SCT2360FPBR
SCT2360FPBR
    SCT(芯洲科技)
    QFN-12(3x3)
    4V-28V Vin,6A同步降压DCDC转换器 QFN12
SCT2360FPBR 数据手册
芯 洲 科 SCT2360 技 Silicon Content Technology Rev. 1.0 4V-28V Vin, 6A Synchronous Step-down DCDC Converter FEATURES DESCRIPTION     The SCT2360 is a high efficiency synchronous stepdown 6A DC-DC converter with 4V-28V input voltage range and adjustable output voltage down to 0.6V. The device fully integrates high-side and low-side power MOSFETs with 36mΩ/16mΩ on-resistance to minimize the conduction loss.        Wide 4V-28V Input Voltage Range 0.6V-14V Output Voltage Range 6A Continuous Output Current Integrated 36mΩ/16mΩ Rdson of HS/LS Power MOSFETs Fixed 1ms Soft-start Time Selectable 400KHz, 800KHz, 1.2MHz Switching Frequencies Selectable PWM, PFM and USM Operation Modes Cycle-by-Cycle Current Limiting Output Over-Voltage Protection Over-Temperature Protection Available in a QFN 12-leads 3mmx3mm Package APPLICATIONS     Auto DTV, Monitor/LCD Display Printer, Charging Station Industry PC The SCT2360 adopts a Constant On-Time (COT) control to provide fast transient response and easy loop stabilization. The switching clock frequency can be selected from 400KHz, 800KHz and 1.2MHz for optimization of the filter size and output voltage ripple. The device offers fixed 1ms soft start to prevent inrush current during the startup of output voltage ramping. Power Good with open drain output signals that the output voltage is within regulation. The SCT2360 has the MODE pin to select Pulse Frequency Modulation (PFM) operation mode to achieve the light load power save, or Ultrasonic Mode (USM) to keep the switching frequency above audible frequency areas during light-load or no-load conditions, or the PWM mode to achieve the small output ripple. Full protection includes over current protection, undervoltage protection, and thermal shutdown. The converter requires a minimum number of external components and is available in a QFN- 12 (3mmx3mm) package. TYPICAL APPLICATION 100.0 VIN C3 C1 ON/OFF PG R3 90.0 BST EN MODE FSEL PG L1 80.0 VOUT SW C4 Efficiency (%) VIN R1 VOUT FB VCC C2 R2 AGND PGND 70.0 60.0 50.0 40.0 30.0 PFM 20.0 FCCM 10.0 USM 0.0 0.001 0.01 0.1 1 10 Iout (A) 4V-28V, Synchronous Buck Converter VIN=12V, Vout=5V, fsw = 400kHz For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2360 1 SCT2360 REVISION HISTORY NOTE: Page numbers for previous revisions may differ from page numbers in the current version. Revision 1.0: Production DEVICE ORDER INFORMATION PART NUMBER PACKAGE MARKING PACKAGE DISCRIPTION SCT2360FPB 2360 12-Lead 3mm×3mm Plastic QFN 1) For Tape & Reel, Add Suffix R (e.g. SCT2360FPBR) ABSOLUTE MAXIMUM RATINGS Over operating free-air temperature unless otherwise PIN CONFIGURATION noted(1) DESCRIPTION MIN MAX UNIT VIN, EN -0.3 32 V SW -1 32 V BST -0.3 38 V BST-SW -0.3 6 V VOUT -0.3 16 V PG, FSEL, MODE,VCC, FB -0.3 6 V Operating junction temperature(2) -40 125 C Storage temperature TSTG -65 150 C EN FB AGND VCC 12 11 VIN (2) 9 1 8 7 BST SW 2 PGND 3 (1) 10 PG 4 FSEL 5 6 VOUT MODE Top View: QFN-12L 3mm x 3mm, Plastic Stresses beyond those listed under Absolute Maximum Rating may cause device permanent damage. The device is not guaranteed to function outside of its Recommended Operation Conditions. The IC includes over temperature protection to protect the device during overload conditions. Junction temperature will exceed 150°C when over temperature protection is active. Continuous operation above the specified maximum operating junction temperature will reduce lifetime. PIN FUNCTIONS NAME NO. PIN FUNCTION VIN 1 Input voltage. Decouple the input rail with at least 0.1uF input ceramic capacitor. Place the capacitor as close to VIN and PGND pins as possible. Use wide PCB traces and multiple vias to make the connection. PGND 2 PG 3 FSEL 4 VOUT 5 2 Power ground. Using wide PCB traces and multiple vias large enough to handle the load current. Power good open-drain output. PG is high if the output voltage is higher than 