RL30-050
RL30-050
    RUILON(瑞隆源)
    PTC_D8X3.1MM_TM
    PTC自恢复保险丝 最大电压:30V 最大电流:40A 保持电流:500mA 跳闸电流:1A
RL30-050 数据手册
Positive Thermal Coefficient (PTC PTC) RL30 Series Description Positive Thermal Coefficient devices(PTC),provide over over-current protection for electrical and electronic devices. They function using conducting strips of metal imbedded inside polymers. Under normal conditions, the devices resistance is near zero, but over-current current conditions will heat the PTC and expand the polymer, increasing the impedance. When current returns to normal, the components mponents cool down, returning to their original shape and very low levels of resistance. Applications l Over-current current and over-temperature over protection of Features automotive electronics l I(hold): 0.5~9.0A l Hard disk drives l 30V Operating voltages l Point-of-sale sale (POS) equipment l Radial leaded devices. l PCMCIA cards l Over-current protection l Power over Ethernet (POE) l Very high voltage surge capabilities. l HDMI 1.4 Source protection l Available in lead-free version. l Computers & peripherals l Fast time–to–trip l Industrial control Halogen-Free l RoHS compliant, Lead- Free and Halogen l Security systems Part Number Code R L X LOGO X X - Voltage rating(VDC) X X X Hold current Environmental Specifications Test Conditions Resistance change Passive aging +85℃,1000hrs ±8% typical Humidity aging +85℃,85%R.H.1000hrs ±8% typical Thermal shock +125℃ to -55℃,10times ±12% typical Resistance to solvent MIL-STD-202,Method 215 No change Vibration MIL-STD-202,Method 201 No change Specifications are subject to change without notice. Please refer to http://www.ruilon.com.cn for current information. Revised: 2021-06-21 Page:1 PTC) Positive Thermal Coefficient (PTC RL30 Series Electrical Characteristic Ihold (A) IT (A) Vmax ( (V) RL30-050 0.50 1.0 RL30-070 0.70 RL30-075 Model Maximum Time to Trip Imax (A) Pd typ (W W) Current(A) Time(S) 30 2.5 4.1 40 1.4 30 3.50 4.3 0.75 1.5 30 3.75 RL30-090 0.90 1.8 30 RL30-110 1.10 2.2 RL30-120 1.20 RL30-135 Resistance(Ω) Rimin R1max 0.5 0.25 0.25~1.20 40 0.6 0.14 0.35 5.2 40 0.6 0.12 0.42 4.5 5.9 40 0.6 0.07 0.30 30 5.5 6.6 40 0.7 0.05 0.26 2.4 30 6.0 8.0 40 0.8 0.08 0.20 1.35 2.7 30 6.75 7.3 40 0.8 0.04 0.22 RL30-160 1.60 3.2 30 8.0 8.0 40 0.9 0.03 0.18 RL30-185 1.85 3.7 30 9.25 8.7 40 1.0 0.03 0.15 RL30-200 2.00 4.0 30 10.0 11 40 1.0 0.03 0.13 RL30-250 2.50 5.0 30 12.5 10.3 40 1.2 0.02 0.10 RL30-300 3.00 6.0 30 15.0 10.8 40 2.0 0.02 0.10 RL30-400 4.00 8.0 30 20.0 12.7 40 2.5 0.01 0.09 RL30-500 5.00 10.0 30 25.0 14.5 40 3.0 0.01 0.08 RL30-600 6.00 12.0 30 30.0 16 40 3.5 0.005 0.06 RL30-700 7.00 14.0 30 35.0 17.5 40 3.8 0.005 0.05 RL30-800 8.00 16.0 30 40.0 18.8 40 4.0 0.005 0.18 RL30-900 9.00 18.0 30 45.0 20 40 4.2 0.005 0.025 IH=Hold current: maximum current at which the device will not trip at 25℃ still air. IT=Trip current: minimum current at which the device will nalways at 25℃ still air. V max=Maximum voltage device can withstand without damage at rated current. Imax=Maximum fault current device can withstand tithout damage at rated voltage. T trip=Maximum time to trip(s) at assigned current. Pd=Typical power dissipation: typical amount of power dissipated by the decice when in state air environment. Ri min=Minimum device resistance at 25℃ prior to tripping. R1 max=Maximum device resistance is measured one hour post reflow. Specifications are subject to change without notice. Please refer to http://www.ruilon.com.cn for current information. Revised: 2021-06-21 Page:2 Positive Thermal Coefficient (PTC PTC) RL30 Series Solder reflow conditions Wave Soldering 300 Soldering Temperature:260℃~270℃ 250 Soldering Time:≤3sec. 200 Soldering Position: Resettable fuse wire and the bottom ≥ 6mm。 