1.5SMC75CA
1.5SMC75CA
    SEMICON
    SMC(DO-214AB)
    TVS二极管 VRWM=64.1V Ppp=1.5KW Ipp=14.8A VBR(Min)=71.3V VC=103V 双向 DO214AB
1.5SMC75CA 数据手册
SEMICON CHAMPION Surface Mount 1500W_1.5SMC Series Quality | Customer Focus Features - 1500W peak pulse power capability at 10/1000μs waveform, repetition rate (duty cycles):0.01% - Excellent clamping capability - Typical failure mode is a short circuit condition for current events exceeding component rating - Plastic package is flammability rated V-0 per UL-94 - Meet MSL level1, per J-STD-020, lead-frame maximum peak of 260°C Applications TVS devices are ideal for the transient voltage clamp protection of I/O Interfaces, DC power line bus and other circuits used in Telecom, Computer, Industrial and Consumer electronic applications. Function Diagram Maximum Ratings and Thermal Characteristics (TA=25OC unless otherwise noted) Parameter Peak Pulse Power Dissipation at TA=25ºC by 10/1000µs Waveform Symbol Value Unit PPPM 1500 W PD 6.5 W IFSM 200 A AGENCY AGENCY FILE NUMBER Pending (Fig.3) Power Dissipation on Infinite Heat O Sink at T L=50 C Peak Forward Surge Current, 8.3ms Single Half Sine Wave (Note 1) Maximum Instantaneous Forward Voltage at 50A for Unidirectional Only(Note 2) Operating Temperature Range Storage Temperature Range 1. Measured on 8.3ms single half sine wave or 3.5/5 V TJ -55 to 150 °C TSTG -55 to 150 °C VF Notes: equivalent square wave for unidirectional device only, duty cycle=4 per minute maximum. 2. VF < 3.5V for single die parts and V F< 5V for stacked-die parts. Jiangsu Semicon Champion Microelectronics Co., Ltd. 1/9 SEMICON CHAMPION Surface Mount 1500W_1.5SMC Series Quality | Customer Focus Characteristics (T =25°C unless otherwise noted) Part Number Part Number (Uni) (Bi) 1.5SMC6.8A 1.5SMC6.8CA 1.5SMC7.5A 1.5SMC7.5CA 1.5SMC8.2A 1.5SMC8.2CA 1.5SMC9.1A 1.5SMC9.1CA 1.5SMC10A 1.5SMC10CA 1.5SMC11A Key Marking UNI 06E BI Reverse Breakdown Voltage Test Stand off VBR (Volts) @ IT Current IT Voltage VR (Volts) MIN MAX (mA) Maximum Clamping Maximum Peak Voltage VC @ Ipp Pulse Current Ipp (A) (V) Maximum Agency Reverse Approval Leakage IR @ VR (µA) 06E 5.80 6.45 7.14 10 10.5 144.8 1000 07F 07F 6.40 7.13 7.88 10 11.3 134.5 500 08T 08T 7.02 7.79 8.61 10 12.1 125.6 200 09O 09O 7.78 8.65 9.50 1 13.4 113.4 50 010 010 8.55 9.50 10.50 1 14.5 104.8 10 1.5SMC11CA 011 011 9.40 10.50 11.60 1 15.6 97.4 5 1.5SMC12A 1.5SMC12CA 012 012 10.2 11.4 12.60 1 16.7 91.0 5 1.5SMC13A 1.5SMC13CA 013 013 11.1 12.4 13.70 1 18.2 83.5 1 1.5SMC15A 1.5SMC15CA 015 015 12.8 14.3 15.80 1 21.2 71.7 1 1.5SMC16A 1.5SMC16CA 016 016 13.6 15.2 16.80 1 22.5 67.6 1 1.5SMC18A 1.5SMC18CA 018 018 15.3 17.1 18.90 1 25.2 60.3 1 1.5SMC20A 1.5SMC20CA 020 020 17.1 19.00 