0.0969 0.1099 0.1746 0.1369 0.1740 0.1827 0.1748 0.1131 0.1743 0.1581 0.1297 0.0503 0.1096 0.0868   4B 7 | Version 1.1 | 2023-02-01 6B LCB CRBP.01 DATASHEET Group Name on Label  Example: KX-3B-34 Brightness Color Chromaticity KX 3B   8 | Version 1.1 | 2023-02-01 Forward Voltage 34 LCB CRBP.01 DATASHEET Relative Spectral Emission 6) Φrel = f (λ); IF = 350 mA; TS = 25 °C Φrel LCB CRBP.01 1,0 : Vλ : converted blue 0,8 0,6 0,4 0,2 0,0 350 400 Radiation Characteristics 450 500 550 600 650 700 750 800 λ / nm 6) Irel = f (ϕ); TS = 25 °C LCB CRBP.01 ϕ/°  -40° -50° -20° -10° 0° 10° 20° 30° 40° 50° 60° 70° 80° 90° 1,0 -30° 0,8 0,6 -60° -70° 0,4 -80° 0,2 -90° 0,0  -100° 9 | Version 1.1 | 2023-02-01 Irel LCB CRBP.01 DATASHEET Forward current Relative Luminous Flux 6) IF = f(VF); TS = 25 °C IF / mA 6), 7) Φv/Φv(350 mA) = f(IF); TS = 25 °C LCB CRBP.01 1000 ΦV LCB CRBP.01 2,5 ΦV(350mA) 2,0 800 1,5 600 1,0 400 0,5 200 Chromaticity Coordinate Shift 6) ΔCx, ΔCy = f(IF); TS = 25 °C ∆Cx ∆Cy LCB CRBP.01 0,03 : ∆ Cx : ∆ Cy  0,02 0,01 0,00 -0,01 -0,02 10 00 80 0 60 0 40 0 20 0 30 -0,03  IF / mA 10 | Version 1.1 | 2023-02-01 10 00 80 0 3,2 3,3 VF / V 60 0 3,0 40 0 2,8 20 0 30 2,6 30 0,0 IF / mA LCB CRBP.01 DATASHEET Forward Voltage Relative Luminous Flux 6) ΔVF = VF - VF(25 °C) = f(Tj); IF = 350 mA ∆VF / V 0,15 6) Φv/Φv(25 °C) = f(Tj); IF = 350 mA LCB CRBP.01 Φv 1,10 LCB CRBP.01 Φv(25°C) 1,05 0,10 1,00 0,05 0,95 0,00 0,90 -0,05 0,85 -0,10 0,80 -0,15 0,75 -0,20 -40 -20 0 20 40 60 80 100120140 Tj / °C 0,70 -40 -20 0 20 40 60 80 100120140 Tj / °C Chromaticity Coordinate Shift 6) ΔCx, ΔCy = f(Tj); IF = 350 mA ∆Cx ∆Cy 0,03 0,02 0,01 LCB CRBP.01  : ∆ Cx : ∆ Cy 0,00 -0,01 -0,02  -0,03 -40 -20 0 20 40 60 80 100120140 Tj / °C 11 | Version 1.1 | 2023-02-01 LCB CRBP.01 DATASHEET Max. Permissible Forward Current IF = f(T) IF / mA LCB CRBP.01 1100 1000 900 800 700 600 500 400 300 200 100 0 Don't use below 30 mA 0 20 40 60 80 100 120 Ts / °C Permissible Pulse Handling Capability Permissible Pulse Handling Capability IF = f(tp); D: Duty cycle; TS = 25 °C IF = f(tp); D: Duty cycle; TS = 85 °C LCB CRBP.01 IF / A 2,4 2,2 LCB CRBP.01 IF / A  2,4 2,2 2,0 2,0 1,8 1,8 1,6 1,4 1,2  10-6 10-5 10-4 10-3 0,01 0,1 12 | Version 1.1 | 2023-02-01 : D = 1.0 : D = 0.5 : D = 0.2 : D = 0.1 : D = 0.05 : D = 0.02 : D = 0.01 : D = 0.005 1 10 Pulse time / s 1,6 1,4 1,2 10-6 10-5 10-4 10-3 0,01 0,1 : D = 1.0 : D = 0.5 : D = 0.2 : D = 0.1 : D = 0.05 : D = 0.02 : D = 0.01 : D = 0.005 1 10 Pulse time / s LCB CRBP.01 DATASHEET Dimensional Drawing 8) Further Information: Approximate Weight: 26.8 mg Corrosion test: Class: 3B Test condition: 40°C / 90 % RH / 15 ppm H2S / 14 days (stricter than IEC 60068-2-43) ESD advice: The device is protected by ESD device which is connected in parallel to the Chip.   13 | Version 1.1 | 2023-02-01 LCB CRBP.01 DATASHEET Recommended Solder Pad 8) For superior solder joint connectivity results we recommend soldering under standard nitrogen atmosphere. Package not suitable for ultra sonic cleaning.   