SIG7192-ITSP24-RL
SIG7192-ITSP24-RL
    SIGNALMICRO(信格勒)
    TSSOP24_7.8X4.4MM
    4.7SPS至4.8kSPS, 超低噪声24位ADC, 带PGA增益1至128
SIG7192-ITSP24-RL 数据手册
SIG7192 SIG7192: 4.8kSPS, 24-bit Sigma-Delta ADC with PGA FEATURES DESCRIPTION Programmable Gain: 1/2/4/8/16/32/64/128 Data Rates: 4.7SPS to 4.8kSPS RMS Noise: 15nV at 10SPS (Gain=128) 22.4 noise-free bits at 10SPS (Gain=1) Offset Drift: 3nV/°C (Gain=128) Gain Drift: 0.5ppm/°C Integral Non-Linearity: 3ppm Internal or External Clock Simultaneous 50Hz/60Hz Rejection 2 Differential/4 Pseudo Differential Inputs Automatic Channel Sequencer Burnout Current Sources 4 General Purpose Digital Outputs Parity Check Power Supply AVDD: 2.7V to 5.25V or ±2.5V DVDD: 2.7V to 5.25V Current: 2.8mA Package: 24-lead TSSOP The SIG7192 is a low noise, low drift, and high-resolution 24-bit analog-to-digital converter (ADC) with integrated programmable gain amplifier (PGA) that offers high-accuracy measurement solutions for bridge sensors, thermocouples, and resistance temperature devices (RTD). The device contains a low noise PGA with gains selected from 1, 2, 4, 8 16, 32, 64, and 128, a delta-sigma (Δ-Σ) modulator, and a programmable digital SINC4/SINC3/fast settling filter. 50Hz/60Hz simultaneous rejection option is also provided. The output data rate from the device can be configured from 4.7SPS up to 4800SPS. This device provides channel sequencer feature to measure two differential inputs or four pseudo differential inputs automatically. Burnout current sources are provided at the analog inputs for sensor connection diagnosis. Offset and gain calibration registers are provided with calibration command or direct register write to calibrate the ADC errors or overall system errors. SPI-compatible interface is used for device configuration and parity check is provided for data integrity. The on-chip oscillator, an external clock, or an external crystal can be used as the clock source to the device. The device can operate with bipolar ±1.35V to ±2.625V analog power supplies, or with a single 2.7V to 5.25V analog power supply. APPLICATIONS The SIG7192 is available in 24-lead TSSOP package and is fully specified over the -40°C to +125°C temperature range. Weigh Scales Strain Gauges Temperature Measurement Industrial Process Control Pressure Sensors Function Block Diagram AVDD REFIN1+ REFIN1- TSSOP-24 DVDD MCLK1 1 24 MCLK2 2 23 DOUT/DRDYn SCLK 3 22 SYNCn_PDn CS 4 21 DVDD P3 5 20 AVDD P2 6 19 DGND P1/REFIN2+ 7 18 AGND P0/REFIN2- 8 17 BPDSW NC 9 16 REFIN1- AINCOM 10 15 REFIN1+ AIN1 11 14 AIN4 AIN2 12 13 AIN3 REFERENCE DETECT Gain=1,2,4,8, 16,32,64,128 BUF AIN4 MUX AIN1 AIN2 AIN3 PGA SYNCn_PDn CSn ΔΣ ADC Digital Filter Serial Interface And Control Logic AINCOM DOUT/DRDYn SCLK P3 P2 TEMP Sensor BPDSW AGND Sept. 2021 DIN Internal Oscillator P0/REFIN2- P1/REFIN2+ Clock Circuitry MCLK2 MCLK1 DGND Signal Micro Incorporated http://www.signal-micro.cn DIN SIG7192 PIN CONFIGURATION and DESCRIPTIONS TOP VIEW (Not To Scale) PIN NO. NAME 1 MCLK1 2 MCLK2 3 4 SCLK CSn 5 6 P3 P2 7 P1/REFIN2+ 8 P0/REFIN2- MCLK1 1 24 MCLK2 2 23 DOUT/DRDYn SCLK 3 22 SYNCn_PDn CS 4 21 DVDD P3 5 20 AVDD P2 6 19 DGND P1/REFIN2+ 7 18 AGND P0/REFIN2- 8 17 BPDSW NC 9 16 REFIN1- AINCOM 10 15 REFIN1+ AIN1 11 14 AIN4 AIN2 12 13 AIN3 SIG7192 TSSOP-24 DIN FUNCTION DESCRIPTION Digital Input Digital Input/Output Digital Input Digital Input Crystal Connection. Master clock input or internal clock output depending on MODE Register bits CLK[1:0]. Serial data clock. Serial chip select. Active low. 9 NC Analog Output Analog Output Analog Input/Output Analog Input/Output Analog 10 11 AINCOM AIN1 Analog Input Analog Input Negative analog input for pseudo differential operation. Analog input channel 1. 12 13 AIN2 AIN3 Analog Input Analog Input Analog input channel 2. Analog input channel 3. 14 15 AIN4 REFIN1+ Analog Input Analog Input Analog input channel 4. Positive reference input. 