File No: JS-CSR-SMF-00
Revision: U
Page: 1 of 7
Current Sensing Resistor
Metal Foil Type >SMF Series
General
•Chip size from 0603 to 2512
•Resistance value from 2m to 200m
•Low thermal EMF
•Low TCR
•Lead free, RoHS compliant for global
•Applications and halogen free
Application
•Switching model power supply
•Battery pack
•Notebook, personal computer
•Test Instrument
•Power Amplifier
Electrical Specifications
Type
Power Rating
at 70℃(W)
0603
0.5
0805
0.5
0.75
1206
0.5
1.0
2010
1.0
1.0
2.0*
2512
Resistance Range(mΩ)
TCR
(ppm/℃)
Resistance
tolerance
3≤R≤9
±200
10≤R≤30
±100
3≤R≤9
±100
10≤R≤47
±50
3≤R≤9
±100
±0.5%(D)
10≤R≤68
±50
±1%(F)
3≤R≤9
±100
10≤R≤100
±50
2
±200
2.5
±200
3≤R≤9
±100
10≤R≤200
±50
“*”:2512 2W applicable resistance range 2~100mΩ
Remark:
a.
0.5 W with total solder pad trace size of 100 mm².
b.
0.75 W with total solder pad trace size of 200 mm².
c.
1.0 W with total solder pad trace size of 200 mm²
d.
2.0 W with total solder pad trace size of 300 mm².
Nanjing SART Science& Technology Development Co., Ltd.
ADD.: Maqun Science & Technology Park, Qingma Road 6#, Nanjing, China
TEL.: 086-25-84354852-8015 FAX.:086-25-83241791 Web.: www.sartfuse.com
±2%(G)
±5%(J)
Operation Temp.
Range
-55℃~+170℃
Revision: U
Page: 2 of 7
Part Number Information
SMF 25 M
2
F
R010
T
【1】【2】【3】【4】【5】【6】 【7】
【1】Series Name: SART Metal Foil Type
【2】Chip size:06:0603 08:0805 12:1206 20:2010 25:2512
【3】Material Code: M:Mn-Cu
【4】Power Code: A :0.5W C:0.75W 1:1W 2:2W
【5】Resistance Tolerance: D:±0.5% F:±1% G:±2% J:±5%
【6】Resistance Code:R010=10mΩ 2M50=2.5mΩ
【7】Packaging Code: T: Tape& Reel
B:Bulk Pack
Dimensions
Type
0603*
0805**
1206
2010
2512
Resistance
Range(mΩ)
3~4
≥5
3~4
≥5
3~4
≥5
3
4~5
≥6
2
2.5
3
4
5~6
7
≥8
L
(mm)
W
(mm)
T
(mm)
A
(mm)
1.60±0.20
0.80±0.20
0.70±0.15
0.35±0.25
2.00±0.20
1.25±0.15
0.70±0.15
0.40±0.25
3.20±0.20
1.60±0.15
0.75±0.15
0.50±0.30
5.00±0.20
2.50±0.20
0.75±0.20
0.60±0.30
6.40±0.20
3.20±0.20
0.75±0.20
0.90±0.30
Remark*: 0603 two-digit mark; **: 0805 3mΩ≤R≤9mΩ& 2010no upper black coating
B
(mm)
0.60±0.20
0.35±0.20
0.70±0.30
0.40±0.20
0.90±0.30
0.50±0.20
1.60±0.30
1.30±0.30
0.80±0.30
2.30±0.30
2.30±0.30
1.90±0.30
1.70±0.30
1.20±0.30
1.10±0.30
0.90±0.30
Revision: U
Page: 3 of 7
Recommended Land Patterns
Resistance
Range (mΩ)
3~4
≥5
3~4
≥5
3~4
≥5
3~9
10~100
2
2.5
3
4
5~6
7
≥8
Type
0603
0805
1206
2010
2512
A
(mm)
0.40
0.60
0.50
0.80
0.80
1.80
1.60
2.70
1.40
1.40
2.20
2.60
3.60
3.80
4.20
B
(mm)
C
(mm)
2.80
1.00
3.20
1.40
4.40
1.80
6.30
2.90
8.00
3.40
Materials
No.
Materials
No.
Materials
1
Ceramic
7
Tin
2
Adhesive film
8
Nicr
3
Alloy
9
Protective coating
4
Protective coating
10
Marking
5
Copper
11
Silver paste
6
Nickel
D
(mm)
1.20
1.10
1.35
1.20
1.80
1.30
2.35
1.80
3.30
3.30
2.90
2.70
2.00
2.20
1.90
Revision: U
Page: 4 of 7
Power Derating Curve
Recommended Solder Curve
1.Infrared Reflow
Temperature:260℃
Time:5sec Max.
Recommend Reflow profile:
2.Wave soldering
Reservoir Temperature:260℃
Time in Reservoir:10sec Max.