21.00 1 27.7 54.9 1 1.5SMC22A 1.5SMC22CA 022 022 18.8 20.9 23.10 1 30.6 49.7 1 1.5SMC24A 1.5SMC24CA 024 024 20.5 22.8 25.20 1 33.2 45.8 1 1.5SMC27A 1.5SMC27CA 027 027 23.1 25.7 28.40 1 37.5 40.5 1 1.5SMC30A 1.5SMC30CA 030 030 25.6 28.5 31.50 1 41.4 36.7 1 1.5SMC33A 1.5SMC33CA 033 033 28.2 31.4 34.70 1 45.7 33.3 1 1.5SMC36A 1.5SMC36CA 036 036 30.8 34.2 37.80 1 49.9 30.5 1 1.5SMC39A 1.5SMC39CA 039 039 33.3 37.1 41.00 1 53.9 28.2 1 1.5SMC43A 1.5SMC43CA 043 043 36.8 40.9 45.20 1 59.3 25.6 1 1.5SMC47A 1.5SMC47CA 047 047 40.2 44.7 49.40 1 64.8 23.5 1 1.5SMC51A 1.5SMC51CA 051 051 43.6 48.5 53.60 1 70.1 21.7 1 1.5SMC56A 1.5SMC56CA 056 056 47.8 53.2 58.80 1 77.0 19.7 1 1.5SMC62A 1.5SMC62CA 062 062 53.0 58.9 65.10 1 85.0 17.9 1 1.5SMC68A 1.5SMC68CA 068 068 58.1 64.6 71.40 1 92.0 16.5 1 1.5SMC75A 1.5SMC75CA 075 075 64.1 71.3 78.80 1 103.0 14.8 1 1.5SMC82A 1.5SMC82CA 082 082 70.1 77.9 86.10 1 113.0 13.5 1 1.5SMC91A 1.5SMC91CA 091 091 77.8 86.5 95.50 1 125.0 12.2 1 1.5SMC100A 1.5SMC100CA 100 100 85.5 95.0 105.0 1 137.0 11.1 1 1.5SMC110A 1.5SMC110CA 110 110 94.0 105.0 116.0 1 152.0 10.0 1 1.5SMC120A 1.5SMC120CA 120 120 102.0 114.0 126.0 1 165.0 9.2 1 1.5SMC130A 1.5SMC130CA 130 130 111.0 124.0 137.0 1 179.0 8.5 1 1.5SMC150A 1.5SMC150CA 150 150 128.0 143.0 158.0 1 207.0 7.3 1 1.5SMC160A 1.5SMC160CA 160 160 136.0 152.0 168.0 1 219.0 6.9 1 1.5SMC170A 1.5SMC170CA 170 170 145.0 162.0 179.0 1 234.0 6.5 1 1.5SMC180A 1.5SMC180CA 180 180 154.0 171.0 189.0 1 246.0 6.2 1 1.5SMC200A 1.5SMC200CA 200 200 171.0 190.0 210.0 1 274.0 5.5 1 1.5SMC220A 1.5SMC220CA 220 220 185.0 209.0 231.0 1 328.0 4.6 1 1.5SMC250A 1.5SMC250CA 250 250 214.0 237.0 263.0 1 344.0 4.4 1 1.5SMC300A 1.5SMC300CA 300 300 256.0 285.0 315.0 1 414.0 3.7 1 1.5SMC350A 1.5SMC350CA 350 350 299.3 332.5 367.5 1 482.0 3.1 1 1.5SMC380A 1.5SMC380CA 380 380 324.9 361.0 399.0 1 524.4 2.9 1 Jiangsu Semicon Champion Microelectronics Co., Ltd. 2/9 SEMICON CHAMPION Surface Mount 1500W_1.5SMC Series Quality | Customer Focus Part Number Part Number (Uni) (Bi) Key Marking UNI BI Breakdown Reverse Voltage VBR Stand off Voltage VR (Volts) (Volts) @ IT MIN MAX Test Current IT (mA) Maximum Clamping Maximum Peak Voltage VC @ Ipp Pulse Current Ipp (A) (V) Maximum Agency Reverse Approval Leakage IR @ VR (µA) 1.5SMC400A 1.5SMC400CA 400 400 342.0 380.0 420.0 1 548.0 2.7 1 1.5SMC440A 1.5SMC440CA 440 440 376.2 418.0 462.0 1 602.0 2.5 1 1.5SMC500A 1.5SMC500CA 500 500 427.5 475.0 525.0 1 690.0 2.2 1 1.5SMC520A 1.5SMC520CA 520 520 444.6 494.0 546.0 1 717.6 2.1 1 1.5SMC540A 1.5SMC540CA 540 540 460.0 513.0 567.0 1 740.0 2.0 1 1.5SMC550A 1.5SMC550CA 550 550 470.3 522.5 577.5 1 759.0 2.0 1 630.0 1 828.0 1.8 1 1.5SMC600A 1.5SMC600CA 600 600 513.0 570.0 Jiangsu Semicon Champion