16 17 REFIN1BPDSW Analog Input Analog Input 18 AGND Analog 19 DGND Digital 20 AVDD Analog 21 DVDD Digital 22 SYNCn_PDn Digital Input 23 24 DOUT/DRDYn DIN Digital Output Digital Input Negative reference input. Bridge Power-down switch to AGND. Negative analog power supply. AGND can be taken below DVSS to provide bipolar power supplies. For example, AGND can be tied to – 2.5V and AVDD can be tied to +2.5V, providing a ±2.5V dual supplies to the ADC. Digital ground reference point. Positive analog power supply. 2.7V to 5.25V relative to AGND. AVDD is independent of DVDD. Digital power supply, 2.7V to 5.25V. DVDD is independent of AVDD. Synchronization control signal. While this pin is low, the digital filter is reset and DOUT pin is forced to high. The device starts a new conversion after this pin goes back to high. The device enters powerdown if holding this pin low for longer than 0.83ms. Serial data output and data ready indicator. Serial data input. Sept. 2021 General purpose output bit between AVDD and AGND. General purpose output bit between AVDD and AGND. General purpose output bit between AVDD and AGND or second positive reference input. General purpose output bit between AVDD and AGND or second negative reference input. No connection (float) or connect to AVDD/AGND. Signal Micro Incorporated http://www.signal-micro.cn 2 SIG7192 PACKAGE/ORDERING INFORMATION MODEL PACKAGE DESCRIPTION SPECIFIED TEMPERATURE RANGE SIG7192 TSSOP-24 -40°C to +125°C ORDERING NUMBER PACKING OPTION SIG7192-ITSP24-TB Tube, 60 SIG7192-ITSP24-RL Reel, 3000 SPECIFICATIONS Absolute Maximum Ratings Over operating free-air temperature range, unless otherwise noted.(1) AVDD to AGND Voltage Current Temperature MIN MAX UNIT –0.3 6.5 V AGND to DGND –3 0.3 V DVDD to DGND –0.3 6.5 V Analog input VAGND – 0.3 VAVDD + 0.3 V Digital input VDGND – 0.3 VDVDD + 0.3 V Input current –10 10 mA Junction (TJ) –50 150 °C Storage (Tstg) -60 150 °C (1) Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. ESD Ratings SYMBOL PARAMTER CONDITION VALUE UNIT HBM Human-body model ANSI/ESDA/JEDEC JS-001 ±6000 V MM Machine model JEDEC EIA/JESD22-A115C ±400 V This integrated circuit can be damaged by ESD. Signal Micro recommends that all integrated circuits be handled with appropriate precautions. Failure to observe proper handling and installation procedures can cause damage. ESD damage can range from subtle performance degradation to complete device failure. Precision integrated circuits may be more susceptible to damage because very small parametric changes could cause the device not to meet its published specifications. Sept. 2021 Signal Micro Incorporated http://www.signal-micro.cn 3 SIG7192 Electrical Characteristics Minimum/Maximum specifications apply from -40˚C to +125˚C. Typical specifications are at +25˚C. All specification are at VAVDD=5V, VAGND=0V, VDVDD=3.3V, VREF=2.5V, fCLK=4.9152MHz, data rate=10SPS, and PGA Gain=1, unless otherwise noted. PARAMETER TEST CONDITION OR NOTES MIN(1) MAX(1) UNITS –VREF/Gain +VREF/Gain V VAGND – 0.05 VAGND + 0.5 VAGND + 0.5 + |VINMAX|·Gain/2 VAVDD + 0.05 VAVDD – 0.5 VAVDD – 0.5 – |VINMAX|·Gain/2 TYP ANALOG INPUTS Differential Input Voltage VIN = VINP – VINN Absolute Input Voltage Buffer Off, Gain = 1 Buffer On Common Mode Input Range Buffer On Absolute Input Current Buffer off, Gain = 1 Buffer On ±100 ±2 V V nA nA SYSTEM PERFORMANCE PGA Gain 1/2/4/8/16/32/64/128 V/V Resolution 24 Bits Data Rate 4.7 Noise Integral Nonlinearity (INL) 4800 SPS See Noise Table Buffer Off, Gain=1 Buffer On ±10 ppm ±2 ppm Offset Error All PGA gains ±150/Gain μV Offset Drift vs. Temperature All PGA gains ±150/Gain ± 2 nV/°C Gain Error All PGA gains Gain Drift vs. Temperature Normal Mode Rejection (NMRR) Common Mode Rejection (CMRR) All PGA gains fIN = 50/60Hz, ±2%, data rate=10SPS fIN = 50Hz, data rate = 1200SPS AVDD, AGND Power Supply Rejection (PSRR) REFERENCE INPUT Differential Reference Voltage (VREF) Absolute Negative Reference Voltage (VREFN) Absolute Positive Reference Voltage (VREFP) Average Voltage Input Current ±0.3 -3 100 ±0.5 % +3 ppm/°C See Table 