NB25Q40ATIGT
NB25Q40ATIGT
    ZETTA(澜智)
    SOP-8
    FLASH存储器 4Mb 2.3V~3.6V 83MHz SOP8_150MIL
NB25Q40ATIGT 数据手册
NB25Q40A NB SPI NOR FLASH 1. GENERAL DESCRIPTIONS The NB25Q40A (4M-bit) Serial Flash memory provides a storage solution for systems with limited space, pins and power. The NB25Q40A series offers flexibility and performance well beyond ordinary Serial Flash devices. They are ideal for code shadowing to RAM, executing code directly from Dual/Quad SPI and storing voice, text and data. The device operates on a single 2.3V to 3.6V power supply with current consumption as low as 4mA active and 1µA for power-down. All devices are offered in space- saving packages. The NB25Q40A support the standard Serial Peripheral Interface (SPI), as well as Dual/Quad I/O SPI: Serial Clock, Chip Select, Serial Data I/O0 (DI), I/O1 (DO), I/O2 (/WP), and I/O3 (/HOLD). SPI clock frequencies of up to 83MHz are supported allowing equivalent clock rates of 133MHz for Dual I/O and These transfer rates can outperform standard Asynchronous 8 and 16-bit Parallel Flash memories. A Hold pin, Write Protect pin and programmable write protection, with top or bottom array control, provide further control flexibility 2. FEATURES  SPI Flash Memories – Standard SPI: SCLK, /CS, SI, SO  Flexible Architecture – Uniform 256-byte Page Erase – Uniform 4K-byte Sector Erase – Dual SPI: SCLK, /CS, IO0, IO1 – Uniform 32/64K-byte Block Erase  Highest Performance Serial Flash – 83 MHz for fast read – Dual I/O Data transfer up to 133Mbits/s – Minimum 100,000 Program/Erase Cycles – Program 1 to 256 byte per programmable page  Fast Program and Erase Speed – 1.6ms page program time – 8ms page erase time – More than 20-year data retention  Low Power Consumption – Single 2.3V to 3.6V supply – 1μA standby current – 0.2μA deep power down current – 8ms 4K-byte sector erase time – 8ms 32K/64K-byte block erase time  Advanced Security Features – 128-Bit Unique ID for each device – 3*256-Byte Security Registers with OTP Locks – 3.5mA active read current at 33MHz – 4.5mA active program or erase current – Discoverable parameters (SFDP) register  Package Information – SOP8 – USON8/DFN8 (3 x2 mm) – TSSOP8 – KGD 1 NB25Q40A NB SPI NOR FLASH 3. PIN DEFINITION 3.1 PIN CONFIGURATION CS# 1 8 VCC CS# VCC SO/ IO1 2 7 HOLD#/ IO3 SO/ IO1 HOLD#/ IO3 WP#/ IO2 3 6 SCLK WP#/ IO2 SCLK VSS 4 5 SI/ IO0 VSS SI/ IO0 TopView 8 - LEAD VSOP/SOP 8 - LEAD WSON/USON 2 NB25Q40A NB SPI NOR FLASH 3.2 PIN DESCRIPTION Table-1. Pin Definition Pin No. Pin Name I/O Description 1 CS# I 2 SO (IO1) I/O Data Output (Data Input Output 1) 3 WP# (IO2) I/O Write Protect Input (Data Input Output 2) 4 VSS 5 SI (IO0) I/O 6 SCLK I 7 HOLD# (IO3) I/O 8 VCC Chip Select Input Ground Data Input (Data Input Output 0) Serial Clock Input Hold Input (Data Input Output 3) Power Supply 4. BLOCK DIAGRAM 3 NB25Q40A NB SPI NOR FLASH 5. MEMORY ORGANIZATION Table-2.0 NB25Q40A Array Organization Each device has Each block has Each sector has Each page has 512K 64/32K 4K 256 Bytes 2K 256/128 16 - Pages 128 16/8 - - Sectors 8/16 - - - Blocks Table-3.0 NB25Q40A Uniform Block Sector Architecture Block (64K-byte) 7 6 …… 1 0 Block (32K-byte) 14~15 12~13 …… 2~3 0~1 Sector (4K-byte) Address Range 127 07F000H 07FFFFH …… …… …… 112 070000H 070FFFH 111 06F000H 06FFFFH …… …… …… 96 060000H 060FFFH …… …… …… …… …… …… …… …… …… 31 01F000H 01FFFFH …… …… …… 16 010000H 010FFFH 15 00F000H 00FFFFH …… …… …… 0 000000H 000FFFH 4 NB25Q40A NB SPI NOR FLASH 6. DEVICE OPERATION 1. Before a command is issued, the status register should be checked to ensure the device is ready for the intended operation. 2. When an incorrect command is input, the device enters standby mode and remains in standby mode until the next CS# falling edge. In standby mode, the SO pin of the device is in High-Z. 3. When the correct command is input, the device enters active mode and remains in active mode until the next rising edge of CS#. 4. For standard single data rate serial mode, input data is latched on the rising edge of Serial Clock (SCLK) and data is shifted out on the falling edge of SCLK. The difference between Serial mode 0 and mode 3 is shown in Figure-1. Figure-1. Serial Modes Supported (for Normal Serial Mode) Standard SPI The NB25Q40A features a serial peripheral interface on 4 signals: Serial Clock (SCLK), Chip Select (CS#), Serial Data Input (SI) and Serial Data Output (SO). Both SPI bus mode 0 and 3 are supported. Input data is latched on the rising edge of SCLK and is data shifted out on the falling edge of SCLK. Dual SPI The NB25Q40A supports Dual SPI operation when using the “Dual Output Fast Read” (3BH), “Dual I/O Fast Read” (BBH) , “Dual I/O Read Manufacture ID & Device ID” (92H) and “Dual Input Page Program” (A2H) commands. These commands allow data to be transferred to or from the device at twice the rate of the standard SPI. When using the Dual SPI command, the SI and SO pins become bidirectional I/O pins: IO0 and IO1. 5 NB25Q40A NB SPI NOR FLASH Hold Driving the HOLD# pin low will pause any serial communications with the device. The HOLD feature will not stop the following operations if already in progress when the HOLD# pin goes low: status register write, program, or erase. The operation of HOLD requires Chip Select (CS#) to remain low and begins on the falling edge of HOLD# pin signal while the Serial Clock (SCLK) signal is low (if the Serial Clock signal is not low, the HOLD operation will not start until the Serial Clock signal is low). The HOLD condition ends on the rising edge of HOLD# pin signal while the Serial Clock (SCLK) signal is low (if the Serial Clock signal is not low, the HOLD operation will not end until the Serial Clock is low). Figure-2. Hold Condition CS# SCLK HOLD# HOLD HOLD During the HOLD operation, the Serial Data Output (SO) is in a high impedance state when the HOLD# pin goes low and will remain in a high impedance state until the HOLD# pin goes high. The Serial Data Input (SI) is ignored (don't care) if both the Serial Clock (SCLK) and HOLD# pin go low and will remain in this state until the SCLK goes low and the HOLD# pin goes high. If Chip Select (CS#) is driven high during the HOLD operation, it will reset the internal logic of the device. To re-start communication with chip, the HOLD# must be driven high and CS# must be at a logic low. Note: The HOLD feature is disabled in Quad I/O mode. 7. STATUS REGISTER Table-4. Status Register S15 S14 S13 S12 S11 S10 S9 S8 SUS1 CMP LB3 LB2 LB1 SUS2 QE SRP1 Read-only Non-volatile S7 S6 S5 S4 S3 S2 S1 S0 SRP0 BP4 BP3 BP2 BP1 BP0 WEL WIP Read-only Read-only Non-volatile Non-volatile OTP Non-volatile 6 Read-only Non-volatile Non-volatile NB25Q40A NB SPI NOR FLASH The status and control bits of the Status Register are as follows: WIP bit The Write in Progress (WIP) bit indicates whether the device is busy executing a program/erase/write status register operation. When the Write in Progress (WIP) bit is set to 1, a program/erase/write status register operation is in progress. When the Write in Progress (WIP) bit is set to 0, the device does not have a program/erase/write status register operation in progress. WEL bit The Write Enable Latch (WEL) bit indicates the status of the internal Write Enable Latch. When set to 1, the internal Write Enable Latch is set, when set to 0 the internal Write Enable Latch is reset, and no Write Status Register, Program or Erase command is accepted. BP4, BP3, BP2, BP1, BP0 bits The Block Protect (BP4, BP3, BP2, BP1, and BP0) bits are non-volatile. They define the size of the area software protected against Program and Erase commands. These bits are written with the Write Status Register (01H) command. When the Block Protect (BP4, BP3, BP2, BP1, BP0) bits are set to the target value, the relevant memory area (as defined in Table-6.X) becomes protected against Page Program (02H), Page Erase (81H), Sector Erase (20H), Half Block Erase (52H) and Block Erase (D8H) commands. The Chip Erase (60H or C7H) command is executed, only if the Block Protect bits are set to “None protected”. The Block Protect bits can be written if the Hardware Protection Mode has not been set. SRP1, SRP0 bits The Status Register Protect (SRP1 and SRP0) bits are non-volatile Read/Write bits in the status register. The SRP bits control the method of write protection: software protection, hardware protection, power supply lock-down or one-time programmable protection. Table-5. Status Register Protection Bits SRP1 SRP0 #WP Status Register 0 0 X Software Protected 0 1 0 Hardware Protected 0 1 1 Hardware Unprotected 1 0 X 1 1 X Description The Status Register can be written to after a Write Enable command, WEL=1. (Default) WP#=0, the Status Register is locked and cannot be written to. WP#=1, the Status Register is unlocked and can be written to after a Write Enable command, WEL=1. Power Supply Status Register is protected and cannot be written to again Lock-Down until the next Power-Down, Power-Up cycle. (1) One Time Program (2) Status Register is permanently protected and cannot be written to. Notes: 1. When SRP1, SRP0= (1, 0), a Power-Down, Power-Up cycle will change SRP1, SRP0 to (0, 0) state. 2. This feature is available on special order. Please contact NB for details. QE bit The Quad Enable (QE) bit is a non-volatile Read/Write bit in the Status Register that allows Quad operation. When the QE bit is set to 0 (Default) the device is set to Standard SPI operation and both WP# and HOLD# 7 NB25Q40A NB SPI NOR FLASH pins are enabled. When the QE bit is set to 1, the Quad IO2 and IO3 pins are enabled and the WP# pin function is not available since this pin is used for IO2. (Set the QE bit to 0 to avoid short issue if the WP# or HOLD# pin is tied directly to the power supply or ground.) LB3, LB2, LB1 bits The LB3, LB2, LB1 bits are non-volatile One Time Program (OTP) bits in Status Register (S13-S11) that provide the write protect control and status for the Security Registers. The default state of LB3-LB1 is 0, with the security registers unprotected. The LB3-LB1 bits can be set to 1 individually using the Write Register (01H) command. The LB3-LB1 bits are One Time Programmable, once setting to 1, the corresponding Security Registers will become read-only permanently. CMP bit The CMP bit is a non-volatile Read/Write bit in the Status Register (S14). It is used in conjunction with the BP4-BP0 bits to provide more flexibility for the memory array protection. Please see the Table-6.X for protect area details. The default setting is CMP=0. SUS1, SUS2 bit The SUS1 and SUS2 bits are read only bits in the status register (S15 and S10) that are set to 1 after executing a Program/Erase Suspend (75H or B0H) command. (The Erase Suspend will set the SUS1 to 1, and the Program Suspend will set the SUS2 to 1). The SUS1 and SUS2 bits are cleared to 0 by the Program/Erase Resume (7AH or 30H) command, the Software Reset (66H+99H) command as well as a power-down, powerup cycle. 