Profile Feature
Average Ramp-Up Rate
(Tsmax to Tp)
Preheat
Temperature Min(Tsmin)
Temperature Max(Tsmax)
Time(Tsminto Tsmax)
Peak Temperature(Tp)
Time within 5℃ of actual
Pb-Free Assembly
Melting tin time(TL)
20sec~30sec
Ramp-Down Rate
6℃/sec Max.
Time 25℃ to Peak
Temperature
8min Max.
3.Hand Soldering
Temperature:350℃
Time:5sec Max.
3℃/sec Max.
150℃
200℃
60sec~120sec
260℃
5sec
Revision: U
Page: 5 of 7
Product Characteristics
Test condition/ Methods
Short Time Overload
0.5W:5X rated power for 5 sec
0.75W:5X rated power for 5 sec
1.0W:5X rated power for 5 sec
2.0W:4X rated power for 5 sec
|R|≤ ±1%
IEC60115-1 4.13
Temperature
Coefficient of
Resistance (T.C.R.)
TCR =(R-R0)/R0(T2-T1)* 106
T1
T2
Test temperature:25℃~125℃
Refer to SART Spec
IEC60115-1 4.8
Load Life
1000 hours at rated power, 70℃± 2℃,
1.5hours “ON”, 0.5hours “OFF”
|R|≤±1%
IEC60115-1 4.25
Bias Humidity
40℃±2℃, 93% ±3% RH, 1000 hours at rated
power, 1.5 hours “ON”, 0.5 hours “OFF”
|R|≤±1%
IEC60115-1 4.24
Thermal Shock
-55℃(30min)/+125℃ (30min), 100 cycles
|R|≤±1%
IEC60115-1 4.19
Solder ability
245℃± 5℃,3sec ± 0.3sec
95%coverage Min.
IEC60115-1 4.17
Resistance to
Soldering Heat
270℃± 5℃,10sec ±1.0sec
|R|≤±1%
IEC60115-1 4.18
High temperature
Exposure
170℃± 2℃ for 1000 hours
|R|≤±1%
IEC60115-1 4.23
Bending test
Epoxy thickness1.6mm, Fulcrums distance
90mm,Bending width 5mm(0603、0805),
Bending width 4mm(1206).Bending width
2mm(2010、2512)
|R|≤±1%
IEC60115-1 4.33
Performance
Standard
Item
Revision: U
Page: 6 of 7
Packaging
1. Paper Tape Dimensions
Type
A
(mm)
B
(mm)
W
(mm)
F
(mm)
E
(mm)
0603
1.85±0.10
1.10±0.10
8.00±0.20
3.50±0.05
1.75±0.10
0805
2.40±0.10
1.60±0.10
8.00±0.20
3.50±0.05
1.75±0.10
1206
3.60±0.20
2.00±0.20
8.00±0.20
3.50±0.05
1.75±0.10
Type
P
(mm)
P0
(mm)
P1
(mm)
D0
(mm)
T
(mm)
0603
4.00±0.10
4.00±0.10
2.00±0.05
1.50±0.10
0.75±0.10
0805
4.00±0.10
4.00±0.10
2.00±0.05
1.50±0.10
0.95±0.10
1206
4.00±0.10
4.00±0.10
2.00±0.05
1.50±0.10
0.95±0.10
2.Embossed Tape Dimensions
Type
A0
(mm)
B0
(mm)
W
(mm)
F
(mm)
E
(mm)
T
(mm)
2010
5.50±0.15
2.80±0.15
12.00±0.10
5.50±0.10
1.75±0.10
0.24±0.05
2512
6.75±0.15
3.45±0.15
12.00±0.10
5.50±0.10
1.75±0.10
0.25±0.05
Type
P
(mm)
P0
(mm)
P1
(mm)
D0
(mm)
D1
(mm)
K0
(mm)
2010
4.00±0.10
4.00±0.10
2.00±0.05
1.50
0.10
1.50±0.10
0.85±0.05
2512
4.00±0.10
4.00±0.10
2.00±0.05
1.50
0.10
1.50±0.10
1.00±0.10
Revision: U
Page: 7 of 7
3.Reel Dimensions
Type
M
(mm)
W
(mm)
T
(mm)
A
(mm)
B
(mm)
C
(mm)
D
(mm)
0603
0805
1206
178.00±2.00
9.5±1.00
12.50±1.50
2.00±0.50
13.00±0.50 21.00±0.50 58.00±0.20
2010
2512
178.00±2.00 13.00±0.50 15.50±1.50
2.00±0.50
13.00±0.50 21.00±0.50 57.00±2.00
4. Quantity of Package
Type
Quantity(PCS)
0603
0805
1206
5000
2010
2512
4000
5. Peeling Test
Storage
The ambient temperature shall between 5℃~30℃.
The relative humidity recommended for storage is between 25%RH~60%RH.
Sealed plastic bags with desiccant shall be used to reduce the oxidation of the termination and shall only
be opened prior to use.
The products shall not be stored in areas where harmful gases containing sulfur or chlorine are present.
很抱歉,暂时无法提供与“SMF12M1FR010T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.33016
- 100+0.26277
- 300+0.22907