95% and lower than 105% of the nominal voltage. Switching frequency selection. Connecting to ground sets clock frequency to 400KHz. Floating sets clock frequency to 800KHz. Connecting to VCC sets clock frequency to 1.2MHz. VOUT is used to sense the output voltage of the buck regulator. Connect VOUT to the output capacitor of the regulator directly. Keep the VOUT sensing trace far away from the SW node. VIAs should also be avoided on the VOUT sensing trace. A trace larger than 25mil is required. For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2360 SCT2360 PFM, USM or FCCM mode selection. Connect the pin to VCC to force the device in Forced Continuous Current Modulation (FCCM) operation mode. Ground the pin to operate the device in Pulse Frequency Modulation (PFM) mode without Ultrasonic Mode (USM). Floating the pin to operate the device in PFM with USM. Switch output. SW is driven up to VIN through the high-side power MOSFET during ontime. The inductor current drives SW to negative voltage through low-side power MOSFET during off-time. Use wide and short PCB traces to make the connection. Keep the SW pattern area minimized. Bootstrap. Must connect a 0.1uF capacitor or greater between SW and BST to form a floating supply across the gate driver of high-side power MOSFET. MODE 6 SW 7 BST 8 VCC 9 Internal VCC LDO output. Decouple with 1µF ceramic capacitor placed as close to VCC as possible. AGND 10 Signal logic ground. AGND is the Kelvin connection to PGND. FB 11 EN 12 Feedback voltage Input. Connect FB to the tap of a resistor divider from output voltage to AGND to set up output voltage. The device regulates FB to the internal reference value of 0.6V typical. Enable logic input. EN is a digital input that controls the converter on or off. EN high turns on the device and EN low turns off the device. Connecting to VIN with a 100kΩ pull-up resistor can enable the device. Floating EN pin automatically starts up the converter. RECOMMENDED OPERATING CONDITIONS Over operating free-air temperature range unless otherwise noted PARAMETER DEFINITION VIN TJ Input voltage range Operating junction temperature MIN MAX UNIT 4 -40 28 125 V °C MIN MAX UNIT -2 +2 kV -0.5 +0.5 kV ESD RATINGS PARAMETER VESD DEFINITION Human Body Model(HBM), per ANSI-JEDEC-JS-0012014 specification, all pins(1) Charged Device Model(CDM), per ANSI-JEDEC-JS-0022014specification, all pins(1) (1) JEDEC document JEP155 states that 500V HBM allows safe manufacturing with a standard ESD control process. (2) JEDEC document JEP157 states that 250V CDM allows safe manufacturing with a standard ESD control process. THERMAL INFORMATION PARAMETER THERMAL METRIC QFN-12L RθJA Junction to ambient thermal resistance(1) 50 RθJC Junction to case thermal resistance(1) 12 UNIT °C/W (1) SCT provides RθJA and RθJC numbers only as reference to estimate junction temperatures of the devices. RθJA and RθJC are not a characteristic of package itself, but of many other system level characteristics such as the design and layout of the printed circuit board (PCB) on which the SCT2360 is mounted. The PCB board is a heat sink that is soldered to the leads and thermal pad of the SCT2360. Changing the design or configuration of the PCB board changes the efficiency of the heat sink and therefore the actual RθJA and RθJC. For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2360 3 SCT2360 ELECTRICAL CHARACTERISTICS VIN=12V, TJ=-40°C~125°C, typical value is tested under 25°C. SYMBOL PARAMETER TEST CONDITION Power Supply and Output VIN Operating input voltage MIN TYP 4 28 V 5 V mV uA ISD IQ Quiescent current VCC VCC internal LDO regulator voltage EN=0, No load, VIN=12V EN=floating, No load, No switching. VIN=12V. BSTSW=5V IVCC=0mA VCC_LR VCC internal LDO load regulation IVCC=5mA 1 % IVCC_LIM VCC internal LDO current limit VCC short to ground 30 mA Buck Reference VREF Reference voltage of FB TJ=25OC IFB VFB=1.2V FB pin leakage current 3.8 300 1 UNIT Input UVLO Hysteresis Shutdown current