8. DATA PROTECTION During power transition, there may be some false system level signals which result in inadvertent erasure or programming. The device is designed to protect itself from these accidental write cycles. The state machine will be reset to standby mode automatically during power up. In addition, the control register architecture of the device ensures that the memory contents can only be changed after specific command sequences have completed successfully. In the following, there are several features to protect the system from the accidental write cycles during VCC power-up and power-down or from system noise.  Valid command length checking: The command length will be checked whether it is at byte base and completed on byte boundary.  Write Enable (06H) command: WREN command is required to set the Write Enable Latch bit (WEL) before issuing other commands to change data.  Software Protection Mode: The Block Protect (BP4, BP3, BP2, BP1, and BP0) bits define the section of the memory array that can be read but not changed.  Hardware Protection Mode: WP# going low to protect the CMP, BP0~BP4 bits and SRP0~1 bits.  Deep Power-Down Mode: By entering deep power down mode, the flash device is ignores all commands until the Release from Deep Power-Down Mode (B9H) command. 8 NB25Q40A NB SPI NOR FLASH Table-6.0 NB25Q40A Protected Area Size (CMP=0) Status Register Content Memory Content BP4 BP3 BP2 BP1 BP0 Blocks Addresses Density Portion x x 0 0 0 NONE NONE NONE NONE 0 0 0 0 1 7 070000H-07FFFFH 64KB Upper 1/8 0 0 0 1 0 6 and 7 060000H-07FFFFH 128KB Upper 1/4 0 0 0 1 1 4 to 7 040000H-07FFFFH 256KB Upper 1/2 0 1 0 0 1 0 000000H-00FFFFH 64KB Lower 1/8 0 1 0 1 0 0 and 1 000000H-01FFFFH 128KB Lower 1/4 0 1 0 1 1 0 to 3 000000H-03FFFFH 256KB Lower 1/2 0 x 1 x X 0 to 7 000000H-07FFFFH 512KB ALL 1 0 0 0 1 7 07F000H-07FFFFH 4KB Upper 1/128 1 0 0 1 0 7 07E000H-07FFFFH 8KB Upper 1/64 1 0 0 1 1 7 07C000H-07FFFFH 16KB Upper 1/32 1 0 1 0 X 7 078000H- 07FFFFH 32KB Upper 1/16 1 0 1 1 0 7 078000H-07FFFFH 32KB Upper 1/16 1 1 0 0 1 0 000000H-000FFFH 4KB Lower 1/128 1 1 0 1 0 0 000000H-001FFFH 8KB Lower 1/64 1 1 0 1 1 0 000000H-003FFFH 16KB Lower 1/32 1 1 1 0 X 0 000000H-007FFFH 32KB Lower 1/16 1 1 1 1 0 0 000000H-007FFFH 32KB Lower 1/16 1 x 1 1 1 0 to 7 000000H-07FFFFH 512KB ALL 9 NB25Q40A NB SPI NOR FLASH Table-6.1 NB25Q40A Protected Area Size (CMP=1) Status Register Content Memory Content BP4 BP3 BP2 BP1 BP0 Blocks Addresses Density Portion x x 0 0 0 0 to 7 000000H-07FFFFH 512KB ALL 0 0 0 0 1 0 to 6 000000H-06FFFFH 448KB Lower 7/8 0 0 0 1 0 0 to 5 000000H-05FFFFH 384KB Lower 3/4 0 0 0 1 1 0 to 3 000000H-03FFFFH 256KB Lower 1/2 0 1 0 0 1 1 to 7 010000H-07FFFFH 448KB Upper 7/8 0 1 0 1 0 2 to 7 020000H-07FFFFH 384KB Upper 3/4 0 1 0 1 1 4 to 7 040000H-07FFFFH 256KB Upper 1/2 0 x 1 x x NONE NONE NONE NONE 1 0 0 0 1 0 to 7 000000H-07EFFFH 508KB Lower 127/128 1 0 0 1 0 0 to 7 000000H-07DFFFH 504KB Lower 63/64 1 0 0 1 1 0 to 7 000000H-07BFFFH 496KB Lower 31/32 1 0 1 0 x 0 to 7 000000H-077FFFH 480KB Lower 15/16 1 0 1 1 0 0 to 7 000000H-077FFFH 480KB Lower 15/16 1 1 0 0 1 0 to 7 001000-07FFFFH 508KB Upper 127/128 1 1 0 1 0 0 to 7 002000-07FFFFH 504KB Upper 63/64 1 1 0 1 1 0 to 7 004000-07FFFFH 496KB Upper 31/32 1 1 1 0 x 0 to 7 008000-07FFFFH 480KB Upper 15/16 1 1 1 1 0 0 to 7 008000-07FFFFH 480KB Upper 15/16 1 x 1 1 1 NONE NONE NONE NONE Notes: 1. X=don’t care 2. If any erase or program command specifies a memory that contains protected data portion, this command will be ignored. 10 NB25Q40A NB SPI NOR FLASH 9. COMMAND DESCRIPTION All commands, addresses and data are shifted in and out of the device, beginning with the most significant bit on the first rising edge of SCLK after CS# is driven low. Then, the one-byte command code must be shifted into the device starting with the most significant bit on SI. Each bit is latched on the rising edge of SCLK. The commands supported by NB25Q40A are listed inTable-7. Every command sequence starts with a one-byte command code. Depending on the command, this might be followed by address or data bytes, by both or none. CS# must be driven high after the last bit of the command sequence has been completed. For the commands of Read, Fast Read, Read Status Register, Release from Deep Power- Down, and Read Device ID, the shifted-in command sequence is followed by a data-out sequence. All read commands can be completed after any bit of the data-out sequence is shifted out, and then CS# must be driven high to return to deselected status. For the Page Program (02H), Sector Erase (20H), Half Block Erase (52H), Block Erase (D8H), Chip Erase (C7H or 60H), Write Status Register (01H), Write Enable (06H), Write Disable (04H) or Deep Power-Down (B9H) commands, CS# must be driven high exactly at a byte boundary, otherwise the command is rejected, and is not executed. That means CS# must be driven high when the number of clock pulses after CS# being driven low is an exact multiple of eight. For Page Program, if CS# is driven high at any time the input byte is not a full byte, nothing will happen and WEL will not be reset. 11 NB25Q40A NB SPI NOR FLASH Table-7. Commands (Standard/Dual/Quad SPI) Command Name Byte 1 Write Enable 06H Write Disable 04H Write Enable for Volatile Status Register 50H Byte 2 Byte 3 Byte 4 Byte 5 Byte 6 n-Bytes Read Status Register-1 05H (S7-S0) (continuous) Read Status Register-2 35H (S15-S8) (continuous) Active Status Interrupt 25H Write Status Register 01H S7-S0 S15-S8 Read Data Bytes 03H A23-A16 A15-A8 A7-A0 (D7-D0) (Next byte) (continuous) Read Data Bytes at Higher Speed 0BH A23-A16 A15-A8 A7-A0 dummy (D7-D0) (continuous) Dual Output Fast Read 3BH A23-A16 A15-A8 A7-A0 dummy (D7-D0) (1) (continuous) Dual I/O Fast Read BBH A23-A8 (2) (D7-D0) (1) (Next byte) (Next byte) (continuous) Quad Output Fast Read 6BH A23-A16 A15-A8 A7-A0 dummy (D7-D0) (3) (continuous) Quad I/O Fast Read EBH dummy (5) (D7-D0) (3) (Next byte) (Next byte) (continuous) Set Burst with Wrap 77H Page Erase 81H A23-A16 A15-A8 A7-A0 Sector Erase 20H A23-A16 A15-A8 A7-A0 Half Block Erase 52H A23-A16 A15-A8 A7-A0 Block Erase D8H A23-A16 A15-A8 A7-A0 Chip Erase C7/60H Page Program 02H A23-A16 A15-A8 A7-A0 D7-D0 Next byte continuous Dual Input Page Program A2H A23-A16 A15-A8 A7-A0 D7-D0 Next byte continuous Quad Input Page Program 32H A23-A16 A15-A8 A7-A0 D7-D0 Next byte continuous Erase Security Register (6) 44H A23-A16 A15-A8 A7-A0 Program Security Register (6) 42H A23-A16 A15-A8 A7-A0 D7-D0 D7-D0 continuous Read Security Register (6) 48H A23-A16 A15-A8 A7-A0 dummy (D7-D0) (continuous) Deep Power-Down B9H Release from Deep Power-Down ABH ABH dummy dummy dummy 90H dummy dummy 00H Release from Deep Power-Down, Read Electronic Signature Read Electronic Manufacturer ID & Device ID A7-A0 M7-M0 (2) A23-A0 M7-M0 (4) dummy W7-W0 (7) 12 (DID7-DID0) (continuous) (MID7- (DID7- MID0) DID0) (continuous) NB25Q40A NB SPI NOR FLASH Command Name Dual I/O Read Electronic Manufacturer ID & Device ID Quad I/O Read Electronic Manufacturer ID & Device ID Byte 1 Byte 2 Byte 3 92H dummy A7-A0,M7-M0 A23-A0, 94H M7-M0 Byte 4 Byte 5 (MID7- MID0) dummy (MID7- MID0) (continuous) (DID7- DID0) (8) (MID7- (JDID15- (JDID7- MID0) JDID8) JDID0) 4BH 00H 00H 00H dummy (UID7- UID0) (continuous) Read SFDP Mode 5AH A23-A16 A15-A8 A7-A0 dummy (D7-D0) (continuous) Continuous Read Mode Reset FFH Read Identification 9FH Program/Erase Suspend 75/B0H Program/Erase Resume 7A/30H Reset Enable 66H Reset 99H Read Unique ID (continuous) 2. Dual Input Address IO0 = A22, A20, A18, A16, A14, A12, A10, A8, A6, A4, A2, A0, M6, M4, M2, M0 IO1 = A23, A21, A19, A17, A15, A13, A11, A9, A7, A5, A3, A1, M7, M5, M3, M1 3. Quad Output Data IO0 = (D4, D0, …..) IO1 = (D5, D1, …..) IO2 = (D6, D2, …..) IO3 = (D7, D3,…..) Quad Input Address IO0 = A20, A16, A12, A8, A4, A0, M4, M0 IO1 = A21, A17, A13, A9, A5, A1, M5, M1 IO2 = A22, A18, A14, A10, A6, A2, M6, M2 IO3 = A23, A19, A15, A11, A7, A3, M7, M3 5. n-Bytes (continuous) (DID7- DID0) Notes: 1. Dual Output data IO0 = (D6, D4, D2, D0) IO1 = (D7, D5, D3, D1) 4. Byte 6 Fast Read Quad I/O Dummy Bits and Data IO0 = (x, x, x, x, D4, D0,…) IO1 = (x, x, x, x, D5, D1,…) IO2 = (x, x, x, x, D6, D2,…) IO3 = (x, x, x, x, D7, D3,…) 13 NB25Q40A NB SPI NOR FLASH 6. Security Registers Address: Security Register1: A23-A16=00H, A15-A8=10H, A7-A0= Byte Address; Security Register2: A23-A16=00H, A15-A8=20H, A7-A0= Byte Address; Security Register3: A23-A16=00H, A15-A8=30H, A7-A0= Byte Address; 7. Dummy bits and Wrap Bits IO0 = (x, x, x, x, x, x, W4, x) IO1 = (x, x, x, x, x, x, W5, x) IO2 = (x, x, x, x, x, x, W6, x) IO3 = (x, x, x, x, x, x, x, x) 8. Address, Continuous Read Mode bits, Dummy bits, Manufacture ID and Device ID IO0 = (A20, A16, A12, A8, A4, A0, M4, M0, x, x, x, x, MID4, MID0, DID4, DID0, …) IO1 = (A21, A17, A13, A9, A5, A1, M5, M1, x, x, x, x, MID5, MID1, DID5, DID1, …) IO2 = (A22, A18, A14, A10, A6, A2, M6, M2, x, x, x, x, MID6, MID2, DID6, DID2, …) IO3 = (A23, A19, A15, A11, A7, A3, M7, M3, x, x, x, x, MID7, MID3, DID7, DID3, …) Tables of ID Definition: Operation Code Table-8.0 NB25Q40A ID Definition MID7-MID0 9FH ID15-ID8 ID7-ID0 40 13 90H/92H/94H 12 ABH 12 14 NB25Q40A NB SPI NOR FLASH 9.1 Write Enable (WREN) (06H) The Write Enable (06H) command sets the Write Enable Latch (WEL) bit. The WEL bit must be set prior to every Page Program, Page Erase, Sector Erase, Half Block Erase, Block Erase, Chip Erase, Write Status Register and Erase/Program Security Register command. The WREN command is entered by driving Chip Select (CS#) Low, sending the command code, and then driving CS# High. Figure-3. Write Enable Sequence Diagram 9.2 Write Disable (WRDI) (04H) The Write Disable (04H) command resets the Write Enable Latch (WEL) bit in the Status Register to 0. The WRDI command is entered by driving Chip Select (CS#) low, shifting the command code “04h” into the SI pin and then driving CS# high. Note that the WEL bit is automatically reset after Power-up and upon completion of the Write Status Register, Page Program, Page Erase, Sector Erase, Half Block Erase, Block Erase, Chip Erase, Erase/Program Security Register and Reset commands. Figure-4. Write Disable Sequence Diagram 9.3 Write Enable for Volatile Status Register (50H) The non-volatile Status Register bits can also be written to as volatile bits. During power up reset, the nonvolatile Status Register bits are copied to a volatile version of the Status Register that is used during device operation. This provides more flexibility to change the system configuration and memory protection schemes quickly without waiting for the typical non-volatile bit write cycles or affecting the endurance of the Status Register non-volatile bits. To write the volatile version of the Status Register bits, the Write Enable for Volatile Status Register (50H) command must be issued and immediately followed by the Write Status Register (01H) command. Write Enable for Volatile Status Register command (Figure-5) will not set the Write Enable Latch (WEL) bit, it is only valid for the next Write Status Register command, to change the volatile Status Register bit values. 