20 dB 120 dB 85 105 dB DVDD 90 110 dB VREF = VREFP – VREFN 0.5 VAVDD – VAGND + 0.1 V VAGND – 0.05 VREFP – 0.5 V VREFN + 0.5 VAVDD + 0.05 V ±500 nA 500 nA Burnout Current Sources Current Setting ADC CLOCK External Clock Internal Oscillator Crystal Oscillation Frequency Range Duty Cycle 1 Nominal Frequency Accuracy Frequency Range 4.9152 40% 5.0 4.9152 MHz –3% ±0.5% 3% 1 4.9152 2.5 Start-up Time MHz 60% 20 MHz ms DIGITAL INPUT/OUTPUT High-level Output Voltage (VOH) IOH = 4mA Low-level Output Voltage (VOL) IOL = –4mA 0.8·VDVDD High-level Input Voltage (VIH) 0.7·VDVDD Low-level Input Voltage (VIL) VDGND Input Hysteresis V VDVDD V 0.3·VDVDD V ±10 μA 0.5 Input Leakage Sept. 2021 V 0.2·VDVDD Signal Micro Incorporated http://www.signal-micro.cn V 4 SIG7192 POWER SUPPLY AGND Voltage (VAGND) –2.625 0 V AVDD Voltage (VAVDD) VAGND + 2.7 VAGND + 5.25 V DVDD Voltage (VDVDD) 2.7 5.25 V AVDD, AGND Current (IAVDD) Buffer Off 0.9 1.3 mA Buffer On 2.5 3.2 mA Sleep Mode Power-down Mode DVDD Current (IDVDD) Total Power Dissipation μA 1 μA 1 360 μA Active Mode 260 Sleep Mode 50 Power-down Mode 1 μA Buffer Off 5.5 mW Buffer On 13.5 mW μA Sleep Mode 0.16 mW Power-down Mode 0.01 mW TEMPERATURE RANGE Specified temperature range –40 125 °C Operating temperature range –50 125 °C Storage temperature range –60 150 °C (1) Compliance to datasheet limits is assured by one or more methods: production test, characterization and/or design. Sept. 2021 Signal Micro Incorporated http://www.signal-micro.cn 5 SIG7192 Timing Requirements: Serial Interface Over the operating ambient temperature range and DVDD = 2.7V to 5.25V, unless otherwise noted. t7 CSn t6 t1 t5 B7 DOUT B6 B4 B5 B3 B2 B1 B0 t2 t8 t3 SCLK t4 t9 t10 DIN B7 B6 B5 B4 B3 B2 B0 B1 Figure 1. Serial Interface Timing Requirements SYMBOL t1 t2 t3 t4 DESCRIPTION CSn falling edge to DOUT/DRDYn driven: propagation delay(1) SCLK falling edge to valid DOUT/DRDYn: propagation delay(1) SCLK low pulse width MIN SCLK high pulse width 100 SCLK period MAX 50 50 100 200 UNIT ns ns ns ns 106 ns 40 ns t5 CSn rising edge to DOUT high impedance: propagation delay t6 Last SCLK rising edge to CSn rising edge: delay time 50 ns t7 CSn high pulse width 50 ns 50 ns time(2) t8 CSn falling edge to first SCLK falling edge: setup t9 Valid DIN to SCLK rising edge: setup time 50 ns t10 Valid DIN to SCLK rising edge: hold time 25 ns (1) DOUT load = 20pF || 100k Ω to DGND. (2) CSn can be tied low. Sept. 2021 Signal Micro Incorporated http://www.signal-micro.cn 6 SIG7192 NOISE PERFORMANCE The noise performance of the ADC is affected by PGA gain, data rate, and digital filter setting. The following tables show the rms noise and peak-to-peak noise for SINC4 and SINC3 filters and fast settling mode with chop disabled. The effective number of bits (ENOB) and noise-free bits are also listed according to Equation (1) and Equation (2): ENOB= log 2 (2×VREF ⁄Gain⁄VRMS ) (1) Noise Free Bits= log 2 �2×VREF ⁄Gain⁄Vp-p � (2) The noise data listed in the table are typical and are generated from continuous ADC readings with differential input voltage of 0 V. With chop enabled, the resolution improves by 0.5 bits. SINC4 and Chop Disabled Table 1. ADC Noise in µVRMS (µVPP) at TA = 25°C, VAVDD = 5 V, VREF = 5 V, SINC4 Filter, Chop Disabled Filter Word Data Rate (SPS) 1023 640 480 96 80 32 16 5 2 1 4.7 7.5 10 50 60 150 300 960 2400 4800 PGA GAIN 1 2 4 8 16 32 64 128 0.211(1.27) 0.267(1.60) 0.308(1.85) 0.689(4.13) 0.755(4.52) 1.19(7.15) 1.64(8.94) 2.69(17.9) 6.91(55.4) 57.8(427) 0.126(0.686) 0.159(0.866) 0.183(1.00) 0.410(2.24) 0.449(2.45) 0.710(3.87) 0.940(5.36) 1.80(11.9) 3.89(30.7) 29.1(229) 0.069(0.368) 0.087(0.465) 0.101(0.537) 0.225(1.20) 0.247(1.32) 0.390(2.08) 0.574(3.13) 1.10(6.86) 2.17(15.6) 14.4(153) 0.044(0.264) 0.055(0.333) 0.064(0.385) 0.143(0.860) 0.157(0.942) 0.248(1.49) 0.353(1.79) 0.652(4.02) 1.20(9.16) 7.36(61.5) 0.028(0.138) 0.035(0.175) 0.041(0.202) 0.091(0.451) 0.099(0.495) 0.157(0.782) 0.213(1.19) 0.391(2.31) 0.691(4.99) 3.60(30.6) 0.018(0.099) 