Microelectronics Co., Ltd. 3/9 SEMICON CHAMPION Surface Mount 1500W_1.5SMC Series Quality | Customer Focus I-V Curve Characteristics PPPM Peak Pulse Power Dissipation -- Max power dissipation VR Stand-off Voltage -- Maximum voltage that can be applied to the TVS without operation VBR Breakdown Voltage -- Maximum voltage that flows though the TVS at a specified test current (IT) VC Clamping Voltage -- Peak voltage measured across the TVS at a specified IPPM (peak impulse current) IR Reverse Leakage Current -- Current measured at VR VF Forward Voltage Drop for Uni-directional Jiangsu Semicon Champion Microelectronics Co., Ltd. 4/9 SEMICON CHAMPION Surface Mount 1500W_1.5SMC Series Quality | Customer Focus Ratings and Characteristic Curves (T =25°C unless otherwise noted) Figure 1. Peak pulse power derating curve Figure2. Pulse waveform Figure 3. Peak pulse power rating curve Figure 4. Maximum non-repetitive surge current Jiangsu Semicon Champion Microelectronics Co., Ltd. 5/9 SEMICON CHAMPION Surface Mount 1500W_1.5SMC Series Quality | Customer Focus Soldering Parameters Reflow Condition Pre Heat Soldering profile Lead–free assembly - Temperature Min (Ts(min)) 150°C - Temperature Max (Ts(max)) 200°C - Time (min to max) (ts) 60 – 180 secs Average ramp up rate (Liquidus Temp (TA) to peak 3°C/second max TS(max) to TA - Ramp-up Rate 3°C/second max Reflow - Temperature (TA) (Liquidus) 217°C - Time (min to max) (ts) 60 – 150 seconds Peak Temperature (TP) 260+0/-5 °C Time within 5°C of actual peak Temperature (tp) 20 – 40 seconds Ramp-down Rate 6°C/second max Time 25°C to peak Temperature (TP) 8 minutes Max. Do not exceed 260°C Jiangsu Semicon Champion Microelectronics Co., Ltd. 6/9 SEMICON CHAMPION Surface Mount 1500W_1.5SMC Series Quality | Customer Focus Dimensions Jiangsu Semicon Champion Microelectronics Co., Ltd. 7/9 SEMICON CHAMPION Surface Mount 1500W_1.5SMC Series Quality | Customer Focus Part Numbering Part Marking Product Type Marking Code 1.5SMC xx xx A: Uni-directional CA: Bi-directional xxx Reverse Standard off Voltage VR Product series Cathode band (for uni-directional products only) Packing Part number Package name Small packing quantity Packing method 1.5SMCXXXX DO-214AB 3000 Tape & Reel Jiangsu Semicon Champion Microelectronics Co., Ltd. 8/9 SEMICON CHAMPION Surface Mount 1500W_1.5SMC Series Quality | Customer Focus Tape and Reel Specification Symbol Millimeter A 16.00±0.10 B 4.00±0.10 C 8.00±0.10 D 1.55±0.05 E 330.20±2.00 F 19.70±2.00 G 13.30±0.30 Revision history of Specification Version Change Items Effective Date 1.0 Initial Release 13-Aug-2021 Jiangsu Semicon Champion Microelectronics Co., Ltd. 9/9
1.5SMC75CA 价格&库存
很抱歉,暂时无法提供与“1.5SMC75CA”相匹配的价格&库存,您可以联系我们找货