15 NB25Q40A NB SPI NOR FLASH Figure-5. Write Enable for Volatile Status Register Sequence Diagram 9.4 Read Status Register (RDSR) (05H or 35H) The Read Status Register (05H or 35H) command allows the Status Register to be read. The Status Register may be read at any time, even while a Program, Erase or Write Status Register cycle is in progress. When one of these cycles is in progress, it is recommended to check the Write In Progress (WIP) bit before sending a new command to the device. It is also possible to read the Status Register continuously. For command code “05H”, the SO will output Status Register bits S7~S0. And for command code “35H”, the SO will output Status Register bits S15~S8. Figure-6. Read Status Register Sequence Diagram 9.5 Active Status Interrupt (ASI) (25H) The Active Status Interrupt (25h) command provides an alternative method to read the Write In Progress (WIP) bit. The SO pin outputs the WIP bit continuously with the ASI command. The SO pin can be connected to an interrupt line of the host controller, and the host controller remains in sleep mode until the SO pin indicates that the device is ready for the next command. The WIP bit can be read at any time, including while an internally self-timed program or erase operation is in progress. To enable the ASI command, the CS# pin must first be asserted and the opcode of 25h must be clocked into the device. The value of WIP is then output on the SO pin and is continuously updated by the device for as long as the CS# pin remains asserted. Additional clocks on the SCLK pin are not required. If the WIP bit changes from 1 to 0 while the CS# pin is asserted, the SO pin will change from 1 to 0 when the program/erase operation is completed. (The WIP bit cannot change from 0 to 1 during an operation, so if the SO pin already is 0, it will not change.) Deserting the CS# pin will terminate the ASI operation and put the SO pin into a high-impedance state. The CS# pin can be deserted at any time and does not require that a full byte of data be read. The sequence of issuing ASI command is: CS# goes low -> send Active Status Interrupt (25H) command 16 NB25Q40A NB SPI NOR FLASH code -> Write In Progress (WIP) data out on SO. Figure-7. Active Status Interrupt Sequence Diagram 9.6 Write Status Register (WRSR) (01H) The Write Status Register (01H) command allows new values to be written to the Status Register. Before it can be accepted, a Write Enable (06H) command must previously have been executed. After the Write Enable command has been decoded and executed, the device sets the Write Enable Latch (WEL). The WRSR command is entered by driving Chip Select (CS#) Low, followed by the command code and the data byte on Data Input (SI). The WRSR command has no effect on S15, S10, S1 and S0 of the Status Register. CS# must be driven high after the sixteenth bit of the data byte has been latched in. If not, the WRSR command is not executed. As soon as CS# is driven High, the self-timed Write Status Register cycle (whose duration is tW) is initiated. While the Write Status Register cycle is in progress, the Status Register may still be read to check the value of the Write In Progress (WIP) bit. The WIP bit is 1 during the self-timed Write Status Register cycle and is 0 when it is completed. When the cycle is completed, the WEL bit is reset. The WRSR command allows the user to change the values of the Block Protect (BP4, BP3, BP2, BP1, BP0) bits. The WRSR command also allows the user to set or reset the Status Register Protect (SRP1 and SRP0) bits in accordance with the Write Protect (WP#) signal. The Status Register Protect (SRP1 and SRP0) bits and WP# signal allow the device to be put in the Hardware Protection Mode. The WRSR command is not executed once the Hardware Protection Mode is entered. CS# must go high exactly at the 16 bit data boundary; otherwise the command will be rejected and not executed. The self-timed Write Status Register cycle time (tW) is initiated as soon as CS# goes high. The WIP bit still can be checked during the Write Status Register cycle is in progress. The WIP is set to 1 during tW and is reset to 0 along with the WEL bit when Write Status Register Cycle is completed. Figure-8. Write Status Register Sequence Diagram 17 NB25Q40A NB SPI NOR FLASH 9.7 Read Data Bytes (READ) (03H) The device is first selected by driving Chip Select (CS#) Low. The command code for the Read Data Bytes (03H) command is followed by a 3-byte address (A23-A0), with each bit latched-in on the rising edge of Serial Clock (SCLK). Then the memory contents, at that address, is shifted out on Data Output (SO), with each bit shifted out at a maximum frequency fR on the falling edge of SCLK. The command sequence is shown in Figure-9. The first byte addressed can be at any location. The address is automatically incremented to the next higher address after each byte of data is shifted out. The whole memory can, therefore, be read with a single READ command. When the highest address is reached, the address counter rolls over to 000000h, allowing the read sequence to be continued indefinitely. The READ command is terminated by driving CS# High. CS# can be driven High at any time during data output. Any READ command to the memory array, while an Erase, Program or Write cycle is in progress, is rejected without having any effects on the cycle that is in progress. Figure-9. Read Data Bytes Sequence Diagram 9.8 Read Data Bytes at Higher Speed (FAST_READ) (0BH) The device is first selected by driving Chip Select (CS#) Low. The command code for the Read Data Bytes at Higher Speed (0BH) command is followed by a 3-byte address (A23-A0) and a dummy byte, each bit being latched-in on the rising edge of Serial Clock (SCLK). Then the memory contents, at that address, is shifted out on Data Output (SO), with each bit shifted out at a maximum frequency fC on the falling edge of SCLK. The command sequence is shown in Figure-10. The first byte addressed can be at any location. The address is automatically incremented to the next higher address after each byte of data is shifted out. The whole memory can, therefore, be read with a single FAST_READ command. When the highest address is reached, the address counter rolls over to 000000h, allowing the read sequence to be continued indefinitely. The FAST_READ command is terminated by driving CS# High. CS# can be driven High at any time during data output. Any FAST_READ command, while an Erase, Program or Write cycle is in progress, is rejected without having any effects on the cycle that is in progress. 18 NB25Q40A NB SPI NOR FLASH Figure-10. Read Data Bytes at Higher Speed Sequence Diagram 9.9 Dual Output Fast Read (DREAD) (3BH) The Dual Output Fast Read (3BH) is similar to the standard Fast Read (0BH) command except that data is output on two pins, SI (IO0) and SO (IO1), instead of just SO. This allows data to be transferred from the NB25Q40A at twice the rate of standard SPI devices. The DREAD command is ideal for quickly downloading code from the flash to RAM upon power-up or for applications that cache code-segments to RAM for execution. Like the Fast Read command, the DREAD command can operate at the highest possible frequency of fT. This is accomplished by adding eight “dummy clocks after the 24-bit address as shown in Figure-11. The dummy clocks allow the device’s internal circuits the time required for setting up the initial address. The input data during the dummy clock is “don’t care”. However, the SI pin should be in a high-impedance state prior to the falling edge of SLCK for the first data out. Figure-11. Dual Output Fast Read Sequence Diagram 19 NB25Q40A NB SPI NOR FLASH 9.10 Dual I/O Fast Read (2READ) (BBH) The Dual I/O Fast Read (BBH) command allows for improved random access while maintaining two IO pins, SI (IO0) and SO (IO1). It is similar to the Dual Output Fast Read (3BH) command but with the ability to input the address bits (A23-0) two bits per clock. This reduced command overhead may allow for code execution (XIP) directly from the Dual SPI in some applications. The 2READ command enables double throughput of Serial Flash in read mode. The address is latched on rising edge of SCLK, and two bits of data (interleave 2 I/O pins) are shifted out on the falling edge of SCLK at a maximum frequency fT. The first address can be at any location. The address is automatically increased to the next higher address after each byte data is shifted out, so the whole memory can be read out with a single 2READ command. The address counter rolls over to 0 when the highest address has been reached. The 2READ command is shown in Figure-12. Figure-12. Dual I/O Fast Read Sequence Diagram (M5-4 ≠ (1,0)) 9.11 Dual I/O Fast Read with “Continuous Read Mode” (BBH) The Dual I/O Fast Read (BBH) command supports Dual I/O Fast Read with “Continuous Read Mode” which can further reduce command overhead by setting the “Continuous Read Mode” bits (M7-0) after the input 3-byte address (A23-A0). If the “Continuous Read Mode” bits (M5-4) = (1, 0), then the next Dual I/O Fast Read command (after CS# is raised and then lowered) does not require the BBH command code. If the “Continuous Read Mode” bits (M5-4) do not equal (1, 0), the next command requires the first BBH command code, thus returning to normal operation. A “Continuous Read Mode” Reset command can be used to reset (M5-4) before issuing a normal command. 20 NB25Q40A NB SPI NOR FLASH Figure-13. Dual I/O Fast Read with “Continuous Read Mode” Sequence Diagram (M5-4 = (1,0)) Note: Dual I/O Fast Read with “Continuous Read Mode”, if (M5-4)=(1,0). If not using “Continuous Read Mode” recommend setting (M5-4)≠(1,0). 