VIN_UVLO VIN rising MAX 130 4.75 0.594 5 0.6 uA 5.25 V 0.606 V 100 nA Power MOSFETs RDSON_H High side FET on-resistance VCC=5V 36 mΩ RDSON_L VCC=5V 16 mΩ Low side FET on-resistance Enable VEN_H Enable high threshold 1.2 V VEN_L Enable low threshold 1.09 V IEN Enable pin input current 1.4 uA IEN_HYS Enable pin hysteresis current 3.6 uA Operation Mode VMD_PWM PWM mode input logic high threshold VMD_USM PFM mode with USM logic threshold VMD_PFM PFM mode input logic low threshold VCC=5V 4.2 V 1.5 3.5 V 0.9 V Switching Frequency FSEL=0V 400 kHz FSEL=open 800 kHz FSEL=5V FSW Switching frequency 1200 kHz TON_TIME Minimum On-time 100 ns TOFF_TIME Minimum Off-time 200 ns Internal soft-start time 1 ms PGRising(in) VFB rising, percentage of VREF (Good) 95 % PGFalling(in) VFB falling, percentage of VREF 85 % PGRising(out) VFB rising, percentage of VREF 115 % PGFallng(out) VFB falling, percentage of VREF (Good) 105 % PGTD PG low to high delay 0.5 ms VPG Power Good PG pull-down strength 0.4 V Soft Start Time tSS Power Good 4 For more information www.silicontent.com IPG =4mA © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2360 SCT2360 SYMBOL PARAMETER TEST CONDITION MIN TYP MAX IPG_LEAK Power Good PG leakage current VPG=5V Output OVP threshold Hysteresis OCP hiccup wait time VOUT rising 120 5 7 % % Cycles Output UVP threshold VOUT falling 75 % ILIM_P LS MOSFET positive current limit 7.5 A ILIM_N LS MOSFET negative current limit From source to drain From drain to source, MODE connects to VCC 2.5 A RDischarge SW to ground resistance 100 Ω TSD Thermal shutdown threshold Hysteresis 160 25 °C 5 UNIT uA Protection VOVP THIC_W VUVP TJ rising For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2360 5 SCT2360 100.0 100.0 90.0 90.0 80.0 80.0 70.0 70.0 Efficiency (%) Efficiency (%) TYPICAL CHARACTERISTICS 60.0 50.0 40.0 PFM FCCM USM 30.0 20.0 10.0 60.0 50.0 40.0 30.0 PFM 20.0 FCCM 10.0 USM 0.0 0.0 0.001 0.01 0.1 1 0.001 10 0.01 1 10 Figure 2. Efficiency, Vin=12V, Vout=5V, Fsw=800kHz Figure 1. Efficiency, Vin=12V, Vout=5V, Fsw=400kHz 100.0 100.0 90.0 90.0 80.0 80.0 70.0 70.0 Efficiency (%) Efficiency (%) 0.1 Iout (A) Iout (A) 60.0 50.0 40.0 60.0 50.0 40.0 30.0 PFM 30.0 PFM 20.0 FCCM 20.0 USM FCCM 10.0 10.0 USM 0.0 0.0 0.001 0.01 0.1 1 0.001 10 0.01 Iout (A) 0.1 1 10 Iout (A) Figure 4. Efficiency, Vin=24V, Vout=5V, Fsw=400kHz Figure 3. Efficiency, Vin=12V, Vout=5V, Fsw=1200kHz 4.945 415 PFM 4.94 FPWM USM Fsw(KHz) Vout(V) 4.935 4.93 4.925 410 4.92 4.915 405 4.91 0 1 2 3 4 5 6 Figure 5. Load Regulation, Vin=12V, Fsw=400kHz For more information www.silicontent.com 10 13 16 19 Vin(V) Iout(A) 6 7 Figure 6. Buck Fsw VS Vin © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2360 22 25 28 SCT2360 FUNCTIONAL BLOCK DIAGRAM VIN 1 12 EN VCC Ibias current VCC regu lator 8 BST Boo tstr ap Regula tor 9 HS MOSFET 6 MODE FSEL Vref Voltage Bias and Reference Mode Sele ction On-time Gen erator and Freq. Sele ction 4 Soft Start DC Err or Correction 0.6V Control Logic and Pro tection 7 SW Gate Driver PWM Compara tor 11 FB LS MOSFET 3 PG 0.57V 0.63V Curren t Sensing 2 PGND OCP Comparator PG Comparators Ramp Compensation Switching Sensing 5 VOUT 10 AGND OVP Disable Output Discharge Figure 7. Functional Block Diagram For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2360 7 SCT2360 OPERATION Overview The SCT2360 is a 4V-28V input, 6A continuous output synchronous buck converter with built-in 36mΩ Rdson highside and 16mΩ Rdson low-side power MOSFETs. It implements the Constant on-time (COT) mode control to regulate output voltage, providing excellent line and load transient response and simplifying the external frequency compensation design. The switching frequency is selectable, 400kHz, 800kHz and 1.2MHz, by setting different FSEL status, to optimizes either the power efficiency or the external components’ sizes. The SCT2360 features an internal 1ms soft-start time to avoid large inrush current and output voltage overshoot during startup. The device