Manual soldering Soldering Temperature:250℃~280℃ Temperature℃ 5s max. 245℃-260 Soldering Pre-heating 150 100℃-130℃ 100 Cooling 50 Soldering Time:≤3sec. 0 Soldering Position: Resettable fuse wire and the bottom ≥ 6mm。 0 50 100 150 200 250 Time(s) Ihold Versus Temperature Ambient Operation Temperature Part Number -40 ºC -20 ºC 0 ºC 25 ºC 40 ºC 50 ºC 60 ºC 70 ºC 85 ºC RL30-050 0.73 0.65 0.58 0.50 0.42 0.38 0.34 0.31 0.26 RL30-070 1.01 0.95 0.84 0.70 0.63 0.58 0.50 0.47 0.38 RL30-075 1.10 1.13 0.93 0.75 0.69 0.63 0.54 0.51 0.42 RL30-090 1.31 1.17 1.04 0.90 0.75 0.69 0.61 0.55 0.47 RL30-110 1.60 1.43 1.27 1.10 0.91 0.85 0.75 0.67 0.57 RL30-135 1.96 1.76 1.55 1.35 1.12 1.04 0.92 0.82 0.70 RL30-160 2.32 2.08 1.84 1.60 1.33 1.23 1.09 0.98 0.83 RL30-185 2.68 2.41 2.13 1.85 1.54 1.42 1.26 1.13 0.96 RL30-200 3.13 2.80 2.35 2.00 1.82 1.66 1.45 1.33 1.01 RL30-250 3.63 3.25 2.88 2.50 2.08 1.93 1.54 1.53 1.30 RL30-300 4.35 3.90 3.45 3.00 2.49 2.31 2.04 1.83 1.56 RL30-400 5.80 5.20 4.60 4.00 3.32 3.08 2.72 2.44 2.08 RL30-500 7.25 6.50 5.75 5.00 4.15 3.85 3.40 3.05 2.60 RL30-600 8.70 7.80 6.90 6.00 4.98 4.62 4.08 3.66 3.12 RL30-700 10.15 9.10 8.05 7.00 5.81 5.39 4.76 4.27 3.64 RL30-800 11.60 10.40 9.20 8.00 6.64 RL30-120 RL30-900 Specifications are subject to change without notice. Please refer to http://www.ruilon.com.cn for current information. Revised: 2021-06-21 Page:3 Positive Thermal Coefficient (PTC PTC) RL30 Series Product Dimensions Marking Marking Marking fig.1 fig.2 fig.3 Dimensions( (in) Dimensions Dimensions(mm) Type Number Shape A(max) B(max) C(typ typ) D(max) LeadΦ (typ) A(max) B(max) C(typ) D(max) LeadΦ (typ) Fig RL30-050 8.0 14.0 5.1 3.1 0.5 0.315 0.551 0.201 0.122 0.02 1 RL30-070 7.4 14.2 5.1 3 0.5 0.291 0.559 0.201 0.118 0.02 2 RL30-075 7.4 14.2 5.1 3 0.5 0.291 0.559 0.201 0.118 0.02 2 RL30-090 7.4 18.5 5.1 3 0.5 0.291 0.728 0.201 0.118 0.02 2 RL30-110 7.4 18.5 5.1 3 0.5 0.291 0.728 0.201 0.118 0.02 2 RL30-120 7.4 18.5 5.1 3 0.5 0.291 0.728 0.201 0.118 0.02 2 RL30-135 9.2 17.6 5.1 3 0.6 0.362 0.693 0.201 0.118 0.024 2 RL30-160 9.2 20.2 5.1 3 0.6 0.362 0.795 0.201 0.118 0.024 2 RL30-185 10.2 20.2 5.1 3 0.6 0.402 0.795 0.201 0.118 0.024 2 RL30-200 15.2 20.2 5.1 3 0.6 0.598 0.795 0.201 0.118 0.024 2 RL30-250 13.2 22.4 5.1 3 0.6 0.52 0.882 0.201 0.118 0.024 2 RL30-300 13.2 20.4 5.1 3 0.8 0.52 0.803 0.201 0.118 0.031 3 RL30-400 14.0 23.7 5.1 3 0.8 0.551 0.933 0.201 0.118 0.031 3 RL30-500 17.7 24.9 10.2 3 0.8 0.697 0.980 0.402 0.118 0.031 3 RL30-600 17.2 27.0 10.2 3 0.8 0.677 1.063 0.402 0.118 0.031 3 RL30-700 19.1 27.0 10.2 3 0.8 0.752 1.063 0.402 0.118 0.031 3 RL30-800 23.5 29.2 10.2 3 0.8 0.925 1.150 0.402 0.118 0.031 3 RL30-900 25.5 30.0 10.2 3 0.8 1.004 1.181 0.402 0.118 0.031 3 Packaging Part Number Quantity RL30-050~RL30-700 500pcs/bag 00pcs/bag RL30-800~RL30-900 200pcs/bag 0pcs/bag Specifications are subject to change without notice. Please refer to http://www.ruilon.com.cn for current information. Revised: 2021-06-21 Page:4
RL30-050 价格&库存
很抱歉,暂时无法提供与“RL30-050”相匹配的价格&库存,您可以联系我们找货