9.12 Quad Output Fast Read (QREAD) (6BH) The Quad Output Fast Read (6BH) command is similar to the Dual Output Fast Read (3BH) command except that data is output on four pins, IO0, IO1, IO2, and IO3. A Quad Enable (QE) of Status Register-2 must be executed before the device will accept the QREAD Command. (The QE bit must equal “1”). The QREAD Command allows data to be transferred at four times the rate of standard SPI devices. The QREAD command can operate at a higher frequency than the traditional Read Data command. This is accomplished by adding eight “dummy” clocks after the 24-bit address as shown in Figure-14. The dummy clocks allow the device's internal circuits the time required for setting up the initial address. The input data during the dummy clocks is “don’t care.” However, the IO pins should be in a high-impedance state prior to the falling edge of SCLK for the first data out. 21 NB25Q40A NB SPI NOR FLASH Figure-14. Quad Output Fast Read Sequence Diagram 9.13 Quad I/O Fast Read (4READ) (EBH) The Quad I/O Fast Read (EBH) command is similar to the Dual I/O Fast Read (BBH) command except that address and data bits are input and output through four pins, SI (IO0), SO (IO1), WP (IO2) and HOLD (IO3). Six dummy clocks are required prior to the data output. A Quad Enable (QE) of Status Register-2 must be executed before the device will accept the 4READ Command. (The QE bit must equal “1”). The Quad I/O dramatically reduces command overhead allowing faster random access for code execution (XIP) directly from the Quad SPI. The 4READ command enables quad throughput of Serial Flash in read mode. The address is latched on rising edge of SCLK, and data four bits of data (interleave on 4 I/O pins) shift out on the falling edge of SCLK at a maximum frequency fQ. The first address can be any location. The address is automatically increased to the next higher address after each byte data is shifted out, so the whole memory can be read out with a single 4READ command. The address counter rolls over to 0 when the highest address has been reached. Once writing 4READ command, the following address / dummy / data out will transfer 4-bits per clock cycle instead of the previous 1-bit. The sequence of issuing 4READ command is: CS# goes low -> send Quad I/O Fast Read (EBH) command -> 24-bit address interleave on IO3, IO2, IO1 and IO0 -> 2+4 dummy cycles -> data out interleave on IO3, IO2, IO1 and IO0 -> end 4READ operation by driving CS# high at any time during data out, as shown in Figure-15. Another sequence of issuing 4READ command especially useful in random access is: CS# goes low -> send Quad I/O Fast Read (EBH) command -> 24-bit address interleave on IO3, IO2, IO1 and IO0 -> “Continuous Read Mode” byte M[7:0] -> 4 dummy cycles -> data out until CS# goes high -> CS# goes low (reduce 4READ command) -> 24-bit random access address. In the Continuous Read Mode, the “Continuous Read Mode” bits M[5:4] = (1,0) can make this mode continue and reduce the next 4READ command. Once M[5:4 ] ≠ (1,0) and after CS# is raised and then lowered, the system then will escape from the enhanced performance mode and return to normal operation. A “Continuous Read Mode” Reset command can be used to reset (M5-4) before issuing normal commands. 22 NB25Q40A NB SPI NOR FLASH While Program/Erase/Write Status Register cycle is in progress, the 4READ command is rejected without any impact on the Program/Erase/Write Status Register operation. Figure-15. Quad I/O Fast Read Sequence Diagram (M5-4 ≠ (1,0)) 4 5 6 9.14 Quad I/O Fast Read with “Continuous Read Mode” (EBH) The Quad I/O Fast Read (EBH) command supports Quad I/O Fast Read with “Continuous Read Mode” which can further reduce command overhead by setting the “Continuous Read Mode” bits (M7-0) after the input 3-byte address (A23-A0). If the “Continuous Read Mode” bits (M5-4) = (1, 0), then the next Quad I/O Fast Read (EBH) command (after CS# is raised and then lowered) does not require the EBH command code. If the “Continuous Read Mode” bits (M5-4) do not equal (1, 0), the next command requires the first EBH command code, thus returning to normal operation. A “Continuous Read Mode” Reset command can be used to reset (M5-4) before issuing a normal command. 23 NB25Q40A NB SPI NOR FLASH Figure-16. Quad I/O Fast Read with “Continuous Read Mode” Sequence Diagram (M5-4 = (1,0)) 4 5 6 4 5 Note: Quad I/O Fast Read with “Continuous Read Mode”, if (M5-4)=(1,0). If not using “Continuous Read Mode” recommend setting (M5-4)≠(1,0). 9.15 Set Burst with Wrap (77H) The Set Burst with Wrap (77h) command is used in conjunction with Quad I/O Fast Read (EBH) command to access a fixed length of 8/16/32/64-byte section within a 256-byte page, in standard SPI mode. The Set Burst with Wrap command sequence: CS# goes low -> Send Set Burst with Wrap (77h) command -> Send 24 dummy bits-> Send 8 bits “Wrap bits” -> CS# goes high. If the W6-W4 bits are set by the Set Burst with Wrap command, all the following Quad I/O Fast Read commands will use the W6-W4 setting to access the 8/16/32/64-byte section within any page. To exit the “Wrap Around” function and return to normal read operation, another Set Burst with Wrap command should be issued to set W4=1. 24 NB25Q40A NB SPI NOR FLASH Table-9. Burst Length and Wrap W6,W5 W4=0 W4=1 (default) Wrap Wrap Wrap Wrap Around Length Around Length 0,0 Yes 8-byte No N/A 0,1 Yes 16-byte No N/A 1,0 Yes 32-byte No N/A 1,1 Yes 64-byte No N/A Figure-17. Set Burst with Wrap Sequence Diagram 9.16 Page Erase (PE) (81H) The Page Erase (81H) command sets all bits to 1 (FFh) inside the chosen page. Before it can be accepted, a Write Enable (06H) command must have previously been executed. After the Write Enable command has been decoded, the device sets the Write Enable Latch (WEL). The PE command is entered by driving Chip Select (CS#) Low, followed by the command code, and three address bytes on Data Input (SI). Any address inside the page is a valid address for the PE command. CS# must be driven Low for the entire duration of the sequence. The command sequence is shown in Figure-18. The CS# must go high exactly at the byte boundary (after the least significant bit of the third address byte is latched-in); otherwise, the command will be rejected and not executed. As soon as CS# is driven High, the self-timed Page Erase cycle (with duration tPE) is initiated. While the Page Erase cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The WIP bit is 1 during the self-timed Page Erase cycle and is 0 when it is completed. At some unspecified time before the cycle is completed, the WEL bit is reset. A PE command may be applied only to a page which is not protected by the Block Protect (BP4, BP3, BP2, BP1, BP0) bits. 25 NB25Q40A NB SPI NOR FLASH Figure-18. Page Erase Sequence Diagram 9.17 Sector Erase (SE) (20H) The Sector Erase (20H) command sets all bits to 1 (FFh) inside the chosen sector. Before it can be accepted, a Write Enable (06H) command must have previously been executed. After the Write Enable command has been decoded, the device sets the Write Enable Latch (WEL). The SE command is entered by driving Chip Select (CS#) Low, followed by the command code, and three address bytes on Data Input (SI). Any address inside the sector is a valid address for the SE command. CS# must be driven Low for the entire duration of the sequence. The command sequence is shown in Figure-19. The CS# must go high exactly at the byte boundary (after the least significant bit of the third address byte is latched-in); otherwise, the command will be rejected and not executed. As soon as CS# is driven High, the self-timed Sector Erase cycle (with duration tSE) is initiated. While the Sector Erase cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The WIP bit is 1 during the self-timed Sector Erase cycle and is 0 when it is completed. At some unspecified time before the cycle is completed, the WEL bit is reset. A SE command may be applied only to a sector which is not protected by the Block Protect (BP4, BP3, BP2, BP1, BP0) bits. Figure-19. Sector Erase Sequence Diagram 9.18 Half Block Erase (HBE) (52H) The Half Block Erase (52H) command sets all bits to 1 (FFh) inside the chosen block. Before it can be accepted, a Write Enable (06H) command must have previously been executed. After the Write Enable command has been decoded, the device sets the Write Enable Latch (WEL). The HBE command is entered by driving Chip Select (CS#) Low, followed by the command code, and three address bytes on Data Input (SI). Any address inside the block is a valid address for the HBE command. CS# must be driven Low for the entire duration of the sequence. The command sequence is shown in Figure-20. The CS# must go high exactly at the byte boundary (after the least significant bit of the third address byte is latched-in); otherwise, the command will be rejected and not executed. As soon as CS# is driven High, the self-timed Half Block Erase cycle (with duration tBE1) is initiated. While the Half Block Erase cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The WIP bit is 1 during the self-timed Block Erase cycle and is 0 when it is completed. 26 NB25Q40A NB SPI NOR FLASH At some unspecified time before the cycle is completed, the WEL bit is reset. A HBE command may be applied only to a half block which is not protected by the Block Protect (BP4, BP3, BP2, BP1, BP0) bits. Figure-20. Half Block Erase Sequence Diagram 9.19 Block Erase (BE) (D8H) The Block Erase (D8H) command sets all bits to 1 (FFh) inside the chosen block. Before it can be accepted, a Write Enable (06H) command must have previously been executed. After the Write Enable 06H command has been decoded, the device sets the Write Enable Latch (WEL). The BE command is entered by driving Chip Select (CS#) Low, followed by the command code, and three address bytes on Data Input (SI). Any address inside the block is a valid address for the BE command. CS# must be driven Low for the entire duration of the sequence. The command sequence is shown in Figure-21. CS# must be driven High after the least significant bit of the third address byte is latched in, otherwise the BE command is not executed. As soon as CS# is driven High, the self-timed Block Erase cycle (whose duration is tBE2) is initiated. While the Block Erase cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The WIP bit is 1 during the self-timed Block Erase cycle and is 0 when it is completed. At some unspecified time before the cycle is completed, the WEL bit is reset. A BE command may be applied only to a block which is not protected by the Block Protect (BP4, BP3, BP2, BP1, BP0) bits. Figure-21. Block Erase Sequence Diagram 9.20 Chip Erase (CE) (60H or C7H) The Chip Erase (60H or C7H) command sets all bits to 1 (FFh). Before it can be accepted, a Write Enable (06H) command must have previously been executed. After the Write Enable command has been decoded, the device sets the Write Enable Latch (WEL). The CE command is entered by driving Chip Select (CS#) Low, followed by the command code on Data Input (SI). CS# must be driven Low for the entire duration of the sequence. The command sequence is shown in Figure-22. CS# must be driven High after the eighth bit of the command code is latched in, otherwise the CE command is not executed. As soon as CS# is driven High, the self-timed Chip Erase cycle (with duration tCE) is initiated. While the Chip Erase cycle is in progress, the Status 27 NB25Q40A NB SPI NOR FLASH Register may be read to check the value of the Write In Progress (WIP) bit. The WIP bit is 1 during the selftimed Chip Erase cycle and is 0 when it is completed. At some unspecified time before the cycle is completed, the WEL bit is reset. The CE command is executed only if all Block Protect (BP4, BP3, BP2, BP1, BP0) bits are 0. The CE command is ignored if one, or more blocks are protected. Figure-22. Chip Erase Sequence Diagram 9.21 Page Program (PP) (02H) The Page Program (02H) command allows bytes to be programmed in the memory. Before it can be accepted, a Write Enable (06H) command must have previously been executed. After the Write Enable command has been decoded, the device sets the Write Enable Latch (WEL). The PP command is entered by driving Chip Select (CS#) Low, followed by the command code, three address bytes and at least one data byte on Data Input (SI). If the 8 least significant address bits (A7-A0) are not all zero, all transmitted data that goes beyond the end of the current page are programmed from the starting address of the same page (from the address whose 8 least significant bits (A7-A0) are all zero). CS# must be driven Low for the entire duration of the sequence. The command sequence is shown in Figure-23. If more than 256 bytes are sent to the device, previously latched data are discarded, and the last 256 data bytes are guaranteed to be programmed correctly within the same page. If less than 256 Data bytes are sent to device, they are correctly programmed at the requested addresses without having any effects on the other bytes of the same page. CS# must be driven High after the eighth bit of the last data byte has been latched in, otherwise the PP command is not executed. As soon as CS# is driven High, the self-timed Page Program cycle (with duration tPP) is initiated. While the Page Program cycle is in progress, the Status Register may be read to check the value of the WIP bit. The WIP bit is 1 during the self-timed Page Program cycle and is 0 when it is completed. At some unspecified time before the cycle is completed, the WEL bit is reset. A PP command may be applied only to a page which is not protected by the Block Protect (BP4, BP3, BP2, BP1, BP0) bits. 28 NB25Q40A NB SPI NOR FLASH Figure-23. Page Program Sequence Diagram 9.22 Dual Input Page Program (DPP) (A2H) The Dual Input Page Program (A2H) command is similar to the standard Page Program command and can be used to program anywhere from a single byte of data up to 256 bytes of data into previously erased memory locations. The DPP command allows two bits of data to be clocked into the device on every clock cycle rather than just one. A Write Enable (06H) command must be executed to set the Write Enable Latch (WEL) bit before sending the DPP command. The Dual Input Page Programming takes two pins: IO0, IO1 as data input, which can improve programmer as well as in-system application performance. The other function descriptions are as same as the standard page program. The sequence of issuing DPP command is: CS# goes low -> send Dual Input Page Program (A2H) command code -> 3-byte address on SI -> at least 1-byte on data on IO[1:0] -> CS# goes high. A DPP command may be applied only to a page which is not protected by the Block Protect (BP4, BP3, BP2, BP1, BP0) bits. 29 NB25Q40A NB SPI NOR FLASH Figure-24. Dual Input Page Program Diagram 9.23 Quad Input Page Program (QPP) (32H) The Quad Input Page Program (32H) command is for programming the memory to be "0". A Write Enable command must be executed to set the Write Enable Latch (WEL) bit and Quad Enable (QE) bit to "1" before sending the QPP command. The Quad Input Page Programming uses four pins: IO0, IO1, IO2, and IO3 as data input, which can improve programmer as well as in-system application performance. The QPP operation supports frequencies as fast as fQPP. The other function descriptions are as same as standard page program. The sequence of issuing QPP command is: CS# goes low -> send Quad Input Page Program (32H) command code -> 3-byte address on IO0 -> at least 1-byte on data on IO[3:0] -> CS# goes high. A QPP command may be applied only to a page which is not protected by the Block Protect (BP4, BP3, BP2, BP1, BP0) bits. 30 NB25Q40A NB SPI NOR FLASH Figure-25. Quad Input Page Program Sequence Diagram 31 NB25Q40A NB SPI NOR FLASH 9.24 Erase Security Register (ERSCUR) (44H) There are three 256-byte Security Registers which can be erased and programmed individually. These registers may be used by system manufacturers to store security and other important information separately from the main memory array. The Erase Security Register (44H) command is like the Sector Erase (20H) command. A Write Enable command must be executed before the device will accept the ERSCUR Command (Status Register bit WEL must equal 1). The command is initiated by driving the CS# pin low and shifting the command code “44H” followed by a 24-bit address (A23-A0) to erase one of the security registers. The ERSCUR command sequence is shown in Figure-26. The CS# pin must be driven high after the eighth bit of the last address byte is latched. If this is not done, the command will not be executed. After CS# is driven high, the self-timed ERSCUR operation will commence for a time duration of tSE. While the Erase Security Register cycle is in progress, the Read Status Register command (05H) may still be accessed for checking the value of the Write in Progress (WIP) bit. The WIP bit is a 1 during the erase cycle and becomes a 0 when the cycle is finished and the device is ready to accept other commands again. After the Erase Security Register cycle has finished, the WEL bit in the Status Register is cleared to 0. The Security Register Lock Bits (LB3-1) in the Status Register are OTP and can be used to protect the security registers. Once the LB bit is set to 1, the corresponding security register will be permanently locked, and an ERSCUR command to that register will be ignored. Table-10.0 Erase Security Register Address ADDRESS A23-16 A15-12 A11-8 A7-0 Security Register #1 00h 0001 0000 Don’t care Security Register #2 00h 0010 0000 Don’t care Security Register #3 00h 0011 0000 Don’t care Figure-26. Erase Security Register Sequence Diagram 9.25 Program Security Register (PRSCUR) (42H) The Program Security Register (42H) command is similar to the Page Program (02H) command. It allows from one byte to 256 bytes of security register data to be programmed at previously erased (FFh) memory locations. A Write Enable (06H) command must be executed before the device will accept the PRSCUR Command (Status Register bit WEL= 1). The command is initiated by driving the CS# pin low then shifting the command code “42H” followed by a 24-bit address (A23-A0) and at least one data byte, into the SI pin. The CS# pin must be held low for the entire length of the command while data is being sent to the device. The PRSCUR command sequence is shown in Figure-27. The Security Register Lock Bits (LB3-1) in the Status Register are OTP can be used to protect the security registers. Once Security Register Lock Bit (LB31) is set to 1, the corresponding security register will be permanently locked, and a PRSCUR command to that register will be ignored. 32 NB25Q40A NB SPI NOR FLASH Table-10.1 Program Security Register Address ADDRESS A23-16 A15-12 A11-8 A7-0 Security Register #1 00h 0001 0000 Byte Address Security Register #2 00h 0010 0000 Byte Address Security Register #3 00h 0011 0000 Byte Address Figure-27. Program Security Register Sequence Diagram 9.26 Read Security Register (RDSCUR) (48H) The Read Security Register (48H) command is similar to the Fast Read (0BH) command and allows one or more data bytes to be sequentially read from one of the three security registers. The command is initiated by driving the CS# pin low and then shifting the command code “48H” followed by a 24-bit address (A23-A0) and eight “dummy” clocks into the SI pin. The code and address bits are latched on the rising edge of the SCLK pin. After the address is received, and following the eight dummy cycles, the data byte of the addressed memory location will be shifted out on the SO pin on the falling edge of SCLK with the most significant bit (MSB) first. The first byte addressed can be at any location. The byte address is automatically incremented to the next byte address after each byte of data is shifted out. Once the byte address reaches the last byte of the register (byte FFh), it will reset to 00h, the first byte of the register, and continue to increment. The command is completed by driving CS# high. The RDSCUR command sequence is shown in Figure-28. If a RDSCUR command is issued while an Erase, Program, or Write cycle is in process (Write in Progress (WIP)=1), the command is ignored and will not have any effect on the current cycle. The RDSCUR command allows each bit being shifted out on SO pin at a Max frequency fC, on the falling edge of SCLK. Table-10.2 Read Security Register Address ADDRESS A23-16 A15-12 A11-8 A7-0 Security Register #1 00h 0001 0000 Byte Address Security Register #2 00h 0010 0000 Byte Address Security Register #3 00h 0011 0000 Byte Address 33 NB25Q40A NB SPI NOR FLASH Figure-28. Read Security Register Sequence Diagram 9.27 Deep Power-Down (DP) (B9H) Executing the Deep Power-Down (B9H) command is the only way to place the device in the lowest power consumption mode (the Deep Power-Down mode). It can also be used as an extra software protection mechanisms the device is not in active use, all Write, Program and Erase commands are ignored. Driving Chip Select (CS#) High deselects the device and puts the device in the Standby mode (if there is no internal cycle currently in progress). However, Standby mode is not the Deep Power-Down mode. The Deep Power-Down mode can only be entered by executing the DP command, to reduce the standby current (from ISB1 to ISB2). Once the device has entered the Deep Power-Down mode, all commands are ignored except the Release from Deep Power-Down, Read Electronic Signature (ABH) command. This command releases the device from this mode and also outputs the Device ID on Data Output (SO). The Deep Power-Down mode automatically stops at Power-Down, and the device always Powers-up in the Standby mode. The DP command is entered by driving CS# Low, followed by the command code on Data Input (SI). CS# must be driven Low for the entire duration of the sequence. The command sequence is shown in Figure-29. CS# must be driven High after the eighth bit of the command code has been latched in, otherwise the Deep Power-Down (B9H) command is not executed. As soon as CS# is driven High, a delay of tDP occurs before the supply current is reduced to ISB2 and the Deep Power-Down mode is entered. Any DP command, while an Erase, Program or Write cycle is in progress, is rejected without having any effects on the cycle that is in progress. 