0.023(0.125) 0.027(0.144) 0.059(0.323) 0.065(0.354) 0.103(0.559) 0.143(0.708) 0.269(1.68) 0.434(3.07) 1.86(15.4) 0.013(0.073) 0.017(0.092) 0.019(0.106) 0.043(0.237) 0.047(0.259) 0.075(0.410) 0.109(0.671) 0.191(1.24) 0.310(2.30) 0.969(7.14) 0.010(0.054) 0.013(0.069) 0.015(0.079) 0.033(0.177) 0.036(0.194) 0.057(0.307) 0.086(0.494) 0.148(0.955) 0.242(1.63) 0.557(4.00) Table 2. ADC ENOB (Noise Free Bits) at TA = 25°C, VAVDD = 5 V, VREF = 5 V, SINC4 Filter, Chop Disabled Filter Word Data Rate (SPS) 1023 640 480 96 80 32 16 5 2 1 4.7 7.5 10 50 60 150 300 960 2400 4800 Sept. 2021 PGA GAIN 1 2 4 8 16 32 64 128 25.5(22.9) 25.2(22.6) 25.0(22.4) 23.8(21.2) 23.7(21.1) 23.0(20.4) 22.5(20.1) 21.8(19.1) 20.5(17.5) 17.4(14.5) 25.2(22.8) 24.9(22.5) 24.7(22.3) 23.5(21.1) 23.4(21.0) 22.7(20.3) 22.3(19.8) 21.4(18.7) 20.3(17.3) 17.4(14.4) 25.1(22.7) 24.8(22.4) 24.6(22.1) 23.4(21.0) 23.3(20.9) 22.6(20.2) 22.1(19.6) 21.1(18.5) 20.1(17.3) 17.4(14.0) 24.8(22.2) 24.4(21.8) 24.2(21.6) 23.1(20.5) 22.9(20.3) 22.3(19.7) 21.8(19.4) 20.9(18.2) 20.0(17.1) 17.4(14.3) 24.4(22.1) 24.1(21.8) 23.9(21.6) 22.7(20.4) 22.6(20.3) 21.9(19.6) 21.5(19.0) 20.6(18.0) 19.8(16.9) 17.4(14.3) 24.0(21.6) 23.7(21.3) 23.5(21.0) 22.3(19.9) 22.2(19.8) 21.5(19.1) 21.1(18.8) 20.1(17.5) 19.5(16.6) 17.4(14.3) 23.5(21.0) 23.2(20.7) 22.9(20.5) 21.8(19.3) 21.7(19.2) 21.0(18.5) 20.5(17.8) 19.6(16.9) 18.9(16.1) 17.3(14.4) 22.9(20.5) 22.5(20.1) 22.3(19.9) 21.2(18.7) 21.0(18.6) 20.4(18.0) 19.8(17.3) 19.0(16.3) 18.3(15.6) 17.1(14.3) Signal Micro Incorporated http://www.signal-micro.cn 7 SIG7192 SINC3 and Chop Disabled Table 3. ADC Noise in µVRMS (µVPP) at TA = 25°C, VAVDD = 5 V, VREF = 5 V, SINC3 Filter, Chop Disabled Filter Word Data Rate (SPS) 1023 640 480 96 80 32 16 5 2 1 4.7 7.5 10 50 60 150 300 960 2400 4800 PGA GAIN 1 2 4 8 16 32 64 128 0.229(1.37) 0.289(1.73) 0.334(2.00) 0.747(4.46) 0.818(4.89) 1.29(7.73) 1.70(10.1) 5.26(32.8) 67.0(351) 558(3050) 0.139(0.844) 0.175(1.07) 0.202(1.23) 0.453(2.75) 0.496(3.02) 0.784(4.77) 1.08(6.56) 3.01(19.1) 35.5(184) 277(1530) 0.080(0.447) 0.101(0.565) 0.117(0.652) 0.262(1.46) 0.287(1.60) 0.453(2.53) 0.666(3.87) 1.67(10.6) 17.3(96.7) 138(787) 0.047(0.303) 0.060(0.382) 0.069(0.441) 0.154(0.987) 0.169(1.08) 0.267(1.71) 0.372(2.38) 0.889(5.51) 8.81(51.3) 68.8(393) 0.032(0.158) 0.041(0.200) 0.047(0.231) 0.105(0.516) 0.115(0.565) 0.182(0.894) 0.226(1.34) 0.516(3.95) 4.30(24.2) 34.7(185) 0.019(0.122) 0.023(0.154) 0.027(0.178) 0.061(0.398) 0.066(0.436) 0.105(0.689) 0.153(0.931) 0.310(1.86) 2.18(13.6) 17.8(98.3) 0.014(0.087) 0.018(0.110) 0.021(0.127) 0.047(0.284) 0.051(0.311) 0.081(0.492) 0.117(0.687) 0.207(1.44) 1.10(6.42) 8.65(48.4) 0.011(0.064) 0.014(0.081) 0.017(0.093) 0.037(0.209) 0.040(0.229) 0.064(0.362) 0.097(0.540) 0.165(1.03) 0.592(3.72) 4.37(25.0) Table 4. ADC ENOB (Noise Free Bits) at TA = 25°C, VAVDD = 5 V, VREF = 5 V, SINC3 Filter, Chop Disabled Filter Word Data Rate (SPS) 1023 640 480 96 80 32 16 5 2 1 4.7 7.5 10 50 60 150 300 960 2400 4800 PGA GAIN 1 2 4 8 16 32 64 128 25.4(22.8) 25.0(22.5) 24.8(22.3) 23.7(21.1) 23.5(21.0) 22.9(20.3) 22.5(19.9) 20.9(18.2) 17.2(14.8) 14.1(11.7) 25.1(22.5) 24.8(22.2) 24.6(22.0) 23.4(20.8) 23.3(20.7) 22.6(20.0) 22.1(19.5) 20.7(18.0) 17.1(14.7) 14.1(11.7) 24.9(22.4) 24.6(22.1) 24.3(21.9) 23.2(20.7) 23.1(20.6) 22.4(19.9) 21.8(19.3) 20.5(17.9) 17.1(14.7) 14.1(11.6) 24.7(22.0) 24.3(21.6) 24.1(21.4) 23.0(20.3) 22.8(20.1) 22.2(19.5) 21.7(19.0) 20.4(17.8) 17.1(14.6) 14.1(11.6) 24.2(21.9) 23.9(21.6) 23.7(21.4) 22.5(20.2) 22.4(20.1) 21.7(19.4) 21.4(18.8) 20.2(17.3) 17.1(14.7) 14.1(11.7) 24.0(21.3) 23.7(21.0) 23.5(20.7) 22.3(19.6) 22.2(19.5) 21.5(18.8) 21.0(18.4) 19.9(17.4) 17.1(14.5) 14.1(11.6) 23.4(20.8) 23.0(20.4) 22.8(20.2) 21.7(19.1) 21.5(18.9) 20.9(18.3) 20.3(17.8) 19.5(16.7) 17.1(14.6) 14.1(11.7) 22.7(20.2) 22.4(19.9) 22.2(19.7) 21.0(18.5) 20.9(18.4) 20.2(17.7) 19.6(17.1) 18.9(16.2) 17.0(14.4) 14.1(11.6) Fast Settling, Average=16, SINC4 and Chop Disabled Table 5. ADC Noise in µVRMS (µVPP) at TA = 25°C, VAVDD = 5 V, VREF = 