features three different operation modes at light loading: Pulse Frequency Modulation (PFM) mode, and Ultra-Sonic Modulation (USM) mode, and PWM mode. The quiescent current is typically 130uA under no load and sleep mode condition to achieve high efficiency at light load. The SCT2360 has a default input start-up voltage of 3.8V with 300mV hysteresis. The EN function features with a precision threshold that can be used to adjust the input voltage lockout thresholds with two external resistors to meet accurate higher UVLO system requirements. Floating EN pin enables the device with the internal pull-up current to the pin. The SCT2360 full protection features include the input under-voltage lockout, the output over-voltage protection, over current protection with cycle-by-cycle current limiting and hiccup mode, output hard short protection and thermal shutdown protection. Constant on-time (COT) Mode Control The SCT2360 employs constant on-time (COT) Mode control providing fast transient with pseudo fixed switching frequency. At the beginning of each switching cycle, since the feedback voltage (VFB) is lower than the internal reference voltage (VREF), the high-side MOSFET (Q1) is turned on during one on-time and the inductor current rises to charge up the output voltage. The on-time is determined by the input voltage and output voltage. After the on-time, the Q1 turns off and the low-side MOSFET (Q2) turns on after dead time duration. The inductor current drops and the output capacitors are discharged. When the output voltage decreases and the VFB decreased below the VREF, the Q1 turns during one on-time after another dead time duration. This repeats on cycle-by-cycle based. The SCT2360 works with an internal compensation for optimizing the loop stability and transient response. Pulse Frequency Modulation (PFM) and Ultra-sonic Modulation (USM) Modes Grounding the MODE pin makes the SCT2360 works at Pulse Frequency Modulation (PFM) mode to improve the power efficiency in light load. As the output current decreases from heavy load condition, the inductor current is also reduced. If the output current is reduced, the valley of the inductor current reaches the zero level, which is the boundary between continuous conduction and discontinuous conduction modes. The low-side MOSFET is turned off when a zero inductor current is detected. As the load current further decreases the converter runs into discontinuous conduction mode. The on-time is kept the same as it is in continuous conduction mode. The off-time increases as it takes more time to discharge the output with a smaller load current. Floating the MODE pin makes the device works at PFM with Ultra-Sonic Modulation (USM) mode to keep the switching frequency out of the acoustic audible frequency. The USM mode block monitors the state of both highside and low-side MOSFETs. When both high-side and low-side MOSFETs are off for 33us, the low-side MOSFET forces to turn on until the negative current limit is triggered or the feedback voltage (VFB) drops below the internal reference voltage (VREF). Forced Pulse Width Modulation (FPWM) mode Connecting MODE pin to VCC, the SCT2360 forces the device operating at forced Pulse Width Modulation (PWM) mode with pseudo-fixed switching frequency regardless loading current. Operating in PWM mode can achieve smaller output voltage ripple compared with PFM or USM at light load. When the load current approaches zero, the low-side MOSFET current crosses zero and sinks current from output to maintain the constant output. Hence power 8 For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2360 SCT2360 efficiency in light load is much lower than heavy load. Enable and Under Voltage Lockout Threshold The SCT2360 is enabled when the VIN pin voltage rises above 3.8V and the EN pin voltage exceeds the enable threshold of 1.18V. The device is disabled when the VIN pin voltage falls below 3.5V or when the EN pin voltage is below 1.1V. An internal 1.4uA