34 NB25Q40A NB SPI NOR FLASH Figure-29. Deep Power-Down Sequence Diagram 9.28 Release form Deep Power-Down (RDP), Read Electronic Signature (RES) (ABH) Once the device has entered the Deep Power-Down mode, all commands are ignored except the Release from Deep Power-Down, Read Electronic Signature (ABH) command. Executing this command takes the device out of the Deep Power-Down mode. Please note that this is not the same as or even a subset of, the JEDEC 16-bit Electronic Signature that is read by the Read Identification (9FH) command. The old-style Electronic Signature is supported for reasons of backward compatibility, only, and should not be used for new designs. New designs should, instead, make use of the JEDEC 16-bit Electronic Signature, and the Read Identification command. When used only to release the device from the power-down state, the command is issued by driving the Chip Select (CS#) pin low, shifting the command code “ABH” and driving CS# high as shown in Figure-30. After the time duration of tRES1 the device will resume normal operation and other commands will be accepted. The CS# pin must remain high during the tRES1 time duration. When used only to obtain the Device ID while not in the power-down state, the command is initiated by driving the CS# pin low and shifting the command code “ABH” followed by 3-dummy bytes. The Device ID bits are then shifted out on the falling edge of SCLK with the most significant bit (MSB) first as shown in Figure-31. The Device ID values are listed in "Tables of ID Definition" (Table-8.X). The Device ID can be read continuously. The command is completed by driving CS# high. When CS# is driven High, the device is put in the Stand-by Power mode. If the device was not previously in the Deep Power-Down mode, the transition to the Stand-by Power mode is immediate. If the device was previously in the Deep Power-Down mode, though, the transition to the Stand-by Power mode is delayed by tRES2, and CS# must remain High for at least tRES2 (max). Once in the Stand-by Power mode, the device waits to be selected, so that it can receive, decode and execute commands. Except while an Erase, Program or Write Status Register cycle is in progress, the RDP, RES command always provides access to the 8-bit Device ID of the device and can be applied even if the Deep Power-Down mode has not been entered. Any RDP, RES command issued to the device while an Erase, Program or Write Status Register cycle is in progress, is not decoded, and has no effect on the cycle that is in progress. 35 NB25Q40A NB SPI NOR FLASH Figure-30. Release from Deep Power-Down (RDP) Sequence Diagram Figure-31. Read Electronic Signature (RES) Sequence Diagram 9.29 Read Electronic Manufacturer ID & Device ID (REMS) (90H) The Read Electronic Manufacturer & Device ID (90H) command provides both the JEDEC assigned Manufacturer ID and the specific Device ID. The REMS command is initiated by driving the CS# pin low and shifting the command code “90H” followed by two dummy bytes and one address byte (A7~A0). After which, the Manufacturer ID for NB and the Device ID are shifted out on the falling edge of SCLK with the most significant bit (MSB) first as shown in Figure-32. The Device ID values are listed in "Tables of ID Definition" (Table-8.X). If the address byte is 00h, the manufacturer ID will be output first, followed by the device ID. If the address byte is 01h, then the device ID will be output first, followed by the manufacturer ID. While CS# is low, the Manufacturer and Device IDs can be read continuously, alternating from one to the other. The command is completed by driving CS# high. 36 NB25Q40A NB SPI NOR FLASH Figure-32. Read Electronic Manufacturer ID & Device ID Sequence Diagram 9.30 Dual I/O Read Electronic Manufacturer ID & Device ID (DREMS) (92H) The Dual I/O Read Electronic Manufacturer ID & Device ID (92H) command is similar to the Read Electronic Manufacturer & Device ID (90H) command and returns the JEDEC assigned Manufacturer ID which uses two pins: IO0, IO1 as address input and ID output I/O. The DREMS command is initiated by driving the CS# pin low and shifting the DREMS command code "92h" followed by two dummy bytes, one address byte (A7~A0) and one byte of ‘Continuous Read Mode’ Bits. After which, the Manufacturer ID for NB and the Device ID are shifted out on the falling edge of SCLK with the most significant bit (MSB) first. If the one-byte address is initially set to 01h, then the device ID will be read first and followed by the Manufacturer ID. The Manufacturer and Device IDs can be read continuously, alternating from one to the other. The DREMS command is completed by driving CS# high. 37 NB25Q40A NB SPI NOR FLASH Figure-33. Dual I/O Read Electronic Manufacturer ID & Device ID Sequence Diagram Note: The “Continuous Read Mode” bits (M5-4) must be set to (1,0) to be compatible with Dual I/O Fast Read command. 9.31 Quad I/O Read Electronic Manufacturer ID & Device ID (QREMS) (94H) The Quad I/O Read Electronic Manufacturer ID & Device ID (94H) command is similar to the Read Electronic Manufacturer & Device ID (90H) command and returns the JEDEC assigned Manufacturer ID which uses four pins: IO0, IO1, IO2, IO3 as address input and ID output I/O. A Quad Enable (QE) of Status Register2 must be executed before the device will accept the QREMS Command (The QE bit must equal “1”). The QREMS command is initiated by driving the CS# pin low and shifting the QREMS command code "94h" followed by two dummy bytes, one address (A7~A0) byte, one byte of ‘Continuous Read Mode’ Bits and two dummy bytes. After which, the Manufacturer ID for NB and the Device ID are shifted out on the falling edge of SCLK with the most significant bit (MSB) first. If the one-byte address is initially set to 01h, then the device ID will be read first and then followed by the Manufacturer ID. The Manufacturer and Device IDs can be read continuously, alternating from one to the other. The QREMS command is completed by driving CS# high. 38 NB25Q40A NB SPI NOR FLASH Figure-34. Quad I/O Read Electronic Manufacturer ID & Device ID Sequence Diagram 4 5 Note: The “Continuous Read Mode” bits (M5-4) must be set to (1,0) to be compatible with Quad I/O Fast Read command. 9.32 Read Identification (RDID) (9FH) The Read Identification (9FH) command allows the 8-bit Manufacturer ID to be read, followed by two bytes of Device ID. The Device ID indicates the memory type in the first byte, and the memory capacity of the device in the second byte. The NB Manufacturer ID and Device ID are list as "Tables of ID Definition" (Table-8.X). Any RDID command issued while an Erase or Program cycle is in progress, is not decoded, and has no effect on the cycle that is in progress. The RDID command should not be issued while the device is in Deep Power down mode. The device is first selected by driving the CS# Low. Then the 8-bit command code for the command is shifted in. This is followed by the 24-bit device identification stored in the memory, shifted out on the SO pin on the falling edge of SCLK. The command sequence is shown in Figure-35. The RDID command is terminated by driving CS# High at any time during data output. When CS# is driven High, the device is placed in the standby mode. Once in the standby stage, the device waits to be selected, so that it can receive, decode and execute commands. 39 NB25Q40A NB SPI NOR FLASH Figure-35. Read Identification Sequence Diagram 9.33 Program/Erase Suspend/Resume The Suspend (75H or B0H) command interrupts a Page Program, Page Erase, Sector Erase, Half Block Erase or Block Erase operation to allow access to the memory array. After the program or erase operation has entered the suspended state, the memory array can be read except for the page being programmed or the page, sector or block being erased. Table-11.0 Readable Area of Memory While a Program or Erase Operation is Suspended Suspended Operation Readable Region of Memory Array Page Program All but the Page being programmed Page Erase All but the Page being erased Sector Erase(4KB) All but the 4KB Sector being erased Half Block Erase(32KB) All but the 32KB Block being erased Block Erase(64KB) All but the 64KB Block being erased When the Serial NOR Flash receives the Suspend command, there is a latency of tPSL or tESL before the Write Enable Latch (WEL) bit clears to “0” and the SUS2 or SUS1 sets to “1”. Afterwards, the device is ready to accept one of the commands listed in Table-11.1 "Acceptable Commands During Program/Erase Suspend after tPSL/tESL" (e.g. Read Data Bytes at Higher Speed (0BH) command). Refer to "AC CHARACTERISTICS" for tPSL and tESL timings. Table-11.2 "Acceptable Commands During Suspend (tPSL/tESL not required)" lists the commands for which the tPSL and tESL latencies do not apply. For example, Read Status Register, Read Security Registers, Reset Enable and Reset can be issued at any time after the Suspend command. Status Register bit 15 (SUS2) and bit 10 (SUS1) can be read to check the suspend status. The SUS2 (Program Suspend Bit) sets to “1” when a program operation is suspended. The SUS1 (Erase Suspend Bit) sets to “1” when an erase operation is suspended. The SUS2 or SUS1 clears to “0” when the program or erase 40 NB25Q40A NB SPI NOR FLASH operation is resumed. Table-11.1 Acceptable Commands During Program/Erase Suspend after tPSL/tESL Command name Command Code Suspend Type Program Suspend Erase Suspend READ 03H • • FAST READ 0BH • • DREAD 3BH • • QREAD 6BH • • 2READ BBH • • 4READ EBH • • RDSFDP 5AH • • RDID 9FH • • REMS 90H • • DREMS 92H • • QREMS 94H • • RDSCUR 48H • • SBL 77H • • WREN 06H RESUME 7AH OR 30H PP 02H • DPP A2H • QPP 32H • • • • Table-11.2 Acceptable Commands During Suspend(tPSL/tESL not required) Command name Command Code WRDI Suspend Type Program Suspend Erase Suspend 04H • • RDSR 05H • • RDSR2 35H • • ASI 25H • • RSTEN 66H • • RST 99H • • NOP 00H • • Figure-36. Resume to Suspend Latency tPRS / tERS CS# Suspend Command Resume Command tPRS: Program Resume to another