14 | Version 1.1 | 2023-02-01 LCB CRBP.01 DATASHEET Reflow Soldering Profile Product complies to MSL Level 2 acc. to JEDEC J-STD-020E OHA04525 300 ˚C T 250 Tp 245 ˚C 240 ˚C tP 217 ˚C 200 tL 150 tS 100 50 25 ˚C 0 0 50 100 150 200 250 s 300 t Profile Feature Symbol Pb-Free (SnAgCu) Assembly Minimum Recommendation Maximum Ramp-up rate to preheat*) 25 °C to 150 °C tS Time tS TSmin to TSmax Ramp-up rate to peak*) TSmax to TP Liquidus temperature  60 2 3 100 120 2 3 Unit K/s s K/s TL 217 Time above liquidus temperature tL 80 100 s Peak temperature TP 245 260 °C Time within 5 °C of the specified peak temperature TP - 5 K tP 20 30 3 6 Ramp-down rate* TP to 100 °C 10 Time 25 °C to TP  All temperatures refer to the center of the package, measured on the top of the component * slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range 15 | Version 1.1 | 2023-02-01 °C 480 s K/s s LCB CRBP.01 DATASHEET Taping 8)   16 | Version 1.1 | 2023-02-01 LCB CRBP.01 DATASHEET Tape and Reel 9) Reel Dimensions A 180 mm W Nmin 12 + 0.3 / - 0.1 mm   17 | Version 1.1 | 2023-02-01 W1 60 mm W2 max 12.4 + 2 mm 18.4 mm Pieces per PU 600 LCB CRBP.01 DATASHEET Barcode-Product-Label (BPL) Dry Packing Process and Materials 8) Moisture-sensitive label or print L E E V l e be sela ). k, H de L If an bl r co ba (R id m ity . H R hu 0% e e /6 tiv ˚C la ared ag ck re fr 30 _ < in pa % k of to 90 rs ea s d ). rs ou or te (p on rs H de , ou iti H an bjec ng ou rs co ˚C 72 si nd H ou 5 te 48 ˚C su es e H co ± 24 6 da e y 40 be oc tim ˚C e or < ith tim ill pr). or ct w O w nt 23 tim e at lo or fa M TO F s al tim at le ˚C at lo at or e. P th F l tic th va lo or ur O F lo s ui on be if: read en w ed l 4 5 F m la ce eq id lo g, n oc l ve vi 5a is in or be 24 de pr ve l 6 Le de , nt whe e te co g: , w e Le ve l ke r ou se da ba ed flo ur e Le ve m % ba e ba al st ur e Le r en re ed e re> 10 oi st e e fo tim ur se al op fo M se oi st ur as k, is or . 33 se is M oi st bed k, lo H an , g ph -0 M oi in an in F R ng ar rbl D M e ba T r po If bl ith % lif ki r C. (if S is p. w ea r ks lf J10 ba to et th va Y ea m rs m _ r w, < he ed 1 ee te Y d, EC iredicat S fte at nt > 1 W Hou D A flody qu In no ire 1. d e ou 4 8 re reity is qu/JE re 2. bo e M tim to es id 2b re C 16 : e a) S tim is IP ic ed loor tim e b) ev Humor or e en F tim lo or D 2a king nc te F op a) lo or 3. b) ba re F lo da e fe l 1 2 F If al re tim ve l 4. se d l 2a ve Le 3 an ve l ag e Le e B ve ur e Le at st ur e Le D oi st ur e M oi st ur M oi st M oi M N E RS s in IV O IT T S C nta N U TIO U coSEND Ais bUagRMEICO T E CThIS S d Barcode label < M RA OS  Humidity indicator Barcode label Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 Desiccant AM OSR OHA00539  Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033. 18 | Version 1.1 | 2023-02-01 LCB CRBP.01 DATASHEET Type Designation System Wavelength (λdom typ.) Emission Color Color coordinates according CIE 1931/Emission color: B: T: J: V: Blue True green Red Verde CB: CY: UW: L: 475 nm 528 nm 625 nm 505 nm Light Emitting Diode Cxy 0.16/0.12 Color on demand blue Cxy 0.57/0.42 Color on demand yellow Cxy 0.33/0.34 Ultra white Package Type C: OSLON (ceramic) Lead / Package Properties R: OSLON Ceramic Material AlN Planar encapsulation TiO2 L B C R B P  Encapsulant Type / Lens Properties B: Outcoupling lens 120°; lambertian Chip Technology P: Power performance Product Version Digit 1 0-9: Count  Product Version Digit 2 0-9: Count 19 | Version 1.1 | 2023-02-01 . 0 1 LCB CRBP.01 DATASHEET Notes The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of lamps and lamp systems). Within the risk grouping system of this IEC standard, the device specified in this data sheet fall into the class moderate risk (exposure time 0.25 s). Under real circumstances (for exposure time, conditions of the eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources have a high secondary exposure potential due to their blinding effect. When looking at bright light sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation. Subcomponents of this device contain, in addition to other substances, metal filled materials including silver. Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize device exposure to aggressive substances during storage, production, and use. Devices that showed visible discoloration when tested using the described tests above did show no performance deviations within failure limits during the stated test duration. Respective failure limits are described in the IEC60810. For further application related information please visit www.osram-os.com/appnotes   20 | Version 1.1 | 2023-02-01 LCB CRBP.01 DATASHEET Disclaimer Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version on our website. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Product and functional safety devices/applications or medical devices/applications Our components are not developed, constructed or tested for the application as safety relevant component or for the application in medical devices. Our products are not qualified at module and system level for such application. In case buyer – or customer supplied by buyer – considers using our components in product safety devices/ applications or medical devices/applications, buyer and/or customer has to inform our local sales partner immediately and we and buyer and /or customer will analyze and coordinate the customer-specific request between us and buyer and/or customer.   21 | Version 1.1 | 2023-02-01 LCB CRBP.01 DATASHEET Glossary 1) Brightness: Brightness values are measured during a current pulse of typically 25 ms, with an internal reproducibility of ±8 % and an expanded uncertainty of ±11 % (acc. to GUM with a coverage factor of k = 3). 2) Chromaticity coordinate groups: Chromaticity coordinates are measured during a current pulse of typically 25 ms, with an internal reproducibility of ±0.005 and an expanded uncertainty of ±0.01 (acc. to GUM with a coverage factor of k = 3). 3) Forward Voltage: The forward voltage is measured during a current pulse of typically 8 ms, with an internal reproducibility of ±0.05 V and an expanded uncertainty of ±0.1 V (acc. to GUM with a coverage factor of k = 3). 4) Reverse Operation: This product is intended to be operated applying a forward current within the specified range. Applying any continuous reverse bias or forward bias below the voltage range of light emission shall be avoided because it may cause migration which can change the electro-optical characteristics or damage the LED. 5) Thermal Resistance: Rth max is based on statistic values (6σ). 6) Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 7) Characteristic curve: In the range where the line of the graph is broken, you must expect higher differences between single devices within one packing unit. 8) Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and dimensions are specified in mm. 9) Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm.   22 | Version 1.1 | 2023-02-01 LCB CRBP.01 DATASHEET Revision History Version Date Change 1.0 2022-10-17 Initial Version 1.1 2023-02-01 Applications Electro - Optical Characteristics (Diagrams) Derating (Diagrams)   23 | Version 1.1 | 2023-02-01 LCB CRBP.01 DATASHEET   Published by ams-OSRAM AG Tobelbader Strasse 30, 8141 Premstaetten, Austria Phone +43 3136 500-0 ams-osram.com © All rights reserved 24 | Version 1.1 | 2023-02-01
LCB CRBP.01-KXLX-3B6B-Y474 价格&库存
很抱歉,暂时无法提供与“LCB CRBP.01-KXLX-3B6B-Y474”相匹配的价格&库存,您可以联系我们找货