pull up current source to EN pin allows the device enable when EN pin floats. EN pin is a high voltage pin that can be connected to VIN directly to start up the device. For a higher system UVLO threshold, connect an external resistor divider (R1 and R2) shown in Figure 8 from VIN to EN. The UVLO rising and falling threshold can be calculated by Equation 1 and Equation 2 respectively. Vrise = 1.18 ∗ (1 + Vfall = 1.1 ∗ (1 + VIN R1 ) − 1.4uA ∗ R1 R2 (1) 1.4uA 3.6uA R1 R1 ) − 5uA ∗ R1 R2 EN (2) R2 where  Vrise is rising threshold of Vin UVLO  Vfall is falling threshold of Vin UVLO 20K + 1.18V Figure 8. System UVLO by enable divide Output Voltage The SCT2360 regulates the internal reference voltage at 0.6V with 1% tolerance over the operating temperature and voltage range. The output voltage is set by a resistor divider from the output node to the FB pin. It is recommended to use 1% tolerance or better resistors. Use Equation 3 to calculate resistance of resistor dividers. To improve efficiency at light loads, larger value resistors are recommended. However, if the values are too high, the regulator will be more susceptible to noise affecting output voltage accuracy. 𝑉𝑂𝑈𝑇 𝑅𝐹𝐵_𝑇𝑂𝑃 = ( − 1) ∗ 𝑅𝐹𝐵_𝐵𝑂𝑇 𝑉𝑅𝐸𝐹 (3) where  RFB_TOP is the resistor connecting the output to the FB pin.  RFB_BOT is the resistor connecting the FB pin to the ground. Internal Soft-Start The SCT2360 integrates an internal soft-start circuit that ramps the reference voltage from zero volts to 0.6V reference voltage in 1ms. If the EN pin is pulled below 1.1V, switching stops and the internal soft-start resets. The soft-start also resets during shutdown due to thermal overloading. Switching Frequency Selection The switching frequency of the SCT2360 is selectable to be one of three options: 400KHz, 800KHz and 1200KHz. The switching frequency selection is programmed by FSEL pin. The selection information is shown in following table. The frequency setting is latched in at each power up and is not be able to be modified during operation. Cycling the input power or the EN pin can reselect the switching frequency. For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2360 9 SCT2360 Table 1. FSEL Pin Set-up for Switching Frequency Selection FSEL Set-up Connect to GND Floating Connect to VCC Switching Frequency 400KHz 800KHz 1200KHz Mode Selection The SCT2360 features three different operation modes at light load by easily programming the MODE pin. The programming information is listed in following table. The mode setting is latched in at each power up and is not be able to be modified during operation. Cycling the input power or the EN pin can reselect the switching frequency. Table 2. MODE Pin Set-up for Mode Selection MODE Set-up Floating Connect to GND Connect to VCC Switching Frequency PFM with USM PFM FPWM Power Good (PG) The Power Good (PG) pin is the output of an open drain output. When the FB pin is typically between 95% and 105% of VREF the PG is de-asserted and floats after a 500μs de-glitch time. A pull-up resistor of 10 kΩ to 100 kΩ is recommended to pull it up to VCC. The PGOOD pin is pulled low when the FB pin voltage falls under 85% or rises over 115% of VREF, including UVP and OVP; or, in an event of thermal shutdown or during the soft-start period. Bootstrap Voltage Regulator An external bootstrap capacitor between BOOT pin and SW pin powers the floating gate driver to high-side power MOSFET. The bootstrap capacitor voltage is charged from 5V VCC power or when high-side power MOSFET is off and low-side power MOSFET is on. Over Current Limit and Hiccup Mode The output over-current limit (OCL) is implemented in SCT2360 by using a cycle-by-cycle valley detect control circuit. The switch current is monitored during the OFF state of the high-side FET (Q1) by measuring the low-side FET(Q2) drain to source voltage. This voltage is proportional to the switch current. During the on time of the highside FET switch, the switch current increases at a linear