Suspend tERS: Erase Resume to another Suspend 41 NB25Q40A NB SPI NOR FLASH 9.34 Erase Suspend to Program The “Erase Suspend to Program” feature allows Page Programming while an erase operation is suspended. Page Programming is permitted in any unprotected memory except within the sector of a suspended Sector Erase operation or within the block of a suspended Block Erase operation. The Write Enable (06H) command must be issued before any Page Program (02H) command. A Page Program operation initiated within a suspended erase cannot itself be suspended and must be allowed to finish before the suspended erase can be resumed. The Status Register can be polled to determine the status of the Page Program operation. The Write Enable Latch (WEL) and Write in Progress (WIP) bits of the Status Register will remain “1” while the Page Program operation is in progress and will both clear to “0” when the Page Program operation completes. Figure-37. Suspend to Read/Program Latency tPSL / tESL CS# Suspend Command Read/Program Command tPSL: Program Suspend Latency tESL: Erase Suspend Latency 9.35 Program Resume and Erase Resume The Resume (7AH or 30H) command resumes a suspended Page Program, Page Erase, Sector Erase, Half Block Erase or Block Erase operation. Before issuing the Resume command to restart a suspended erase operation, make sure that there is no Page Program operation in progress. Immediately after the Serial NOR Flash receives the Resume command, the Write Enable Latch (WEL) and Write in Progress (WIP) bits are set to “1” and the SUS2 or SUS1 is cleared to “0”. The program or erase operation will continue until finished ("Resume to Read Latency") or until another Suspend (75H or B0H) command is received. A resume-to-suspend latency of tPRS or tERS must be observed before issuing another Suspend command ("Resume to Suspend Latency"). Figure-38. Program Resume and Erase Resume Sequence Diagram tSE / tBE / tPP CS# Read Command Resume Command 9.36 No Operation (NOP) The No Operation (00H) command is only able to terminate the Reset Enable (66H) command and will not affect any other command. The IO[3:1] are don't care. 42 NB25Q40A NB SPI NOR FLASH 9.37 Reset Enable (RSTEN) (66H) and Reset (RST) (99H) The Software Reset operation combines two commands: Reset Enable (66H) command and Reset (99H) command. It returns the device to standby mode. All the volatile bits and settings will be cleared which returns the device to the same default status as power on. The Reset command immediately following a Reset Enable command, initiates the Software Reset process. Any command other than Reset following the Reset Enable command, will clear the reset enable condition and prevent a later Reset command from being recognized. If the Reset command is executed during a program or erase operation, the operation will be disabled and the data under processing could be damaged or lost. Figure-39. Reset Enable and Reset Sequence Diagram 9.38 Read Unique ID (RUID) (4BH) The Read Unique ID (4BH) command accesses a factory-set read-only 128-bit number that is unique to each NB25Q40A device. The ID number can be used in conjunction with user software methods to help prevent copying or cloning of a system. The RUID command is initiated by driving the CS# pin low and shifting the command code “4BH” followed by four dummy bytes. Then, the 128-bit ID is shifted out on the falling edge of SCLK as shown in Figure-40. 43 NB25Q40A NB SPI NOR FLASH Figure-40. Read Unique ID Sequence Diagram 9.39 Read SFDP Mode (RDSFDP) (5AH) The Serial Flash Discoverable Parameter (SFDP) standard provides a consistent method of describing the functional and feature capabilities of serial flash devices in a standard set of internal parameter tables. These parameter tables can be queried by host system software to enable adjustments needed to accommodate divergent features from multiple vendors. The concept is similar to the one found in the Introduction of JEDEC Standard, JESD68 on CFI. SFDP is a JEDEC Standard, JESD216B. NB25Q40A features the Read SFDP Mode (5AH) command. The host system can retrieve the operating characteristics, structure and vendor specified information such as identifying information, memory size, operating voltage and timing information of this device by SFDP mode. The device is first selected by driving Chip Select (CS#) Low. The command code for the RDSFDP is followed by a 3-byte address (A23~A0) and a dummy byte, with each bit latched-in on the rising edge of Serial Clock (SCLK). Then the memory contents, at the specified address, is shifted out on Data Output (SO) at a maximum frequency fC on the falling edge of SCLK. The command sequence is shown in Figure-41. The first byte addressed can be at any location. The address is automatically incremented to the next higher address after each byte of data is shifted out. The entire SFDP table can, therefore, be read with a single RDSFDP command. When the highest address is reached, the address counter rolls over to 0x00h, allowing the read sequence to be continued indefinitely. The RDSFDP command is terminated by driving CS# High. CS# can be driven High at any time during data output. Any RDSFDP commands issued, while an Erase, Program or Write cycle is in progress, is rejected without having any effects on the cycle that is in progress. 44 NB25Q40A NB SPI NOR FLASH Figure-41. Read Serial Flash Discoverable Parameter Sequence Diagram Table-12. Serial Flash Discoverable Parameter (SFDP) Table Description SFDP Signature Comment Fixed: 50444653H Add (H) DW Add (Byte) (Bit) 00H Data Data 07:00 53H 53H 01H 15:08 46H 46H 02H 23:16 44H 44H 03H 31:24 50H 50H SFDP Minor Revision Number Start from 00H 04H 07:00 00H 00H SFDP Major Revision Number Start from 01H 05H 15:08 01H 01H Number of Parameters Headers Start from 00H 06H 23:16 01H 01H 07H 31:24 FFH FFH 08H 07:00 00H 00H Start from 0x00H 09H 15:08 00H 00H Start from 0x01H 0AH 23:16 01H 01H 0BH 31:24 09H 09H 0CH 07:00 30H 30H Unused ID number (JEDEC) Parameter Table Minor Revision Number Parameter Table Major Revision Number Contains 0xFFH and can never be changed 00H: It indicates a JEDEC specified header Parameter Table Length How many DWORDs (in double word) in the Parameter table First address of JEDEC 45 NB25Q40A NB SPI NOR FLASH Description Parameter Table Pointer (PTP) Unused ID Number (NB Device Manufacturer ID) Parameter Table Minor Revision Number Parameter Table Major Revision Number Comment (Byte) (Bit) 0DH Data 15:08 00H 00H 0EH 23:16 00H 00H 0FH 31:24 FFH FFH It is indicates NB manufacturer ID 10H 07:00 Start from 0x00H 11H 15:08 00H 00H Start from 0x01H 12H 23:16 01H 01H 13H 31:24 03H 03H 14H 07:00 60H 60H 15H 15:08 00H 00H 16H 23:16 00H 00H 17H 31:24 FFH FFH 01:00 01b 02 1b 03 0b Flash Parameter table Contains 0xFFH and can never be changed How many DWORDs in the (in double word) Parameter table Unused DW Add Data Parameter Table Length Parameter Table Pointer (PTP) Add (H) First address of NB Flash Parameter table Contains 0xFFH and can never be changed 00: Reserved; 01: 4KB erase; Block/Sector Erase Size 10: Reserved; 11: not support 4KB erase Write Granularity 0: 1Byte, 1: 64Byte or larger Write Enable Instruction 0: Nonvolatile status bit Requested for Writing to Volatile 1: Volatile status bit Status Registers (BP status register bit) 0: Use 50H Opcode, Write Enable Opcode Select for Writing to Volatile Status Registers 30H E5H 1: Use 06H Opcode, Note: If target flash status register is 04 0b 07:05 111b 15:08 20H 16 1b 18:17 00b Nonvolatile, then bits 3 and 4 must be set to 00b. Unused Contains 111b and can never be changed 4KB Erase Opcode 31H (1-1-2) Fast Read 0=Not support, 1=Support Address Bytes Number used in 00: 3 Byte only, 01: 3 or 4 Byte, addressing flash array 10: 4 Byte only, 11: Reserved Double Transfer Rate (DTR) clocking 0=Not support, 1=Support 19 0b (1-2-2) Fast Read 0=Not support, 1=Support 20 1b (1-4-4) Fast Read 0=Not support, 1=Support 21 1b 46 32H 20H F1H NB25Q40A NB SPI NOR FLASH Description (1-1-4) Fast Read Comment Add (H) DW Add (Byte) (Bit) 0=Not support, 1=Support Unused Unused 33H Data 22 1b 23 1b 31:24 FFH Data FFH 003FFFFFH/ Flash Memory Density 37H:34H 31:00 001FFFFFH/ 000FFFFFH/ 0007FFFFH/ (1-4-4) Fast Read Number of Wait 00000b: Wait states states (Dummy Clocks) not support (1-4-4) Fast Read Number of Mode Bits 39H (1-1-4) Fast Read Number of Wait 00000b: Wait states states (Dummy Clocks) not support Bits 3BH (1-1-2) Fast Read Number of Wait 00000b: Wait states states (Dummy Clocks) not support (1-1-2) Fast Read Number of Mode Bits 3DH (1-2-2) Fast Read Number of Wait 00000b: Wait states states (Dummy Clocks) not support (1-2-2) Fast Read Number of Mode Bits (2-2-2) Fast Read 3FH 0=not support 1=support Unused (4-4-4) Fast Read 0=not support 1=support 010b 15:08 EBH 20:16 01000b 40H Unused EBH 08H 23:21 000b 31:24 6BH 04:00 01000b 6BH 08H 07:05 000b 15:08 3BH 20:16 00000b 3EH 000b: Mode Bits not support (1-2-2) Fast Read Opcode 07:05 3CH 000b: Mode Bits not support (1-1-2) Fast Read Opcode 44H 3AH 000b:Mode Bits not support (1-1-4) Fast Read Opcode 00100b 38H 000b:Mode Bits not support (1-4-4) Fast Read Opcode (1-1-4) Fast Read Number of Mode 04:00 3BH 80H 23:21 100b 31:24 BBH 00 0b 03:01 111b 04 0b 07:05 111b BBH EEH Unused 43H:41H 31:08 FFH FFH Unused 45H:44H 15:00 FFH FFH 20:16 00000b (2-2-2) Fast Read Number of Wait 00000b: Wait states states (Dummy Clocks) not support (2-2-2) Fast Read Number of Mode Bits 46H 000b: Mode Bits not support 00H 23:21 000b (2-2-2) Fast Read Opcode 47H 31:24 FFH FFH Unused 49H:48H 15:00 FFH FFH 47 NB25Q40A NB SPI NOR FLASH Description Comment (4-4-4) Fast Read Number of Wait 00000b: Wait states states (Dummy Clocks) not support (4-4-4) Fast Read Number of Mode Bits Sector/block size=2^N bytes 0x00b: this sector type doesn’t exist Sector Type 1 erase Opcode Sector Type 2 Size Sector/block size=2^N bytes 0x00b: this sector type doesn’t exist Sector Type 2 erase Opcode Sector Type 3 Size Sector/block size=2^N bytes 0x00b: this sector type doesn’t exist Sector Type 3 erase Opcode Sector Type 4 Size DW Add (Byte) (Bit) 4AH Data Data 20:16 00000b 00H 23:21 000b 4BH 31:24 FFH FFH 4CH 07:00 0CH 0CH 4DH 15:08 20H 20H 4EH 23:16 0FH 0FH 4FH 31:24 52H 52H 50H 07:00 10H 10H 51H 15:08 D8H D8H 52H 23:16 08H 08H 53H 31:24 81H 81H 61H:60H 15:00 3600H 3600H 63H:62H 31:16 2300H 2300H 000b: Mode Bits not support (4-4-4) Fast Read Opcode Sector Type 1 Size Add (H) Sector/block size=2^N bytes 0x00b: this sector type doesn’t exist Sector Type 4 erase Opcode 2000H=2.000V Vcc Supply Maximum Voltage 2700H=2.700V 3600H=3.600V 1650H=1.650V Vcc Supply Minimum Voltage 2250H=2.250V 2350H=2.350V 2700H=2.700V HW