5 V, SINC4 Filter, Chop Disabled Filter Word Data Rate (SPS) 96 30 6 5 2 1 3.125 10 50 60 150 300 PGA GAIN 1 2 4 8 16 32 64 128 0.286(1.36) 0.511(2.43) 1.14(5.44) 1.25(5.96) 1.61(7.75) 3.73(22.7) 0.144(0.816) 0.258(1.46) 0.578(3.26) 0.633(3.58) 0.927(5.36) 2.05(11.6) 0.080(0.442) 0.143(0.791) 0.320(1.77) 0.351(1.94) 0.595(3.73) 1.18(7.60) 0.042(0.221) 0.076(0.396) 0.170(0.885) 0.186(0.969) 0.359(1.86) 0.587(3.28) 0.030(0.144) 0.053(0.258) 0.120(0.578) 0.131(0.633) 0.218(1.04) 0.340(1.94) 0.020(0.098) 0.036(0.175) 0.081(0.391) 0.089(0.428) 0.135(0.689) 0.228(1.34) 0.015(0.076) 0.027(0.137) 0.061(0.306) 0.067(0.335) 0.107(0.596) 0.155(0.903) 0.012(0.062) 0.021(0.110) 0.047(0.246) 0.051(0.270) 0.089(0.442) 0.113(0.666) Table 6. ADC ENOB (Noise Free Bits) at TA = 25°C, VAVDD = 5 V, VREF = 5 V, SINC4 Filter, Chop Disabled Filter Word Data Rate (SPS) 96 30 6 5 2 1 3.125 10 50 60 150 300 Sept. 2021 PGA GAIN 1 2 4 8 16 32 64 128 25.1(22.8) 24.2(22.0) 23.1(20.8) 22.9(20.7) 22.6(20.3) 21.4(18.8) 25.0(22.5) 24.2(21.7) 23.0(20.5) 22.9(20.4) 22.4(19.8) 21.2(18.7) 24.9(22.4) 24.1(21.6) 22.9(20.4) 22.8(20.3) 22.0(19.4) 21.0(18.3) 24.8(22.4) 24.0(21.6) 22.8(20.4) 22.7(20.3) 21.7(19.4) 21.0(18.5) 24.3(22.0) 23.5(21.2) 22.3(20.0) 22.2(19.9) 21.5(19.2) 20.8(18.3) 23.9(21.6) 23.0(20.8) 21.9(19.6) 21.7(19.5) 21.1(18.8) 20.4(17.8) 23.3(21.0) 22.4(20.1) 21.3(19.0) 21.2(18.8) 20.5(18.0) 19.9(17.4) 22.7(20.3) 21.8(19.4) 20.7(18.3) 20.5(18.1) 19.7(17.4) 19.4(16.8) Signal Micro Incorporated http://www.signal-micro.cn 8 SIG7192 ON-CHIP REGISTER MAPS There are total eight registers inside the device which is 8-bit or 24-bit wide. These registers are used to configure and control the ADC to the desired mode of operation. These registers can be accessed through the SPI-compatible serial interface by using register read and write commands. At power-on or reset, the registers default to their initial settings, as shown in the Reset Value column of Table 7. Table 7. Register map BIT 7 BIT 6 BIT 5 R RESET VALUE 80 DRDYn NOREF MODE R/W 080060 SINC3 ERR MD[2:0] 0 CHOP 0 0 CONFIG R/W 000117 BCS REFDET 0 x 0 x BPDSW x GP32EN ADDR. NAME DIR. 3’b000 STATUS 3’b001 3’b010 3’b011 DATA R 000000 3’b100 3’b101 ID GPOCON R R/W X0 00 3’b110 OFFSET R/W 800000 3’b111 GAIN R/W 555555 ENPAR BIT 4 BIT 3 BIT 2 BIT 1 BIT 0 PARITY CHD[3:0] DATUS CLK[1:0] AVG[1:0] 0 SINGLE REJ60 FS[9:8] FS[7:0] REFSEL 0 0 0 0 CH[7:0] BUF FORMAT PGA[2:0] DATA[23:16] DATA[15:8] DATA[7:0] x 0 0 0 0 GP10EN P3DAT P2DAT P1DAT P0DAT OFFSET[23:16] OFFSET[15:8] OFFSET[7:0] GAIN[23:16] GAIN[15:8] GAIN[7:0] STATUS Register Table 8. STATUS Register (Address = 3’b000) BIT 7 BIT 6 BIT 5 BIT 4 DRDYn ERR NOREF PARITY BIT 3 BIT 2 BIT 1 BIT 0 CHD[3:0] Power-On/Reset Value = 0x80 Bits Bit Name Access Reset Description 7 DRDYn R 1’b1 ADC Ready Bit: This bit is cleared when new data is written to the ADC data register. It is set automatically after the ADC data register is read. In addition to this bit, DOUT/DRDYn pin can also be used as an alternative to monitor the update of new ADC data. 6 ERR R 1’b0 ADC Error Bit. This bit is written at the same time as new data update. Error sources include input overrange, input underrange, or lower than expected reference voltage. 5 NOREF R 1’b0 No External Reference Bit: The function of this bit is only enabled by setting the REFDET bit in the CONFIG Register to 1. While the REFDET bit is 1 and the selected reference voltage is below a specified threshold, which is about 0.4V, this bit is set and conversion results are clamped to all 1s. 4 PARITY R 1’b0 Parity Check Bit: The function of this bit is only enabled by setting the ENPAR bit in MODE Register to 1. While the ENPAR bit is 1 and there is odd number of 1s in the data register, this bit is set. Otherwise it is always 0. 