rate determined by input voltage, output voltage, the ontime and the output inductor value. During the on time of the low-side FET switch, this current decrease linearly. The average value of the switch current is the load current IOUT. If the measured drain to source voltage of the low-side FET is above the voltage proportional to current limit, the low side FET stays on until the current level becomes lower than the OCL level which reduces the output current available. When the current is limited, the output voltage tends to drop because the load demand is higher than what the converter can support. When the output voltage falls below 75% of the target voltage, the UVP comparator detects it and shuts down the device immediately, the device re-starts after a hiccup time of 7ms. In this type of valley detect control the load current is higher than the OCL threshold by one half of the peak to peak inductor ripple current. When the overcurrent condition is removed, the output voltage returns to the regulated value. If an OCL condition happens during start-up then the device enters hiccup-mode immediately without a wait time of 1ms. The hiccup protection mode above makes the average short circuit current to alleviate thermal issues and protect the regulator. Under-voltage Protection The SCT2360 features the Under-voltage Protection (UVP) by monitoring the output voltage to detect the undervoltage voltage. When the feedback voltage falls below 75% of VREF, the SCT2360 enters hiccup mode until the under-voltage scenario released. 10 For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2360 SCT2360 Over voltage Protection The SCT2360 implements the Over-voltage Protection (OVP) circuitry to minimize output voltage overshoot during load transient, recovering from output fault condition or light load transient. The overvoltage comparator in OVP circuit compares the FB pin voltage to the internal reference voltage. When the feedback voltage rises higher than 120% of the feedback voltage, the OVP comparator output goes high and the circuit turns off the HS-FET driver. The LS-FET driver turns on until trigger negative current limit or FB below reference voltage. Then HS-FET turns on with normal ON-time and turn off, following with a LS-FET on until negative current limited triggered or FB lower than reference voltage. The device exits this regulation period when the feedback voltage falls below 115% of the reference voltage. Thermal Shutdown The SCT2360 protects the device from the damage during excessive heat and power dissipation conditions. Once the junction temperature exceeds 160C, the internal thermal sensor stops power MOSFETs switching. When the junction temperature falls below 135C, the device restarts with internal soft start phase. For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2360 11 SCT2360 APPLICATION INFORMATION Typical Application R4 0 VIN C1 22uF VIN C2 22uF C3 0.1uF BST SCT2360 SW EN R1 100K MODE FSEL PG R2 NC R3 100K VCC C4 1uF AGND C5 0.1uF L1 3.3uH VOUT 5V R7 75k FB Cf NC C7 22uF VOUT R8 10.2k PGND Figure 9. 12V Input, 5V/6A Output Design Parameters 12 Design Parameters Example Value Input Voltage 12V Output Voltage 5V Output Current 6A Output voltage ripple (peak to peak) 50mV Switching Frequency 400kHz For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2360 C8 22uF C9 22uF SCT2360 Input Capacitor Selection For good input voltage filtering, choose low-ESR ceramic capacitors. A ceramic capacitor 22μF is recommended for the decoupling capacitor and a 0.1μF ceramic bypass capacitor is recommended to be placed as close as possible to the VIN pin of the SCT2360. Use Equation 4 to calculate the input voltage ripple: ∆𝑉𝐼𝑁 = 𝐼𝑂𝑈𝑇 VOUT 𝑉𝑂𝑈𝑇 × × (1 − ) 𝐶𝐼𝑁 × 𝑓𝑆𝑊 VIN 𝑉𝐼𝑁 (4) Where:  CIN is the input capacitor value  fsw is the converter switching frequency  IOUT is the maximum load current Due to the inductor current ripple, the input voltage changes if there is parasitic inductance and resistance