Reset# pin 0=not support 1=support 00 0b HW Hold# pin 0=not support 1=support 01 1b Deep Power Down Mode 0=not support 1=support 02 1b SW Reset 0=not support 1=support 03 1b SW Reset Opcode Should be issue Reset Enable (66H) before Reset cmd. 65H:64H 11:04 1001 1001b (99H) F99EH Program Suspend/Resume 0=not support 1=support 12 1b Erase Suspend/Resume 0=not support 1=support 13 1b 14 1b 15 1b 66H 23:16 77H 77H 67H 31:24 64H 64H Unused Wrap-Around Read mode 0=not support 1=support Wrap-Around Read mode Opcode 08H:support 8B Wrap-Around read Wrap-Around Read data length 16H:8B&16B 32H:8B&16B&32B 64H:8B&16B&32B&64B 48 NB25Q40A NB SPI NOR FLASH Description Individual block lock Individual block lock bit (Volatile/Nonvolatile) Comment 0=not support Add (H) DW Add (Byte) (Bit) 1=support 0=Volatile 1=Nonvolatile Individual block lock Opcode Individual block lock Volatile protect bit default protect status 0=protect 1=unprotect 6BH:68H Data 00 0b 01 0b 09:02 FFH 10 0b Secured OTP 0=not support 1=support 11 1b Read Lock 0=not support 1=support 12 0b Permanent Lock 0=not support 1=support 13 0b Unused 15:14 11b Unused 31:16 FFFFH Data CBFCH FFFFH 9.40 Continuous Read Mode Reset (CRMR) (FFH) The “Continuous Read Mode” bits are used in conjunction with Dual I/O Fast Read (BBH) and Quad I/O Fast Read (EBH) commands to provide the highest random Flash memory access rate with minimum SPI command overhead, thus allowing more efficient XIP (execute in place) with this device family. A device that is in a continuous high performance read mode may not recognize any normal SPI command or the Software Reset (66H, 99H) command. It is recommended to use the Continuous Read Mode Reset (FFH) command after a system Power on Reset or, before sending a Software Reset, to ensure the device is released from “Continuous Read Mode”. The “Continuous Read Mode” bits M7-0 are set by the Dual/Quad I/O Fast Read (BBh or EBh) commands. M5-4 are used to control whether the 8-bit SPI command code (BBh or EBh) is needed or not for the next command. When M5-4 = (1,0), the next command will be treated the same as the current Dual/Quad I/O Fast Read command without requiring the 8-bit command code; when M5-4 do not equal (1,0), the device returns to normal SPI command mode, in which all commands can be accepted. M7-6 and M3-0 are reserved bits for future use, either 0 or 1 values can be used. Because the NB25Q40A has no hardware reset pin, if Continuous Read Mode bits are set to (1,0), the NB25Q40A will not recognize any standard SPI commands. The Continuous Read Mode Reset (FFH) will release the “Continuous Read Mode” and return to normal SPI operation. The command sequence is shown in Figure-42. 49 NB25Q40A NB SPI NOR FLASH Figure-42. Continuous Read Mode Reset Sequence Diagram 10. ELECTRICAL SPECIFICATIONS 10.1 POWER-ON TIMING Figure-43. Power-On Timing Sequence Diagram Table-13 Power-Up Timing and Write Inhibit Threshold Sym. Parameter Min. tVSL VWI VPWD tPWD VCC(min.) to device operation Write Inhibit Voltage VCC voltage needed to below VPWD for ensuring initializtion will occur The minimum duration for ensuring initialization will occur 0.3 1 10.2 300 Max. 1.55 0.5 Unit ms V V us INITIAL DELIVERY STATE The device is delivered with the memory array erased: all bits are set to 1(each byte contains FFH).The Status Register contains 00H (all Status Register bits are 0). 50 NB25Q40A NB SPI NOR FLASH 10.3 ABSOLUTE MAXIMUM RATINGS Table-14 Absolute Maximum Ratings Parameter Value Ambient Operating Temperature Storage Temperature Applied Input / Output Voltage Transient Input / Output Voltage(note: overshoot) VCC Unit -40 to 85 -65 to 150 -0.6 to VCC+0.4 -2.0 to VCC+2.0 -0.6 to 4.2 °C °C V V V Figure-44. Maximum Negative/positive Overshoot Diagram Maximum Negative Overshoot Waveform Maximum Positive Overshoot Waveform 20ns Vcc + 2.0V Vss - 2.0V Vcc 20ns 10.4 20ns 20ns Vss 20ns 20ns AC MEASUREMENT CONDITIONS Table-15. AC Measurement Conditions Sym. CIN COUT CL 10.5 Parameter Min. Input Capacitance Output Capacitance Load Capacitance Input Input Pulse Voltage Input Timing Reference Voltage Output Timing Reference Voltage Typ. Max Unit 6 8 pF pF pF ns V V 30 5 0.1VCC to 0.8VCC 0.2VCC to 0.7VCC 0.5VCC Conditions VIN = 0V VOUT = 0V DC CHARACTERISTICS Table-16. DC Parameters Sym. Parameter IDPD Deep power down current ISB Standby current ICC1 Low power read current (03h) ICC2 Read current (0Bh) ICC3 Conditions CS#=VCC, 2.3V to 3.6V Min. Typ. Max. Unit 0.2 2 uA 0.2 1 uA f=1MHz; IOUT=0mA 2.0 3.0 mA f=33MHz; IOUT=0mA 3.5 5.0 mA f=66MHz; IOUT=0mA 4.5 7.0 mA f=85MHz; IOUT=0mA 5.0 7.5 mA Program current CS#=Vcc 4.5 7.0 mA ICC4 Erase current CS#=Vcc 4.5 7.0 mA ILI Input load current 1.0 uA VIN=VCC or VSS CS#=VCC, VIN=VCC or VSS All inputs at CMOS level 51 NB25Q40A NB SPI NOR FLASH All inputs at CMOS level ILO Output leakage VIL Input low voltage VIH Input high voltage VOL Output low voltage IOL=100uA VOH Output high voltage IOH=-100uA 1.0 uA 0.3Vcc V V 0.7Vcc 0.2 V V Vcc-0.2 Note: Typical values measured at 3.0V @ 25°C for the 2.3V to 3.6V range. 10.6 AC CHARACTERISTICS Table-17. AC Parameters Symbol Alt. Parameter 2.3V~3.6V Min. Typ. Max. Unit Clock Frequency for the following commands: fSCLK fC 83 MHz Clock Frequency for READ command 40 MHz Clock Frequency for DREAD command 66 MHz Clock Frequency for 2READ command 50 MHz Clock Frequency for QREAD command X MHz Clock Frequency for 4READ command X MHz Clock Frequency for QPP (Quad page program) X MHz FAST_READ, RDSFDP, PP,SE, BE32K, BE, CE, DP,RES, WREN, WRDI, RDID, RDSR, WRSR(7) fRSCLK fR fT fTSCLK fQ fQPP tCH(1) tCLH Clock High Time 6 ns tCL(1) tCLL Clock Low Time (fSCLK) 45% x (1fSCLK) 6 ns tCLCH(7) Clock Rise Time (peak to peak) 0.1 v/ns tCHCL(7) Clock Fall Time (peak to peak) 0.1 v/ns CS# Active Setup Time (relative to SCLK) 5 ns CS# Not Active Hold Time (relative to SCLK) 5 ns tSLCH tCSS tCHSL tDVCH tDSU Data In Setup Time 2 ns tCHDX tDH Data In Hold Time 3 ns tCHSH CS# Active Hold Time (relative to SCLK) 5 ns tSHCH CS# Not Active Setup Time (relative to SCLK) 5 ns CS# Deselect Time From Read to next Read 15 ns 30 ns 40 ns CS# Deselect Time From Write, Erase, Program to tSHSL tCSH Read Status Register Volatile Status Register Write Time tSHQZ(7) tDIS tCLQV tV Output Disable Time 12 ns Clock Low to Output Valid Loading 30pF 12 ns 52 NB25Q40A NB SPI NOR FLASH Clock Low to Output Valid Loading 15pF tCLQX tHO 12 ns Output Hold Time 0 ns tHLCH HOLD# Active Setup Time (relative to SCLK) 5 ns tCHHH HOLD# Active Hold Time (relative to SCLK) 5 ns tHHCH HOLD# Not Active Setup Time (relative to SCLK) 5 ns tCHHL HOLD# Not Active Hold Time (relative to SCLK) 5 ns tHHQX tLZ HOLD# to Output Low-Z 6 ns tHLQZ tHZ HOLD# to Output High-Z 6 ns tWHSL(3) Write Protect Setup Time 20 ns tSHWL(3) Write Protect Hold Time 100 ns tDP CS# High to Deep Power-Down Mode tRES1 tRES2 tW us 8 us 8 us 12 ms CS# High To Standby Mode Without Electronic Signature Read CS# High To Standby Mode With Electronic Signature Read Write Status Register Cycle Time 9 Reset recovery time (for erase/program operation tReady 3 30 except WRSR) Reset recovery time (for WRSR operation) us 12 8 ms Table-18. AC Parameters for Program and Erase Sym. TESL TPSL 2.3V to 3.6V Parameter Min. Typ. Max. Unit (6) Erase Suspend Latency 30 us (6) Program Suspend Latency 30 us TPRS (4) TERS (5) Latency between Program Resume and next Suspend 0.3 us Latency between Erase Resume and next Suspend 0.3 us tPP Page program time (up to 256 bytes) tPE 1.6 2.5 ms Page erase time 8 12 ms tSE Sector erase time 8 12 ms tBE1 Block erase time for 32K bytes 8 12 ms tBE2 Block erase time for 64K bytes 8 12 ms tCE Chip erase time 8 12 ms Notes: 1. tCH + tCLmust be greater than or equal to 1/Frequency. 2. Typical values given for TA=25°C. Not 100% tested. 3. Only applicable as a constraint for a WRSR command. 4. Program operation may be interrupted as often as system request. The minimum timing of tPRS must 53 NB25Q40A NB SPI NOR FLASH be observed before issuing the next program suspend command. However, for a Program operation to make progress, tPRS ≥ 100us must be included in resume-to-suspend loop(s). Not 100% tested. 5. Erase operation may be interrupted as often as system request. The minimum timing of tERS must be observed before issuing the next erase suspend command. However, in order for an Erase operation to make progress, tERS ≥ 200us must be included in resume-to-suspend loop(s). Notes. Not 100% tested. 6. Latency time is required to complete Erase/Program Suspend operation. 7. The value guaranteed by characterization, not 100% tested inproduction. Figure-45. Serial Input Timing Figure-46. Output Timing Figure-47. Hold Timing 54 NB25Q40A NB SPI NOR FLASH Figure-48. WP Timing 55 NB25Q40A NB SPI NOR FLASH 11. ORDERING INFORMATION NB 25X XX X X XX X Packaging Type T:Tube R:Tape & Reel Y:Tray Green Code G: Low-halogen, Lead(Pb)-free P: Lead (Pb) - free Temperature Range E: Extended (-25℃~85℃) I: Industrial(-40℃~85℃) Package Type T: 150mil SOP8 O:173mil TSSOP8 U:USON8(3*2mm, 0.45mm) K:USON6(1.2*1.2mm,0.40mm) Version A: A Version B: B Version C: C Version Device Density 40: 4Mbit Base Part Number 25Q:2.3V-3.6V Dual SPI Nor Flash Manufacturer 56 NB25Q40A NB SPI NOR FLASH 12. PACKAGE INFORMATION 12.1 Package SOP8 150MIL D 5 8 E E1 h L 1 4 “A” L1 Ɵ b Base Metal A2 A e c A1 b Detail “A” Dimensions Symbol A A1 A2 b c D E E1 Min 1.35 0.05 1.35 0.38 0.17 4.80 5.80 3.80 Nom 1.55 0.10 1.40 - - 4.90 6.00 3.90 Max 1.65 0.15 1.50 0.51 0.25 5.00 6.20 4.00 Unit mm Note: 1. Both the package length and width do not include the mold FLASH. 2. Seating plane: Max. 0.25mm. 57 e L L1 0.50 1.27 0.60 0.80 1.04 h θ 0.30 0° 0.40 - 0.50 8° NB25Q40A NB SPI NOR FLASH 12.2 Package TSSOP8 D 8 5 E1 E h L “A” 1 L1 Ɵ 4 b Base Metal A2 A e c A1 b Detail “A” Dimensions Symbol Unit A Min mm A1 A2 b c D E E1 0.05 0.8 0.19 0.09 2.90 6.20 4.30 1.00 - - 3.00 6.40 4.40 1.05 0.30 0.20 3.10 6.60 4.50 Nom Max 1.2 0.15 Note: 1. Both the package length and width do not include the mold FLASH. 2. Seating plane: Max. 0.25mm. 58 e L L1 0.45 0.65 0.60 0.75 h θ 0° 1.00 8° NB25Q40A NB SPI NOR FLASH 12.3 Package USON8/DFN8 (3x2x0.55mm) D b e L D2 h E2 E h 1 2 Nd EXPOSED THERMAL TOP VIEW PAD ZONE BOTTOM VIEW A c A1 SIDE VIEW Dimensions Symbol Unit mm A A1 b c D D2 Min 0.5 0 0.2 0.1 1.9 1.5 Nom 0.55 0.02 0.25 0.15 2 1.6 Max 0.6 0.05 0.3 0.2 2.1 1.7 59 e 0.50BSC Nd 1.50BSC E E2 L L1 h 2.9 0.1 0.3 0.05 0.05 3 0.2 0.35 0.1 0.15 3.1 0.3 0.4 0.15 0.25 NB25Q40A NB SPI NOR FLASH 13. REVISION HISTORY Version No Description Date 1.0 Initial Release 2021-10-22 1.1 Add Package information 2022-08-18 60
NB25Q40ATIGT 价格&库存
很抱歉,暂时无法提供与“NB25Q40ATIGT”相匹配的价格&库存,您可以联系我们找货