3:0 CHD[3:0] R 4’b0000 Data Channel Number: These bits indicate the corresponding channel to the ADC data in data register (see Table 11). Sept. 2021 Signal Micro Incorporated http://www.signal-micro.cn 9 SIG7192 MODE Register Table 9. MODE Register (Address = 3’b001) BIT 23 BIT 22 BIT 21 BIT 20 BIT 19 BIT18 BIT 17 BIT 16 BIT 15 BIT 14 BIT 13 BIT 12 BIT 11 BIT10 BIT 9 BIT 8 BIT 6 BIT 5 BIT 4 BIT 3 BIT 2 BIT 1 BIT 7 MD[2:0] SINC3 DATUS 0 ENPAR CLK[1:0] 0 SINGLE BIT 0 AVG[1:0] REJ60 FS[9:8] FS[7:0] Power-On/Reset Value = 0x080060 Bits Bit Name Access Reset Description 23:21 MD[2:0] R/W 3’b000 Mode Select Bits: These bits select the operating mode of the device. 000: Continuous conversion mode. (default) 001: Single conversion mode. ADC first wakeup if in idle or sleep mode; resets the filter to perform one conversion; and enters sleep mode. The conversion result remains in the data register with DOUT/DRDYn as low. 010: Idle mode. The digital filter is in reset state with ADC free running. 011: Sleep mode. Most of circuitry is turned off to save the power. BPDSW remains active in sleep mode. 100: Internal zero-scale calibration. 101: Internal full-scale calibration. 110: System zero-scale calibration. 111: System full-scale calibration. For each above calibration mode, DOUT/DRDYn goes high when the calibration is initiated and returns low when the calibration is complete. The ADC is automatically placed in idle mode after the calibration. The measured offset/full-scale coefficient is placed in the offset/full-scale register of the selected channel. 20 DATUS R/W 1’b0 Status Enable Bit: When DATUS is set, the contents of the status register are transmitted along with each data register read. 19:18 CLK[1:0] R/W 2’b10 Clock Select Bits: This bits select the clock source for SYSCLK. 00: External crystal applied between MCLK1 and MCLK2. 01: External clock applied to the MCLK2 pin. 10: Internal 4.9152MHz clock with MCLK2 tristated. (default) 11: Internal 4.9152MHz clock with its output on MCLK2 pin. 17:16 AVG[1:0] R/W 2’b00 Fast Settling Filter Setting: In fast settling mode, a first-order average is added after the SINC filter to further improve the rms noise. It can work for any data rate select bits FS[9:0]. 00: Not averaging (default) 01: Average by 2 10: Average by 8 11: Average by 16 15 SINC3 R/W 1’b0 SINC3 Enable Bit: 0: SINC4 filter (default) 1: SINC3 filter 14 RESERVED R/W 1’b0 Reserved Always write 1’b0 13 ENPAR R/W 1’b0 Enable Parity Bit: This bit enables the parity check on the data register. 12 RESERVED R/W 1’b0 Reserved Always write 1’b0 Sept. 2021 Signal Micro Incorporated http://www.signal-micro.cn 10 SIG7192 11 SINGLE R/W 1’b0 Single Cycle Conversion Bit: When this bit is set, the ADC settles in one conversion cycle so that it functions as a zero latency ADC. When chop is disabled, fast settling mode is disabled, continuous conversion mode is selected, and SINGLE bit is set, the output data rate is Output Data Rate=SYSCLK/1024/FS[9:0]/N Where N is 3 for SINC3 filter and 4 for SINC4 filter. With a nominal SYSCLK of 4.9152MHz, default Data Rate bits 0x060=96, and SINC3 bit set to 0, output data rate is 4915200/1024/96/4=12.5SPS. 10 REJ60 R/W 1’b0 50/60Hz Notch Bit: This bit can only be effective while FS[9:0]=0x060. A filter notch is placed at 60Hz to allow simultaneous 50Hz/60Hz rejection. 9:0 FS[9:0] R/W 0x060 Data Rate Select Bits: The 10 bits are used to configure the ADC data rate. When chop is disabled, fast settling mode is disabled, and continuous conversion mode is selected, the output data rate is Output Data Rate=SYSCLK/1024/FS[9:0] With a nominal SYSCLK of 4.9152MHz and default Data Rate bits 0x060=96, output data rate is 4915200/1024/96=50SPS. CONFIG Register Table 10. CONFIG Register (Address = 3’b010) BIT 23 BIT 22 BIT 21 BIT 20 BIT 19 BIT18 BIT 17 BIT 16 BIT 15 BIT 14 BIT 13 BIT 12 BIT 11 BIT10 BIT 9 BIT 8 BIT 7 BIT 6 BIT 5 BIT 4 BIT 3 BIT 2 BIT 1 BIT 0 CHOP 0 0 REFSEL 0 0 0 0 CH7 CH6 CH5 CH4 CH3 CH2 CH1 CH0 BURN REFDET 0 BUF FORMAT PGA[2:0] Power-On/Reset Value = 0x000117 Bits Bit Name Access Reset Description CHOP R/W 1’b0 Chop Enable Bit: When this bit is enabled, the offset and offset drift of the ADC are dramatically