between the power supply and the VIN pin. It is recommended to have enough input capacitance to make the input voltage ripple less than 100mV. Generally, two 22uF input ceramic capacitor is recommended for most of applications. Choose the right capacitor value carefully with considering high-capacitance ceramic capacitors DC bias effect, which has a strong influence on the final effective capacitance. Inductor Selection The performance of inductor affects the power supply’s steady state operation, transient behavior, loop stability, and buck converter efficiency. The inductor value, DC resistance (DCR), and saturation current influences both efficiency and the magnitude of the output voltage ripple. Larger inductance value reduces inductor current ripple and therefore leads to lower output voltage ripple. For a fixed DCR, a larger value inductor yields higher efficiency via reduced RMS and core losses. However, a larger inductor within a given inductor family will generally have a greater series resistance, thereby counteracting this efficiency advantage. Inductor values can have ±20% or even ±30% tolerance with no current bias. When the inductor current approaches saturation level, its inductance can decrease 20% to 35% from the value at 0-A current depending on how the inductor vendor defines saturation. When selecting an inductor, choose its rated current especially the saturation current larger than its peak current during the operation. To calculate the current in the worst case, use the maximum input voltage, minimum output voltage, maxim load current and minimum switching frequency of the application, while considering the inductance with -30% tolerance and low-power conversion efficiency. For a buck converter, calculate the inductor minimum value as shown in equation 5. 𝐿𝐼𝑁𝐷𝑀𝐼𝑁 = (5) 𝑉𝑂𝑈𝑇 × (𝑉𝐼𝑁𝑀𝐴𝑋 − 𝑉𝑂𝑈𝑇 ) 𝑉𝐼𝑁𝑀𝐴𝑋 × 𝐾𝐼𝑁𝐷 × 𝐼𝑂𝑈𝑇 × 𝑓𝑆𝑊 Where:  KIND is the coefficient of inductor ripple current relative to the maximum output current. Therefore, the peak switching current of inductor, ILPEAK, is calculated as in equation 6. 𝐼𝐿𝑃𝐸𝐴𝐾 = 𝐼𝑂𝑈𝑇 + 𝐾𝐼𝑁𝐷 × 𝐼𝑂𝑈𝑇 2 (6) Set the current limit of the SCT2360 higher than the peak current ILPEAK and select the inductor with the saturation current higher than the current limit. The inductor’s DC resistance (DCR) and the core loss significantly affect the efficiency of power conversion. Core loss is related to the core material and different inductors have different core loss. For a certain inductor, larger current ripple generates higher DCR and ESR conduction losses and higher core loss. For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2360 13 SCT2360 Output Capacitor Selection The selection of output capacitor will affect output voltage ripple in steady state and load transient performance. The output ripple is essentially composed of two parts. One is caused by the inductor current ripple going through the Equivalent Series Resistance ESR of the output capacitors and the other is caused by the inductor current ripple charging and discharging the output capacitors. To achieve small output voltage ripple, choose a low-ESR output capacitor like ceramic capacitor. For ceramic capacitors, the capacitance dominates the output ripple. For simplification, the output voltage ripple can be estimated by Equation 7 desired. ∆VOUT = Where       𝑉𝑂𝑈𝑇 ∗ (𝑉𝐼𝑁 − 𝑉𝑂𝑈𝑇 ) (7) 8 ∗ 𝑓𝑆𝑊 2 ∗ 𝐿 ∗ 𝐶𝑂𝑈𝑇 ∗ 𝑉𝐼𝑁 ΔVOUT is the output voltage ripple fSW is the switching frequency L is the inductance of inductor COUT is the output capacitance VOUT is the output voltage VIN is the input voltage Due to capacitor’s degrading under DC bias, the bias voltage can significantly reduce capacitance. Ceramic capacitors can lose most of their capacitance at rated voltage. Therefore, leave margin on the voltage rating to ensure adequate effective capacitance. Typically, three 22μF ceramic output capacitors work for most applications. Output Feedback Resistor Divider Selection The SCT2360 features external programmable output voltage by using a resistor divider network R7 and R8 as shown in the typical application circuit Figure 9. Use equation 8 to calculate the resistor divider values. 