improved with longer conversion time and settling time. For default data rate settling of 50SPS with SINC4 filter, the conversion time is 20ms and the settling time is 80ms with chop disabled. If chop is enabled, the conversion time is 80ms and the settling time is 160ms. RESERVED R/W 2’b00 Reserved Always write 2’b00 REFSEL R/W 1’b0 Reference Select Bit: Select the reference source for the ADC. 0: REFIN1+, REFIN1- (default) 1: REFIN2+, REFIN2- 19, 18, 17, 16 RESERVED R/W 4’b0000 Reserved Always write 4’b0000 15:8 CH7 to CH0 R/W 0x01 Channel Select Bits: This bits select which channels are enabled for ADC conversion (see Table 11). When more than one channel are enabled, ADC automatically sequences them and places the data into data register with corresponding channel information in STATUS register and append them during data register read if DATUS bit in MODE Register is enabled. For calibrations, only one channel can be selected and the lowest bit channel is selected if more than one channels are enabled. 7 BURN R/W 1’b0 Burnout Enable Bit: When this bit is enabled, a pair of 500nA current sources are applied to analog inputs to source positive input and sink negative input. 6 REFDET R/W 1’b0 Reference Detection Enable Bit: When this bit is enabled, the NOREF bit in the STATUS register indicates when the reference input 23 22, 21 20 Sept. 2021 Signal Micro Incorporated http://www.signal-micro.cn 11 SIG7192 voltage is less than specified threshold, which is about 0.4V. 5 RESERVED R/W 1’b0 Reserved Always write 1’b0 4 BUF R/W 1’b0 Buffer Enable Bit: When this bit is set, analog input is buffered. Otherwise the input buffer is bypassed. 3 FORMAT R/W 1’b0 Data Format Bit: This bit sets the ADC data format. 0: Bipolar mode (default) 1: Unipolar mode 2:0 PGA[2:0] R/W 3’b111 PGA Gain Configuration: Selects the PGA gain. If PGA gain is set to other than 1, the BUF bit setting is ignored with buffer always enabled. 000: Gain=1 001: Gain=2 010: Gain=4 011: Gain=8 100: Gain=16 101: Gain=32 110: Gain=64 111: Gain=128 (default) Table 11. Channel Selection Channel Enabled Negative Input AIN- Status Register Bits CHD[3:0] Calibration Register Pair Positive Input AIN+ CH0=1 AIN1 AIN2 0000 0 CH1=1 AIN3 AIN4 0001 1 0010 None Channel CH2=1 Temperature Sensor CH3=1 AIN2 AIN2 0011 0 CH4=1 AIN1 AINCOM 0100 0 CH5=1 AIN2 AINCOM 0101 1 CH6=1 AIN3 AINCOM 0110 2 CH7=1 AIN4 AINCOM 0111 3 DATA Register Table 12. DATA Register (Address = 3’b011) BIT 23 BIT 22 BIT 21 BIT 20 BIT 19 BIT18 BIT 17 BIT 16 BIT 15 BIT 14 BIT 13 BIT 12 BIT 11 BIT10 BIT 9 BIT 8 BIT 7 BIT 6 BIT 5 BIT 4 BIT 3 BIT 2 BIT 1 BIT 0 DATA[23] DATA[22] DATA[21] DATA[20] DATA[19] DATA[18] DATA[17] DATA[16] DATA[15] DATA[14] DATA[13] DATA[12] DATA[11] DATA[10] DATA[9] DATA[8] DATA[7] DATA[6] DATA[5] DATA[4] DATA[3] DATA[2] DATA[1] DATA[0] Power-On/Reset Value = 0x000000 Bits Bit Name Access Reset Description 23:0 DATA[23:0] R 0x000000 Data Bits: The 24-bit word is signed number in 2’s complement format. See Data Format section for more information. Sept. 2021 Signal Micro Incorporated http://www.signal-micro.cn 12 SIG7192 ID Register Table 13. ID Register (Address = 3’b100) BIT 7 BIT 6 BIT 5 BIT 4 BIT 3 BIT 2 BIT 1 BIT 0 x x x x 0 0 0 0 Power-On/Reset Value = 0xX0 Bits Bit Name Access Reset Description 7:0 ID R 8’bxxxx0000 ID Bits: Read only. GPOCON Register Table 14. GPOCON Register (Address = 3’b101) BIT 7 BIT 6 BIT 5 BIT 4 BIT 3 BIT 2 BIT 1 BIT 0 0 BPDSW GP32EN GP10EN P3DAT P2DAT P1DAT P1DAT Power-On/Reset Value = 0x00 Bits Bit Name Access Reset Description 7 RESERVED R/W 1’b0 Reserved Always write 1’b0 6 BPDSW R/W 1’b0 Bridge Power-down Switch Control Bit: When this bit is set to 1, the switch is closed to short BPDSW to AGND with low on-resistor of typical 3 Ohms. The switch is open if the bit is cleared. The switch remains active in idle and sleep modes. 5 GP32EN R/W 1’b0 P3 and P2 Output Enable Bit: When this bit is set to 1, the P3 and P2 pins are configured as outputs. When this bit is set to 0, the P3 and P2 pins are tri-state. 