𝑅7 = (𝑉𝑂𝑈𝑇 − 𝑉𝑟𝑒𝑓 ) × 𝑅8 𝑉𝑟𝑒𝑓 (8) Table 3. Recommended Component Values for Typical Output Voltage (Vin=12V) Fsw (kHz) 400 800 1200 Vout (V) L (uH) R7 (kΩ) R8 (kΩ) Cout(uF) 1.0 3.3 5.0 1.0 3.3 5.0 1.0 3.3 5.0 1.0 3.3 3.3 0.56 1.5 1.5 0.33 1.0 1.0 6.8 46.4 75.0 6.8 46.4 75.0 6.8 46.4 75.0 10.2 10.2 10.2 10.2 10.2 10.2 10.2 10.2 10.2 100 88 66 100 88 66 100 88 66 Table 4. Recommended Component Values for Typical Output Voltage (Vin=24V) Fsw (kHz) 400 800 1200 14 Vout (V) L (uH) R7 (kΩ) R8 (kΩ) Cout(uF) 3.3 5.0 3.3 5.0 3.3 5.0 3.3 3.3 1.5 1.5 1.0 1.0 46.4 75.0 46.4 75.0 46.4 75.0 10.2 10.2 10.2 10.2 10.2 10.2 88 66 88 66 88 66 For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2360 SCT2360 Application Waveforms(continued) Vin=12V, Vout=5V, unless otherwise noted Figure 10. Power up Figure 11. Power down Figure 12. EN toggle (Iload=6A) Figure 13. EN toggle (Iload=10mA) Figure 14. Over Current Protection(1A to hard short) Figure 15. Over Current Release (hard short to 1A) For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2360 15 SCT2360 Application Waveforms Vin=12V, Vout=5V, unless otherwise noted 16 Figure 16. Load Transient (1.5A-4.5A, 1.6A/us) Figure 17. Output Ripple (Iload=0A, PFM) Figure 18. Output Ripple (Iload=0A, USM) Figure 19. Output Ripple (Iload=0A, FPWM) Figure 20. Output Ripple (Iload=6A) Figure 21. Thermal, 12VIN, 5Vout, 6A For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2360 SCT2360 Layout Guideline Proper PCB layout is a critical for SCT2360 stable and efficient operation. The traces conducting fast switching currents or voltages are easy to interact with stray inductance and parasitic capacitance to generate noise and degrade performance. For better results, follow these guidelines as below: 0402 1. Place a low ESR ceramic capacitor as close to VIN pin and the ground as possible to reduce parasitic effect. 2. For operation at full rated load, the top side ground area must provide adequate heat dissipating area. Make sure top switching loop with power have lower impendence of grounding. 3. The bottom layer is a large ground plane connected to the ground plane on top layer by vias. it is recommended 8mil diameter drill holes of thermal vias, but a smaller via offers less risk of solder volume loss. On applications where solder volume loss thru the vias is of concern, plugging or tenting can be used to achieve a repeatable process. 4. Output inductor should be placed close to the SW pin. The area of the PCB conductor minimized to prevent excessive capacitive coupling. 5. UVLO adjust and loop compensation and feedback components should connect to small signal ground which must return to the GND pin without any interleaving with power ground. 6. Route BST resistor and capacitor with a minimized length between the BST PIN and SW PIN. VOUT EN FB AGND VCC 12 11 10 9 11 VIN 8 7 PG BST 0603 SW 22 PGND 3 PG 4 FSEL 5 6 VOUT MODE L1 0805 VOUT Figure 22. PCB Layout Example For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2360 17 SCT2360 PACKAGE INFORMATION SYMBOL MIN 0.7 0 A A1 A2 A3 b b1 D E e e1 L L1 L2 aaa ccc eee bbb 0.2 0.25 0.3 1.725 1.95 MILLIMETER NOM 0.75 0.02 0.55 0.203REF 0.25 0.3 3 BSC 3 BSC 0.5 BSC 1.1 BSC 0.4 1.825 2.05 0.1 0.1 0.08 0.1 MAX 0.8 0.05 0.3 0.35 0.5 1.925 2.15 NOTE: 1. 2. 3. 4. 5. Drawing proposed to be made a JEDEC package outline MO-220 variation. Drawing not to scale. Thermal pad shall be soldered on the board. Dimensions of exposed pad on bottom of package do not include mold flash. Contact PCB board fabrication for minimum solder mask web tolerances between the pins. 18 For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2360 SCT2360 TAPE AND REEL INFORMATION For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2360 19
SCT2360FPBR 价格&库存
很抱歉,暂时无法提供与“SCT2360FPBR”相匹配的价格&库存,您可以联系我们找货