4 GP10EN R/W 1’b0 P1 and P0 Output Enable Bit: When this bit is set to 1, the P1 and P0 pins are configured as outputs. When this bit is set to 0, the P1 and P0 pins are tri-state. 3 P3DAT R/W 1’b0 Data Output P3 Bit: This bit sets the value of the P3 output pin if GP32EN bit is set to 1. During GPO register read, the P3DAT reflects the status of the P3 pin if GP32EN bit is set to 1. 2 P2DAT R/W 1’b0 Data Output P2 Bit: This bit sets the value of the P2 output pin if GP32EN bit is set to 1. During GPO register read, the P2DAT reflects the status of the P2 pin if GP32EN bit is set to 1. 1 P1DAT R/W 1’b0 Data Output P1 Bit: This bit sets the value of the P1 output pin if GP10EN bit is set to 1. During GPO register read, the P1DAT reflects the status of the P1 pin if GP10EN bit is set to 1. 0 P0DAT R/W 1’b0 Data Output P0 Bit: This bit sets the value of the P0 output pin if GP10EN bit is set to 1. During GPO register read, the P1DAT reflects the status of the P0 pin if GP10EN bit is set to 1. Sept. 2021 Signal Micro Incorporated http://www.signal-micro.cn 13 SIG7192 OFFSET Register The device has four OFFSET registers, each channel has a dedicated OFFSET register (see Table 11). OFFSET register read is allowed anytime, but writing to OFFSET register is only allowed while the device is in idle or sleep mode. Table 15. OFFSET Register (Address = 3’b110) BIT 23 BIT 22 BIT 21 BIT 20 BIT 19 BIT18 BIT 17 BIT 16 BIT 15 BIT 14 BIT 13 BIT 12 BIT 11 BIT10 BIT 9 BIT 8 BIT 7 BIT 6 BIT 5 BIT 4 BIT 3 BIT 2 BIT 1 BIT 0 OFFSET[23] OFFSET[22] OFFSET[21] OFFSET[20] OFFSET[19] OFFSET[18] OFFSET[17] OFFSET[16] OFFSET[15] OFFSET[14] OFFSET[13] OFFSET[12] OFFSET[11] OFFSET[10] OFFSET[9] OFFSET[8] OFFSET[7] OFFSET[6] OFFSET[5] OFFSET[4] OFFSET[3] OFFSET[2] OFFSET[1] OFFSET[0] Power-On/Reset Value = 0x800000 Bits Bit Name Access Reset Description 23:0 OFFSET[23:0] R/W 0x800000 Offset Calibration Bits: The 24-bit word is signed number in offset binary format. See Calibration section for more information. GAIN Register The device has four GAIN registers, each channel has a dedicated GAIN register (see Table 11). GAIN register read is allowed anytime, but writing to GAIN register is only allowed while the device is in idle or sleep mode. Table 16. GAIN Register (Address = 3’b111) BIT 23 BIT 22 BIT 21 BIT 20 BIT 19 BIT18 BIT 17 BIT 16 BIT 15 BIT 14 BIT 13 BIT 12 BIT 11 BIT10 BIT 9 BIT 8 BIT 7 BIT 6 BIT 5 BIT 4 BIT 3 BIT 2 BIT 1 BIT 0 GAIN[23] GAIN[22] GAIN[21] GAIN[20] GAIN[19] GAIN[18] GAIN[17] GAIN[16] GAIN[15] GAIN[14] GAIN[13] GAIN[12] GAIN[11] GAIN[10] GAIN[9] GAIN[8] GAIN[7] GAIN[6] GAIN[5] GAIN[4] GAIN[3] GAIN[2] GAIN[1] GAIN[0] Power-On/Reset Value = 0x555555 Bits Bit Name Access Reset Description 23:0 GAIN[23:0] R/W 0x555555 Gain Calibration Bits: The 24-bit word is unsigned positive number in binary format. See Calibration section for more information. Sept. 2021 Signal Micro Incorporated http://www.signal-micro.cn 14 SIG7192 REVISION HISTORY The revision history provided is for informational purposes only and is believed to be accurate, but not warranted. Please contact to make sure you have the latest revision. DATE REVISION Sept. 20, 2021 CHANGE Initial release. DISCLAIMER Signal Micro reserves the right to make any change in circuit design, specification or other related things if necessary without notice at any time. All trademarks and registered trademarks are the property of their respective owners. Sept. 2021 Signal Micro Incorporated http://www.signal-micro.cn 15 SIG7192 PACKAGE OUTLINE DIMENSIONS 0.30 0.19 0.65 0.10 M 13 24 0.15 NOM 4.50 4.30 6.60 6.20 0.25 o 0 -8 o 0.75 0.50 12 1 7.90 7.70 1.10 MAX 0.15 0.05 0.10 Seating Plane A. Compliant to JEDEC STARDARDS MO-153-AD. B. All linear dimensions are in millimeters. C. This drawing is subject to change without notice. Sept. 2021 Signal Micro Incorporated http://www.signal-micro.cn 16
SIG7192-ITSP24-RL 价格&库存
很抱歉,暂时无法提供与“SIG7192-ITSP24-RL”相匹配的价格&库存,您可以联系我们找货
